Direct tv tivo dvrhd34 "To record episode press R on your remote control" annoying pop up ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 06-29-2013, 11:16 PM - Thread Starter
sportman1's Avatar
This morning the record pop up appeared on CH 206 espn! and on other ESPN channels and others to I can not get rid of it do you know where I can get rid of it ?
sportman1 is offline
post #2 of 13 Old 06-30-2013, 07:49 AM
joed32's Avatar
Quoted: 70 Post(s)
Liked: 65
I have read on some other boards that if you set up 5 or 6 series to record that goes away. It's a bug and they have to be series set to record and not single episodes. I don't have a 34 but some people that I really trust swear by this. good luck!
joed32 is offline
post #3 of 13 Old 06-30-2013, 01:41 PM - Thread Starter
sportman1's Avatar
joed32 when you say up 5 or 6 series to record that goes could you please tell me the number of episode I record 1 episode per series and I can delete everything and pop up will go away
post #4 of 13 Old 07-01-2013, 05:43 AM
joed32's Avatar
Quoted: 70 Post(s)
Liked: 65
As I said, I don't have a 34 so I wouldn't know, experiment a little and find out how it works.
joed32 is offline
post #5 of 13 Old 07-01-2013, 04:15 PM
tylerSC's Avatar
Quoted: 679 Post(s)
Liked: 155
Does the DirecTV Tivo have an ATSC tuner for OTA antenna input?
tylerSC is offline
post #6 of 13 Old 07-01-2013, 09:40 PM - Thread Starter
sportman1's Avatar
I did set up series. did not change the default options on the DVR popup went away but if you need to have (always) at least 6 series links it is not realestic to do your DVR will keep recording shows and fill up my DVR any other way to make pop up go away
post #7 of 13 Old 07-02-2013, 06:34 AM
joed32's Avatar
Quoted: 70 Post(s)
Liked: 65
Change the options for each of those series to "Keep one at most" and it will not fill up your DVR. It's a bug and they will probably fix it eventually but for now there is only one way.
joed32 is offline
post #8 of 13 Old 07-02-2013, 10:59 AM - Thread Starter
sportman1's Avatar
Could you set options for each of those 6 series links first run and no Repeats will it work?
post #9 of 13 Old 07-02-2013, 11:01 AM - Thread Starter
sportman1's Avatar
I meant Could you set options for each of those 6 series links first run and Repeats will it work?
post #10 of 13 Old 07-02-2013, 12:26 PM - Thread Starter
sportman1's Avatar
post #11 of 13 Old 07-03-2013, 07:47 AM
joed32's Avatar
Quoted: 70 Post(s)
Liked: 65
Try it!!!!
joed32 is offline
post #12 of 13 Old 07-03-2013, 02:31 PM - Thread Starter
sportman1's Avatar
joed32 I meant Could you set options for each of those 6 series links first run and with NO Repeats will pop up go away will it work?
post #13 of 13 Old 07-04-2013, 11:44 AM - Thread Starter
sportman1's Avatar
Tell me please the set options for first run and with NO Repeats on the Direct tv dvrhd34 in the series manager the order it is display on the Reciver ?
Reply HDTV Recorders
