8300 8240HDC playback problem-Press Play, just says Press List endlessly - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-15-2013, 12:47 PM - Thread Starter
Smartings's Avatar
Playback problem with SA Explorer 8300 (actually 8240HDC) on Charter Cable.
Using list, I select a title to play. I press Play but instead of playing, it just says Press List.
I press list again. Press play again. Says press list. Endless loop.
Why does it do that?
Did it actually record on hard drive or not?
How can I prevent it from doing it?
How can I get to play title?
Any help appreciated
Smartings is offline
post #2 of 5 Old 01-15-2013, 01:28 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
What IPG/firmware? SARA? Passport Echo? Other??
domino92024 is offline
post #3 of 5 Old 01-16-2013, 08:27 AM - Thread Starter
Smartings's Avatar
It's SARA on Charter Cable in Burbank CA
post #4 of 5 Old 01-16-2013, 01:08 PM
Quoted: 126 Post(s)
Liked: 216
Man, it's been years since I used SARA. Have you checked the 8300/SARA AVS thread?
http://www.avsforum.com/t/471859/sa-8300-hd-tips-tricks-sara
Is this a recent failure (of a previously working DVR), or a new setup? If the latter, I'd bet it's something you're doing wrong. Read through the 8300/SARA manual.
http://www.scientificatlanta.com/ExplorerClubGuides/getting_started/4003870.pdf
post #5 of 5 Old 01-19-2013, 11:22 AM - Thread Starter
Smartings's Avatar
It's a periodic failure. The endless loop. Of Play. List, Play.
It was on previous same model DVR I'd turned back in.
I don't know what causes it.
But then it corrects itself.
Generally, I record both SD and HD to guarantee a good copy and add a 3rd backup on a DVD recorder with HD.
But I'd like to know why it happens and if there is anything I can do to play unique recordings.
Reply HDTV Recorders
