NV-DH1 VHS over Firewire? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-31-2013, 12:20 PM - Thread Starter
Amechan's Avatar
I have a chance to get a Panasonic NV-DH1 DVHS player from a friend.
I do not really need it but I was wondering if it is possible to connect a DVHS player to a PC and record standard VHS tapes on a PC over firewire to the PC?
I assume the iLink transfers digital tapes no problem but will it work with standard VHS?
If so I can record a lot of old home movies.
Thanks a lot.
Amechan is offline
post #2 of 3 Old 01-31-2013, 05:04 PM
ctdish's Avatar
Quoted: 71 Post(s)
Liked: 35
I doubt it. The JVC DVHS machines will likely do what you want because they have an MPEG2 encoder in them. This is a thread with some info on the Panasonic machine. http://www.avsforum.com/t/91169/possible-replacement-for-pv-hd1000-available-in-japan/0_100
John
ctdish is offline
post #3 of 3 Old 01-31-2013, 07:45 PM - Thread Starter
Amechan's Avatar
Thanks for the info.
I did a forum search before posting and read that thread but was not clear after if it could or not.
Amechan is offline
Reply HDTV Recorders
