Channel Master DVR+ Owners Thread - Page 108 - AVS Forum | Home Theater Discussions And Reviews
 3288Likes
post #3211 of 14219 Old 04-22-2014, 08:06 AM
Kelson's Avatar
Quoted: 1960 Post(s)
Liked: 1152
Originally Posted by P Smith View Post
from CM site, it was there initially ...
It is not there now -- at least not that I can find.
wiscojim has apparently saved a copy of 101R and made it available for download.
His post.
Hopefully enough people will download it and keep it as a retainer along with 103R.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #3212 of 14219 Old 04-22-2014, 08:53 AM
artisticimaging's Avatar
Quoted: 167 Post(s)
Liked: 78
Originally Posted by reacheks View Post
HDD problems here too. I have experienced these glitches when playing my recorded videos. I have a USB3.0 SATA enclosure case with it's own power supply. Inside this case is a Seagate Barracuda ST1000DM003 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive Bare Drive which was in my last computer build. The HDD was reformatted by the DVR+ but after 20 days of recording, I experienced several "disk initialization" errors. In one case I did another HDD format since the DVR+ could not read my library of recorded files.
I installed the Windows Ext2Fsd (Ext2 File System Driver for Windows) utility so I could check the Linux Partitions and files. Both partitions appeared fine and my recorded shows were all there in partition 2. I also did the "FFMPEG" video conversion and got my video file(s) to run in both VLC Media Player and Windows Media Player.
I attempted to get the DVR+ to initialize my USB disk several times using the (1) power on/off trick, (2) CHKDSK function and (3) disconnecting the USB disk, powering on DVR+ then power down then reconnecting USB Disk. There was no sure hit or miss routine I used to get the USB Drive to initialize but I did get it working a few times. In all cases, going to the settings menu, I checked the technical selection to verify that the disk parameters were recognized and logged correctly on the boot-up. In those cases where it recognized the disk after a clean boot-up, the DVR function would not work and I would get the not able to initialize disk error.
I ordered the recommended Seagate Expansion 3TB USB 3.0 Desktop External Hard Drive w/ separate enclosure and power (STBV3000100). I noticed that this is 5400RPM. I wonder if my SATA 7200RPM USB 3.0 drive had compatibility issues (even though it is USB2.0 backward compatible).
Now that I have a way to save my Video library doing a reformat is not so painful. FWIW, when I did do the reformat DVR+ command, in ALL cases my DVR recording option worked fine. But after about 10% of the disk was filled and/or about 20 days of 24/7 usage, I experienced the disk initialization issues described above. The new 3TB Seagate drive should arrive in a few days, so I hope I should resolve this particular issue.
EKS
I wonder if the issue is the 7200rpm hard drive, since mine is a 7200rpm too? Maybe 7200rpm is too fast for the DVR+ is buffer?
artisticimaging is offline
post #3213 of 14219 Old 04-22-2014, 08:59 AM
P Smith's Avatar
Quoted: 568 Post(s)
Liked: 305
nope, it cannot be that way, opposite is yes
and @reacheks:
you guys should start checking a health of the drives first - connect it to PC (better directly to SATA port) and obtain SMART info by using bootable MHDD (burn CD from ISO file) or Victoria under Windows
get the SMART, run Scan wit Remap=on, get second SMART, post here - we will talk about the drive with some facts
P Smith is offline
post #3214 of 14219 Old 04-22-2014, 09:59 AM
Kelson's Avatar
Liked: 1152
Maybe not the speed but the need for continuous throughput of multiple AV streams. I have a media server disk farm of the same Seagate Barracuda drives but larger (ST3000DM001) and they are very fast in burst mode.
My DVR's all came with AV rated drives which are 5900 rpm drives that are made to run 24x7 with big buffers and the ability to handle multiple HD streams going in and out of the drive. If it were me with a DVR+, to add an external drive I would buy a Seagate Pipeline AV drive (what came in my TiVo Roamio) and put it in a self-powered USB enclosure for the DVR+. Others may prefer the WD AV drives which would be just as good.
- kelson h
Kelson is offline
post #3215 of 14219 Old 04-22-2014, 10:00 AM
reacheks's Avatar
Location: Silicon Valley (Evergreen Foothills) - Found 16 transmitters within 50 miles of antenna location
S.M.A.R.T. (Self-Monitoring, Analysis and Reporting Technology; often written as SMART) is a monitoring system for computer hard disk drives (HDDs) and solid-state drives (SSDs)[1] to detect and report on various indicators of reliability, in the hope of anticipating failures.
Can you suggest any one of the tools listed in this link that works on Windows 7?
Comparison of S.M.A.R.T. tools and/or a link to one that you use.
EKS
reacheks is offline
post #3216 of 14219 Old 04-22-2014, 10:06 AM
wiscojim's Avatar
Quoted: 149 Post(s)
Liked: 238
And here is 102R for anyone that wants it.
https://www.dropbox.com/s/s9vf6em3gov2j5t/102R_prod_signed_usb_download.str
I suggest anyone that may ever anticipate needing it in the future should downlaod and save these now, I have no idea if CM will want me to remove it at some point.
For now, it should probably be available. You guys are doing some of the troubleshooting for them.
wiscojim is online now
post #3217 of 14219 Old 04-22-2014, 10:23 AM
reacheks's Avatar
Have you tried (or is it possible) to connect the DVR+ to some type of "virtual" disk which is part of a NAS system? My long term plan is to run a PLEX media server connected to a NAS system (using DD-WRT) located at two different remote locations (main home & vacation home). I was going to copy the DVR+ video library periodically to the NAS system and/or to the main media server disk(s) then create new meta data (using PLEX) to update my master Plex media files.
I have not tested the DD-WRT NAS options but have flashed all my Asus RT-N66U routers located at my remote locations w/ the latest build ( DD-WRT v24-sp2 (07/24/13) big). I know I can mount EXT3 disk formats and thought I could trick the DVR+ to write out the "*.ts files" to a virtual disk and/or even clone the standard Linux DVR+ disk format structure (ie. partition 1 and 2 detail formats) . Once in the NAS system, I can easily create the MPEG-2 TS Video (.ts) format using the ffmpeg converter.
I probably want to have one or more of those AV rated disks in my NAS build but for now, I am just experimenting with the different pieces so I can eventually build a seamless media server that can automatically create and update my media library.
EKS
reacheks is offline
post #3218 of 14219 Old 04-22-2014, 10:49 AM
Quoted: 167 Post(s)
Liked: 78
and @reacheks:
Here is SMART info:
*** DiskCheckup V3.2 Build: 1000 Report ***
SysInfo DLL Version: SysInfo v1.0 Build: 1041
Time of export: 10:41:17 22-Apr-2014
Device information:
Device ID: 1
Interface: USB
Device Capacity: 476937 MB
Serial Number: 5QG27BL5
Model Number: ST3500630AS
Firmware Revision: 3.AFM
Partitions:
N/A
ATA information:
Disk geometry:
Cylinders: 60801
Tracks/Cylinder: 255
Sectors/Track: 63
Bytes/Sector: 512
Total disk sectors: 976773168
Logical sector size: 512
Physical sector size: 512
Media rotation rate: N/A
Buffer size: 16384 KB
ECC size: 4 Bytes
Standards compliance:
ATA8-ACS Supported: No
ATA/ATAPI-7 Supported: Yes
ATA/ATAPI-6 Supported: Yes
ATA/ATAPI-5 Supported: Yes
ATA/ATAPI-4 Supported: Yes
World Wide ID: 0000000000000000
Feature support:
SMART supported: Yes
SMART enabled: Yes
SMART self-test supported: Yes
SMART error log supported: Yes
LBA supported: Yes
IORDY supported: Yes
CFast supported: No
DMA supported: Yes
Maximum Multiword DMA mode supported: 2
Multiword DMA selected: None
Maximum UltraDMA mode supported: 6
UltraDMA selected: 5
Maximum PIO mode supported: 4
SATA Compliance: Yes
NCQ priority information supported: No
Unload while NCQ commands are outstanding supported: No
Phy Event Counters supported: Yes
Receipt of power management requests supported: No
NCQ feature set supported: Yes
SATA Gen2 Signaling Speed (3.0Gb/s) supported: Yes
SATA Gen1 Signaling Speed (1.5Gb/s) supported: Yes
Software Settings Preservation: Not supported
In-order data delivery: Not supported
Initiating power management: Supported, Disabled
DMA Setup auto-activation: Not supported
Non-zero buffer offsets: Not supported
Trusted Computing supported: No
Host Protected Area (HPA) supported: Yes
Read look-ahead supported: Yes
Read look-ahead enabled: Yes
Write cache supported: Yes
Write cache enabled: Yes
Power management supported: Yes
Security mode supported: Yes
Security mode enabled: No
Device Configuration Overlay (DCO) supported: Yes
48bit Addressing supported: Yes
Auto Acoustic Managment (AAM) supported: No
Power-up in Standby (PUIS) supported: Yes
Power-up in Standby (PUIS) enabled: Yes
Advanced Power Management (APM) supported: No
CompactFlash Association (CFA) supported: No
General Purpose Logging (GPL) supported: Yes
Streaming supported: No
Media card pass through supported: No
Extended power conditions supported: No
Extended status reporting supported: No
Write-read-verify supported: No
Free-fall control supported: No
TRIM command supported: No
SCT command transport supported: No
NV Cache enabled: No
NV Cache Power Management supported: No
SMART ATTRIBUTES:
ID Description Status Value Worst Threshold Raw Value TEC
1 Raw Read Error Rate OK 100 253 6 0 N.A.
3 Spin Up Time OK 93 91 0 0 N.A.
4 Start/Stop Count OK 100 100 20 888 N.A.
5 Reallocated Sector Count OK 100 100 36 0 N.A.
7 Seek Error Rate OK 72 60 30 15896837 N.A.
9 Power On Time OK 99 99 0 1454 N.A.
10 Spin Retry Count OK 100 100 97 0 N.A.
12 Power Cycle Count OK 100 100 20 226 N.A.
187 Reported Uncorrectable Errors OK 100 100 0 0 N.A.
189 High Fly Writes OK 100 100 0 0 N.A.
190 Temperature Difference from 100 OK 59 33 45 690487337 N.A.
194 Temperature OK 41 67 0 41 C N.A.
195 Hardware ECC Recovered OK 71 57 0 223836897 N.A.
197 Current Pending Sector Count OK 100 100 0 0 N.A.
198 Uncorrectable Sector Count OK 100 100 0 0 N.A.
199 UltraDMA CRC Error Count OK 200 200 0 0 N.A.
200 Write Error Count OK 100 253 0 0 N.A.
202 Data Address Mark Errors OK 100 253 0 0 N.A.
SMART HISTORY:
Error retrieving history
post #3219 of 14219 Old 04-22-2014, 10:59 AM
P Smith's Avatar
Quoted: 568 Post(s)
Liked: 305
I would recommend using the tool : http://sourceforge.net/apps/trac/smartmontools/wiki
as to your drive's health ... it's looks good, perhaps HW ECC errors could be reduced if use direct SATA cable
major minus in your report, you didn't check the drive, need run Scan with Remap=ON and pull other SMART report
P Smith is offline
post #3220 of 14219 Old 04-22-2014, 11:14 AM
Quoted: 167 Post(s)
Liked: 78
Your link does not work for me.
post #3221 of 14219 Old 04-22-2014, 11:25 AM
Charles R's Avatar
Liked: 560
WMC supports this via iSCSI and it works very nicely. I have (4) network tuners which travel to the PC and from the PC to the NAS for recording and then back to the PC for viewing and or other displays. With four recordings and several streaming concurrently the overhead never hits 10% of available network bandwidth. The iSCSI virtual drive is never taxed as well...
reacheks likes this.
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Sony UBP-X800 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Roku Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
post #3222 of 14219 Old 04-22-2014, 11:44 AM
Kelson's Avatar
Liked: 1152
Try it again. It works for me.
- kelson h
Kelson is offline
post #3223 of 14219 Old 04-22-2014, 02:12 PM
Aleron Ives's Avatar
Quoted: 1607 Post(s)
Liked: 1348
This link would probably be more direct:
http://sourceforge.net/projects/smartmontools/files/smartmontools/6.2/
You'll want to download smartmontools-6.2-1.win32-setup.exe.
Aleron Ives is offline
post #3224 of 14219 Old 04-22-2014, 02:30 PM
P Smith's Avatar
Quoted: 568 Post(s)
Liked: 305
more important to obtain a report after Scan+Remap !
P Smith is offline
post #3225 of 14219 Old 04-22-2014, 03:22 PM
mulliganman's Avatar
Originally Posted by slprp1 View Post
Ditto!......or "AMEN to that!!!!" (courtesy of "mulliganman")
Really??? Sorry if you took offense to my comment. But, at some point you have to try to troubleshoot and take the suggestions people give you or more than likely everyone will put you on ignore.
osu1991 likes this.
mulliganman is offline
post #3226 of 14219 Old 04-22-2014, 03:40 PM
Quoted: 167 Post(s)
Liked: 78
This is what I get when I click on the links and even after a google I get this.
This page can’t be displayed
•Make sure the web address http://smartmontools.sourceforge.net is correct.
post #3227 of 14219 Old 04-22-2014, 03:55 PM
Quoted: 889 Post(s)
Liked: 358
Works for me too. Try this:
JoeKustra is online now
post #3228 of 14219 Old 04-22-2014, 03:56 PM
Quoted: 167 Post(s)
Liked: 78
Same thing!
•Make sure the web address http://sourceforge.net is correct.
•Look for the page with your search engine.
•Refresh the page in a few minutes.
post #3229 of 14219 Old 04-22-2014, 04:33 PM
Chuck Tribolet's Avatar
Location: Silicon Valley (Morgan Hill, CA and Marina, CA).
Quoted: 20 Post(s)
Liked: 68
In order to spin at 7200 RPM and still have the heads work right, all other things being equal (that pretty much means same generation of drive), they put proportionately less data on a track, so the data transfer rates work out to be about the same.  Plus, data is read off the disk into a memory buffer in the electronics of the card.  So that's not it.
And BTW, I see the glitches sometimes and I have a wall powered (UPS-powered actually) 3.5" hard drive on my DVR+.
And BTW2, I recently had the time get two minutes, and then six minutes slow.  Rebooting the DVR+ cleared that up.
Chuck
Chuck Tribolet is offline
post #3230 of 14219 Old 04-22-2014, 04:38 PM
kent2174's Avatar
Quoted: 26 Post(s)
last night my device would not turn on from standby.....either with the remote or front button.
Unplugged the device for 1 minute.....all okay.
This happens about once a month......not heard anyone speak to this issue.
kent2174 is offline
post #3231 of 14219 Old 04-22-2014, 04:38 PM
Russell_'s Avatar
Quoted: 37 Post(s)
Liked: 30
Chuck
Not sure how closely you've been following ... the time issues should go away with the next release of the firmware.
Russell_ is offline
post #3232 of 14219 Old 04-22-2014, 05:39 PM
P Smith's Avatar
Quoted: 568 Post(s)
Liked: 305
I would concentrate on Scan+remap instead of the program :shrug:
P Smith is offline
post #3233 of 14219 Old 04-22-2014, 05:46 PM
DawnSun's Avatar
Quoted: 14 Post(s)
I recently had two issues I posted about here (post #3153). I wrote to Channel Master today and received these prompt replies (in the same e-mail):
(1) Somehow I was "upgraded" to 103R without my being aware it was happening--until I went into my settings in search of answers to my time delay.
CM reply: "I am sorry for the trouble you are having with the software 103R. I do know that it is not possible for us to download the new software onto your box. You would have to do that."
(2) The time started being six minutes slow, and I was missing 5-6 minutes at the beginning of each recording.
CM reply: "Now there has been a fix for this software that will be ready very soon [please define]. The time issue is known and we will make sure to get this taken care of as soon as possible [wiggle room]. This will take care of all the time issues that you are having."
What just happened: I tried fiddling with the ZIP code setting, but ended up leaving it the same. I also switched back and forth between Auto time and Manual setting, leaving time set to Auto. When I stopped messing about, the time was correct! Let's see if it stays that way.
Ah, the mysteries.
--DawnSun
DawnSun
DawnSun is offline
post #3234 of 14219 Old 04-22-2014, 06:21 PM
Quoted: 20 Post(s)
Liked: 68
I've reported on this in the past.  About the same monthly frequency.
Chuck
post #3235 of 14219 Old 04-22-2014, 10:19 PM
slprp1's Avatar
Quoted: 12 Post(s)
Liked: 49
No offense taken.....
but..... what others (including yourself) need to realize is that:
A) This specific problem is intermittent and I frequently don't have the hours and hours that it takes to troubleshoot it.
B) Relative to A.....I've already invested many, many hours and seem to get zero credit for this on this forum (discouraging!).
C) It's a fact that these video/audio glitches have definitely occurred with a self powered EHD (several people have recently reported this). It's not an isolated incident.
D) If there was conclusive proof that these problems are related to USB powered drives,
don't you think that CM would have (at the very least) stopped recommending and selling this type of drive?
.....Just because I haven't had the time to deal with this currently and the thought of buying and returning drives doesn't exactly appeal to me (not to mention my limited budget), that's no excuse for other's here (who know who they are) to criticise and ridicule me as they have!
It's not fair, since I've invested far more time on this project (with two units, in two different locations and six different hard drives) than many others here (including perhaps the complainers)!
It's easy to sit there and delegate and/or criticize. Yes....I've been highly critical (all deservedly so) of the DVR+ but.....I've at least tried my best to help myself and others!......
Enough with the (inappropriate) complaints!
......and.....should others chose to "ignore" me, that's their loss.......as (in reality) I've been quite helpful here!
Russell_ and LenL like this.
slprp1 is offline
post #3236 of 14219 Old 04-22-2014, 10:30 PM
slprp1's Avatar
Quoted: 12 Post(s)
Liked: 49
So.....Kelson.....
What's new with 106R (and especially how it relates to the aforementioned "glitchy" video and audio issues plaguing these units)?
slprp1 is offline
post #3237 of 14219 Old 04-22-2014, 10:42 PM
wiscojim's Avatar
Quoted: 149 Post(s)
Liked: 238
slprp1 would you please just sit on your hands for a couple of weeks and just wait to see what develops?
Your redundant posts have even those of us who have had much more serious troubles with the DVR+ sick of seeing them.
And no, we just can't ignore your posts. Two-thirds of the rest of the posts here are specific responses to yours.
Kelson, kwg, osu1991 and 3 others like this.
post #3238 of 14219 Old 04-22-2014, 11:13 PM
slprp1's Avatar
Quoted: 12 Post(s)
Liked: 49
Sorry.....I'm not quite ready to sit on my hands (while at the same time being asked to do further testing)! This represents nothing more than a complete contradiction!
I would also greatly appreciate it if you (and others here) would stop trying to stifle me.....as it's not serving any constructive purpose!......(especially when you consider that I spend most of the time having to respond to inappropriate criticisms (such as this one)!
......Speaking of inappropriate.....please.....I'm very curious......explain what you're referring to as "much more serious troubles" than trying to watch a recording (or even "live TV") and having to deal with skipped portions of video and/or audio and sudden freezes......and then being forced to to replay the same scenes over again!!......knowing full well that you have perfect reception and a perfectly good EHD!
Give me an example of what's "worse".
Thank you!
LenL likes this.
slprp1 is offline
post #3239 of 14219 Old 04-22-2014, 11:19 PM
slprp1's Avatar
Quoted: 12 Post(s)
Liked: 49
Originally Posted by jjeff View Post
I've tried Lenkeng which outsources for many companies, Atlona and Monoprice(Lenkeng clone) and wasn't satisfied with any. In the end I ended up keeping a Lenkeng clone and while I'm not really satisfied with it's picture quality for the $30 I paid for it I figured it would give me options for HDMI only devices or devices that letterbox SD outputs but not HDMI outputs. My Nikon camera is one such device, while it has composite and HDMI outputs only the HDMI output is full screen 16:9, the composite output is 4:3 letterboxed mad.gif
I've been told HD Fury makes a higher quality converter but no way I'm going to pay $300 for a converter to use on a $299 device rolleyes.gif
Thanks for all of your help!
The HD fury (which sounded interesting) converts HDMI to component video. That certainly complicates things (even if you had the budget for it, although the one I'm referring to is $160.00, which is not too unreasonable).
slprp1 is offline
post #3240 of 14219 Old 04-22-2014, 11:24 PM
slprp1's Avatar
Quoted: 12 Post(s)
Liked: 49
The glitches were already there with the original 101R.
The Youtube video with the glitches was uploaded January 20. That's before any upgrade was available.
So why is he insisting that it was after he "upgraded" to 103R?
slprp1 is offline
Reply HDTV Recorders
578 , 999 , Channel Master , dvr+ , maintanance restart , P552UI-B2 , vid posts 576/578 , vizio 4k
