Keeping local programs on DirecTV DVR after moving to another market - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-21-2013, 10:10 AM - Thread Starter
esdx's Avatar
I don't know if this has been covered before, but I have a question about whether or not it is possible to keep programs recorded on channels you no longer can access...i.e... let's say I record a favorite episode of the Big Bang Theory on my local CBS affiliate, as well as a local newscast. I move, keeping my current DVR and re-establish service in my new city, which has different affiliates. Does the DVR keep access to this recorded program(s), even though it was recorded in another city and I can no longer access the affiliate since I now have a new set of affiliates in my new city?
esdx is offline
post #2 of 3 Old 04-21-2013, 10:49 AM
texasbrit's Avatar
Quoted: 47 Post(s)
Liked: 34
Yes, it's recorded on your DVR's disk drive and you will still be able to play it after you move.
texasbrit is offline
post #3 of 3 Old 04-22-2013, 12:55 PM
Beerstalker's Avatar
Liked: 24
Like Texasbrit said, the existing recordings should play just fine as long as you hook your DVR up to a satellite at your new home, and turn your DirecTV service back on (if it was temporarily turned off).
However, I believe you have to set up all of your series links for the new networks. For example if you have a series link for The Big Bang Theory on your old CBS affiliate, you will need to delete that series link and set up a new one for your new CBS affiliate. I'm fairly certain the DVR doesn't automatically do that for you. This should only effect series links for your local affiliates though, any series links for national cable channels like USA, FX, TBS, etc should continue to work just fine.
Beerstalker is offline
Reply HDTV Recorders
