Channel Master DVR+ Owners Thread - Page 146 - AVS Forum | Home Theater Discussions And Reviews
 2778Likes
post #4351 of 12342 Old 08-01-2014, 06:46 PM
Sandman905's Avatar
Quoted: 29 Post(s)
Liked: 33
Originally Posted by artisticimaging View Post
Not having trouble with the wrong show being recorded, but I gave up on the Record all programs with this same name. It would work for two weeks and then would stop so I gave up on the Auto record and went to the Manuel Record. My ROVI is updating everyday so I don't think it is cause by that. It is possible your issue is from the ROVI check how often it updates.
I still have the Video Glitches with my Seagate Hard Drive and I am using the 108.
I agree, my experience is that Record by Name works for a while and then stops. I've found when this happens the DVR+ appears to have reset itself as indicated by the Session Time on the second STB Health Screen under Technical Info.
Just remember to edit the default "Manual Recording" name to indicate which program your are recording and to set the Repeat option correctly.
I've never noticed any video glitches from my Seagate drive which is one of the ones recommended by CM.
artisticimaging likes this.
Sandman905 is offline
post #4352 of 12342 Old 08-01-2014, 07:52 PM
Quoted: 33 Post(s)
Liked: 1
playback picture breaks up 5 - 30 seconds
I've owned my DVR+ with Seagate 1TB USB external disk for about a month. Occasionally while playing back a recorded program the picture breaks up for between 5 - 30 seconds. I don't think this is a reception problem because watching the station in real-time never breaks up. This is unacceptable. Can you imagine if this was a recording of the super bowl that you had watched for 3 hours and you weren't able to watch the last 30 seconds of a goal line situation that determined the results of the game??
Any suggestions of my path to a solution?
noHatNoCattle is offline
post #4353 of 12342 Old 08-01-2014, 08:46 PM
P Smith's Avatar
Quoted: 412 Post(s)
Liked: 253
get WDC drive
P Smith is offline
post #4354 of 12342 Old 08-02-2014, 09:43 AM
artisticimaging's Avatar
Quoted: 138 Post(s)
Liked: 72
What happens if you replay that spot?
artisticimaging is offline
post #4355 of 12342 Old 08-02-2014, 10:23 AM
SEMIJim's Avatar
Quoted: 116 Post(s)
Liked: 53
Originally Posted by LenL View Post
So you really don't know until you put an antenna up and give it a try.
That can be an expensive proposition for something that may not work out. I don't recall what I paid for it, seven years ago, but the Winegard HD7078P VHF/UHF "medium" antenna I bought was not exactly cheap. Nor was the high-quality low-noise mast-mounted preamp I tried.
I think that if I were in blackbeasst's shoes, I'd call around and see if there was anybody that would contract to put up an antenna with a certain level of guaranteed results, before I'd go making $200-$300, or more, guesses.
blackbeasst: You might be better-served by moving your reception/antenna questions over to the geographically proper thread in the Local HDTV Info and Reception forum.
Jim
SEMIJim is offline
post #4356 of 12342 Old 08-02-2014, 03:45 PM
Quoted: 33 Post(s)
Liked: 1
I have a 1 hour recording which was recorded yesterday using the "record all with this name" option (not manual). It starts breaking up at the 15 minute mark and continues to the end. I reset to the front and played back through the program recording. It has the same picture breakup at the 15 minute mark.
Is this is a "feature" of "record all with this name"? Maybe there are no problems if done with "manual recording" ???
post #4357 of 12342 Old 08-02-2014, 03:54 PM
Aleron Ives's Avatar
Quoted: 1469 Post(s)
Liked: 1179
The fact that the playback error occurs every time at the same spot means that you had a reception problem during that time. You can determine if a breakup is caused by the firmware glitch by playing the same footage more than once. If it plays fine the second time, the glitchy playback was caused by the firmware, rather than poor reception.
Aleron Ives is offline
post #4358 of 12342 Old 08-02-2014, 03:58 PM
Quoted: 138 Post(s)
Liked: 72
No not a feature of auto record. This is a new issue. In the Video Glitch thing it plays back okay the second time. I don't know what to tell you other then see if you can check the Hard Drive or call CM.
post #4359 of 12342 Old 08-02-2014, 05:51 PM
Quoted: 33 Post(s)
Liked: 1
No x4 on fast forward/reverse
I have x2, x8, x32 and x64 speeds for fast forward/reverse. Sure would be nice if there was x4 !! How can CM skip x4?? Is this just mine ??
post #4360 of 12342 Old 08-02-2014, 07:04 PM
Quoted: 33 Post(s)
Liked: 1
Originally Posted by P Smith View Post
get WDC drive
The Seagate drives recommended by CM don't work ?
post #4361 of 12342 Old 08-02-2014, 09:59 PM
Liked: 1179
Seagate and Western Digital have a longstanding rivalry. WD seems to have pulled ahead in recent years, but you can always potentially get a lemon when you buy a mechanical device, regardless of which brand you choose.
post #4362 of 12342 Old 08-02-2014, 10:00 PM
P Smith's Avatar
Quoted: 412 Post(s)
Liked: 253
it's just Green or Purple (more expensive) drives are AV-GP and by many reports working better
[you never know what kind of relationship between CM and Seagate to procure CM's choice]
P Smith is offline
post #4363 of 12342 Old 08-03-2014, 06:28 AM
SEMIJim's Avatar
Quoted: 116 Post(s)
Liked: 53
I can't speak to that, but, over many years in I.T., I've generally felt something other than Seagate to be the better choice. Currently I prefer Western Digital.
TBH: It never even occurred to me that CM had tested/recommended USB drives. I just went out and bought the current iteration of what's been working for me, in a backup role on my home server, for 2-1/2 years.
Jim
SEMIJim is offline
post #4364 of 12342 Old 08-04-2014, 07:59 AM
Quoted: 20 Post(s)
Liked: 2
Originally Posted by dlflannery View Post
So .... for scheduled recordings you have to manually aim the antenna at either Bakersfield or Fresno ahead of time? Seems kind of cumbersome.
Luckily the azimuth of the Fresno stations is near 180 degrees from the azimuth of the Bakersfield stations. So the antenna picks them both up... one on the front and the other on the backside. But you're right about the issue... I do have to rotate if I want to guarantee the best signal in all conditions.
t_f_s is offline
post #4365 of 12342 Old 08-04-2014, 04:58 PM
trp2525's Avatar
Liked: 58
Originally Posted by la196 View Post
Looking to purchase a working CM7000PAL remote???
http://www.ebay.com/itm/280784044482
trp2525 is offline
post #4366 of 12342 Old 08-04-2014, 05:55 PM
OTAhead's Avatar
Quoted: 12 Post(s)
I found a glitch in the grid recording this week... I used the guide to record EXTANT this past week, which in the guide showed to be on between 8 and 9 CDT. In the meantime, the network moved EXTANT to the 9 to 10 CDT time slot. The DVR did not correct the time. It recirded the replacement show in the 8 to 9 time slot as originally scheduled and not EXTANT. I have been following this thread for awhile, and I don't recall seeing this particular situation before, but please correct me if that is not the case. Anybody else run across this? I ended up having to stream the episode using a Verizon wi-fi hotspot which only has 5 gigs of data access...
You never know where the LIMIT is until you EXCEED it... Dianne B. "Let's try that again... without the oops." (Will Smith and Jeff Goldblum in "Independence Day")
OTAhead is offline
post #4367 of 12342 Old 08-04-2014, 06:16 PM
Quoted: 37 Post(s)
Liked: 2
Cool Discrete ON/OFF codes
With the help of IrScrutinizer, was able to create discrete on and off commands:
POWER ON: 47
POWER OFF: 46
According to Channel Master the commands are:
Discrete On 0x37 (Function 55 Decimal)
Discrete Off 0x38 (Function 56 Decimal)
But, the CM commands did not work for me.
idoug is offline
post #4368 of 12342 Old 08-04-2014, 06:19 PM
la196's Avatar
Originally Posted by trp2525 View Post
@trp2525 According to the people at Channel Master, the only remote they say will work is theirs which they are out of production. Are you suggesting this DISH remote would be compatible? They said a universal remote won't work. If you're fairly sure it's compatible I'll go buy the one from the link to eBay.
la196 is offline
post #4369 of 12342 Old 08-04-2014, 07:11 PM
mishmosh's Avatar
Thanks for posting. I thought my DVR+ was back to recording the wrong channel again. I didn't know Extant was shown an hour later.
mishmosh is offline
post #4370 of 12342 Old 08-04-2014, 07:22 PM
trp2525's Avatar
Liked: 58
Obviously the people at Channel Master don't know what they are talking about. They should do more reading here at AVS Forum to get an education about their own products.
Do a thorough search of this thread and the Dish DTVPal DVR/Channel Master CM-7000PAL DVR thread and you will see that the Dish 20.1 learning remote is a direct replacement remote (or as close as you will find) for both the Dish DTVPal DVR and the Channel Master CM-7000PAL DVR. It can also be used with the Channel Master DVR+ (some people like it much better than the original remote that comes with the DVR+). Some posters in both threads have also posted extensive programming tips and suggestions for use of the Dish 20.1 learning remote with these DVRs. Plus $6.75 with free shipping is not a bad deal at all!
The original Dish DTVPal DVR remote is on the left and the Dish 20.1 learning remote is on the right in the attached picture. The Channel Master CM-7000PAL DVR came with the same remote as the Dish DTVPal DVR but it was black in color instead of silver.
Name:	Dish 20.0 IR Remote.jpg
Chuck44 likes this.
trp2525 is offline
post #4371 of 12342 Old 08-05-2014, 03:48 AM
frank70's Avatar
Quoted: 92 Post(s)
Liked: 76
And not only is it compatible with the the PAL, it works (for the PAL) out-of-the-box (no learning or programming required) when the SAT button is pressed. Mine has the AUX mode programmed for the DVR+, so I can control both (though I don't because I have the original PAL remote too).
Not quite sure how this topic drifted over to this thread - probably best to take it back over there.
frank70 is offline
post #4372 of 12342 Old 08-05-2014, 10:15 AM
terrykuntz's Avatar
Discrete on and off codes
POWER ON: 47
POWER OFF: 46
Can you please explain how to use these codes? I have a MX-850 remote controller. How do program that to accept the Discrete and on and off codes? This device will accept the Pronto hex codes, do you know those codes are?
terrykuntz is offline
post #4373 of 12342 Old 08-05-2014, 03:05 PM
Liked: 1179
It's a risk you take when relying on a guide for your recordings. If the guide is wrong, you'll miss them. This is especially true if your guide data only gets refreshed once a week or every few days, as sudden schedule changes won't be reflected in the old guide data. Even TiVo has this problem sometimes, depending upon how sudden the schedule change is.
post #4374 of 12342 Old 08-05-2014, 03:13 PM
jjeff's Avatar
Quoted: 588 Post(s)
Liked: 206
Yes I've had the same thing happen with my Tivo that only updates it's guide ~ every 30 hrs.
Note it's not just name based or guide recordings that would be effected by a schedule change, time or VCR based recordings would be the same thing(even worse since they don't update, ever). If you programmed Extant a week ago to record at 8-9pm and the network moved it to 9-10pm you'd still miss it
jjeff is offline
post #4375 of 12342 Old 08-05-2014, 03:16 PM
Charles R's Avatar
Liked: 406
True. But I think you can rate various vendors on how accurately (quickly) they update their guides. I know in this case WMC reflected the change. And it certainly wasn't a last minute change.... perhaps other DVR+ users were updated... of which I'm guessing.
| Mitsubishi HC7900DW Projector | 16x9 120" Screen | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 (on order) & AudioSource AMP110 | NVIDIA Shield | 20TB Media Server | TiVo
Charles R is offline
post #4376 of 12342 Old 08-05-2014, 03:33 PM
Quoted: 33 Post(s)
Liked: 1
Looking for good antenna for Fremont CA
If you're located in Fremont CA or nearby and your DVR+ antenna pulls in all the local stations without drop outs I'd be interested in knowing what antenna you're using, if you use a pre-amp, how high is your antenna and how long the cable is between your antenna and the DVR+.
My directional antenna points to San Francisco where most of the nearby TV towers are.
Channel 36 KICU drops out all the time. The KICU tower is 3 miles away in San Jose, 120 degrees away from where my antenna points.
KRON channel 4, drops out occasionally. The KRON tower is 36 miles away in San Francisco. The antenna level is 47 and antenna quality is 100 for KRON.
Considering I have a large directional antenna, 20 feet high, pointing at KRON, that's only 36 miles away, I'm surprised the antenna level is only 47. Maybe I need a pre-amp. My cable is 30 feet between the antenna and the DVR+ and on a 2 way splitter.
post #4377 of 12342 Old 08-05-2014, 04:18 PM
la196's Avatar
I ordered two of them last night! I have my original CM7000PAL box and remote that I bought brand new from Channel Master around 4 years ago which is still working perfectly. I finally decided to purchase a second CM7000PAL box and remote on eBay two weeks ago and unfortunately the remote doesn't work which was a bummer because I paid 300.00. Oh well.
Even though my original remote still works I still went ahead and bought two of these remotes you have recommended. Looking forward in receiving them. I'll give a quick reply back once they arrive.
I'm glad to be able to have them Thanks again.
BTW--nice bonus that it's good to go out of the box too!
la196 is offline
post #4378 of 12342 Old 08-05-2014, 05:46 PM
Liked: 1179
I recall reading that the DVR+ would only update its Internet guide weekly by default, in which case it would be far more vulnerable to schedule changes than a TiVo, which updates multiple times each week. I could be wrong about the interval, though.
It is true that both name-based and time-based recordings are vulnerable to schedule changes, but at least if you're using timers, you expect that you'll have to make adjustments. The general reliability of name-based recording trains you not to check up on your DVR, so when a recording is missing, it comes as more of a surprise.
post #4379 of 12342 Old 08-06-2014, 04:42 AM
SEMIJim's Avatar
Quoted: 116 Post(s)
Liked: 53
The MX-850 is a learning remote, just like my MX-500. So why not just teach it from the original? That's what I did. Works like a champ!
Jim
SEMIJim is offline
post #4380 of 12342 Old 08-06-2014, 08:29 AM
Quoted: 37 Post(s)
Liked: 2
Cool
Every remote controller system, like AV equipment, is different. I am not familiar with the MX-850. Learning remotes can only learn from the existing buttons on the teaching remote. The DVR+ has a power toggle button. But, it does not have a power on or off buttons. This is your opportunity to learn how to program your remote. Search the Internet and support pages to find out how to programmatically add device commands to macros.
If your remote system can send and receive commands via your local network, the irScrutinizer http://www.harctoolbox.org/ is a great tool for translating the device command to your remote control system.
I use RoomieRemote and it does an excellent job of knowing if a device is on or off. However, I still like being able to press one button and know all my devices will be turned off. You cannot do this with a power toggle function. You need to know each devices discrete power off command.
idoug is offline
Reply HDTV Recorders
578 , 999 , Channel Master , dvr+ , maintanance restart , P552UI-B2 , vid posts 576/578 , vizio 4k
taboola here
