Tired of satelite..... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-25-2013, 01:59 PM - Thread Starter
Justin Murphy's Avatar
I'm looking to "cut the cable" so to speak. I'm spending a ton for Dish and I'm looking at what my options are.
If I just keep my DSL and get an antenna to pick up my locals, what DVR is the best for the money?
Also looking at Roku as well.
Any and all suggestion welcome PLEASE!
Justin Murphy is offline
post #2 of 9 Old 02-25-2013, 02:49 PM
Aleron Ives's Avatar
Quoted: 1580 Post(s)
Liked: 1289
How well OTA TV will serve your needs depends on where you live and which programs you watch. You won't have access to cable-exclusive programs anymore, unless they happen to be available on the network's website (which seems to be becoming more common). It would help for us to know your location, since we can't tell how many channels you'll receive without knowing which market you're in.
As for a DVR, keep in mind that most OTA DVRs don't work the same way as cable ones do. They don't make name-based recordings and find your programs for you: you either click on the guide to set a timer to record that timeslot, or you set up a manual timer, the way you would with a VCR. You'll record whatever is broadcast during that timeslot, so if your program gets moved at the last minute, you'll miss it. OTA guide data is also determined on a station-by-station basis, so how much program information you see and how complete it is will vary by network. The main DVR options still available are:
CM 7000
CM 7400
TViX 6620
PHD-VRX
TiVo
Of these, only the CM 7400 and TiVo support paid guides that will let you continue to do name-based recording, but current TiVos no longer have OTA tuners, so you can't use the latest model with an antenna.
The other models have their own quirks and bugs, some worse than others. It would help us to make recommendations if we knew some of your priorities.
Aleron Ives is offline
post #3 of 9 Old 02-26-2013, 05:00 AM
ozonedan's Avatar
CM 7000
CM 7400
TViX 6620
PHD-VRX
TiVo
Actually, the Tivo Premiere does have OTA tuners. I cut the cord over a year ago and couldn't be happier. The others just had too many bugs and were expensive right out of the box. I bought two and went with the monthly fee for the guide because I couldn't afford the lifetime cost. I also have Netflix and Amazon Prime. And also Playon. I have a PS3 that gets all the above plus Crackle. I purchased Playon several years ago when it was real cheap. You might want to get it a try.
Lake Worth, FL
If it won't fit force it.
If it breaks it needed replacing, anyway.
ozonedan is offline
post #4 of 9 Old 02-26-2013, 07:45 AM
Charles R's Avatar
Liked: 536
Best bet is TiVo with Lifetime (if you decide to punt its resell value is very high). The cheapest (in many cases) and perhaps the best might be WMC. The link in my signature will give you further details.
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Philips BDP7501 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
post #5 of 9 Old 02-26-2013, 12:48 PM
Liked: 1289
If I'm not mistaken, the latest Premiere Elite models only work with pay TV. Only the original Premiere and Premiere XLs can do OTA. The TC just needs to be careful which model he purchases if he goes the TiVo route.
post #6 of 9 Old 02-26-2013, 03:59 PM
Kelson's Avatar
Quoted: 1952 Post(s)
Liked: 1147
The current models are the:
Premier (2 x tuners - OTA and/or Cable)
Premier 4 (4 x tuners - Cable only)
Premier 4XL (4 x tuners + 1 TB HDD - Cable only)
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #7 of 9 Old 02-26-2013, 04:10 PM
jjeff's Avatar
Quoted: 689 Post(s)
Liked: 245
Premier (2xOTA + 2xCable)
Premier 4 (4xCable)
Premier 4XL (4xCable + 1TB HDD)
Just to clarify, the basic Premier only has 2 tuners which can do either OTA(ATSC) or Cable(QAM) not sure but I'd think they may also do analog......
jjeff is online now
post #8 of 9 Old 02-26-2013, 04:59 PM
Possumgirl's Avatar
Liked: 58
Adding to the clarification, the Premiere XL is still readily available brand new even though TiVo ended production of it. It's same as Premiere but with larger HDD (1TB) and fancier remote.
The OP could also consider a used TiVo series 3 with lifetime. Seems there is a never-ending supply of them on eBay in the $350 range.
Possumgirl is offline
post #9 of 9 Old 02-27-2013, 07:56 AM
Kelson's Avatar
Liked: 1147
Thanks, I realize my post was unclear. I edited it to make it more specific.
- kelson h
Kelson is offline
Reply HDTV Recorders
