PHD-8VX - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-04-2013, 11:26 AM - Thread Starter
T0R0's Avatar
Anyone know where I can purchase this unit? I don't see a buy option on this page.
http://www.epvision.com/HDTVSTB/phd8vxmain.htm
T0R0 is offline
post #2 of 4 Old 03-05-2013, 07:36 AM
videobruce's Avatar
Quoted: 597 Post(s)
Liked: 246
I guess they don't want anyone to buy it.
I believe it's also sold through Amazon. Call them and point out their error. Depending on exactly how you plan to use it, you might consider the PHD-VRX which is newer and has DVR capability, but less inputs. wink.gif
Free, abundant OTA television separates this country from many others. ATSC1 has only been in force since 2009. The wireless industry has enough spectrum. Enough of 'planned obsolesce'.
videobruce is offline
post #3 of 4 Old 03-05-2013, 06:25 PM - Thread Starter
T0R0's Avatar
Amazon was out of stock.
What unit would you recommend for OTA to connect to a receiver for my home theater setup. The monitor (plasma 1080p) has no tuner. I'm versed in the htpc aspect of my setup but I need this to bypass the htpc part which gf refuses to use. rolleyes.gif
Right now she receives OTA signals well enough with plain old antenna on top of tv.
So I need something that will pull in good reception. It's an apartment so can't put anything outside.
I didn't really need the dvr part of it but I won't discount a super solid tuner with it.
Need help, moving in soon and I need to address this issue.
So as far as I can tell its either the channelmaster or epvision, right??
T0R0 is offline
post #4 of 4 Old 03-05-2013, 07:52 PM
Aleron Ives's Avatar
Quoted: 1587 Post(s)
Liked: 1293
CM-7400 has a terrible tuner, so if your reception is spotty, you will probably be unhappy with it. The PHD-VRX has a better tuner, and I've found the TViX 6620's tuner to be satisfactory, as well.
Aleron Ives is offline
Reply HDTV Recorders
