iView-3500STB Tuner & DVR Owners Thread - Page 119 - AVS Forum
 22Likes
post #3541 of 3555 Old 08-29-2014, 10:20 PM
Liked: 0
well im just gunna tape the sensor on my tv and just turn it on manually least until i get my new tv and hope i can get it to work with that cause i really would like a dvr.. but can anyone at lease direct me to the latest firmware update for the model with the 3/4 switch so i can get my channels scanned.
Garret Stillions is offline
post #3542 of 3555 Old 08-30-2014, 05:12 AM
rene52's Avatar
Originally Posted by JHBrandt View Post
Yes. The firmware will display the box model it was written for, but it's compatible with the older boxes as well. Only the latest boxes (with the channel 3/4 switch) are incompatible with V13.
If you still have the remote that came with your 3500STB, you'll find some of the buttons don't function as labeled with V13. The 3500STBII's shipped with the new remotes, a few of the buttons are different, and the V13 firmware was written for the new button layout. If this bugs you, you can buy one of the new remotes from iView for $10 (free shipping). You'll probably like it better anyway.
So I can use the firm ware for ether 3500 or 3500II as long as it doesn't have the 3/4 switch?
rene52 is online now
post #3543 of 3555 Old 08-30-2014, 03:31 PM
JHBrandt's Avatar
Quoted: 56 Post(s)
Liked: 157
Yes, just don't freak out that the Information display says 3500STBII. It'll even say that if you load V13 on a Homeworx!
JHBrandt is offline
post #3544 of 3555 Old 08-30-2014, 03:42 PM
JHBrandt's Avatar
Quoted: 56 Post(s)
Liked: 157
This post has a link to the new firmware for the boxes with the channel 3/4 switch: iView-3500STB Tuner & DVR Owners Thread
If you need QAM (digital cable) you'll probably have the best luck with V1; aside from QAM I'm not sure if there are any differences between the four versions in the .zip file.
I hope videobruce puts a link to this firmware in post 5 soon. My links keep getting lost as more folks post.
JHBrandt is offline
post #3545 of 3555 Old 08-30-2014, 08:26 PM
dkreichen1968's Avatar
Liked: 26
Originally Posted by R Johnson View Post
Thanks to the FCC, the era of Clear QAM is likely drawing to a close for almost everyone.
The current head of the National Cable and Telecommunications Association (big cable) is a former FCC chairman. And, let's see here, no more cable theft, and you no longer need to send a tech out to connect or disconnect the cable!
It's 2014 and you're still paying for television?
dkreichen1968 is offline
post #3546 of 3555 Old 08-31-2014, 10:38 AM
JHBrandt's Avatar
Quoted: 56 Post(s)
Liked: 157
And the current FCC chairman is a former lobbyist for big cable. The "revolving door" is a major reason why the FCC is more interested in protecting the industries it's supposed to regulate than in protecting consumers or the public.
... let's see here, no more cable theft, and you no longer need to send a tech out to connect or disconnect the cable!
Which is great for the cable industry - no one should be a victim of theft - but have you seen your cable bill drop thanks to these savings? That's what I thought....
JHBrandt is offline
post #3547 of 3555 Old 08-31-2014, 11:31 AM
Liked: 26
And, they can charge extra for every DTA and CableCard. So, ultimately it is just a major win for the cable companies, and part of the reason I don't have cable, and don't plan on ever having it.
JHBrandt likes this.
post #3548 of 3555 Old Yesterday, 12:30 PM
jprc's Avatar
Quoted: 22 Post(s)
Liked: 112
My iView decided to take labor day seriously and stopped working completely today. Well, I just thought that was kind of funny, so humor me for sharing. Anyway, it's officially dead. I wasn't using it when it happened. It was plugged into a surge protector so shouldn't have been a power surge and my electricity didn't go off at any point. Left it unplugged for an hour and plugged back into a couple different sockets. No signs of life. Took it apart and reset all the connectors and air dusted it, although there was no visible dust in there anyway. No signs of damage inside and nothing loose. The USB died awhile ago so I was only using it as a third tuner. RIP.
jprc is offline
post #3549 of 3555 Old Yesterday, 09:00 PM
StormCrow's Avatar
Thanks for the link!
I had emailed iView requesting these a while back. Did this via their contact us web email page, as well as their direct email address and never a reply.. Not, even an automated one. (Checked junk mail box, etc.)
Using V3 and notice now, that the green LED goes out when unit is off. A good things, as these are too bright!
Haven't scheduled any recordings yet.
(Previous issue was that often, unit would not shut off when recordings ended. Then, the file it produced when this would happen, was too small and did not show total length. While playing the file FF caused file to stop and next file would start playing.)
The other issue, was it kept switching audio back to PCM, from HDMI RAW.
I will report if this FW fixes these.
StormCrow is offline
post #3550 of 3555 Old Yesterday, 09:14 PM
Liked: 0
Hi all, im new to this, but i have install my Ota antenna, i able to get my channel, but since i was with the cable company , i want to be able to watch and record at the same time, like at 2 different channel,i think what i need is a dual tuner?
I wanted to know if the iView-3500STB can do that? I have a small budget, or do you know any model that can do that for not too much money?
Thank !
Steven Désilets is offline
post #3551 of 3555 Old Yesterday, 09:18 PM
jprc's Avatar
Quoted: 22 Post(s)
Liked: 112
Thank !
No, the iview cannot do that. Yes, you need a box with at least two tuners. Well, technically you can watch a subchannel while recording but I doubt that fits anyone's needs who wants this capability.
However, assuming your TV has a working tuner, you can use a splitter (or if loop through is working without one) to watch through your TV tuner while recording through the iview.
jprc is offline
post #3552 of 3555 Old Yesterday, 09:20 PM
mdavej's Avatar
Quoted: 225 Post(s)
Liked: 324
Doesn't exist at iView prices. All you need is another cable, if your TV has a tuner. Set the iView to pass thru.
mdavej is offline
post #3553 of 3555 Old Yesterday, 09:24 PM
Liked: 0
Great will go with a splitter,
Thank for the info!
post #3554 of 3555 Old Yesterday, 10:16 PM
mdavej's Avatar
Quoted: 225 Post(s)
Liked: 324
You don't need a splitter. iView will split.
mdavej is offline
post #3555 of 3555 Old Yesterday, 10:19 PM
jprc's Avatar
Quoted: 22 Post(s)
Liked: 112
That depends. For some of our boxes, it would only work with the Iview on. Some others, it would only work with the iview off. Some did not work at all. Others, depending on the firmware could get it working both on and off.
I don't think anyone with a 3/4 switch has answered (but i may have missed it) whether loop through is still an option either in software or by default, and if it is, how it does or doesn't work.
jprc is offline
Reply HDTV Recorders
User Tag List
