iView-3500STB Tuner & DVR Owners Thread - Page 109 - AVS Forum | Home Theater Discussions And Reviews
 91Likes
post #3241 of 4874 Old 06-12-2014, 10:37 AM
danshane's Avatar
Quoted: 56 Post(s)
Liked: 60
Originally Posted by summerski View Post
No. This unit does not get hot or very warm. I have a boxee box that gets so hot you could almost light a cigarette from it. This one seems safe but I left mine on for about 8 straight months and it burned out. (died)
I can testify that the box runs quite cool. In fact, I removed the USB port from the front of the 3500 and tucked my little hard drive inside the box connected to the USB jack hanging loose within. Makes for a tidy arrangement, and the drive cable does not get knocked loose as it sometimes did.
I have learned that the 3500 likes some disk drives better than others when relying on the USB interface to power the drive. I used to believe that the USB line might be somewhat defective, but I am now pretty comfortable with the idea that some drives are more power-hungry than others. If I had a USB drive with an external power supply I would have more assurance that my theory is correct; perhaps other users can verify that.
Be seeing you...
Dan Shane
danshane is offline
post #3242 of 4874 Old 06-12-2014, 12:47 PM
orrin1933's Avatar
Quoted: 20 Post(s)
This 'ematic' unit seems to be similar to the iView... has anyone checked it out?
http://www.amazon.com/AT103B-CONVERT...eywords=ematic
Orrin - Engineer/Photographer/Webmaster
orrin1933 is offline
post #3243 of 4874 Old 06-12-2014, 12:52 PM
jprc's Avatar
Quoted: 82 Post(s)
Liked: 120
It's been talked about several times here and in other threads, including just a few posts ago.
jprc is offline
post #3244 of 4874 Old 06-12-2014, 12:57 PM
jprc's Avatar
Quoted: 82 Post(s)
Liked: 120
I used two externally powered HDD with it and it would sporadically show as disconnected even when the light was still flashing for it being in use. It got worse and worse until it would not record more than few minutes with out showing as disconnected. Then it stopped recognizing all drives including flash drives.
jprc is offline
post #3245 of 4874 Old 06-12-2014, 01:09 PM
danshane's Avatar
Quoted: 56 Post(s)
Liked: 60
Well, that seems to point to a problem on the iView mainboard after all. I am running the latest firmware (v13). I do not know if other versions exhibit the same USB connection drops.
Be seeing you...
Dan Shane
danshane is offline
post #3246 of 4874 Old 06-12-2014, 05:02 PM
orrin1933's Avatar
Quoted: 20 Post(s)
I did a search on 'ematic' here with no results...thants why I posted.
A link to these "other threads" would be appreciated.
post #3247 of 4874 Old 06-12-2014, 05:14 PM
jprc's Avatar
Quoted: 82 Post(s)
Liked: 120
This thread, like I said just a few posts before you asked the question and several other times in this thread, the Homeworx thread, the List of Comsumer DVRs thread, the epVision thread, the Magnavox thread, and others - not in "quotes."
jprc is offline
post #3248 of 4874 Old 06-12-2014, 05:52 PM
satpro's Avatar
What would you like to know about the ematic at103b? It is the same menus just a different remote code. The first batch of 10k was sold out in 04/14, the new batch of the at103b might even have the other demod, haven't seen one yet. They made 10k in 09/13 and starting selling them in 11/13 and Walmart sold all of them in less then 6 months through online only. The first ematic batch had good working firmware from 081713.
I am hoping somebody can confirm or deny if their is something wrong with the factory firmware on the 3500stbii with the ch 3/4 switch.
I have a feeling that this new demod might have caused a step back in the firmware just like the sunkey based firmware problems.
satpro is offline
post #3249 of 4874 Old 06-13-2014, 03:12 PM
LJD51's Avatar
Liked: 4
I have both 3500stbII models, a recent one with and one without the 3/4 external switch.
It seems there is no difference in the firmware performance between the two other than the incompatibility between the two box versions, the 'without' box is currently running v13a. Both units have menu transparency in percentages. The 'with' box does not indicate in the menu options a 'modulation' choice of channel 3/4 choice nor loop through under 'channel search'. It would seem the external switch takes care of that and the unit always passes the analog signal whether the box is on or off.
I read this entire thread and still gambled on buying one of these knowing the pitfalls. The first unit is the 'without' box, I ordered a second and got a 'with' version.
After a month of tinkering I have some observations:
1 - By far the worst problem with both boxes in the unreliability of the USB port. I have external powered 3.5 HDs, one IDE, one SATA. The connections are unacceptably loose and will fail connection to the iView with the slightest touch of the plug. The problem does not exist when the HD USB connection is made on my PC port.
The iView port can be made more secure by removing the little PC board and carefully bending the side springs and even more carefully bending the bottom springs in the port. I am considering replacing the port if I can determine the exact correct replacement port.
2 - After some frustrating attempts to get the iView to faithfully see the 1T HD I resorted to this sequence. I had successfully recorded around 100g of hidef. program material. Then the iView decided there was no space available to record nor was there any space on the HD! It read 0.00g. In one attempt I copied the files and reformatted (NTSC) the entire drive on the PC but the same thing happened again. I then reformatted again on the PC but also let the iView format the drive and got the 123456789 filename. So far so good. . .
3 - I have read and experienced others' problems with program schedules getting dropped. I have the same problem as I use both iViews for only OTA reception. It appears the dropped schedules/missing station identification is due to reception issues and happens on the same channels. In my area it is Fox and a weaker local PBS channel. Both boxes have the same issue with the same channels.
This is my worst complaint about this little box - the unreliability of scheduled recordings. I will continue to attempt to make antenna adjustments to see if this solves this problem; both are indoor, a large one in the attic and another small one in a bedroom. Aside from this the hidef. recordings are really great, I watch them on a 55" Samsung 6350 TV and a smaller Sony.
The EPG will sometimes freeze, not often, and if I wait for it to populate it will not freeze on both boxes. When it does, iView will restart itself after some time. When that happens I have learned to check all the menu settings and have had to to reset them. Daily, weekly and through midnight programming works fine - when it records!
Still, this is an amazing box for the price of a little over 30 bucks even with the quirks. It seems they are still trying to improve the 3500stbII with a new model. Oh, and BTW, they must have listened to the early complaints about the brightness of the cryptic channel display as it is an acceptable brightness, much dimmer than my 'without' box! And curiously, when the newer box is 'off', both red and green LEDs are lit. Whatevah. . .
Lastly, apologies for a long first post, and I have hi-res. pics of the new box if necessary to post.
Thanks - LJD51
satpro, danshane and jprc like this.
LJD51 is offline
post #3250 of 4874 Old 06-13-2014, 05:20 PM
satpro's Avatar
If you could please post a picture of the entire new board with the ch 3/4 switch that would be great. I would like to see the 5v/12v power configuration and to see what this new board might tell us like msd 7816 or klf 7816 compared to others. Thanks
As far as the USB connection problems I use USB 3.0 flash drives in 16 32 and 64 gb, Maxell, Team, and Muskin brands. I do not damage the usb port on these boxes by using a very shory 6,9,18, or 24" extension cord where I change drives.
I also have a 320gb HDD and it olny likes one 18" extension cord out of the 5 I have tested, otherwise it will loose power during an event or need to be externally powered.
satpro is offline
post #3251 of 4874 Old 06-13-2014, 05:34 PM
LJD51's Avatar
Liked: 4
new iView 3500stbII pics
Hope I did this right
ID:	114633   Click image for larger version
ID:	114641   Click image for larger version
ID:	114649   Click image for larger version
satpro likes this.
LJD51 is offline
post #3252 of 4874 Old 06-13-2014, 07:02 PM
satpro's Avatar
Great work, Here is a picture of the power supply pinouts from the 3500stbii without the ch 3/4 switch which had 12v and 5v, As I suspected this new board with the ch 3/4 switch appears to use 5V only just like the sunkey based boxes have a 5V external supply.
LJD51 likes this.
satpro is offline
post #3253 of 4874 Old 06-13-2014, 10:49 PM - Thread Starter
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
The only difference between the original and the "II" is the remote. Interior pics were already posted in the first 5 posts.
Free, abundant OTA television separates this country from many others. ATSC1 has only been in force since 2009. The wireless industry has enough spectrum. Enough of 'planned obsolesce'.
videobruce is offline
post #3254 of 4874 Old 06-13-2014, 10:58 PM
jprc's Avatar
Quoted: 82 Post(s)
Liked: 120
There is a difference in the power to the USB port.
jprc is offline
post #3255 of 4874 Old 06-14-2014, 05:06 AM - Thread Starter
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
But those pics don't show that jumper.
post #3256 of 4874 Old 06-14-2014, 09:01 AM
localuser's Avatar
ftdi interface
Next to the antennae cans is a serial ftdi interface. Has anyone attached an ftdi connector to their computer to see what debug data and menu options are available via that interface yet? I am wondering if it is worth my effort to try or not. Here is a picture of the underside of the board with the pinouts labeled.
This is the ch 3/4 version, but I confirmed that both boards have the interface in a similar location.
localuser is offline
post #3257 of 4874 Old 06-14-2014, 12:18 PM
LJD51's Avatar
Liked: 4
Correct. And thanks.
I also used your information on page 107 and rewired my 'without' box to have the 5v lead sent to the main board as your pics show. That now powers down the USB interface as the 'with 3/4 switch' box does.
Image 4183 shows the main board labeled 'iView Gorilla-A A1'. It is a different board from the version II with the newer remote.
I'd like to thank all the early adopters of this box for the work involved in helping to get it to where it is now and for VB for starting this thread. Those early days must have been maddening!
I am now currently attempting to determine what exactly causes the 3/4 switch box to power down the external drive 12v to the HD. The interface I'm using is a USB 3.0 Star Tech kit. I have to swap that on my 'without' box and see if that works or not. A 2.0 USB interface, however, will not power down the 12v. I'd like to have that feature on both boxes. Back to tinkering. . .
LJD51 is offline
post #3258 of 4874 Old 06-14-2014, 03:53 PM
jprc's Avatar
Quoted: 82 Post(s)
Liked: 120
Here's what the "II" board and connections look like, the version without the 3/4 switch: iView-3500STB Tuner & DVR Owners Thread
You can see the difference in the power connections to the USB. I'm assuming you are talking about that version when you refer to II since the latest 3rd hardware version has multiple differences besides the remote.
jprc is offline
post #3259 of 4874 Old 06-14-2014, 03:57 PM - Thread Starter
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
The comment referred to the photos he just posted, not those.
post #3260 of 4874 Old 06-14-2014, 04:04 PM
jprc's Avatar
Quoted: 82 Post(s)
Liked: 120
blue_z has. Here is a link to one place he talked about it in the Homeworx forum, and there is a bit more further up on that page. There was a link to his post in the iview forum as well but since the forum upgrade that link doesn't work for me anymore. So maybe you can find it. Or maybe the Homeworx link gives you some info you want.
Homeworx HW-150PVR, Support and Discussion
jprc is offline
post #3261 of 4874 Old 06-15-2014, 06:43 PM
satpro's Avatar
Here is a collection of some of the other MSD7816 ATSC boxes and my findings.
After considering the new info about the MSTAR demod versus the Samsung demod I starting experimenting further with these boxes, I have mentioned my findings in the past about sucessfully running firmware on the ematic but now it also turns out that the even the 12V Naxa NT-52, the 5V Supersonic Ikonvert SC-55, and the 5V QFX CV-100 all happen to have the same Samsung demod in combination with the msd7816 CPU and are compatible in some ways with the HW and IV firmwares.
I show the boards below.
First, I started with the one that came with the worst factory firmware which was the QFX.
Now even though it was 5V external power supply the version AA and V9 loaded fine and it responds to the V2 iview remote. The analog audio did not work except during a resolution change, and the analog video was at a low level, however the HDMI, USB and tuner all worked as expected and the recordings with the timer now work great.
So I then loaded HW v13 firmware on the QFX and now even the analog audio also worked. I also determined that the reason for the low level on the analog RCA video was because they left out a part that in comparison the SC-55 happens to include so even the RCA video works on the SC-55 v2. See picture 5.
I then also tested the naxa NT-52 which does not have the HDMI out just a component out. With the HW firmware it worked fine for the component out, the analog audio out, the tuner scan was successful and the USB works fine, the naxa just requires a HW150 remote now. On the Naxa the analog composite video level was low because they also left out that one part on the board.
The original (V1) 3500stb V6 and VR firmware load fine but the tuner finds nothing with these so something in that firmware must be powering the tuner differently.
I also tested the RF pass through on the tuners and the modulator functions and have found varied results which aren't worth mention here because I doubt anyone would use the ch 3/4 outputs anyway.
I should also mention that even though the QFX and the SC-55 have the ch 3/4 switch because they use the original Samsung demod and not the newer mstar demod the firmwares were compatible.
I will also note that I tested the SL DT-1200 firmware and found it to be compatible with the above mentioned boxes in the same ways and also utilized the same remote code as the factory firmware for the naxa nt-52, ikonvert sc-55 and the qfx cv-100. The firmwares may disable the front panel lights or the power buttons but never impact the HDMI, USB and the IR eye connection back to the CPU. I kind of suspected this would be the case since I had found a diagram of the MSD7818 chip I/Os through baidu
These findings lead me to suspect that should Iview ever release the firmware for the new V3 with the ch 3/4 switch that it would be compatible with the sunkey based boards that use the new mstar MSB demod chip. I had posted about that board a few weeks ago here as well as the picture of that board.
Axess CB-3001 / Lutema AirTV / Sunkey SK-903H firmware ATSC USB recorders Supersonic ikonvert SC-57
Also see my other post above about the demodulator chips
http://mstar.wikia.com/wiki/MBoot
http://mstar.wikia.com/wiki/Firmware_update
http://mstar.wikia.com/wiki/MSD7818
http://mstar.wikia.com/wiki/Debricking
http://mstar.wikia.com/wiki/Flash_Backup
http://mstar.wikia.com/wiki/Special:NewFiles
Name:	1. 5V supersonic ionvert sc-55 v2.jpg
ID:	119466   Click image for larger version
Name:	2. 5V qfx cv-100.jpg
ID:	119474   Click image for larger version
Name:	3. 12V naxa nt-52.JPG
ID:	119482   Click image for larger version
Name:	4. ematic at103b.JPG
ID:	119490   Click image for larger version
Name:	5. missing part.jpg
videobruce and laridae like this.
satpro is offline
post #3262 of 4874 Old 06-15-2014, 08:35 PM - Thread Starter
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
Wow!
Now, can you compile similar with the main components that ePVision uses??
And just think, a certain narrow minded elitist here complained that I spent too much time on these Chineese DVR's when I made the comparison thread.
post #3263 of 4874 Old 06-16-2014, 12:01 PM
danshane's Avatar
Quoted: 56 Post(s)
Liked: 60
Wow!
I must say that the iView 3500 boxes I own have proved to be among the most frustrating yet most fun appliances I ever threw my TV pennies at. I have never seen any piece of A/V hardware receive so many firmware upgrades in such a short span of time, and the interior layout afforded plenty of room for hardware tinkering.
I had a half-dozen 2.5" SATA drives of various make in my drawer that I pulled from defunct laptops, so this afforded me a reasonable way to experiment with compatibility. I started with a self-contained 1 TB WD Passport USB 2.0 drive, and I was happy with the performance until the USB cable got knocked about a few times (thanks to the vulnerable front-panel USB port on the 3500), and I found myself doing an undesirable amount of cable-wiggling to renew the connection. This never seemed to last very long.
By this time I had purchased a second unit, and for this one I attached one of the 160 GB laptop drives mounted inside a Sargent USB enclosure. Worked great for a while, then it too suffered from the dreaded "USB device removed" bug. Pinching the USB cable's plug with a pair of pliers seemed to help for a time, but eventually the problem would resurface.
Finally I performed the same surgery that LJD51 did on the iView's USB board, but in my case I actually removed the port from the front panel, cleaned the connectors well, made sure everything was good and snug, then wrapped the connection in electrical tape. Then I tucked the drive, enclosure and all, inside the unit and closed the box. I quit using the WD Passport drive on my original unit and repeated the hack with a 40 GB SATA drive (again in a Sargent enclosure). This 3500 is only used for occasional time-shifting so I did not need a large drive.
So far both units have been rock-solid for many days, and they got moved around plenty from the time they were reassembled. With the connectors and cables taped down the flaky USB seems to have been cured (not to mention the space saved on my shelves). My practice is to leave both iViews in standby mode, and they have faithfully kicked on and recorded all my scheduled programs. If the boxes continue to perform this way I will wear a satisfied smile for a long time for having attempted such an easy mod. The drives cost me nothing thanks to recycling, and the enclosures (cables included) were less than $5 each with shipping.
$80 and a bit of creativity gives me the ability to record two channels at the same time (in separate locations). No fancy Rovio or Tivo 2-week scheduling, but for the savings I do not miss it. The iView may not be for the person who expects everything to just work out of the box, but for me the little guy has proved to be a good bit of fun and really fills the bill.
LJD51 likes this.
Be seeing you...
Dan Shane
danshane is offline
post #3264 of 4874 Old 06-16-2014, 01:30 PM
LJD51's Avatar
Liked: 4
Agreed!
Something I did not see discussed but could have missed is this -
In the PVR, Photo, Movie, and possibly Music view, there is a feature available by pressing the 'repeat' button (although I don't have any media stored in the last three the feature is available in at least Photo and Movie along with PVR). This feature is not addressed in the User Manual.
I took three pics from the TV to show in the upper right corner the icon for the features available. The first is 1 repeat of whatever file is selected to play. A second press of 'repeat' will replay the folder, and a third press will repeat the folder randomly. The icons are visually intuitive.
ID:	121090   Click image for larger version
ID:	121098   Click image for larger version
LJD51 is offline
post #3265 of 4874 Old 06-17-2014, 03:02 PM
Liked: 0
I confess, I haven't read the entire thread, but I read the first five posts and the last couple of pages. I currently use an older Zenith digital converter box. It would be nice to have the ability to record OTA programs and to timeshift. Given that I would only use the box for OTA (no cable channels), in your opinions, what iView is the better box: 3500STB or 3500STBII? Additionally, if I were to use an externally powered HDD and I bent the springs in the USB connector (as described by LJD51) do you think I'd have a fairly reliable box for recording of OTA programming, or should I look for more expensive options? The ~$35 price-point is fairly enticing...
overt is offline
post #3266 of 4874 Old 06-17-2014, 03:21 PM
Aleron Ives's Avatar
Quoted: 1568 Post(s)
Liked: 1272
It's surely the best option at this price point, but if you want reliability, you'll have to pay more. The iView's reliance on PSIP for its clock means that it doesn't always record what you want and when you want it.
Aleron Ives is offline
post #3267 of 4874 Old 06-17-2014, 03:56 PM
laridae's Avatar
Quoted: 29 Post(s)
Liked: 49
As stated, "reliable" is not how I would characterize these boxes. "Flaky" would be a more accurate term.
They are inexpensive and fun to play with if you are looking for a new little hobby. But if you're counting on recording a show, forget it!
Cable-free since Nov 2013
laridae is offline
post #3268 of 4874 Old 06-17-2014, 05:02 PM
LJD51's Avatar
Liked: 4
Definitely the 'II' box, either version with or without the 3/4 switch. They both are packaged with the more desirable remote.
I decided to roll the dice and buy one knowing all the pitfalls. I guess it depends on how frustrated you'd get by the surprises!
Leaving the box tuned to the channel you would be recording in the future before turning it off will keep the time accurate for recording for that channel.
You have to look at your local OTA channels and be aware of their time differences, knowing if you will schedule multiple events on different channels while you are away they will start and end on the time designated by each channel you have scheduled. In my area the major broadcasters are all the same, one local PBS channel is a minute faster and another PBS channel is three minutes slower. You just sort of have to pay attention.
You also may have to play interface roulette finding a USB to IDE/SATA interface that the iView likes. Ditto on the HD.
If this sounds like fun, it's only ~30 bucks!
LJD51 is offline
post #3269 of 4874 Old 06-17-2014, 07:59 PM
travishauch's Avatar
I have a 3500STB with Comcast in Northeast Wisconsin. We still have analog/digital broadcast coming to the home I'm assuming. I'm learning about qam, clear, etc so bear with me please. Our TVs receive 2-69 and we get the locals too 2.1,2.2,2.3, etc.
From what I understand, the 3500 does not have an NTSC tuner like the tv's.
My problem is I cannot get any of the locals to show up on the 3500. I have tried multiple firmwares and switching between cable/air to figure out what to do.
I have 2 3500 and an ikonvert sc-58 and can't get any channels to populate.
Any ideas?
Travis
travishauch is offline
post #3270 of 4874 Old 06-17-2014, 09:10 PM
QAM
QAM's Avatar
Quoted: 18 Post(s)
Get the 3500STBII (has a superior remote)
Yes, externally powered HDD is the way to go
Jury is out on USB socket... Better to loop the USB cable from HDD under the unit to put tension on the plug in the USB socket... AND NEVER TOUCH THE CABLE OR UNIT AGAIN! Works for me.
QAM is offline
Reply HDTV Recorders
