Replacing A Blown Beywonz Dvr - Kaiser Baas Or Maybe Hauppage - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-16-2013, 04:15 PM - Thread Starter
alect's Avatar
My current set up is – Beyonwiz DP-S1, Acer Aspire Revo HTPC running Win7 and XBMC (And Serviio), all using IceTV (which I love).
Lately the Beyonwiz HDD has been acting up – I am thinking it has either failed or is cloe to failing. So thinking of migrating to a USB Dual TV Stick plugged into the HTPC, recording all TV and watching it back via XBMC (or whatever).
Are there any inconsistencies/incompatibilities that are likely to be a problem? Any other red flags? The advantages I see from the move KaiserBass:
- one fewer boxes to run and house
- tv recorded in a universal format (avi/mpeg/etc) which is viewable from XBMC or through Serviio/DLNA (beyonwiz records in a proprietary format).
I have learnt that IceTV works well with Win MC, which I can use with the Kaiser Baas, instead of the total media software they supply.
The alternative to the Kaiser Baas is the Hauppauge Novo-TD USB Dual Digital - how does this compare to the Kaiser Baas - are they pretty much the same?
Any recommendations or thoughts welcome.
One more thing – all of the above controlled by a logitech harmony 600 – are the above both compatible with the Logitech or will I need to use the provided remote with each?
alect is offline
post #2 of 2 Old 02-22-2013, 11:31 AM
videobruce's Avatar
Quoted: 669 Post(s)
Liked: 254
Since some of that seems native to your country, you might be better off asking it in a forum there. wink.gif
Recording free OTA TV for 'time shifting' has been here since 1977. Will there be DVR's to do the same when ATSC3 obsoletes existing DVR's??
videobruce is offline
Reply HDTV Recorders
