iView-3500STB Tuner & DVR Owners Thread - Page 103 - AVS Forum | Home Theater Discussions And Reviews
 121Likes
post #3061 of 5075 Old 03-23-2014, 09:59 AM
LenL's Avatar
Location: Randolph, NJ, 725' above sea level, 30 miles west of ESB
Quoted: 272 Post(s)
Liked: 237
Make sure you read post #5 and your USB stick is properly formatted (fat32). Nothing else should be on the USB stick. You have to download and unzip the files and copy to your USB stick. There are usually 2 bin files created when you unzip correctly.
LenL is offline
post #3062 of 5075 Old 03-23-2014, 01:25 PM
DoctorM's Avatar
Quoted: 685 Post(s)
Liked: 209
iView 3500STBII is listed on Amazon with the feature of 'Closed Captioning'.
Did they really finally add this feature or is it still only on live TV and not recordings?
DoctorM is offline
post #3063 of 5075 Old 03-23-2014, 01:37 PM
jprc's Avatar
Quoted: 83 Post(s)
Liked: 120
It's the same as on the original. All these similar boxes under their various names list CC support and all of them show CC on live TV and record the CC stream. But the recorded captions can only be played back on another device (or possibly if you use some software to take out the CC and then embed it or something similar, but I haven't tried it or looked into it myself since it's easier just to watch it on the computer and I only occasionally have a reason to use CC).
jprc is offline
post #3064 of 5075 Old 03-23-2014, 01:54 PM
DoctorM's Avatar
Quoted: 685 Post(s)
Liked: 209
So the lie continues. Thank you.
Btw, VLC (VideoLan) will play closed captions without needing to extract and remux.
DoctorM is offline
post #3065 of 5075 Old 03-25-2014, 01:28 AM
rollyholly's Avatar
I purchased a 3500STB (not 3500STBII) a year or two ago when they first came out for $35. I finally got around to putting into service sometime last year. After many frustrating hours trying to "grok" this box I (fortunately) came across this forum and started reading the 3000+(!) entries trying to make some sense of this thing. I just missed out getting a free "new" remote and had to pay for a new one, BFD $10. I am VERY happy with the picture quality.
I'm a longtime lurker on this website.
Videobruce and others, thanks for your tireless work. Why doesn't iview implement more (any) of your and others suggestions?
My unit (on a UPS) locks up requiring power off/on and/or spontaneously reboots (usually while receiving a corrupted OTA signal); upon rebooting, channel 49 (ION) and subchannels (only?!) mysteriously appear in the "Program" list until I manually delete them again. Anyone else have this issue?
I have other issues but I'm tired of ranting now...
This could be such a great box if someone would work on the firmware.
rollyholly is offline
post #3066 of 5075 Old 03-25-2014, 03:31 AM - Thread Starter
videobruce's Avatar
Quoted: 648 Post(s)
Liked: 254
Easy answer; it's only a $40 item, it's not worth it to go farther. I'm really surprised they went as far as they did.
I'm waiting (probably hoping) they follow through with what I was told and plan to introduce a 2nd far more advanced model.
Regarding the ION problem, this is a known issue if you are in a market that has certain extra sub-channels. I forgot the specific details, but it causes problems on some DVR's
Recording free OTA TV for 'time shifting' has been here since 1977. Will there be DVR's to do the same when ATSC3 obsoletes existing DVR's??
videobruce is offline
post #3067 of 5075 Old 03-25-2014, 01:25 PM
LenL's Avatar
Quoted: 272 Post(s)
Liked: 237
Agree. For $40 you don't get a lot but you do get your $40 worth. Too bad they did not build one with 2 tuners (essentially combine the components or most of them from 2 boxes) and keep RF pass through and sell it for $100 or less and it would be a very very hot item.
LenL is offline
post #3068 of 5075 Old 03-27-2014, 11:28 AM
servantes173's Avatar
I purchased this device recently and started testing it out.
I wanted to run this in a bedroom setup for his DVR functionality and it seems to work fine over the air but i cannot get any QAM channels to show up from my Cable, none at all, not even encrypted ones, i have Charter Cable and i am not sure if Virtual or Physical, i changed several firmwares and tried dozend of combinations.
I just cant get any Cable channels to show up ever not even a glimpse. Charter should have Clear QAM but they state that they are transmitted in sub channels and that I have to manually integrate them ( CH 2.1 etc ) here is the article from the Charter Website about it if anyone can make sense of it :
DigitalSub Channels
Local broadcasters may use their FCC assigned over-the-air digital channel to provide one or more sub-channels beyond their primary channel.  When using a Charter digital receiver or CableCARD enabled device to access any of these channels carried by Charter, simply tune the Charter assigned channel number.  When using a clear QAM tuner in a TV or other device, you would tune the actual physical channel and program number.   Typically to do this, enter the physical channel, a decimal or hyphen, and the program number (e. g. 3.1, 14.2).  This will vary by market, but a channel scan by the TV or other device will determine which ones are available.
Anyone has similar experience ?
Great Device for the price ! and great Post here !
Thanks !
servantes173 is offline
post #3069 of 5075 Old 03-27-2014, 11:50 AM
To add, i have V13 on but tested all the way down :)
post #3070 of 5075 Old 03-27-2014, 12:27 PM
LenL's Avatar
Quoted: 272 Post(s)
Liked: 237
Servantes,
If you have not already done so read post #5 and from 3068 on. You might find the answer to your issues.
I would also advise anyone not using this for OTA but planning to use the IVIEW with cable to DO YOUR RESEARCH FIRST on the AVS forum so you know what you are getting yourself into!
LenL is offline
post #3071 of 5075 Old 03-27-2014, 12:59 PM
I read Post #5 several times and followed everything exact :) still no luck !
I knew what i was getting into, the small investment was worth exploring the realm of "no need to pay a rental fee"
It was worth a shoot :)
post #3072 of 5075 Old 03-28-2014, 11:40 AM - Thread Starter
videobruce's Avatar
Quoted: 648 Post(s)
Liked: 254
Are you receiving them on other tuners (yours, not theirs)?
post #3073 of 5075 Old 03-28-2014, 02:07 PM
I do not have any other standalone receivers, i have several tv's who get cabkle directly and have around 80 channels including some HD ones.
Is there a posibility that Charter has no QAM but only  analog ones ?
post #3074 of 5075 Old 03-28-2014, 02:21 PM - Thread Starter
videobruce's Avatar
Quoted: 648 Post(s)
Liked: 254
Those TV's, assuming they are HD, have you connected your CATV feed directly to the RF input and scanned for stations?
post #3075 of 5075 Old 03-28-2014, 02:26 PM
I feed teh CATV directly into these TV's , one big one is HD and i get HD channels there, most of teh channels are 2.1 / 5.1  so 5 would be SD and 5.1 the HD version of the same channel. Thats why i though it should have QAM but getting not 1 channel with the I-View brough me down crashing with that theory
to add, these TV's have no Cablecard on, i have anotehr setup with a TIVO and a cable card and another tuner and it works fine, there is a TIER of channels i get only there.
post #3076 of 5075 Old 03-28-2014, 02:36 PM - Thread Starter
videobruce's Avatar
Quoted: 648 Post(s)
Liked: 254
I believe there has been reports of certain cable TV operators doing things differently, causing a situation like yours.
post #3077 of 5075 Old 03-28-2014, 02:42 PM
Its inconclusive, i researched for days and all i could find about Charter is that they do run Clear QAM, now the exact specs , nowhere to find...
Now i am wondering, if its all QAM, shouldn i have crystal clear SD and HD reception ? on both TV's i get snowy pictures on some channels sometimes, that sound more like Analog to me ?
If i have only Analog as per posts = no analog
Is there a test method to determine what signal i have? ( digital or analog QAM )
post #3078 of 5075 Old 03-28-2014, 04:55 PM
Aleron Ives's Avatar
Quoted: 1640 Post(s)
Liked: 1389
You're right. That's definitely NTSC, not QAM. The iView can't tune such channels.
Aleron Ives is offline
post #3079 of 5075 Old 03-28-2014, 05:40 PM
Do you happen to know a box that has similar functions that would be able to tune these ?
post #3080 of 5075 Old 03-28-2014, 07:16 PM
Liked: 1389
If you want to be able to record them, no. Your best bet would be a VCR in terms of price and simplicity. Other than that, a Hauppauge capture card would be able to record them to your PC.
post #3081 of 5075 Old 03-28-2014, 07:24 PM
Thank you, i can confirm there is no box except the Magnavox that can record on HDD, the Magnavox MDR-513H/F7 has a DVD Recorder and a HDD but it does not have a real DVR functionality but may be not so bad ?
http://download.p4c.philips.com/files/m/mdr513h_f7/mdr513h_f7_dfu_aen.pdf
Why is it here the U.S. so limited ? i would think that there would be a huge audience for these type of devices ?
I have a friend from germany and he has tons of different DVR's to choose from ? sounds like someone made a good deal with the FCC ?
post #3082 of 5075 Old 03-28-2014, 09:31 PM
Liked: 1389
There is no longer a market for those devices, as your cable system is obsolete. Most cable systems are digital now, and yours may switch soon, too.
post #3083 of 5075 Old 03-29-2014, 12:13 PM
johngbm4el's Avatar
Do any of the firmware versions offer a "Mon-Fri" option to record a show? My "Daily" setting to record Letterman is conflicting with the Sat. 11:30 time slot to record SNL??
johngbm4el is offline
post #3084 of 5075 Old 03-29-2014, 12:19 PM
jprc's Avatar
Quoted: 83 Post(s)
Liked: 120
No. The only thing you can do is create 5 weekly programs for each day of letterman and then one weekly for SNL.
jprc is offline
post #3085 of 5075 Old 03-29-2014, 01:16 PM
johngbm4el's Avatar
good idea,
thanks
post #3086 of 5075 Old 03-29-2014, 04:58 PM
I checked with a new LED TV that arrived today and found out that my cable carries 80 NTSC Analog Channels and 75 Clear QAM ones, i called Charter and talked to a tech and he confirmed that they have and will leave on NTSC and QAM.
So why cant i get any QAM channels to show ? The previous statement where i found only fuzzy Analog channels was done by an much older TV who has only NTSC in but no QAM
post #3087 of 5075 Old 03-29-2014, 07:49 PM
apw2607's Avatar
Quoted: 285 Post(s)
Liked: 335
^ some clear QAM simply doesn't work with the 3500. Simple as that. When I first brought this up in the thread I got the same story that I must have old analog channels, but I knew this wasn't the case. After all some of the ClearQAM channels include many full HD Channels.
So even though my Sony TV tuner picks them up fine, it was always a mystery why the 3500 could not.
Since then, I've tried a HDhomerun Dual which picked up the HD ClearQAM channels fine, as did the Philips DVR 5710.
apw2607 is offline
post #3088 of 5075 Old 03-29-2014, 08:59 PM
Thank you !
Its too bad, i would be ok if i would at least get 1 channel, i like the functionality of it, i have Tivo's and i though i will be able to get rid of them, tired of paying them a fee for Programming that could be free, it looks like i have no other option then to run Computers with Cable Cards and a Media Center, i wanted to avoid that...
The little device is still pretty good for ATSC ... maybe i am lucky and we get a firmware that will work for me :)
post #3089 of 5075 Old 03-30-2014, 10:58 AM
Thread Ender
WS65711's Avatar
Quoted: 509 Post(s)
Liked: 341
Thank you !
The little device is still pretty good for ATSC ... maybe i am lucky and we get a firmware that will work for me smile.gif
Wow.. we need to get this added to the DVR Comparison thread. TiVo charging a fee for Programming! Outrageous! There oughta be a law!! rolleyes.gif
To anyone interested in a Google Chromebox or Chromebook..
Be aware that these boxes run a variant of Linux and DO NOT support HDCP!!!
This means no support for HD on most streaming services. I wish I would have known this beforehand....
Blu-rays & DVD's
WS65711 is offline
post #3090 of 5075 Old 03-30-2014, 12:05 PM
jjeff's Avatar
Quoted: 761 Post(s)
Liked: 267
Thank you !
I know you know WS but for the OP, I haven't payed a fee(monthly that is) for my Tivo for the last 5 years, just payed $550 upfront(box + lifetime) for a wonderful DVR that NEVER needs babysitting, it just works! I supplement it with my little iView for a third tuner when the need arises but it's quite painful programming and searching with the iView compared to my Tivo. Also for what ever reason I bet 20% of the events I program with my iView just don't record :( I always use the iView for my least important event, that way if(and when) it fails I'm not so bummed out.
jjeff is offline
Reply HDTV Recorders
