DVR Expansion - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-29-2012, 10:46 AM - Thread Starter
ricoms's Avatar
Hi there, I have a Verizon QIP7216 which has a SATA input. I also have an older WD My Book World external drive which has Ethernet and USB 2.0 ports. Is it possible to expand the DVR capacity by connecting the drive using a USB to SATA adaptor? Or do I need to have a drive with a SATA port? Thank you
ricoms is offline
post #2 of 2 Old 12-30-2012, 07:27 AM
Super Moderator
DrDon's Avatar
Quoted: 902 Post(s)
Liked: 1769
You need a SATA drive. The USB-to-SATA adapters work in the other direction.. for attaching a SATA drive to a computer without a SATA port. Or you could pull the drive out of the WD enclosure and put it in one that has a sata port.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
Reply HDTV Recorders
