atsc tuner - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-20-2013, 04:47 PM - Thread Starter
uncledok's Avatar
just a basic question, but i'm not familiar at all with the tivo products, can a
tivo series 4 be used as an OTA tuner to receive local channels without
paying the monthly or lifetime fees. inotherwords, can i use the tuner to
watch tv using the hdmi output but not the dvr function free? thanx for any
and all replies, i am a tivo newbie (as u can certainly tell).. thanx again,
uncledok
uncledok is offline
post #2 of 2 Old 02-21-2013, 11:46 AM
demonfoo's Avatar
Quoted: 49 Post(s)
Liked: 36
If the TiVo you get is new, you'll have a week of free service in which you can run the Guided Setup, and get your local lineup. Otherwise, if you don't pay, you can do a channel scan, but it won't have the correct call letters/network logos for your channels. You won't be able to make recordings either, though live "trick play" (pause, rewind/FF through live buffer) should work. Of course, Netflix, Amazon VoD, YouTube, etc., and streaming/downloads from a PC won't work either. Basic tuning and trick play functionality will be all you'll get.
Also, keep in mind that the clock is set through the TiVo service, so the clock will probably not be correct either.
demonfoo is offline
Reply HDTV Recorders
