preset codes? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-18-2012, 10:55 AM - Thread Starter
tedcousens's Avatar
Quoted: 28 Post(s)
I just bought a Marantz av7701 and wish to program the remote. Does anyone have the codes for the Comcast/Motorola set top box remote? Mine is a DCT 3412 dual tuner/dvr. Also , if anyone had the code for a Syntax Olevia tv, that would be awesome as well. Thanks.
I've seen things you people wouldn't believe...
Roi Batty
tedcousens is offline
post #2 of 2 Old 11-19-2012, 10:25 PM
Arvy's Avatar
Quoted: 93 Post(s)
Liked: 83
Motorola STBs respond to codes 0476 and usually 0276, also.
Arvy
Arvy is offline
Reply HDTV Recorders
