Tv tuner with 'Native output" - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 01-16-2013, 10:23 AM - Thread Starter
sandman123's Avatar
Hello all,
I've been reading through this forum quite a bit and can't find any good answers yet.
Could someone please direct me to a Tv tuner (other than tivo - I know about this one) that has 'Native output' capability (dosent' scale or affect colors)
Hopefully one that is also reliable, and you can manually enter channels.
Thanks very much
sandman123 is offline
post #2 of 12 Old 01-16-2013, 01:58 PM
Kei Clark's Avatar
I'm not sure about tuners that outupt native resolution, if you are looking to output 1080i/720p, the TViX M6620N will do that. Unfortunately, the output is set in the configuration so it will upscale SD (480i/p) to whatever you set as the output resolution.
Kei Clark is offline
post #3 of 12 Old 01-16-2013, 02:37 PM - Thread Starter
sandman123's Avatar
kei,
Thanks, but I'm looking specifically for one that will not automatically upscale, or affect colors.
post #4 of 12 Old 01-16-2013, 05:55 PM
Kelson's Avatar
Quoted: 1952 Post(s)
Liked: 1147
For whatever reason, native output is pretty rare. I only know of TiVo and Oppo. I'll be curious if anybody answers this thread and can identify another native output device.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #5 of 12 Old 01-17-2013, 10:34 AM - Thread Starter
sandman123's Avatar
Kelson,
Does oppo make tv tuners?
post #6 of 12 Old 01-17-2013, 10:42 AM
Kelson's Avatar
Liked: 1147
No, I was just making the point that native output is rare across a number of device-types.
- kelson h
Kelson is offline
post #7 of 12 Old 01-17-2013, 11:09 AM
veryoldschool's Avatar
Not sure if this falls under the OP's question, but All of the DirecTV HD receivers have a native output option.
A.K.A. VOS
veryoldschool is offline
post #8 of 12 Old 01-18-2013, 10:33 AM
mdavej's Avatar
Quoted: 2129 Post(s)
Liked: 940
Yep, the AM21 does exactly what the OP wants. Not sure why preserving the integrity of crappy SD is important, but it will certainly do it.
Can you be more specific on the type of tuner (QAM, ATSC)? Stand-alone or PC based? What are you doing with this unmolested SD content? What tuner do you have now that's doing such a bad job of upconverting?
mdavej is offline
post #9 of 12 Old 01-18-2013, 10:39 AM
BillFromCH's Avatar
The Sony DHG HDD-250/500 will output native. As TVGOS goes away you may find some of these at tuner-only prices.
BillFromCH is offline
post #10 of 12 Old 01-18-2013, 12:07 PM
In my case the TV will make SD look a lot better than the receiver does.
A.K.A. VOS
post #11 of 12 Old 01-18-2013, 07:59 PM
jjeff's Avatar
Quoted: 693 Post(s)
Liked: 246
As the OP said in either this or another thread he started(in another forum) he's looking for a OTA HD tuner(ATSC) to run through his Oppo BD player(that has the ability to upconvert in a quality much better than a typical tuner) at least thats what I remember smile.gif
I agree with BillFromCH if the OP could get a Sony DVR cheap enough that might be a good option.
jjeff is online now
post #12 of 12 Old 01-22-2013, 07:31 AM
videobruce's Avatar
Quoted: 599 Post(s)
Liked: 246
Problem w/ a Sony DVR as a tuner is power consumption. 33 watts for just a tuner is 4x what a plain tuner should consume and it runs 24/7 when you aren't using it. You also have a HDD spinning needlessly.
Since there are only two resolutions 480 & 720 that would/could be upconverted, further assuming 480 wouldn't be one of them, I don't see the concern about going from 720 to 1080.
Free, abundant OTA television separates this country from many others. ATSC1 has only been in force since 2009. The wireless industry has enough spectrum. Enough of 'planned obsolesce'.
videobruce is online now
Reply HDTV Recorders
