iView-3500STB Tuner & DVR Owners Thread - Page 123 - AVS Forum
 25Likes
post #3661 of 3668 Old Today, 06:12 AM
JHBrandt's Avatar
Quoted: 73 Post(s)
Liked: 160
Another possible cause of the problem is that you're recording one of the stations that just seems to flummox the iView. Ion affiliates are particularly bad about this, but I've seen it on others as well.
Many stations will cause the iView to "double-clutch" when you tune them: the station tunes in, but then the screen goes blank for a second and then the station tunes in again. Usually that's just a minor annoyance, but a few stations seem to go further: the station seems to get completely erased and added back. Any subchannels you deleted, renamed, or skipped suddenly reappear and go back to their original names. If this happens, I suspect you'd lose any timers you've set for the station as well.
I don't know of any sure cure for this. Leaving the iView turned on and tuned to the station in question may help, but even that's not guaranteed.
JHBrandt is offline
post #3662 of 3668 Old Today, 01:14 PM
Liked: 0
Question Questions
Originally Posted by JHBrandt View Post
How 'bout a powered USB enclosure? I like the NexStar CX, which has both USB and eSATA ports, for the iView and a PC. Mine's a 3.5" model but they make 2.5" models too.
Then you can use a USB-powered hub. I use an IOGear 4-port hub, mostly because it was cheap. Works fine. A hub doesn't draw much current, so it won't overtax your iView.
Did you use the 2.0 USB enclosure or the 3.0?
AntheaH is offline
post #3663 of 3668 Old Today, 01:52 PM
JHBrandt's Avatar
Quoted: 73 Post(s)
Liked: 160
No problem. I use a USB-powered 2.0 hub; to make sure it worked I tried it with both a USB-powered 3.0 HDD and an externally-powered USB 2.0 HDD. IIRC if both were plugged in, it labeled one 'C' and the other 'D' and I had to select one. If only one was plugged in, it was always 'C'.
AntheaH likes this.
JHBrandt is offline
post #3664 of 3668 Old Today, 02:02 PM
Liked: 0
Names of shows in recordings
My number one biggest complaint with this unit is it doesn't tell me Seinfeld recorded at 11:30 PM on Channel 5 INSTEAD it says something arcane like WKRC-011:30-12:00-3-3-14. Has anyone hacked a fix for this or know if the company knows of it and will fix.
Brian
Brian Mikesell is offline
post #3665 of 3668 Old Today, 02:12 PM
Aleron Ives's Avatar
Quoted: 240 Post(s)
Liked: 324
You can only rename the files manually, e.g. by connecting the drive to a PC. The manufacturer doesn't seem to consider it to be a problem, as it would have been an easy change to make in any of the half dozen different firmware revisions that exist.
Aleron Ives is offline
post #3666 of 3668 Old Today, 05:01 PM
Quoted: 12 Post(s)
Liked: 0
Thats what really bites about this, I guess you have to buy a tv guide to keep up with what you record. Sad because the info is right there for the thing to use.
BeatnikV is offline
post #3667 of 3668 Old Today, 05:20 PM
R Johnson's Avatar
If the Iview were to name the file based on the PSIP data when the recording started, I'd be in trouble.
I start the recording one minute before the scheduled start in order to ensure a complete program. Thus, I'd probably have the file name based on the preceding program. Oops!
R Johnson is offline
post #3668 of 3668 Old Today, 06:39 PM
Quoted: 240 Post(s)
Liked: 324
Some DVRs compensate for that, but you're probably right: even if iView added the ability to name recordings based on PSIP, the recordings would probably have the wrong names when you started your recording early. It sounds just like something iView would do.
Reply HDTV Recorders
User Tag List
