SA Explorer Faceplate removal - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-30-2013, 03:04 PM - Thread Starter
patsc23's Avatar
For the longest time I've wanted to black out the faceplate for my SA 8300, but I can't seem to figure out how to remove it w/o cracking anything? Does anyone know the proper way to remove it? I looked on the underside and there looks to be one clip which should be pulled out to release, however there are two other different tabs as well. Any help would be very appreciated.
Thx!
patsc23 is offline
post #2 of 2 Old 03-30-2013, 10:04 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
Thx!
Your 8300? Or your cable company's 8300?
domino92024 is offline
Reply HDTV Recorders
