Official* Xfinity X1 STB Thread - Page 62 - AVS | Home Theater Discussions And Reviews
 10Likes
post #1831 of 1831 Unread Today, 08:54 AM
Kosmo886's Avatar
Originally Posted by JazzGuyy View Post
It sounds like an HDMI handshake issue. I have seen this on my TV when the HDMI connection from the X1 box to my Pioneer Elite receiver is even the slightest bit loose. I can usually correct it by resetting the connection. In my case, this happens when I have been fiddling around with other connections and accidentally loosen the box to receiver connection ever so slightly. Other causes for this can be a too stiff or too heavy HDMI cable that can loosen slightly due to weight or tension.
I would recommend trying a different HDMI cable and being absolutely sure you have the tightest fit possible. Many HDMI cables are notorious for not fitting well.
Hi - Thanks for your reply. I have tried several different HDMI cables but I have the same issue. All connections are tight as well.
Kosmo886 is online now
Reply HDTV Recorders
x1 comcast activation problem companion
