Official* Xfinity X1 STB Thread - Page 67 - AVS Forum | Home Theater Discussions And Reviews
 63Likes
post #1981 of 2366 Old 06-13-2015, 07:45 PM
PaulGo's Avatar
Quoted: 134 Post(s)
Liked: 60
Originally Posted by skriefal View Post
Why wouldn't it simply buffer the program on the DVR's hard drive, and stream from that buffer?
Maybe if someone is using the DVR to watch live programming the hard drive buffer is in use and it would cause a lack of responsiveness (just a guess).
PaulGo is online now
post #1982 of 2366 Old 06-13-2015, 07:55 PM
skriefal's Avatar
Quoted: 85 Post(s)
Liked: 69
It shouldn't be any different than the DVR recording the program, and the "satellite" box playing the recording while in progress. I believe that's what the Dish Network and DirecTV boxes do. But Comcast probably skimped on the hardware much more than Dish/DTV did...
skriefal is offline
post #1983 of 2366 Old 06-14-2015, 08:33 AM
bruce24's Avatar
I'm not sure what the reason was, but I can tell you it is much smoother moving around the buffer on the Xi3 vs. moving around a recording on the XG1 DVR from a RNG150n box.
bruce24 is offline
post #1984 of 2366 Old 06-14-2015, 12:06 PM - Thread Starter
donaldsonjune's Avatar
Quoted: 41 Post(s)
hello all,
xi3 box couldn't pass a video signal thur my integra 30.6 receiver. audio only.
video signal ok from box directly to tv. the Comcast tech tried switching hdmi cables with no luck.
so back to the blue lite satellite box.
anyone else using the xi3 box with a receiver?
June
"IF YOU FAIL TO PLAN, YOU PLAN TO FAIL"
donaldsonjune is offline
post #1985 of 2366 Old 06-28-2015, 02:23 PM - Thread Starter
Quoted: 41 Post(s)
hello all,
I had to use the hdcp hdmi input to get video.
June
post #1986 of 2366 Old 06-28-2015, 02:27 PM
CaptainVideoJW's Avatar
Liked: 42
Originally Posted by donaldsonjune View Post
hello all,
Are you saying you had a HDCP non-compliant input on your receiver?
CaptainVideoJW is offline
post #1987 of 2366 Old 06-28-2015, 04:41 PM - Thread Starter
Quoted: 41 Post(s)
hey captain,
I only have one on the integra htr30.6. need 2 the other for a sony bdp-5200 blue ray player. looking for a hdcp hdmi switcher
June
post #1988 of 2366 Old 06-28-2015, 04:51 PM
Liked: 42
hey captain,
Sounds like you're running into a compatibility issue.
Have you tested another device like your Blu-ray player to see if it passes copy protected video?
HDCP 2.2 is the new kid on the block. And it sounds like you may have a lot of frustration ahead. ;(
"The compatibility conundrum
While that’s bad news for bad guys, it’s a potential headache for the rest of us, too. HDCP 2.2 is not backward compatible with the previous versions of HDCP that are currently used by most of the HD devices in all our homes. Thanks to its ignominious track record of exploitations, the protocol required a clean refresh, and since it's implemented at the hardware level, manufacturers can't simply release new firmware to bring old gear up to speed.
In order to watch copy-protected Ultra HD content--be it on a disc, a download, or via an over-the-top stream—you’ll need HDCP 2.2 compatible devices at every link in the signal chain. Because this isn’t just about media players and TVs; it applies to any component with an HDMI connection. Having a non-HDCP 2.2 sound bar or AV receiver in your home theater system will be enough to terminate the handshake and your afternoon plans for watching The Godfather in glorious 4K resolution."
http://www.techhive.com/article/2881620/4k-content-protection-will-frustrate-consumers-more-than-pirates-meet-hdcp-22.html
http://www.integrahometheater.com/Products/model.php?m=DTR-30.6&class=Receiver&source=prodClass
oneeyeblind likes this.
post #1989 of 2366 Old 06-28-2015, 04:51 PM
Wireless member
pepar's Avatar
Quoted: 929 Post(s)
Liked: 506
hey captain,
Geffin
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is offline
post #1990 of 2366 Old 06-29-2015, 02:35 PM
nexsen's Avatar
Originally Posted by Feddie View Post
I am having lip sync issues with the Arris X1 DVR box. I mainly get it when watching recorded shows on HGTV or Food Network. Watching HBO, Showtime, etc it seems to be fine. I have it hooked up via HDMI to a Yamaha Aventage 720 with lip sync correction set to auto. Is this a known issue or just my setup? Any help would be appreciated.
The AUTO feature of HDMI 1.3 and 1.4 doesn't do anything except allow your TV to tell your AV receiver a FIXED delay to use for progressive and interlaced formats. Those two "fixed" delays remain the same no matter how much lip-sync error in the signal changes. You probably already knew that but many people assume it can actually correct for lip-sync error as it changes. The only way to do that is with dedicataed lip-sync correction devices from companies like Alchemy2, Felston, Primare, etc which offer remote control adjustment in 1 ms steps (and even 1/3 ms for some) while watching.
But what I am seeing in this thread is that audio is already delayed too much. If that's the case even my Felston DD740 wouldn't help since it could only add more delay but you would definitely want to turn AUTO to OFF since that's making it add delay increasing the error. It might still be off if audio arrives delayed but it won't be off as much if you turn AUTO to off.
You might also check your TV and STB settings to be sure they aren't adding any delay. Sometimes they put the audio delay settings in the s/pdif output menu. If you find your TV was adding a delay and AUTO was adding another delay that might add up to quite a bit of lip-sync error.
nexsen is offline
post #1991 of 2366 Old 06-30-2015, 09:18 AM
Feddie's Avatar
The original post was from almost a year ago. It has since been resolved because it was a problem with the box. I did not have to make any changes.
Feddie is offline
post #1992 of 2366 Old 07-17-2015, 04:40 PM
moparbob7's Avatar
Quoted: 77 Post(s)
Liked: 33
Hey Guys, a couple of questions. Can you have 2 X1 DVR boxes in the house? I read on comcast site you can but when I chatted with a rep they first said no then I said I read about it then they said yes another rep says no. I asked at the comcast building and they said no. I asked about the price of a second X1DVR box and it is $19.95 same as the non X1 second DVR box which we have now.
How good is the satellite box? I see the Xi3 is out and I asked to see it down at Comcast and it is small!! I would really like to have 2 DVR boxes though for our setup.
With the DVR and satellite box how may shows can you watch at the same time all together. I read record 4 and watch a 5th but with the satellite box it has no turner so it uses the DVR box?
moparbob7 is offline
post #1993 of 2366 Old 07-18-2015, 06:20 AM
Wireless member
pepar's Avatar
Quoted: 929 Post(s)
Liked: 506
You can have two DVR's. I do. But it only doubles your storage capacity. All other functions of your system will remain the same, i.e. all units ... DVR or slave ... can schedule or play recorded content.
Oh, each DVR has four tuners so two DVRs should be able to record eight shows simultaneously. I have seen our system record five at once. Somebody verify this?
Jeff
pepar is offline
post #1994 of 2366 Old 07-18-2015, 01:05 PM
Garrett Adams's Avatar
Quoted: 886 Post(s)
Liked: 896
Originally Posted by pepar View Post
Oh, each DVR has four tuners so two DVRs should be able to record eight shows simultaneously. I have seen our system record five at once. Somebody verify this? Jeff
Last week the X1 "unlocked" the two other tuners. You can now record 6 programs at the same time. Obviously this means there is no On Demand or live view when all 6 are recording, but the user can still watch recorded shows. Check the 6th tuner thread on the X1 forum
Garrett Adams is offline
post #1995 of 2366 Old 07-23-2015, 12:47 AM
sonofsoren's Avatar
Quoted: 95 Post(s)
Liked: 27
Anyone know how to get the X1 to switch to surround sound? I tried to switch it in settings but it would not let me switch it from stereo to surround sound. I have a SlingBox 500 attached to the output from the X1 then on to my AV receiver. I also put in a TII ground loop isolator to get rid of a chirping sound that was coming through my speakers in the cable side of my connection (also have high speed internet with Comcast). Lastly I put in a hdmi to hdmi to component adapter that was recommended by SlingBox for use with this type of set top box so I can still get HD out of the SlingBox from the X1. Any help with this would be greatly appreciated.
Samsung UN75HU8550 SEK-3500 Marantz AV8802A Monster Power Parasound A51x2 Samsung UDB-K8500 Oppo BDP-105D Rega RP-6 Panasonic DMR-EZ48V Sony PS4 Xfinity X1 DVR
Slingbox 500 Sony PS4 Sonos Connect Amp Apple TV Roku 4 Amazon Fire TV Nvidia Shield
Adcom GFS-3 Speaker Selector B&W Nautilus 11.2 Speaker Setup Velodyne DD-18x2
sonofsoren is offline
post #1996 of 2366 Old 07-23-2015, 11:16 AM
PaulGo's Avatar
Quoted: 134 Post(s)
Liked: 60
If the X1 cannot detect a surround sound HDMI connection it will not allow switching to surround sound.
post #1997 of 2366 Old 07-31-2015, 11:44 AM
videoguy60467's Avatar
Quoted: 173 Post(s)
Liked: 201
Yep. I just got 2 X1 DVRS installed today. I have a Mits DLP connected to one. The old DVR would pass bit-stream through my Mits TV to my Sony receiver. On the X1, it reverts to PCM regardless of setting. It would be great if they would enable a forced bit-stream setting to get Dolby Digital.
I have read that there is a planned firmware update to allow this. In the meantime I'll have to get a 12' Toslink cable to go from the DVR to the AV receiver.
videoguy60467 is offline
post #1998 of 2366 Old 08-03-2015, 09:22 AM
Jimmy's Avatar
Ok I Give Up
Ok, I've searched and searched. Just had the X1 system installed last week. An HDVR and two of the small boxes. Everything seems to be working fine as I learn my way around the features and the remote. Before I signed up for the upgrade, I remember reading the reviews last year and something about you should never turn your boxes off, at the box, ie pushing the blue power button. The more the box was off, the more you had problems with the boxes syncing and working properly.
I can't find anything about that anymore. I've turned my DVR X1 off one night. No apparent problems.
Does anybody turn off their boxes? I know there is no apparent power savings by doing so. My wife hates leaving some appliances on when we go away.
Your help appreciated.
Jimmy
Jimmy is offline
post #1999 of 2366 Old 08-03-2015, 01:24 PM
Wireless member
pepar's Avatar
Quoted: 929 Post(s)
Liked: 506
Jimmy
I never turn off our two DVR boxes, or the "small" box on a TV we use all the time. (The TV and audio amp get turned off.) I do turn off the small box in the home theater as it gets infrequent use. I have never had any issues with them losing their minds.
Jeff
pepar is offline
post #2000 of 2366 Old 08-04-2015, 09:40 AM
Jimmy's Avatar
Thanks Jeff, since it doesn't seem to be a great down side to leaving them on, that's what I'll probably do. I also have a small box in a quest room that maybe gets used less than 25 hours a year. Might turn that off. My plan is to ditch that one anyway after the contract.
Jimmy is offline
post #2001 of 2366 Old 08-04-2015, 09:53 AM
PaulGo's Avatar
Quoted: 134 Post(s)
Liked: 60
I does save some electricity in "turning them off" - or better put putting them in a low power state. They still get updates in the low power state and I have had no problems in putting them in that state.
post #2002 of 2366 Old 08-06-2015, 06:45 AM
murffee1's Avatar
Quoted: 16 Post(s)
Jimmy
In my area, Comcast does some form of maintenance every night around 2:00AM. If you are watching TV at that time, the box will receive a signal and reboot. I assume that this happens in all areas. If your box is not turned on, it will not get any firmware upgrades.
murffee1 is offline
post #2003 of 2366 Old 08-06-2015, 06:51 AM
crossbeaux's Avatar
Quoted: 26 Post(s)
I'm not sure that's true about not getting firmware updates. I don't know how the X1 compares to previous boxes in that regard, but with previous DVRs, if it was turned off and a program was set to record during that time, the box would turn on and record the program. I assume it could also be reset from that off state.
crossbeaux is offline
post #2004 of 2366 Old 08-06-2015, 07:03 AM
Wireless member
pepar's Avatar
Quoted: 929 Post(s)
Liked: 506
I haven't tried it as I do not want to miss a recording, but I *think* the X1 DVR will NOT power up if off when a scheduled event occurs. Hence the advice to keep them on.
Jeff
pepar is offline
post #2005 of 2366 Old 08-06-2015, 07:21 AM
Jimmy's Avatar
I have a non important, to me problem, where the small video screen at the bottom of the guide will not come up with the guide. Either one or the other will show but not both at the same time. I notice that in the morning, or first time the tv is turned on, the program view screen in the guide works. So I'm guessing that the DVR is getting rebooted at night, fixing the problem. Unfortunately, that fix doesn't last after going to the guide a couple of times. I have stuff recording every night and so far so good. As we go along we will learn more. I would like to turn the boxes off when I leave for a couple of weeks. Anybody have a problem with that small program screen in the guide issue I mention?
Jimmy is offline
post #2006 of 2366 Old 08-06-2015, 11:37 AM
Wireless member
pepar's Avatar
Quoted: 929 Post(s)
Liked: 506
Have you tried removing AC power completely and then rebooting?
pepar is offline
post #2007 of 2366 Old 08-06-2015, 01:42 PM
Mark12547's Avatar
Quoted: 721 Post(s)
Liked: 475
I'm not on X1 so this might not apply.
Whenever my DVR starts acting odd (the DVR takes way too long to bring up the schedule of my favorites, or deleting a recording doesn't delete it, or a recording doesn't capture information about the show, or missing information on some displays), I find that turning it off (which just puts it in "standby" and not really off) and then unplugging it for about 30 seconds will cure most of the ills, but then it takes about 2 days to fully load the program guide. My 34 years in IT tells me that this "smells" like a memory leak and a complete reboot (in the case of the DVR, and actual pulling the power plug, and then reinserting the power plug) recovers that memory so the process of "leaking memory" can start afresh.
I have to do this about once a month, though I have read of some people in the past having to do this every other week.
My very humble setup:
Spoiler!
Mark12547 is offline
post #2008 of 2366 Old 08-06-2015, 03:30 PM
Wireless member
pepar's Avatar
Quoted: 929 Post(s)
Liked: 506
Sounds like that DVR needs to be retired.
pepar is offline
post #2009 of 2366 Old 08-07-2015, 05:09 AM
Jimmy's Avatar
Everything works so great I'm reluctant to mess with it. I'm really liking this X1. Having that small p frame come up in the guide and hiding the channel details is lame anyway. I am sure we will have a power failure at some point then I'll find out what goes on with these boxes when they do a hard reboot, all at the same time.
Jimmy is offline
post #2010 of 2366 Old 08-07-2015, 11:27 AM - Thread Starter
Quoted: 41 Post(s)
hello pepar,
the x1 will record if in power off mode.
June
Reply HDTV Recorders
x1 comcast activation problem companion
