iView-3500STB Tuner & DVR Owners Thread - Page 143 - AVS Forum | Home Theater Discussions And Reviews
 67Likes
post #4261 of 4282 Old 08-21-2015, 07:27 PM
R Johnson's Avatar
Quoted: 17 Post(s)
Last night, after returning from a four day holiday, I was pleased to see that my IVIEW was recording. And about 8 recordings had been made.
As I watched the third recording, playback froze and none of the remote buttons had any effect. I tried a power cycle. For a little while, I had a live picture. When I hit the blue button it said USB Device Removed.
But shortly I heard click-click-click from the portable USB drive. Not a good sound! I tried the blue button and got something like Unrecognized Format. I tried another disk drive and got the same result.
Shortly after this, the TV reported No Signal. The IVIEW was completely dead.
Connecting both USB drives to my laptop revealed that everything was OK on the drives. Whew!
A bummer, but the IVIEW has been very valuable to me since I bought it in June 2014. Fourteen months until failure is not too good.
As I'm not aware of any more suitable devices for my purposes, I ordered another one this afternoon. At $36 I should probably have a spare. Fortunately I don't think there are any programs I really need to record until the replacement arrives.
R Johnson is online now
post #4262 of 4282 Old 08-21-2015, 07:49 PM
jprc's Avatar
Quoted: 48 Post(s)
Liked: 115
Mine died last year, about the same amount of time. The USB port died first. The port stopped working completely while still under warranty but it was going to cost me $25 for warranty repair, which I thought was ridiculous for a box of this price, so I didn't send it in. When it died completely a few months later, I was even more glad I didn't waste money on the warranty repair of the usb port since it would have been completely useless just a few months later.
Anyway, it sounds like you already ordered a new iview, but if not, it was brought up in the Homeworx thread that there is a new iview PVR out - the 3200. Here is a link to it on Amazon - http://www.amazon.com/IVIEW-3200STB-.../dp/B00RDQGBIE
jprc is offline
post #4263 of 4282 Old 08-21-2015, 08:05 PM
R Johnson's Avatar
Quoted: 17 Post(s)
Thanks for mentioning the 3200!
I browsed Amazon a bit, and saw that the 3500stbii was "old version" but I did not see a link to the "newer" version. I think I saw a "3200" but didn't pay any attention to it.
There was discussion of a likely new model a month or so ago in this thread. Perhaps I missed it, but I don't think there was a post about the actual new model in this thread.
I'll have to look into the 3200...
post #4264 of 4282 Old 08-21-2015, 08:34 PM
R Johnson's Avatar
Quoted: 17 Post(s)
B&H shows that the 3200stb is discontinued and shows the 3500stbii as an alternative.
http://www.bhphotovideo.com/c/produc...erter_box.html
But Amazon shows
Date First Available as October 7, 2013 for the 3500stbii
and December 24, 2014 for the 3200stb.
The importer's web store only lists ONE converter box -- the 3500stbii.
http://www.iviewus.com/index.php/iview-store.html
Curious.
post #4265 of 4282 Old 08-22-2015, 12:32 AM
jprc's Avatar
Quoted: 48 Post(s)
Liked: 115
But Amazon shows
Curious.
It's showing in stock on the iview site: http://www.iviewus.com/index.php/iview-3200stb.html
iView's numbering scheme and naming scheme has always been so bizarre, I wouldn't be surprised if they re-used the model number.
jprc is offline
post #4266 of 4282 Old 08-22-2015, 01:43 AM
m. zillch's Avatar
Quoted: 579 Post(s)
Liked: 372
B&H shows that the 3200stb is discontinued...
It is quite rare, in fact almost unheard of, for a retailer to have numerous descriptions for "not in stock, you can't order this" even though there can be several reasons. "Discontinued" should not be, necessarily, taken literally. It could be (for example) the two units are running concurrently but they only have one of the two of them...currently. We don't know for sure.
In A/V reproduction accuracy, there is no concept of "accounting for taste". We don't "pick" the level of bass, etc., any more than we pick the ending of a play. High fidelity means an unmodified, neutral, exact copy (or "reproduction") of the original artist's tonal balance, timing, dynamics, etc..
m. zillch is offline
post #4267 of 4282 Old 08-22-2015, 06:51 AM
afterlife2's Avatar
Quoted: 73 Post(s)
Liked: 36
Keep a small fan on top all these DVR's tend to overheat and freeze, erase channels, etc. Got the idea from JH. Get something like this and put it on top with air circulating out it helps. 1 fan should be good enough: http://www.amazon.com/iDeaUSA-Coolin...ptop+fan+1+fan
afterlife2 is offline
post #4268 of 4282 Old 08-23-2015, 11:14 PM
crabboy's Avatar
Quoted: 23 Post(s)
Liked: 37
Not a bad idea for any electronics w/ heat issues.
afterlife2 likes this.
Jiggery - Pokery!
crabboy is offline
post #4269 of 4282 Old 08-24-2015, 09:00 AM
dleedlee's Avatar
Quoted: 24 Post(s)
I saw the 3200 but was not quite sure what it was compared to the 3500.
I bought an "old version" from Amazon thinking it might be the 3500STBII w/o the 3/4 switch but it had the 3/4 switch. It replaced my first 3500STBII (non 3/4) that I got last April. It had been acting wonky for the past couple weeks before finally giving up the ghost. Opened it up and looked like it might have a slight leaky cap.
dleedlee is online now
post #4270 of 4282 Old 08-24-2015, 09:49 AM
R Johnson's Avatar
Quoted: 17 Post(s)
From a case design perspective, the 3200stb appears to be newer model than the 3500stbii. (Custom case versus a generic box.)
It would be interesting to read comments from any users who have both models.
post #4271 of 4282 Old 08-25-2015, 04:27 PM
R Johnson's Avatar
Quoted: 17 Post(s)
My second 3500stbii arrived. It seems a bit less sensitive than the one that died. Same antenna and location. On the PBS station that I usually record, it will display a picture without any problems. But when it goes into Record mode, the picture breaks up quite a bit. This happened on the defunct unit too, until I found the "perfect" indoor antenna location.
While I'll work with alternate antenna positioning, I ordered an iview 3200stb this evening. It should be an interesting experiment.
post #4272 of 4282 Old 08-25-2015, 08:02 PM
JHBrandt's Avatar
Quoted: 526 Post(s)
Liked: 335
One of the biggest frustrations with these boxes has been their susceptibility to RFI from an attached HDD - which pretty much defeats the purpose if you lose the signal any time you try to record it!
Try moving the HDD as well as the antenna. You might also look for a USB cable with ferrite chokes at each end.
JHBrandt is offline
post #4273 of 4282 Old 08-26-2015, 02:56 PM
dleedlee's Avatar
Quoted: 24 Post(s)
I can recommend the WD 3TB Elements External Desktop. I tried a couple WD portables with sporadic success until I settled on the Elements. It's been wonderfully stable since Dec/Jan.
post #4274 of 4282 Old 09-01-2015, 09:15 AM
R Johnson's Avatar
Quoted: 17 Post(s)
A brief report on the iview 3200stb vs the 3500stbii:
The 3200 appears to be a newer, cost reduced model. A much smaller custom designed case; no display or buttons on the case; no component video output; a wall wart power supply; a much smaller remote. Vestiges of the 3500stbii remain in the manual.
Reception of the channel I'm most interested in recording was not good at the time I did a quick test. (Same antenna and position as I had used for months with my first 3500stbii.) I had hoped for better.
The larger remote for the 3500 seems to work well with the 3200.
When I tried to playback recordings from the 3500 using the 3200, it found the usual file folder, but WOULD NOT play back either of the two recordings there,
End of test 1. 3500stbii back in the system.
dleedlee and m. zillch like this.
post #4275 of 4282 Old 09-01-2015, 01:06 PM
m. zillch's Avatar
Quoted: 579 Post(s)
Liked: 372
That was an excellent, concise report, thanks.
post #4276 of 4282 Old Yesterday, 06:43 AM
QAM
QAM's Avatar
Yes, nice report on the 3200. Can you tell us what firmware revision number your 3200 has? Also can program timers span 12 midnight.
You say the 3200 remote is smaller, how so. Are any of the buttons/functions missing that the 3500 had? Have they improved the USB connector on the 3200? What about the "useless" display on the unit. Does it still show the "C00xx" channel info like the 3500? Any indication that the unit is "recording" (ie LED lit)? Just curious. Thanks for any info.
QAM is offline
post #4277 of 4282 Old Yesterday, 08:53 AM
dleedlee's Avatar
Quoted: 24 Post(s)
Hmmm...time to stockpile 3500s?
I've really come to appreciate the remote on the 3500stbii. This, especially after grappling with Samsung's TV "mini" remotes.
post #4278 of 4282 Old Yesterday, 09:25 AM
R Johnson's Avatar
Quoted: 17 Post(s)
No idea of FW version. (Not hooked up now.) No idea on timer spanning midnight, but unlikely. NO display. Just one light / IR sensor. No idea if USB connector improved. See attached pictures for size, remotes.
Name:	IMG_4832 iview 3200.jpg
ID:	920586   Click image for larger version
Name:	IMG_4847 iview sizes.jpg
ID:	920594   Click image for larger version
Name:	IMG_4851 iview remotes.jpg
post #4279 of 4282 Old Yesterday, 12:33 PM
QAM
QAM's Avatar
Thanks for the pix RJ, worth a thousand words. The new smaller remote is nice, looks like they moved the Play/FF/Stop buttons to the top, which suites me just fine. Always felt a little cramped for space at the bottom of the current remote. Also looks like they canned the TV programmable buttons, which is a bad thing. This was a good feature.
I guess having no channel numbers on the box really doesn't matter as this was a relative thing.
OK, didn't mean to rush you about the firmware info. BTW, as far as the USB port, did you feel that it had a 'tighter' fit than the 3500. The problem with the original was that there was too much slack in the connection. A tighter fit would solve a lot. Please keep us informed in the future.
QAM is offline
post #4280 of 4282 Old Yesterday, 08:58 PM
JHBrandt's Avatar
Quoted: 526 Post(s)
Liked: 335
A similar problem has been reported with the Homeworx equivalent of the 3200 (the HW-180). There are multiple firmware versions (V9, V10, and V10.1 have been reported). All versions use the NTFS file system and the .mts file format. Yet V10 will not play back files recorded with V9. Unsure which, if either, will play back files from a 3500 or HW-150. (Actually I'm not even sure if you can play back recordings on a different box with the same firmware version!)
It looks like these new boxes stamp recordings somehow (version and/or serial number?) and refuse to play recordings with a different stamp. For the life of me I don't know why the firmware developers would have done this. These boxes all record completely unencrypted video with no DRM issues whatsoever.
If you get a chance, try changing the file extensions from .mts to .ts and playing them as "movies." See if that gets around the inability to play 3500 recordings.
JHBrandt is offline
post #4281 of 4282 Old Today, 09:49 AM
R Johnson's Avatar
Quoted: 17 Post(s)
.... (Actually I'm not even sure if you can play back recordings on a different box with the same firmware version!)
My new 3500stbii will play recordings made by the previous 3500. Those recordings were also usually playable by my Sony Blu-ray player (as MTS files) for viewing on my projector. (I vaguely recall changing to TS for playback on some device many months ago.)
I'll probably experiment a bit more with the 3200, but it's likely that I'll stick with the 3500. Getting a spare might be a good idea.
post #4282 of 4282 Old Today, 01:43 PM
JHBrandt's Avatar
Quoted: 526 Post(s)
Liked: 335
That's true; I've never heard of any sort of incompatibility between different 3500STB models. Same goes for the Homeworx HW-150 models. In fact I'm pretty sure you can play recordings from a 3500STB on an HW-150 and vice versa.
I'm guessing you can play a recording from a 3200 on a 3500, but not vice versa, because I think the 3200 checks the version stamp in the recording (and so will only play recordings from its own firmware version), but the 3500 doesn't care. But someone will have to check on that and report back.
At any rate, this sounds like a really annoying wrinkle in the new 3200 models, even if it turns out you can get around it by changing the file extension. (Someone needs to check on that too.)
JHBrandt is offline
Reply HDTV Recorders
