JVC HM-DH4000U - 40k - HS record head - AVS | Home Theater Discussions And Reviews
post #1 of 3 Old 05-20-2013, 02:55 PM - Thread Starter
tvmaster's Avatar
OK, it seems like I have a problem recording in the HS speed.
Only seems to be a record problem, as I can play back older HS speed HDTV recordings just fine.
I can also record at all other speeds, just not in HD of course. When these machines sense an HD signal, they auto-switch to the HS record speed.
Question: Does anyone know which is the HS record head, so I can clean it.
I don't have a service manual, so I have no way to know which of the many heads is the one to clean.
is it labeled somehow - it must be, yeah?
tvmaster is offline
post #2 of 3 Old 06-02-2013, 09:26 PM
NJRoadfan's Avatar
Service manual is available here: http://www.digitalfaq.com/forum/vcr-repair/4769-service-manual-jvc.html
It might be worth asking for repair advice while you are there too.
NJRoadfan is offline
post #3 of 3 Old 06-03-2013, 11:25 AM - Thread Starter
tvmaster's Avatar
brilliant - thanks a bunch
tvmaster is offline
Reply HDTV Recorders
