iView-3500STB Tuner & DVR Owners Thread - Page 107 - AVS Forum | Home Theater Discussions And Reviews
 130Likes
post #3181 of 5187 Old 05-22-2014, 07:48 PM
billin30's Avatar
I just purchased one of these units and I got one of the new batch units with the 3/4 switch on the back. Glad I read through everything again before trying to flash some firmware that would have bricked the thing.
Anyway, similar to someone else on the thread, I purchased this box so I could route my QAM cable channels through my HDMI receiver as opposed to connecting the coax directly to my TV. I was able to pick up all the local channels in HD when plugging the coax into the TV. I was hoping to get the same result from this box as it specifically says QAM on the box. I don't need anything else but the local stuff.
It looks like those of us with units from this new batch either need to wait for them to give us a firmware update or just return our units. Their website says firmware is in testing now, but who knows what that means.
Does anyone know of a different box that could perform the same function that I was hoping this one would perform? Or should I just hold out and see if new firmware will help?
billin30 is offline
post #3182 of 5187 Old 05-22-2014, 08:10 PM
jprc's Avatar
Quoted: 83 Post(s)
Liked: 120
I'll throw out some possibilities but no one here that has an original version has posted about also having a new chipset version so we don't really know much for certain about the software that is on it.
My guess is that the firmware on the new boxes is similar in function to the fw that the version II boxes with old chipset originally shipped with. That would be v9 btw. V9 can pick up virtual cable channels only and besides that simply does not work well with cable. IF your software if based off that you can expect the same results.
So, you can email iview and see if they have an eta on new fw and ask whether it will support physical cable channels. Or you can just wait. Or you can use an antenna to get local channels unless that is not an option where you live. Or you can return it and get an original version of the box that you can upgrade to v13 or any other version posted here. Even with an upgrade that supports physical QAM channels, there is no guarantee you will be able to get them in.
The only other thing I would mention before doing any of that is to make sure the cable channels you get directly connected to your TV are not analog.
jprc is offline
post #3183 of 5187 Old 05-24-2014, 09:31 AM
lilpilgrim's Avatar
I am wanting to update my iview but dont know what version that I have. How can I find out? where do I look?
lilpilgrim is offline
post #3184 of 5187 Old 05-24-2014, 03:00 PM
jprc's Avatar
Quoted: 83 Post(s)
Liked: 120
You should read at minimum the first 5 posts of this thread.
jprc is offline
post #3185 of 5187 Old 05-25-2014, 03:26 PM
Antproof's Avatar
I am a new user. I have the iView 3500 TBII. It's connected to an analog tv and was working fine right out of the box. Today I started exploring with a view to using the record function. I pressed a menu item that was labelled "channel 3 modulation" or such like and now I have nothing but static. I can't access the menu or get out of the static. Unplugging the 3500 hasn't helped. Anyone with an idea on how to restore my channels?
Antproof is offline
post #3186 of 5187 Old 05-25-2014, 03:37 PM
jprc's Avatar
Quoted: 83 Post(s)
Liked: 120
Don't worry. I posted a method to get it back. Let me go find it again in my posts since I'm not where my iview is right now to try it out again. I will edit this post when I've got it. Wait a few minutes.
Edit: Here it is. Post 2986: http://www.avsforum.com/t/1465875/iview-3500stb-tuner-dvr-owners-thread/2940_60#post_24330225
jprc is offline
post #3187 of 5187 Old 05-25-2014, 04:01 PM
Antproof's Avatar
Excellent, thanks so much jpcr. I love this place.
Antproof is offline
post #3188 of 5187 Old 05-26-2014, 10:19 AM
AceDog100's Avatar
AceDog100 is offline
post #3189 of 5187 Old 05-26-2014, 10:23 AM
AceDog100's Avatar
As a side note and to make a long story short I needed to do a factory reset because PAL was selected and there was nothing on the display. I don't own the 3500ii anymore, but I was able to a factory reset as shown below to recover. The steps below are from Amazon reviews. I modified them slightly by adding step 0:
0. Press the EXIT button on the remote
1. Press the Menu button on the converter box remote.
2. Wait for the Converter Box's display to show four dashes
3. Press the RIGHT arrow key 5 times
4. Press the DOWN arrow key 3 times
5. Press the Right arrow key 1 time
6. Enter zero 6x (000000) Note: this is the default password. Change if you set a different
password.
7. Press "OK" The converter should reset.
post #3190 of 5187 Old 05-26-2014, 02:48 PM
jprc's Avatar
Quoted: 83 Post(s)
Liked: 120
password.
I could have saved you the factory reset if you had asked here. smile.gif I know it's too late for you, but for anyone else who changes that setting, here is how to change it back without erasing all your data.
-Turn it off and then turn it on again.
-After you give it time to be fully booted, press Menu.
-Using the navigation keys do the following: Right, Down 3 times, Right.
-Give it a couple seconds to switch - it may not be instantaneous.
-Hit Exit so you don't accidentally change it again.
Btw, the reason that I suggest turning the box off and then on again in both my sets of instructions is to make sure you are starting at the right place. There are several places in iview navigation, like if you are recording, timeshifting, in the PVR menu and also other places where Exit will not Exit you out without you pressing another button, like OK or the Stop button for instance. Usually when people change one of these settings and can't view the screen anymore, they end up pressing every button on their remote and pressing things multiple times. They can end up anywhere and even multiple Exits may not get them back to a place where they can bring up the Menu to start the above steps correctly.
jprc is offline
post #3191 of 5187 Old 05-26-2014, 04:50 PM
bscoles's Avatar
Has anyone has issues with not being able to flash the unit?
I place the file on a flash drive, go to the menus, select the file to flash. The unit then shows the iview logo, goes black, shows the iview logo again, the screen flashes green briefly and then brings me back to the installation guide.
No blue screen with "upgrading software".
Of course, when I go back to the menu and check the firmware version nothing has changed.
I've tried a couple of different flash drives, thinking that it might be picky. I even let it format one of the flash drives before copying the files over to it. No version of the firmware has upgraded the box. I'm stuck at the 918 version.
bscoles is offline
post #3192 of 5187 Old 05-26-2014, 05:02 PM
jprc's Avatar
Quoted: 83 Post(s)
Liked: 120
Are you downloading the files from here or from the iview site? If iview, don't use their files. Make sure you are not choosing the flash.bin file - that won't update anything. Make sure there are no spaces in the filename.
jprc is offline
post #3193 of 5187 Old 05-26-2014, 07:48 PM
bscoles's Avatar
Initially I was trying the files from iview, but was not having any luck. I then came here and tried the files from post #5 of this thread. The files are named as extracted from the archives - 120113_V12_physical.bin and V13a_122713.bin
Essentially everything looks just like the pictures posted, except when I select OK when I'm on the highlighted file, it never goes to the blue 'Upgrading Software" screen.
What do you mean "Make sure you are not choosing the flash.bin file?" I hope I'm not just being dense here...?!?
I have flashed plenty of other devices... Mede8er, TViX, other media boxes that I don't even remember the name of, Motherboards, etc.
bscoles is offline
post #3194 of 5187 Old 05-26-2014, 10:12 PM
bscoles's Avatar
Originally Posted by satpro View Post
For upgrade you need to use fat32 format but before you do anything make sure your unit does not have the new ch 3/4 switch on the rear. In that case do not use any of the files.
Fat32, that's the ticket. I'm usually transporting files bigger than 4GB so I usually format everything to NTFS.
No ch 3/4 switch. Upgraded great.
Thank You!
bscoles is offline
post #3195 of 5187 Old 05-27-2014, 02:03 AM
vr24cod's Avatar
Always look at the first postings on page one for most current updates.  As the thread owner updates the post with new info.
vr24cod is offline
post #3196 of 5187 Old 05-27-2014, 02:09 AM
vr24cod's Avatar
Remember input to the 3500STB needs to be digital not analog.  And most vcrs / cable boxes ect. produce a analog signal output.
vr24cod is offline
post #3197 of 5187 Old 05-27-2014, 07:13 AM
jjeff's Avatar
Quoted: 777 Post(s)
Liked: 278
Your first part is true but I do take exception with your word "most" in youir second sentence. I've never seen a vcr or cable box that outputted anything other than modulated analog channels, you can be assured if your trying to record from such a modulated output it will be analog and therefor not recordable by the iView :)
jjeff is online now
post #3198 of 5187 Old 05-28-2014, 06:00 AM
peterd4's Avatar
I scanned for channels, got 15 channels, after scanning picture shows on tv and then 20 seconds later the screen goes blank and message on screen says "NO VIDEO",  does anyone have any idea whats wrong?
peterd4 is offline
post #3199 of 5187 Old 05-28-2014, 09:27 AM
PA_Prowler's Avatar
I have experienced this on one or two individual channels from time to time, but not on all of them. Are you losing all of them? I noticed it happens on the channel with the weakest signal, at least as far as I can tell from the relative signal strength graph. It's annoying because once the channel disappears, it gets deleted from the list, and the box then rearranges the rest of the channels proceeding it. I have to do a full rescan to restore the one that goes missing, but eventually it disappears again.
BTW, I'm using QAM over cable, not OTA.
PA_Prowler is offline
post #3200 of 5187 Old 05-28-2014, 11:51 AM
peterd4's Avatar
I think your right about a weak signal, but once I get the message my box freezes and I have to power it down and restart, is this normal for it to freeze?
peterd4 is offline
post #3201 of 5187 Old 05-28-2014, 04:42 PM
PA_Prowler's Avatar
The only time I've ever experienced a freeze was immediately after doing a channel scan, while it was in the process of saving the found channels. It doesn't do it all the time. Fortunately the channels get saved and I don't have to initiate the scan over again. I just have to disconnect the power for a couple of seconds, then re-power it back on.
post #3202 of 5187 Old 05-29-2014, 02:03 PM
dleedlee's Avatar
Quoted: 51 Post(s)
Which version of the firmware do you have? My box came with v9 but I upgraded to v13 and found it to be ,mostly, more stable.
dleedlee is online now
post #3203 of 5187 Old 05-29-2014, 02:09 PM
peterd4's Avatar
I just bought the box about 2 weeks ago and it came with the 3/4 channel switch on the back and there was a big red message not to load any software until they had a fix because of some foreign chip put into it.
peterd4 is offline
post #3204 of 5187 Old 05-29-2014, 02:27 PM
superc's Avatar
Here is the PDF for the NM120 tuner NM120Tuner.pdf 506k .pdf file
superc is offline
post #3205 of 5187 Old 05-29-2014, 02:42 PM
peterd4's Avatar
Sorry, but what will the pdf file do for me?
peterd4 is offline
post #3206 of 5187 Old 05-29-2014, 02:55 PM
superc's Avatar
Sorry, The PDF is to show the group what the tuner chip is.
superc is offline
post #3207 of 5187 Old 05-30-2014, 12:08 PM
QAM
QAM's Avatar
Quoted: 27 Post(s)
Just throwing this out there to see if any others have seen this. After 6 months+ of flawless OTA recording on my 3500STBII (with factory original V7 FW and external 2.5" HDD) I found that I now only get about 1GB worth of a HD program (set to record for 1hr, which is usually 9GB+). SD recordings have no problems, and record fully.
At first I thought it had something to do with the time signal broadcast by the HD station. But switching to a different HD station produces the same results. Soooo, the result is that I can no longer FULLY record HD programs.
Short of trying a "factory reset" and losing all my programming/setup data, I'm lost. No need for a FW update as V7 did all I asked of it (don't care about cable). I suppose I could reformat the drive, but that just sounds desperate. Anyone else seeing this? Maybe "chanting" would help (just kidding LOL).
QAM is offline
post #3208 of 5187 Old 05-30-2014, 12:31 PM
QAM
QAM's Avatar
Quoted: 27 Post(s)
How is the external powered? From the receiver or through a separate power supply?
external 2.5" HDD is USB powered from 3500STBII.
QAM is offline
post #3209 of 5187 Old 05-30-2014, 02:31 PM
QAM
QAM's Avatar
Quoted: 27 Post(s)
Also is it NTFS or FAT32?
Seems like the PS in the iview is degraded over time. As far as why it would not do it on SD, SD isn't writing constantly to the drive like with HD.
aaahhhh! It's NTFS, so lots more disk access. Also didn't know about degrading PS issue. Makes sense. Will try swapping out USB powered HDD with different externally powered HDD. Bummer, my power strip is full up. Need to fiddle with this some more, given the info provided. Thanks.
QAM is offline
post #3210 of 5187 Old 05-31-2014, 11:06 AM
Bigham16's Avatar
Quoted: 198 Post(s)
Liked: 142
Just hooked up the 3500STBII and can't edit channels because it asks for a password. I can't change the password because I don't know the old one. I can't do a factory reset because it asks for the password. I never set up a password. I ordered the unit from Amazon. I am guessing this unit belonged to someone else before me.
Does anybody know how to bypass the password?
EDIT: Figured it out! Thanks
Bigham16 is offline
Reply HDTV Recorders
