iView-3500STB Tuner & DVR Owners Thread - Page 131 - AVS Forum
 36Likes
post #3901 of 3908 Unread 12-19-2014, 04:33 AM
ZBear's Avatar
Been reading a lot of the stuff posted about this box and read about half way through the posts and haven't seen my issue. I figured if there was an solution, it would be early on. iView works really decent so far except for one issue. How do I get it to display the correct date and time? I programmed it with cable QAM and got all the available channels. However my cable company doesn't broadcast any guide info. Do I need to hook up some rabbit ears and download OTA channels and info to get the correct clock setting, the switch settings and scan cable again. Currently it shows today's date as July 11, 2011 and time about 3 hours off.
I figure there is a solution but my brain just doesn't work as well as it once did. I will continue to read ALL the posts and thank all that have gone ahead of me on this DVR. Thanks, Bear
ZBear is offline
post #3902 of 3908 Unread 12-19-2014, 05:34 AM
jjeff's Avatar
Quoted: 162 Post(s)
Liked: 100
Originally Posted by ZBear View Post
....Do I need to hook up some rabbit ears and download OTA channels and info to get the correct clock setting, the switch settings and scan cable again. Currently it shows today's date as July 11, 2011 and time about 3 hours off.
I think that might be worth a shot. Unfortunatly because your cable system doesn't send out PSIP and PSIP is the ONLY place it can get it's time info, I think you might be SOL. Your one hope might be as you suggested, first scanning OTA and getting the correct time and then switching back to QAM and hope the time stays. Of course if the time drifts(which these cheap boxes are known to do unless they are constantly updated) your time will slowly get off. IMO the lack of a manual clock setting is one of the biggest downfalls of these boxes, you'd think mfgs. would have learned to offer a manual clock for DVRs after all the issues when we switched to digital and dropped analog channels but I guess learning from history isn't something they do well
jjeff is offline
post #3903 of 3908 Unread 12-19-2014, 01:21 PM
JHBrandt's Avatar
Quoted: 251 Post(s)
Liked: 215
[SIZE=4]How do I get it to display the correct date and time? I programmed it with cable QAM and got all the available channels. However my cable company doesn't broadcast any guide info. Do I need to hook up some rabbit ears and download OTA channels and info to get the correct clock setting, the switch settings and scan cable again.
You can hook up some rabbit ears, switch the iView to "Air," do a manual scan of your best local OTA channel, then tune to it. That should get the time set correctly, then you can hook up cable and switch the iView back to cable. As long as you don't do an auto scan your cable channels should still be there.
Don't know how long the time will remain correct though. You'll probably have to switch back to OTA at least once or twice a week to keep it synced up with whatever OTA station you use for the time.
JHBrandt is online now
post #3904 of 3908 Unread 12-19-2014, 06:35 PM
ZBear's Avatar
I did exactly that except I did auto scan when I switched back to cable. It retained time and date and i pulled off a half hour recording. Until I get an external storage device, I stuck in an unused 8G thumb drive. Recording was just fine.
ZBear is offline
post #3905 of 3908 Unread 12-23-2014, 09:53 PM
SD73's Avatar
Not having a lot of luck. I purchased the MikroTik 5VUSB 5V Power Injector for my WD HDD and I didn't have any luck. The power adapter seemed to be heating up and it's rated for USB 3.0 power. I also tried my USB sticks again and some were found but sometimes after a short while they'd drop off too. Jiggling helped in some cases, but not others. I'll call Iview again after the holiday and see if I can bring it in for servicing. It's pretty frustrating with a new product. I was contemplating buying a laptop hdd and an enclosure to see if it'd would fix my storage issue, but I'm going to hold off until I can get my USB connectivity issues resolved. I've returned my USB 3.0 1.5tb Western Digital HDD.
SD73 is offline
post #3906 of 3908 Unread Today, 11:11 AM
Jim1348's Avatar
I just rana cross this thread and I am considering one of these. At $39.99 the price seems right. As of today, is this a good choice or can I do better in quality for a smiliar price?
Jim1348 is offline
post #3907 of 3908 Unread Today, 01:06 PM
Aleron Ives's Avatar
Quoted: 513 Post(s)
Liked: 450
There are no other entries at this price point (aside from the Homeworx, which uses the same hardware as this and thus isn't really a different product), but more expensive entries are certainly more reliable and have more features than the iView does.
Aleron Ives is offline
post #3908 of 3908 Unread Today, 07:12 PM
JHBrandt's Avatar
Quoted: 251 Post(s)
Liked: 215
Watch out for boxes in the $60-$70 range though. They are often just overpriced clones of the iView.
To get a truly better product, you'll probably need to look for something in the $200 range (or a TiVo, which is under $200 but you must buy a $15/mo "subscription" for it to work).
Reply HDTV Recorders
