Problem with playing back recorded video on Motorola DCX3400 for Comcast - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-09-2012, 09:27 PM - Thread Starter
avdoubleu's Avatar
Hello everyone,
I currently just got cable for the first time in a long time and I'm having a major problem with playing back the recorded videos.
Here's what I'm working with.
Motorola DCX3400
HDMI out and into
Yamaha RX-V565
HDMI out and into
Panasonic TC-P65S1
Regular cable plays just fine but if I go back to play any show the DVR freezes in about 2 seconds on "play" and the only way to stop it is to unplug. I know this has been addressed multiple times but no one has had just a problem with items that are recorded.
Also, when I do first turn everything on I am getting the flash of a "green screen" that others have discussed.
I thank you in advance and greatly appreciate your help.
avdoubleu is offline
post #2 of 2 Old 11-26-2012, 12:59 PM
Rudy1's Avatar
Quoted: 964 Post(s)
Liked: 1278
Try connecting the HDMI output from the Motorola DCX3400 directly to your plasma TV, then connect the TV to the AVR using a Toslink cable. Go into the USER SETTINGS menu for the Motorola (turn off the DVR, then immediately press MENU on the device or its remote), go into ADDITIONAL HDMI SETTINGS, and select PASS THROUGH from the AUDIO OUTPUT menu. The optical output from the TV should pass the Dolby Digital signal from the DCX3400 to the Yamaha AVR, and this in turn should eliminate the green screen flash (HDMI handshake issue) as well as the DVR freezing during playback.
ASKHOLE: (n.) A person who constantly asks for your advice, yet always does the opposite of what you told them.
Rudy1 is offline
Reply HDTV Recorders
