iView-3500STB Tuner & DVR Owners Thread - Page 112 - AVS Forum | Home Theater Discussions And Reviews
 130Likes
post #3331 of 5189 Old 07-30-2014, 10:18 AM
milkboy31's Avatar
Originally Posted by 1972bigcarr View Post
Just got some beta firmware for the 3500STBII with the 3/4 switch after calling Iview. I called about the QAM virtual/real channel mapping. Haven't had time to test it out if someone else wants to let me know.
Same issue here... I have a CCTV setup in multiple buildings that use physical clear QAM channel 3-1. The new 3/4 switch model of this box doesn't see any stations on manual or auto scans... the meter does peg out when doing a manual scan and entering channel 3, but it doesn't find anything once scanned.
As others suspected, I'm guessing the new chipset/firmware default doesn't work with physical QAM channels only virtual QAM channels.
Hopefully this new beta firmware (V1) will fix it. I will post back with results later today. I'm not holding my breath though as the lady on the phone sounded like she had no idea what I was asking.
milkboy31 is offline
post #3332 of 5189 Old 07-30-2014, 12:57 PM
milkboy31's Avatar
Confirmed. New Firmware V1 on the channel 3/4 switch model DOES bring back the ability to tune in QAM physical channels like 3-1. See attached pic for how the new firmware version reads. You will need to call them (I just used the phone number on the first post of this thread) and they will email you the firmware.
post #3333 of 5189 Old 07-31-2014, 04:17 PM
rene52's Avatar
Are there 3500STBII tuners without the RF3/4 switch and are they programmable with the 3500STB firmware?I just want to know
because a vender on eBay has 3500STBII without the RF switch, I just hate to order them and have to return them like I did with the vender on amazon in which the ad showed the 3500STB and he sent me the 3500STBII.
rene52 is offline
post #3334 of 5189 Old 07-31-2014, 04:42 PM
jprc's Avatar
Quoted: 83 Post(s)
Liked: 120
Why don't you just contact iview and get the software that was mentioned above for the new box? I've been telling people to do that for months but no one listened to me and kept sending their boxes back unnecessarily.
Anyway, yes there are 3500stbII boxes without manual RF switches. Versions 9, 12, and 13 can be loaded on it but versions before v9 should be avoided on it (although v7 can be loaded but with some issues).
jprc is offline
post #3335 of 5189 Old 07-31-2014, 09:08 PM
Liked: 1
I have had the STBII for almost a week now. In defence of that 3/4 switch: Very handy for squirting out a signal over coax to my kitchen under cabient flip down TV via a run in the basement.
Constructive feedback for iView:
We gotta get this recording name sorted out. The titles of the shows show up in the EPG and it would make this unit so much more useable when the recording takes place that it at least picks up the show title as the filename. Refining it further a folder based listing would be very helpful.
I thought of a workaround I'd like to share for this recording title mayhem on a PC running Windows or Linux (needs web server) :
1. Using Media Portal and EPGCollector
2. Grab EPG everynight and use MP to get data into database using the XMLTV import feature of MP TV server.
3. Write SQL queries to match filename date and channel to find EPG data grab title and use PHP to rename the file (and perhaps kick off FFMPEG from PHP to get it to H.264.
But really, if the EPG data is on the STB why are we having such filenames in a single folder?
Biggest issue by far, worse than the remote.
duracell80 is offline
post #3336 of 5189 Old 08-01-2014, 05:56 AM
Liked: 1
hello all,
i just recently received my 3500STB2 and have an issue i'd like to share and possibly get some input.
i connected this hardrive in a 3.0 usb enclosure to the iview:
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
and when i go to timeshift on the iview it takes about 2 minutes or longer to pause even when i hit play the playback is extra jumpy and unwatchable. the same can be said for playback on any recording i've made.
i'm guessing that my hardrive is too slow for proper recording and playback?
if that's the case then i need help picking out a suitable replacement. i'd like to stay as affordable as possible while still maintaining quality and enough speed to work properly.
i've found these:
http://www.amazon.com/dp/B00FE2N1WS/...3083CZL3&psc=1
and
http://www.amazon.com/dp/B00E3W15P0/...CF34C0HL&psc=1
one is half the price of the other but i'm not sure if it's fast enough. any comments or suggestions?
Hairywoo is offline
post #3337 of 5189 Old 08-01-2014, 07:45 AM
Liked: 1
Originally Posted by duracell80 View Post
We gotta get this recording name sorted.
I should say my recording title workaround involves using a USB tuner on my PC for EPGCollector
to get the data. Media Portal can get EPG from IMDB without using a tuner.
More thoughts on PVR function:
0. When exiting PVR mode it should return to live TV and to exit you should be able to press PVR again (to save looking for the exit button).
1. Playback should be fullscreen by default.
2. When skipping, pressing play will pause the video instead of playing, unless you've already pressed it once. The play pause button should not pause when in skipping mode.
2.1. Agreed with all skipping comments the skip should be 30 seconds not speed based.
3. When recording it's annoying to have the "Rec 00:38:00" box in the top left corner. That should timeout and pop back up when you attempt to interupt the recording.
3.1. If a HDD is attached it should be fast enough to allow you to watch a recording while a current recording is on going. I can only think the flash drive option is what held back this functionality.
4. Pressing info should bring up meta data like show title and description rather than technical details.
5. Aspect ratio cannot be changed when in playback mode.
I'll keep playing and see what other user interface snags I can find.
post #3338 of 5189 Old 08-01-2014, 08:10 AM
dleedlee's Avatar
Quoted: 51 Post(s)
Originally Posted by Hairywoo View Post
hello all,
i just recently received my 3500STB2 and have an issue i'd like to share and possibly get some input...
I had a similar experience on playback, rarely use timeshift on this, when I first got my STBII. At first, I though it was my cheap antenna(I'm OTA only), or possibly interference from the STB and the HDD - I moved the HDD to the other (left) side of the STB. It drove me nuts. After a few weeks, the jitters stopped and I've never reencountered it. Throughout the whole time, I've been using a portable WD Passport Ultra, 1TB. Maybe, it's just a burn in period?
dleedlee is offline
post #3339 of 5189 Old 08-01-2014, 12:53 PM
PhilKE3FL's Avatar
Location: Maryland North of Washington D.C. and West of Baltimore MD.
Problem: My USB powered hard drive is ticking and the iView is unable to find anything (files or folder structure) on the HD. This is after a few months of it working flawlessly.
I tested the HD on my laptop and it works fine. I tested a self power HD on the iView and it worked fine. I tested the USB powered HD on the iView and it started ticking again.
Conclusion: the iView didn't have enough power to run the USB HD.
Quick fix for the problem: Buy or make a USB cable that has both the normal data/power from the iView as well as another plug for just additional power input from an AC USB power supply, I used a 5V, 2A USB wall power supply which wasn't doing anything.
This worked just fine and has now been doing so for about a month.
Initial worry: I was worried that the USB HD would remain in the On condition, it does not. When the iView turns off it must be sending an off signal to the USB HD because it too turns off. Using a switching USB AC power supply means that when the HD turns off the power usage goes way down, less than 1 watt since the Kill-O-Watt meter cannot measure it.
They used to make these things for USB external HDs but not any longer that I know of. Also, I've never seen one for a USB 2 and 3 type external HD, which is what mine is & I think all new ones are.
Rather than modifying the USB cord that came with the HD, I bought two USB 2 extension cables and combined them into the Y-cable needed with two inputs and one output. Buy two of the same type cable and then wire the same color wires together and it should be fine. NOTE: We're only going to patch in the power wires NOT the signal wires from the extra power input plug.
Before you do this buy some large heat shrink tubing to cover it all when you're done.
You only need to attach the red & black wires for the extra USB plug to the AC power supply. DO NOT CUT the other two wires on the one cable that is supplying both power and signal, those are the signal wires. When you are done connecting the power wires and soldering them cover them with tape or plastic dip. Once finished, wrap some aluminum foil over this area, make sure it connects to the previous shielding from the two cables. Now shrink the tubing over this area to both protect the area and to force a good connection with the original shielding and the new aluminum foil wrapped around the area. Having too much shielding is better than not having enough.
Test it on something other than your HD, perhaps a USB light if you have one. Make sure both inputs can supply power to the device under test ONE AT A TIME. I have a third USB extension cable with the power wires cut so I can test how much voltage and/or current is on the line to the device under test so you might want to buy a third USB extension cable for this type of testing. It does not have to be the same manufacturer as the other two since we're not wiring anything together.
Good-luck & I hope that if you've been having a similar problem this will give you the solution you need.
PhilKE3FL is offline
post #3340 of 5189 Old 08-01-2014, 01:40 PM
jprc's Avatar
Quoted: 83 Post(s)
Liked: 120
hello all,
i've found these:
and
Any hard drive should be fast enough to handle this. It could be your enclosure or the connectors that are causing the problem or there could be a problem with the drive or it could just be a random incompatibility/bug. The iview is very finicky, often with no rhyme or reason. But the speed of any modern hard drive is not going to be the issue.
I also always suggest using externally powered drives when possible. And if you have weak signal and/or indoor antenna then you will have to spend some time rearranging your equipment for least interference, but that will not cause a 2 minute delay when hitting the pause button so I think you have some kind of hardware problem either on the iview, the drive, the enclosure, or the connectors.
jprc is offline
post #3341 of 5189 Old 08-01-2014, 01:57 PM
jprc's Avatar
Quoted: 83 Post(s)
Liked: 120
You can get immediate fullscreen playback by hitting the Play button.
You can get rid of the REC timer onscreen by hitting Exit.
Press Info twice for show decription.
Although you can't watch a separate recording while recording another, you can watch/timeshift a program at the same time that you are recording it when using a hard drive.
Don't expect the filename change to EPG info you requested. The iview does not record by EPG, it records by time. Although you can use the EPG as a shortcut to program a recording, it is not using the EPG at all for the recording. It simply starts at the specified time and goes for the number of minutes until the end time. It does not know what program it is. The filename of a program is station and date/time because that is the programmed info and that is all it knows.
jprc is offline
post #3342 of 5189 Old 08-01-2014, 03:14 PM
Aleron Ives's Avatar
Quoted: 1693 Post(s)
Liked: 1451
That's not necessarily a true limitation, though. The TViX records by time, too, but all recordings are named with date, time and the name of the program as provided by PSIP. The iView's programmers are just too lazy to pick up the PSIP name and append it to the filename.
Aleron Ives is offline
post #3343 of 5189 Old 08-01-2014, 03:25 PM
jprc's Avatar
Quoted: 83 Post(s)
Liked: 120
Well, I said don't expect it. I didn't say it was impossible. And because of iview not having it's own clock, appending PSIP info wouldn't be very useful to most people since everyone I know sets their timer to begin several minutes before the program, so it would actually have the wrong program name. If you're going to have to change the name anyway or remember or write down what programs are playing before each program you record so that you can figure out which program it really is, that just doesn't seem very useful to me. But either way, we can't expect iview to change it realistically.
jprc is offline
post #3344 of 5189 Old 08-01-2014, 08:14 PM
Liked: 1
hello all,
i just recently received my 3500STB2 ...... and when i go to timeshift on the iview it takes about 2 minutes or longer to pause even when i hit play the playback is extra jumpy and unwatchable. the same can be said for playback on any recording i've made.
Had a thought on this. Have you run any disk error checking on it? If it's hitting some bad sectors that may impact performance. Defragment with Windows if FAT. A USB cable issue could happen too, if you have another cable try that.
If there's no valuable data on it I'd try making a partion just for DVR usage and try different file systems.
Try SD channels too, high bitrates will take longer to write.
post #3345 of 5189 Old 08-01-2014, 08:27 PM
Liked: 1
You can get immediate fullscreen playback by hitting the Play button ... you can watch/timeshift a program at the same time that you are recording it when using a hard drive.
Aha! Thanks for the tips! I do like that you can rewind a recording as it happens could be a nice hack to get constant timeshifting rather than having to enter that mode.
The EPG data could be stored
in an XML file (.nfo) next to the recording or as you book the recording it could set the filename there and then (like a label) or write an .nfo file as the show is booked.
It's a big let down having EPG data but it vanishing into the ether because you don't wanna be figuring out which ABC, NBC CBS file is the one you want to watch. Considering a text file named exactly as the recording filename would suffice.
Unless the preview window could be auto playing the file as selected with the down arrow? That could be a neat workaround?
If iView want to set us up as beta testers we could really help. Humax did a similar thing when I lived in the UK and the interface became killer.
post #3346 of 5189 Old 08-01-2014, 08:42 PM
Liked: 1
To clarify I was suggesting
having the STB pull the show title into a text file that lived along side the recording (like the example of the hand writen note).
The example of writing down what you recorded and when is meta data. It's a low tech .nfo file. Nobody who uses a Dish or DirectTV DVR has hand written notes to direct them to the correct recording.
My frustration is that a DVR without meta data (show title) is useless.
As a user you don't select a recording to watch based on when it was recorded. You say I would like to watch House and normally the top of the list is the most recent.
Most DVR users won't recall the exact time and channel it was recorded on they want to call up the "Simpsons Folder" and watch the mos recent recordings (top of the list not bottom of the list). Filtering out all other irellevant recordings from the list.
This software cannot function as a DVR without meta data and organisation.
post #3347 of 5189 Old 08-01-2014, 10:39 PM
jprc's Avatar
Quoted: 83 Post(s)
Liked: 120
I think you're forgetting how much (little) this box costs. You pay Dish and DirecTV monthly fees and they are large companies. You can't expect the same functionality from a cheap one time purchase from a discount company that is reselling cheap discount boxes for which they don't even have full access to the code.
I have to completely disagree with your statement that a DVR without meta data is useless. The primary purpose of a DVR/PVR is to record and (as long as it is working properly) the iView does that. You can have all the meta data in the world but without a recording the meta data is useless. On the other hand, a recording without meta data is far from useless though because it is still a recording and you can watch it, which is the whole purpose. It just takes a couple extra seconds to determine which recording it is. Yes, it would be ideal to have a show title or more descriptive filename and not have to take those extra couple seconds to figure it out, but not having the show title doesn't change the fact that you recorded what you wanted to record and can play it back and watch it. Nothing useless about that at all.
There are lots of things I wish this box did differently but you do have to keep the price point in mind. Even the things that could have been done differently originally without increasing the price cannot be done now after the fact without costing more money. Most things are simply not going to be changed. Those of us who were early adopters of this product did a lot of beta testing for iview. Some of us, myself being one, put countless hours of work into this and did everything we could to get the changes that we got so far just to make the box functional as a PVR at all. It's original shipping state was truly next to useless as a PVR. I'm just trying to tell you that you need to set your expectations more realistically.
LenL likes this.
jprc is offline
post #3348 of 5189 Old 08-02-2014, 04:14 AM
Hallmerk's Avatar
Quoted: 21 Post(s)
USB Sticks
I am having the exact same problem after my unit worked well for about four months. My Seagate 500GB just freezes, and the led on it goes blank indicating it has no power. I do not believe my problem is with the USB connectors, but rather with something related to the Iview box itself. Will give you fix a try if I get up the courage to make the necessary cable.
Hallmerk is offline
post #3349 of 5189 Old 08-02-2014, 05:46 AM
laridae's Avatar
Quoted: 29 Post(s)
Liked: 49
Actually that's not entirely true - the key is to be realistic in your expectations. It works fine for me;
But then I'm a watch-and-delete kind of guy so I only have a few shows on the go at any one time, usually one page in the listing of files.
Sure, the lack of show names on the files is a pain but you get used to it. It's taken me a while to get used to this flaky little box (actually I have a couple of Homeworx 150's, but same diff). It's great value for the price and a real boon for the growing mass of cord-cutters. And, let's face it, there's really not much else out there at this price point so let's be grateful that these boxes at least offer us a choice!
You get what you pay for.
Cable-free since Nov 2013
laridae is offline
post #3350 of 5189 Old 08-02-2014, 12:24 PM
Hallmerk's Avatar
Quoted: 21 Post(s)
Dual Power a concern?
It appears to me that this fix will ultimately supply power to the HD from both the Iview's USB port, AND the AC power supply simultaneously. This won't cause a problem? Seems like 5 volts and 5 more volts going to the same device could cause a problem. What am I missing here?
Hallmerk is offline
post #3351 of 5189 Old 08-02-2014, 01:42 PM
Liked: 1
In parallel, it's still 5v. Try it with 2 batteries connecting pos to pos and neg to neg.
sent by mirrorflash Morse code
mat55555 is offline
post #3352 of 5189 Old 08-02-2014, 09:41 PM
Liked: 1
Originally Posted by laridae View Post
Actually that's not entirely true - the key is to be realistic in your expectations. It works fine for me.
And that's great but cord cutters will be disapointed and by that I mean non-technical people who are being priced out of DVR's.
There are a tonne of issues still remaining that hold it back from being a DVR that people can use and I was highlighting these issues.
These boxes are the best option at the moment for non computer users who just want an affordable DVR (my wife). I'm perfectly happy with XBMC and 5 tuners (as cord cutters) but it's overkill for the general public. My wife isn't a cord cutter but does need a DVR without the high fees.
These boxes promise to be a DVR but haven't got to the point where you can use them as DVR's (by far the biggest issue is the usability of the software).
It's eaiser to playback the recordings from this box on a computer and that just defeats the point.
post #3353 of 5189 Old 08-02-2014, 09:47 PM
Liked: 1
Modify a cable to only supply power from an external source and cut the black/red cables coming from the iView.
post #3354 of 5189 Old 08-03-2014, 05:38 AM
laridae's Avatar
Quoted: 29 Post(s)
Liked: 49
If a cord cutter is going to be happy with one of these boxes it would help if they were;
Resourceful - they'll need to jump through some hoops and install an OTA antenna, and
Flexible - they'll need to learn new ways of doing things and reception of their shows will become unreliable and subject to the vagaries of weather, leaves, aircraft, etc. If watching that show is life-or-death (and you can't wait for the boxed set) then this is not for you.
It would also help if they are somewhat disillusioned or at least indifferent to TV in general. There's a lot of crap out there and most of it isn't worth watching. So, take it or leave it. Develop alternatives. Find something else to do with that extra $100 a month.
laridae is offline
post #3355 of 5189 Old 08-03-2014, 02:58 PM
Liked: 1451
On the other hand, satellite TV is notorious for being affected by weather patterns, and cable systems have a habit of going dark, too. At least when the OTA stops working, you don't have to wait for the cable guy to show up "some time between 12 and 5 on Tuesday" to fix it.
post #3356 of 5189 Old 08-03-2014, 09:57 PM
Liked: 1
That's very true. OTA holds up well during storms when our Dish goes out. Plus with the USB tuner in the laptop if the power goes out we can still watch live radar and storm tracks.
post #3357 of 5189 Old 08-03-2014, 10:05 PM
Liked: 1
I reckon I've figured out where the iView STB (and others with the same software) fits in to my setup.
It's not a DVR. It just doesn't store meta data and can't be organised enough to be a DVR.
I would advocate this as a timeshift device, ie pause live tv and maybe make the occasional recording.
I assume the 4GB limit on timeshift is due to filesystems. Would be awesome if usinf NTFS the system could let you select "infinity".
Why isn't it a DVR? EPG data only goes out a few hours so you can't see a trailer for a show on Thursday when it's Monday and book it (this is not an issue with the iView but EPG data broadcast inband). When you do book a recording no meta data is stored with it like show title which makes finding a recording very difficult.
You can't series link with this device and it'll record weekend events if you set up a daily timer (sometimes BBC news for example jumps around PBS, this box cannot detect that in the EPG data so it can miss things).
Also you can't watch a previous recording while a current recording is ongoing (spoilers). To get around that you'd need a second box with a second hard drive and you'd have to have the presence of mind to swap drives over to your "playback box" if what you want to watch is on the disk that's in your "recording box" and you couldn't do that if the recording had already started so you'd be screwed.
It's not a DVR.
That's actually a bigger deal than in seems. What's the point of recording something if you are forced ro watch it as it is recording?
Don't waste time or money on a 1TB HDD for this box because you'll have a tonne of nonsense titles to scroll through before you find what you were looking for.
For $30 you cannot go wrong and this is awesome for watching live TV on the TV, but for a DVR just hook up a PC to your TV and run XBMC with Media Portal (you can record series links with a plugin).
post #3358 of 5189 Old 08-03-2014, 10:51 PM
jprc's Avatar
Quoted: 83 Post(s)
Liked: 120
It's not a DVR.
You can't just change existing definitions of words/acronyms to suit yourself. A DVR has a definition and this fits it. It is a DVR. That's a fact. It's not an opinion and it's not something you get to decide based on your own personal whims. You may not like how it works but it doesn't change the fact that it is a DVR.
If you want the extra features and automation you're talking about, then like with any other product, you have to pay for it. If you want $400 features, you don't spend $30-$40 and then call it useless because it doesn't do what the $400 box does. That's like buying a bike and complaining that it doesn't have all the features of a car. People spend more money when they want more features. That is how all products work.
If you want to spend 1/10 of the price of the product that does what you want it to do, then there are going to be trade offs. It's either not going to do many of the things you want or you are going to have to do some extra work yourself to get what you want. Just like you have to pedal the bicycle instead of just stepping on the gas pedal, if you want your recordings nicely organized by name and sorted into folders then you have to take a few minutes every so often to do it yourself.
None of that changes the definition of what a DVR is or the fact that this is a DVR. I have major issues with the way the box functions myself and I've had many complaints about it, but I don't make up my own definitions and say it isn't what it is.
jprc is offline
post #3359 of 5189 Old 08-03-2014, 11:45 PM
Liked: 1451
It's not a DVR TiVo.
Fixed. Why yes, you're absolutely correct.
The problem isn't that the iView lacks the features of the more expensive DVRs; that's a given. The problem is that the iView doesn't always implement the features it does support correctly, which leads to missed recordings.
post #3360 of 5189 Old 08-04-2014, 05:38 AM
Liked: 1
i fixed my problems i was having with jittery play back and extra long timeshift wait. i had the resolution set to 1080i when doing the initial set up with component cables. my reciever doesn't have hdmi so i was trying to run it through the surround sound but for some reason i wasn't getting any sound. i ended up just running hdmi from the iview directly to my TV but i never changed the resolution to 1080p. when i changed it to 1080p everything functions normally.
dleedlee likes this.
Hairywoo is offline
Reply HDTV Recorders
