Channel Master DVR+ Owners Thread - Page 143 - AVS Forum | Home Theater Discussions And Reviews
 3367Likes
post #4261 of 14439 Old 07-20-2014, 11:25 AM
phughes200's Avatar
Quoted: 12 Post(s)
Thanks. I got a great deal on the Premiere so decided to try it. If it doesn't work I can Ebay it for more then I paid. The Roamio was too pricey and I was concern about the age of the series 3. My research confirms what you said. It will be a gamble.
I really want to try the CM but since this was a lower cost solution with low risk I decided to try it.
phughes200 is offline
post #4262 of 14439 Old 07-22-2014, 05:23 PM
SEMIJim's Avatar
Quoted: 116 Post(s)
Liked: 53
Lost It's Tiny Little Mind
Went to set up a recurring recording, this evening, and found the only commands the DVR+ would heed were channel up/down and power on/off. Furthermore, when changing channels the PSIP information didn't show. Unplugged for 20 seconds and it was okay again.
Hoping this is not a recurring problem. This is the kind of software glitch that used to drive us nuts with the Panasonic DVD recorders.
Jim
SEMIJim is offline
post #4263 of 14439 Old 07-22-2014, 05:32 PM
Chuck Tribolet's Avatar
Location: Silicon Valley (Morgan Hill, CA and Marina, CA).
Quoted: 20 Post(s)
Liked: 68
Jim
What firmware level?
Chuck
Chuck Tribolet is offline
post #4264 of 14439 Old 07-23-2014, 06:19 PM
SEMIJim's Avatar
Quoted: 116 Post(s)
Liked: 53
Chuck
108R (0.5)
Jim
SEMIJim is offline
post #4265 of 14439 Old 07-23-2014, 08:13 PM
Quoted: 33 Post(s)
Liked: 1
video freezes, power button does not respond
While watching TV on CM DVR+ the video broke up and froze. Changing stations was possible via the remote but only the audio changed. The video remained frozen. Pushing the power button on the front in and attempt to reset the CM DVR+ had no effect. Unplugged CM DVR+ and plugged back in. CM DVR+ and TV viewing continued as normal once the system finished restarting. CM DVR+ is 3 weeks old. Anyone else seen this problem?
noHatNoCattle is offline
post #4266 of 14439 Old 07-23-2014, 09:19 PM
P Smith's Avatar
Quoted: 608 Post(s)
Liked: 320
are you surprised ?
that's "normal" behavior of buggy FW, so you should be tolerant and just do what you did - cold reboot
btw, the issue could be unique to your spot: station equipment, errors by your multipath or a radar or something like that
P Smith is offline
post #4267 of 14439 Old 07-24-2014, 07:17 AM
Quoted: 104 Post(s)
Liked: 34
Real dumb question, I know. And I have searched here and on CM's site before posting.
How does the streaming function work on the DVR+? Does it have apps on it for Netflix, Hulu, Amazon? Like a dummy, I bought a Magnavox MDR533(5?,7?)H DVD recorder to use with OTA only to find out that the output is not HD. I thought that its HQ record mode was the same as HD. I am clearly showing my AVS ignorance here.
I am currently streaming through my Samsung Blu Ray player. Of course, with that there is no recording ability.
So now I'm looking at a DVR+. And with the video streaming function can you record stuff from say Hulu?
matonanjin is offline
post #4268 of 14439 Old 07-24-2014, 07:48 AM
Arenal04's Avatar
Quoted: 117 Post(s)
Liked: 64
Currently, the DVR+ supports only Vudu.
Arenal04 is offline
post #4269 of 14439 Old 07-24-2014, 08:24 AM
Kelson's Avatar
Quoted: 1978 Post(s)
Liked: 1167
Originally Posted by noHatNoCattle View Post
While watching TV on CM DVR+ the video broke up and froze. . . . Unplugged CM DVR+ and plugged back in. CM DVR+ and TV viewing continued as normal once the system finished restarting.
With all devices that have complex firmware, sometimes something just causes a memory leak and you crash a sub-system. It happens -- even TiVo's crash if they run long enough without a reboot. If it's infrequent it's just something to live with. One thing you can do is make it a point to periodically cold boot your DVR's. I have a routine I have stuck to and rarely see a leaking memory crash -- on the first of the month the dog gets its heart-worm pill, its application of FrontLine plus and I reboot the DVR's and the servers.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #4270 of 14439 Old 07-24-2014, 08:56 AM
Kelson's Avatar
Liked: 1167
Yeah, sometimes it's hard to get past the marketing spin on those boxes that makes them sound better than they are. As was noted the DVR+ currently only supports Vudu. If you want a stand-alone DVR (not HTPC) with a large array of streaming Internet channels, you will have to go to TiVo. None of the DVR's allow you to record a streaming channel -- it's a license restriction. But then why would you have to since the purpose of a streaming site is instant access, anytime. If you want to stay in the DVR+ price range, the next choice would be to add a RoKu box for all the streaming channels. RoKu was built for streaming and has the most channels of any box.
If you want to record streaming content to keep, then that is where your Magnavox recorder can find use if you are past the return date. You can capture the SD composite output of the streaming box to the DVD recorder. Most streaming sites use some sort of copy protection to prevent this so you will also have to buy a copy-protection buster box like a Grex or Video Filter to go between the streamer and the DVD recorder. There is more info on this in the DVD Recorder Forum -- look for a poster named DigaDo.
- kelson h
Kelson is offline
post #4271 of 14439 Old 07-24-2014, 10:14 AM
Quoted: 104 Post(s)
Liked: 34
Wow, Kelson thanks for the thoughtful, inclusive reply. And thanks Arenal04.
I have some questions but have to get to Dr.'s appt. Will respond this evening. Thanks to you both again.
post #4272 of 14439 Old 07-24-2014, 12:15 PM
Quoted: 904 Post(s)
Liked: 363
I started the first of the month reboot two months after getting my first TiVo. Since then I have had no unwanted reboots. As for a streaming device, there are over 60 "channels" on my Blu-ray and TV. The Sony BDP-S6200 is a very flexible device at a reasonable price. Crappy remote though.
JoeKustra is offline
post #4273 of 14439 Old 07-24-2014, 09:25 PM
la196's Avatar
Channel Master CM7000PAL Remote
Looking to purchase a working CM7000PAL remote???
la196 is offline
post #4274 of 14439 Old 07-24-2014, 10:36 PM
P Smith's Avatar
Quoted: 608 Post(s)
Liked: 320
seems to me you got no rules at all
- do not cross post (same post in different forums/thread)
- do not post offtopic
- read response to your question and don't repaet same
- etc
P Smith is offline
post #4275 of 14439 Old 07-25-2014, 04:58 AM
wizwor's Avatar
Quoted: 288 Post(s)
Liked: 172
If you want to DVR streaming media, PlayLater is probably the best option right now. I have been lobbying CM to add a Plex channel. That would open a lot of doors.
wizwor is offline
post #4276 of 14439 Old 07-25-2014, 05:26 AM
Liked: 0
CM-7500GB16 hard drive upgrade/install
Has anyone had the opportunity to open up the CM-7500GB16 to see if it is possible to add your own 1tb hard drive to the unit?
-Thanks
mdehass is offline
post #4277 of 14439 Old 07-25-2014, 05:59 AM
SEMIJim's Avatar
Quoted: 116 Post(s)
Liked: 53
-Thanks
Yes: Channel Master DVR+ Owners Thread
mdehass likes this.
SEMIJim is offline
post #4278 of 14439 Old 07-25-2014, 06:35 AM
SEMIJim's Avatar
Quoted: 116 Post(s)
Liked: 53
Week Two Update and a Wish List
It's been two weeks and I believe we've explored pretty much all of the device's capabilities. A couple nights ago we watched something that had already been recorded whilst another show was in the process of being recorded. Last night we watched a show that was still in the process of being recorded. In both cases we arbitrarily rewound, fast-forwarded, paused, played and skipped, both directions, as we desired. The DVR+ performed flawlessly.
Other than the Lost Its Tiny Little Mind software glitch we experienced a couple days ago, the device has performed flawlessly. (Hopefully glitches like that will not become a Regular Occurrence.)
On the two week anniversary, I'd like to offer some minor (?) enhancement requests:
  • Anynet+. It's unclear to me just what Anynet+ is, but it's handy. For all of the DVD and BD players/recorders we've had: Turning them on/off caused the TV to automatically switch to/from that device. It would be nice if the DVR+ supported that protocol.
  • "Fast-ish Forward": I don't know how fast they're forwarding, but our DVD and BD devices have all lately included a "fast" forward that was a "mild" speed-up, allowing you to speed through content but still watch and hear it.
  • Page Up/Down Wrap: When you get to the end or beginning of the Guide: Perhaps a 2nd Up/Down press within a couple seconds could cause the listing to wrap around?
Of course: If CM really wanted to go for some Cool Factor, they could add to that list a DLNA server and mobile device (Android, iStuff and [ugh] WinThings) support
Jim
jjeff likes this.
SEMIJim is offline
post #4279 of 14439 Old 07-25-2014, 07:28 AM
Kelson's Avatar
Liked: 1167
I don't stream from the Internet but my understanding of its attraction is video on demand -- play it when you want it. I'm probably missing something, so could you give me an example of why one would want or need to DVR a streaming channel?
- kelson h
Kelson is offline
post #4280 of 14439 Old 07-25-2014, 07:33 AM
Kelson's Avatar
Liked: 1167
You probably have mentioned this already but what brand/model/size of external HDD are you using?
I know you said you planned on getting a 1TB WD Passport ultra. Is that what you settled on?
- kelson h
Kelson is offline
post #4281 of 14439 Old 07-25-2014, 07:39 AM
wiscojim's Avatar
Quoted: 149 Post(s)
Liked: 238
I can give you the one that is probably the most frequent, annoying, and obvious.
It's this simple: Here today, gone tomorrow.
Streaming content on the internet is only temporary. Providers only offer certain programs for certain time periods and then delete them. Purging of older programs or reshuffling of the programs offered occurs regularly. If you want to archive a whole series of programs for later viewing, you usually have to do it incrementally, catching them when they are available, for fear that tomorrow they won't be available.
wiscojim is offline
post #4282 of 14439 Old 07-25-2014, 07:48 AM - Thread Starter
Aero 1's Avatar
Quoted: 337 Post(s)
Liked: 169
-because licenses expire and are taken down often, facilitates archiving for later viewing, just like a dvr.
-people with caps whose children watch the same cartoon over and over can just record it and stream it locally.
-transfer recordings to phones, tablets without using data.
I use playlater all the time. record it, it automatically gets indexed by plex for later viewing on a TV. playon and playlater are hooked into my tivo with pytivo so i can initiate a recording of anything that those two pieces of software support.
Cord Cutter | OTA - NYC DMA - 6 TB TiVo Roamio - 3 TiVo Mini's | Plex Pass | Netflix | Hulu | Amazon Prime | MLB.tv & MLS Live with No Blackouts!
Aero 1 is offline
post #4283 of 14439 Old 07-25-2014, 07:53 AM
SEMIJim's Avatar
Quoted: 116 Post(s)
Liked: 53
Yup. Works like a champ
Jim
SEMIJim is offline
post #4284 of 14439 Old 07-25-2014, 08:24 AM
Kelson's Avatar
Liked: 1167
Got it. That is what I was missing.
- kelson h
Kelson is offline
post #4285 of 14439 Old 07-25-2014, 09:10 AM
wizwor's Avatar
Quoted: 288 Post(s)
Liked: 172
Generally, it's easy to record OTA content. This DVR+ is the best set top DVR not sold by TiVo. The Simple and Tablo DVRs are great for recording programs non-interactively. You can easily download files from the DVR+ and Simple DVRs for playback away from your DVR (DVR+) or when there is not internet (Simple).
PlayOn is a server that streams content from the internet to a set top or portable device. PlayLater is a program that lets you save this content as MP4 files which can be played when you have insufficient internet access. You can learn more at http://playon.tv and http://playlater.tv.
Personally, I prefer set top + whole house DVR. I have a DTVPal on five tvs in my home and six Simple DVRs in my basement. This provides for a great interactive experience (pause/rewind/fast forward/slow motion with video preview) plus intelligent program collection and remote access.
If all you have access to is streaming TV, PlayLater will easily record programs for you in 720p. For a one time fee of $40, I think this makes more sense that recording A/V out to another DVR. Reasons you may want to record streaming media...
- your internet access is unreliable during prime time
- you want to watch something on an airplane or in a car
- you want to watch something at work
I posted the tip in response to discussion of whether the DVR+ could record streamed content (it can't) in which it was suggested that plugging a DVR into a streaming device was an option. I offered PlayLater as an alternative.
wizwor is offline
post #4286 of 14439 Old 07-25-2014, 09:30 AM
Quoted: 104 Post(s)
Liked: 34
And one more reason, my main reason, for "time shifting" to avoid commercials. Even though Hulu and others don't have nearly as many commercials as network, which can be 5 minutes at a time. I still like to record and then skip through them. We may start watching the show while is still recording. But we'll delay it just enough so we can "chase it" skipping commercials.
post #4287 of 14439 Old 07-25-2014, 10:06 PM
Primestar31's Avatar
Quoted: 92 Post(s)
Liked: 55
A SERIOUSLY big issue with PlayLater is that it's impossible to do a "scheduled recording".
We have been begging MediaMall to add that feature, and they have not done so as of yet. That one missing feature makes it almost worthless as a perfect "dvr" type program.
Primestar31 is offline
post #4288 of 14439 Old 07-26-2014, 03:36 AM
wizwor's Avatar
Quoted: 288 Post(s)
Liked: 172
Definitely a worthwhile feature. Recording a file at night or during working hours for viewing in prime time can alleviate a lot of congestion/performance concerns. I don't think lack of that program renders PlayLater worthless by any means.
Some guy has posted a workaround here...
http://www.playon.tv/forum/help/play...#comment-38943
wizwor is offline
post #4289 of 14439 Old 07-26-2014, 02:19 PM
LloydSoCal's Avatar
Quoted: 14 Post(s)
Mine just dropped dead
Originally Posted by P Smith View Post
are you surprised ?
Mine's 2 Weeks old, all of a sudden nothing worked. It just plain dropped dead. I contacted Tech Support and wound up changing Batteries (no solution), but the suggestion to "warm? boot solved the problem. Still, everything is slow as Molasses on Ice to get responses after pressing a Remote Key. I suspect that an underpowered CPU is really behind it. LloydSoCal
LloydSoCal is offline
post #4290 of 14439 Old 07-26-2014, 02:25 PM
LloydSoCal's Avatar
Quoted: 14 Post(s)
I have the Passport too, but
I learned from CM Tech Support that they do not support anything except 2 specific Seagate Model HHDs. So (not knowing that I needed to visit the Site to learn that before ordering from Amazon) I decided that the WD Drive made more sense. So, be aware if you depart from the "supported" Drives.
Reply HDTV Recorders
578 , 999 , Channel Master , dvr+ , maintanance restart , P552UI-B2 , vid posts 576/578 , vizio 4k
