iView-3500STB Tuner & DVR Owners Thread - Page 108 - AVS Forum | Home Theater Discussions And Reviews
 90Likes
post #3211 of 4835 Old 05-29-2014, 03:42 PM
peterd4's Avatar
Sorry, but what will the pdf file do for me?
peterd4 is offline
post #3212 of 4835 Old 05-29-2014, 03:55 PM
superc's Avatar
Sorry, The PDF is to show the group what the tuner chip is.
superc is offline
post #3213 of 4835 Old 05-30-2014, 01:08 PM
QAM
QAM's Avatar
Quoted: 17 Post(s)
Just throwing this out there to see if any others have seen this. After 6 months+ of flawless OTA recording on my 3500STBII (with factory original V7 FW and external 2.5" HDD) I found that I now only get about 1GB worth of a HD program (set to record for 1hr, which is usually 9GB+). SD recordings have no problems, and record fully.
At first I thought it had something to do with the time signal broadcast by the HD station. But switching to a different HD station produces the same results. Soooo, the result is that I can no longer FULLY record HD programs.
Short of trying a "factory reset" and losing all my programming/setup data, I'm lost. No need for a FW update as V7 did all I asked of it (don't care about cable). I suppose I could reformat the drive, but that just sounds desperate. Anyone else seeing this? Maybe "chanting" would help (just kidding LOL).
QAM is offline
post #3214 of 4835 Old 05-30-2014, 01:22 PM
satpro's Avatar
How is the external powered? From the receiver or through a separate power supply?
satpro is online now
post #3215 of 4835 Old 05-30-2014, 01:31 PM
QAM
QAM's Avatar
Quoted: 17 Post(s)
external 2.5" HDD is USB powered from 3500STBII.
QAM is offline
post #3216 of 4835 Old 05-30-2014, 02:09 PM
satpro's Avatar
Also is it NTFS or FAT32?
I would try powering it externally as a test by adding a Y cable and 5v power supply from a hub or stand alone usb cell phone wall charger, they sell them everywhere for like $5. Most people have some laying around from old phones.
Seems like the PS in the iview is degraded over time. As far as why it would not do it on SD, SD isn't writing constantly to the drive like with HD.
QAM likes this.
post #3217 of 4835 Old 05-30-2014, 03:31 PM
QAM
QAM's Avatar
Quoted: 17 Post(s)
aaahhhh! It's NTFS, so lots more disk access. Also didn't know about degrading PS issue. Makes sense. Will try swapping out USB powered HDD with different externally powered HDD. Bummer, my power strip is full up. Need to fiddle with this some more, given the info provided. Thanks.
QAM is offline
post #3218 of 4835 Old 05-31-2014, 12:06 PM
Bigham16's Avatar
Quoted: 196 Post(s)
Liked: 140
Just hooked up the 3500STBII and can't edit channels because it asks for a password. I can't change the password because I don't know the old one. I can't do a factory reset because it asks for the password. I never set up a password. I ordered the unit from Amazon. I am guessing this unit belonged to someone else before me.
Does anybody know how to bypass the password?
EDIT: Figured it out! Thanks
Bigham16 is offline
post #3219 of 4835 Old 05-31-2014, 02:10 PM
MannyE's Avatar
Quoted: 16 Post(s)
Glad to hear it Bigham! How did you fix the problem?
Truck? What truck?
MannyE is offline
post #3220 of 4835 Old 05-31-2014, 03:17 PM
satpro's Avatar
master password for mstar boxes 888888
default password 000000
post #3221 of 4835 Old 06-09-2014, 08:21 AM
summerski's Avatar
Ok, so I got a new unit and didn't bother to check for the CH. 3/4 switch (which it has) or read the instructions that were clearly posted here and I updated the firmware and killed the unit. Is it toast or is there any way to uninstall the firmware? The unit won't power up at all. I'm thinking it's back to Amazon......
Thanks for any help or suggestions.
Kind Regards.
W-
summerski is offline
post #3222 of 4835 Old 06-09-2014, 02:26 PM - Thread Starter
videobruce's Avatar
Quoted: 586 Post(s)
Liked: 243
Which firmware version?
Free, abundant OTA television separates this country from many others. ATSC1 has only been in force since 2009. The wireless industry has enough spectrum. Enough of 'planned obsolesce'.
videobruce is offline
post #3223 of 4835 Old 06-09-2014, 04:53 PM
summerski's Avatar
The latest. V13a_122713
I had no idea a newer unit was even offered.. It is the same model number as the one I purchased last year. (which worked great but died for no apparent reason). So I just installed the firmware, which killed the unit.
Thanks for any help.
William
post #3224 of 4835 Old 06-09-2014, 05:34 PM - Thread Starter
videobruce's Avatar
Quoted: 586 Post(s)
Liked: 243
You say it killed the unit. What is it doing or not doing now?
post #3225 of 4835 Old 06-09-2014, 07:20 PM
summerski's Avatar
It won't even power up. No lights whatsoever. After installing the firmware there were several led lines across the front. I waited forever and nothing happened so I unplugged it. I plugged it back in and got nada. Is there anyway to reset it back to factory default?
I cant be but probably am the only person do experience this. lol
Cheers,
Will
post #3226 of 4835 Old 06-09-2014, 09:33 PM
navelhole's Avatar
I bought a NAXA digital tuner / dvr several months ago from FRYS but had to return it because it got too hot and kept on losing the "Pacific Time" Setting, then a week ago, bought a Digitrex tuner with NO dvr, same problem with IT getting too hot and also losing time. The same company that makes the NAXA tuners also makes Digitrex tuners; I will see if this is any different when I get my IVIEW tuner / dvr from Solid Signal. Wish me luck. Please E-mail me at jesuschrysler1@live.com. Thank you
navelhole is offline
post #3227 of 4835 Old 06-09-2014, 09:40 PM
navelhole's Avatar
Plug it into your navel and it will work> BAZINGA.
post #3228 of 4835 Old 06-10-2014, 03:56 AM - Thread Starter
videobruce's Avatar
Quoted: 586 Post(s)
Liked: 243
^ confused.gif ^
post #3229 of 4835 Old 06-10-2014, 08:00 AM
summerski's Avatar
The navel trick didnt work so I ordered another one form Amazon for 32.50 and its the older version w/o the Ch. switch. The older version can pick up different channels with the same frequency and then you can delete the weaker of the two. The new one would only pick up the weaker signal, even with a manual scan.
I still think this is the best product on the market for what it does. I can pause and record live tv with the wife yells at me to do something.
Cut the cord.
W-
post #3230 of 4835 Old 06-10-2014, 08:11 AM
dleedlee's Avatar
Quoted: 43 Post(s)
Cut the cord.
W-
I'm considering getting a second (STBii) box but how did you ascertain you were getting the original STBii and not the 3/4 version? Or did you mean the original STB?
dleedlee is offline
post #3231 of 4835 Old 06-10-2014, 08:23 AM
mrice0118's Avatar
Cut the cord.
W-
How did you know it was the one without the Ch switch? Got a link you can send me? I went through the same thing as you with the firmware.
mrice0118 is offline
post #3232 of 4835 Old 06-10-2014, 09:11 AM
summerski's Avatar
Here's the link from Amazon. Near the bottom of the page is a link for the newer version. .....
http://www.amazon.com/Multi-function-Digital-Converter-Box-Recording/dp/B00BFIJQ10/ref=sr_1_1?ie=UTF8&qid=1402412861&sr=8-1&keywords=iview+tv+converter+box
The older one has a different remote as well. Takes a bit of getting used to but it works fine once you memorize all the buttons.
Cheers.
W
post #3233 of 4835 Old 06-10-2014, 11:28 AM
laridae's Avatar
Quoted: 29 Post(s)
Liked: 49
So, does that just bring it up to the level of the latest Homeworx 150 model with the new remote?
Or have they made some other improvements to it as well?
What I'm really looking for is improved reliability. These boxes would be great if only they weren't so flaky!
Cable-free since Nov 2013
laridae is offline
post #3234 of 4835 Old 06-10-2014, 12:23 PM
franklinvives's Avatar
I have an iview 3500STB. It is stuck with "boot". How do I solve this problem.
Franklin
franklinvives is offline
post #3235 of 4835 Old 06-10-2014, 04:41 PM
navelhole's Avatar
Does this box get warm or hot? I would like to know. Thank you.
post #3236 of 4835 Old 06-10-2014, 05:44 PM
summerski's Avatar
No. This unit does not get hot or very warm. I have a boxee box that gets so hot you could almost light a cigarette from it. This one seems safe but I left mine on for about 8 straight months and it burned out. (died)
post #3237 of 4835 Old 06-10-2014, 06:26 PM
navelhole's Avatar
okay. thank you.
post #3238 of 4835 Old 06-10-2014, 08:55 PM
satpro's Avatar
I have determined that the new version with the ch 3/4 switch must use the mstar msb1237 demodulator chip based on the picture posted a few weeks ago by another user (just like sunkey based boxes I posted about also use the msb1237 now). I am still waiting for somebody to obtain a decent picture though. It is the chip behind the tuner can. The new demod chip is much smaller than the one the older versions of the 3500stb and 3500stbii and the homeworx /Stellar Labs /Ematic/ Naxa used which was the samsung S5H1411 demodulator. This is why when we loaded those firmwares they did not disable those boxes and only required the correct remote to recover them. In the last few weeks I have been able to obtain a few other msd7816 based boxes like the sc-55 v2 and the qfx cv-100 on the cheap. Both of which had junk firmware out of the box and should be avoided along with the the naxa, sunkey, lutema, supersonic ikonvert, proscan, and axess. The only usable firmware boxes are the iview, the homeworx and the ematic which just happen to be the only three that have custom and unique remote codes. The rest of the brands including the stellar labs all use the default remote and codes.
Somebody also posted the following over on a newegg review of the hw150 about the hw180
"Other Thoughts: Chipsets: M-star MSD 7618 VLSI 128-pin CPU chip; Samsung 6-th Generation S5H1411 demodulator chip, and Rafael 820T silicon tuner.
The HW180 model has the same M-star CPU and Rafael silicon tuner, but uses an M-star MSB1237 demodulator chip in place of the Samsung. Samsung discontinued the S5H1411, so I presume the newer HW180 had to go with a different chip (M-star)."
This tells me the 180 is like the sk903h but with the pvr disabled.
post #3239 of 4835 Old 06-11-2014, 12:10 AM
localuser's Avatar
Is this the picture you are looking for?  I have the box with the channel 3/4 switch.
I also happen to have one without the switch too.
localuser is offline
post #3240 of 4835 Old 06-11-2014, 10:42 PM
satpro's Avatar
Thanks, that confirms it.
Reply HDTV Recorders
