Channel Master DVR+ Owners Thread - Page 265 - AVS Forum | Home Theater Discussions And Reviews
 3548Likes
post #7921 of 14923 Old 03-24-2015, 01:23 PM
pachinko's Avatar
Quoted: 858 Post(s)
Liked: 449
Originally Posted by P Smith View Post
Sorry to pick your post - just grabbed "end point of the chain" - you guys AMUSED me with your guesswork !
Instead of fixing on letter in names, you MUST get VID_/PID_ and just verify against existing table of USB WiFi adapter's IDs in THE thread.
Not models, not chips (well it's good to know if it has right one), not letters...
Just 2+2 hex numbers.
Been trying, but can’t find a post with VID_/PID_ values (other than post 2071, not by you, with one set of values). Only find your post 576 where you state “I see in FW 101R, they have a driver for support only Realtek Rtl8192cu adaptor”.
I don’t know where to find a VID_/PID_ number. It’s not on the packaging, or listed in Windows Device manager (although it may be under one of the numerous obscure “properties” that I haven’t checked).
Please advise.
Last edited by pachinko; 03-24-2015 at 06:15 PM. Reason: Wrong page referenced. Changed 271 to 2071.
pachinko is offline
post #7922 of 14923 Old 03-24-2015, 02:41 PM
Quoted: 920 Post(s)
Liked: 368
Your right chance to say : BINGO !
I'm sure everyone is glad you are amused. The PID for the RTL8811AU is PID_8811&REV0000, and for the RTL8812AU the PID is PID_8812&REV0000. Doesn't seem very important. I already posted the VID, but here it is again: VID_0BDA.
JoeKustra is offline
post #7923 of 14923 Old 03-24-2015, 02:44 PM
Quoted: 920 Post(s)
Liked: 368
Originally Posted by pachinko View Post
Been trying, but can’t find a post with VID_/PID_ values (other than post 271, not by you, with one set of values). Only find your post 576 where you state “I see in FW 101R, they have a driver for support only Realtek Rtl8192cu adaptor”.
Please advise.
Use the Realtek driver. The numbers are under Properties, Details, Hardware Ids. Even money says the PID has 8192 in it.
pachinko likes this.
post #7924 of 14923 Old 03-24-2015, 05:35 PM
pachinko's Avatar
Quoted: 858 Post(s)
Liked: 449
Thanks Joe! The PID for both of my Realtek Rtl8192cu WiFi adapters is 8178, rev 020, and VID_OBDA. Both work perfectly on the DVR+.
Name:	Pachinko - Realtek Rtl8192cu - VID_OBDA - PID_8178 Rev_0200.jpg
pachinko is offline
post #7925 of 14923 Old 03-24-2015, 06:30 PM
Quoted: 920 Post(s)
Liked: 368
That's great. My 8812AU driver disk supplies drivers for the 8178 also. Same VID. But you don't need an 802.11ac adapter. The 8811 is great for laptops however. Have fun.
post #7926 of 14923 Old 03-24-2015, 07:09 PM
pachinko's Avatar
Quoted: 858 Post(s)
Liked: 449
The only reason this WiFi adapter is plugged into Windows is to view the VID and PID for this discussion (the PC has built-in WiFi). I didn't install any software, Windows 8.1 just recognized the device and that's what it set up! As soon as I got the info, I moved the device back to the DVR+ where it lives quite happily!
pachinko is offline
post #7927 of 14923 Old 03-24-2015, 10:07 PM
P Smith's Avatar
Quoted: 668 Post(s)
Liked: 339
Now you did amuse me. If you could read back around that time when we digged into wifi adapters compatible with the K77 and check how drivers(SW) do enumerating, you'll know what part of the id string is relevant. So, it would be helpful to pick relevant and pertinent numbers.
P Smith is offline
post #7928 of 14923 Old 03-24-2015, 10:15 PM
P Smith's Avatar
Quoted: 668 Post(s)
Liked: 339
Yeah, no need to install drivers if you need only id string.
P Smith is offline
post #7929 of 14923 Old 03-25-2015, 07:57 AM
Quoted: 162 Post(s)
Liked: 121
Originally Posted by Dee Barvo View Post
It's T-Mobile, I'm on 3G. When you live out in the country, nobody can afford to run cable to homes on 5 acre lots. Phone cable is too far from the equipment, so that won't work; other than Dial up. I doubt we ever get 4G, they'll spend the money where they have lots of customers and get the money back.
How is your computer connecting to the Internet now? Dialup? Or, are you using a T-Mobile USB connection?
If either of these, your computer will usually act as the router for the rest of your home network, since all devices must go through the PC to get to the internet. The Windows network setup wizards might help you with this. I've never set up a PC as a router myself.
Then, all you need is any ol' wireless router that you set up as an access point connected to your computer's Ethernet port.
Just a bit of jargon (apologies of you already know this): The router is like the traffic cop of your network. It routes traffic from one device to another, or from one device to the wide area network (Internet). The router is the device connected to your network that is running the DHCP server (Dynamic Host Configuration Protocol server). You only want one router on your home network (unless you are doing something more complicated than a simple home network). To configure a wireless router to be an access point, all you do is go into the configuration screen for the device and select "access point" (if that choice is given), or disable DHCP Server (if the configuration screen is a bit more primitive).
RTPVid is offline
post #7930 of 14923 Old 03-25-2015, 02:32 PM
Donald1800's Avatar
Quoted: 24 Post(s)
Liked: 35
I'm sorry this isn't a good experience for you. I can state that the RTL is a Realtek device. I have two that are sold as PremierTek. Since I have them in a heavy duty application, they would be overkill if used for the light use of the DVR+. From my experience a device needs to be designed to accept a USB network adapter, like the DVR+. I don't have any device like that except my two computers. I have CAT5 to WiFi adapters used on my AVR, Blu-ray, and TiVo. To use these adapter a PC is needed to configure the SSID and password. They then "look" like wired connections. I don't have experience using USB devices that do not need to be configured, so others on this thread need to help you find the problem. Best of luck.
I too MUCH prefer Ethernet WiFi adapters as they are fool proof, faster and a universal solution for overpriced adapters that have only one driver installed (NOT able to download a device driver) such as the DVR+. I have used the ASUS N66 with great success and no problems with my older Sony Blu-Ray player without a built-in WiFi system. Expensive (buy a re-certified unit) but very good in all applications. Easy to set up with the newer updated software.
Donald1800 is offline
post #7931 of 14923 Old 03-25-2015, 02:51 PM
Quoted: 920 Post(s)
Liked: 368
The ASUS EA-N66r is the best unit I have found so far. I have tried the Linksys - not so good. There is new software, "p", for the unit. I have no problem with my older Sony either, only on the new 2.4GHz BDP-S6200. For my desktop though, the Realtek (PremierTek) RTL8812AU is nice. I have it on an 18" extension, which should be USB 3.0 if you're OCD like me. I like the 867Mbps link speed. I'm not too happy with the Netgear EX-6200 but it does support everything. Just not as much power. It would be ok with the DVR+ (and four more wired devices at once).
post #7932 of 14923 Old 03-25-2015, 04:46 PM
Quoted: 36 Post(s)
Liked: 4
It's the T=Mobile connection. Supposedly my Lenovo laptop has a WIFI transmitter. But it's Win8, so everything is hidden. You need to know how those morons in Redmond put it together, which is not simple.
I'd love to find the autistic clowns at MS that put 8 together, and beat the living **** out of them; repeatedly.
Dee Barvo is offline
post #7933 of 14923 Old 03-26-2015, 11:48 AM
Quoted: 186 Post(s)
Liked: 44
Over-priced, fast-crapping remotes
Originally Posted by JHBrandt View Post
Sony used to make an 8-device learning remote (model RM-VL600) that could be programmed with macros. A few years ago, I bought one at Target for under $30 and was amazed by all its features. Unfortunately Sony doesn't make it anymore. You can still find some on Amazon, but the prices for new ones have gone up over $40. (There is a used one being offered for under $20.)
Well, you don't have to follow his mapping exactly. Personally, I map the DVR+ Back button to the 20.1 Recall button and the DVR+ Exit button to the 20.1 Cancel button...
Yes, I assumed I wouldn't need to map it the same way. You're right, the Recall button makes perfect sense, as in recall previous channel and recall previous screen, and so forth. Too bad if they've really stopped making fairly priced learning/macro remotes. Thanks for the info.
Originally Posted by chazdole View Post
... My Harmony remotes lasted just a little over 2 years before a few buttons started not working reliably. I've tried cleaning them to no avail. There is a compound ($29) you can buy to paint onto the contacts to restore their functionality, not sure how well that would hold up... How is it that you can buy a $10 keyboard that will last 10 years, but $30-$100 and up remotes crap out after 2?
That's hilarious! I wouldn't wanna pay more than $29 for a remote! Honestly, the only reason they're selling remotes for $100 or more is because there is
"one" born every minute.
artisticimaging likes this.
[Signature not found -- or just not clever enough.]
SirCrow is offline
post #7934 of 14923 Old 03-26-2015, 12:46 PM
jakep_82's Avatar
Quoted: 18 Post(s)
Originally Posted by SirCrow View Post
That's hilarious! I wouldn't wanna pay more than $29 for a remote! Honestly, the only reason they're selling remotes for $100 or more is because there is "one" born every minute.
Or perhaps you live alone and don't have a complicated home theater setup. Try running a TV, AVR, DVR, Blu-Ray, OTT streamer, and game console all from a cheap universal remote. Then try teaching your less technically inclined significant other and children how to use each of those devices from that crappy remote. I'll spend $100 all day long to avoid that frustration. Harmony remotes are worth their weight in gold.
promike, Kelson, blakepro and 1 others like this.
jakep_82 is offline
post #7935 of 14923 Old 03-26-2015, 12:48 PM
Quoted: 35 Post(s)
Originally Posted by davebmck View Post
I bought the E-more brand. It had pretty good reviews and included a coaxial audio output. I'll post the results when I get everything hooked up.
I got my DVR+ setup today and said I would comment on the E-more HDMI to component converter. I bought this one: http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1 and it seems to work fine. Granted I'm not videophile, but it looks as good or better than what I was getting out of my satellite receiver.
Now I have another problem. The unit is not recognizing the wireless adapter. I bought this one which was recommended in this thread: http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1 I was reading elsewhere in the thread about how to check its properties on my computer, but my computer will not recognize it. When I plug it in, it says its installing a driver, but then that fails and the devise does not show up under the Computer map. I managed to cut the included disk in half when opening the packaging and I have not been able to locate a driver anywhere on the internet. Anyone have any idea how I can find out if this thing is the correct version and working?
davebmck is offline
post #7936 of 14923 Old 03-26-2015, 01:01 PM
Quoted: 920 Post(s)
Liked: 368
Look here: The numbers are under Properties, Details, Hardware Ids. It will probably be an unknown USB device. Just scroll down using Device Manager. What version Windows? Check the VID list in post 576.
post #7937 of 14923 Old 03-26-2015, 01:33 PM
pachinko's Avatar
Quoted: 858 Post(s)
Liked: 449
I’m not 100% certain about this, so use your judgement, but below is the RealTek URL for driver downloads. Search the page for 8192CU (see attached screenshot).
http://www.realtek.com/downloads/dow...Downloads=true
FYI, my mini-disc is labeled “RTL8188CU/8192FEB28”. That’s what I Googled. Check your disc and Google that.
Good luck!
pachinko is offline
post #7938 of 14923 Old 03-26-2015, 01:34 PM
Quoted: 35 Post(s)
Thanks Joe, I found the info there. It shows:
USB\VID_0BDA&PID_818B&REV0200
I believe that matches the numbers others have posted here. So why is the DVR not recognizing it? I have tried it in both USB ports and the external drive is working on one of them now.
davebmck is offline
post #7939 of 14923 Old 03-26-2015, 01:36 PM
pachinko's Avatar
Quoted: 858 Post(s)
Liked: 449
Good luck!
Name:	Realtek RTL8192CU WiFi Dongle Driver Download.jpg
pachinko is offline
post #7940 of 14923 Old 03-26-2015, 01:43 PM
Quoted: 35 Post(s)
Nothing much on the disk, just Wireless-N USB Adapter and 8192EU18JUL. Ok, I see the 8192 is common and there is a date. I can give the Realtek driver a try, but I was able to find the VID and PID following Joe's suggestion to use Device Manager.
davebmck is offline
post #7941 of 14923 Old 03-26-2015, 01:56 PM
Arenal04's Avatar
Quoted: 117 Post(s)
Liked: 64
No guarantees, but 2 things you can try. First is a soft-reset. With the DVR+ in "standby" mode (what we would call "off") hold down the power button until the color changes from blue, then release the power button. Second is a hard reset. With the DVR+ in standby mode, disconnect the power cable. Wait 10 minutes, then plug the power cable back in. The DVR+ will go thru its motions for a few minutes, then be ready for use.
As to whether or not to have the WiFi adapter plugged into the DVR+ when doing either procedure, I couldn't say. Try it both ways.
Arenal04 is offline
post #7942 of 14923 Old 03-26-2015, 02:09 PM
pachinko's Avatar
Quoted: 858 Post(s)
Liked: 449
I don't see PID_818B on post 576 or 578. On post 7997, Paul210 reports problems with model 8192EU.
pachinko is offline
post #7943 of 14923 Old 03-26-2015, 02:28 PM
JHBrandt's Avatar
Quoted: 1803 Post(s)
Liked: 863
Originally Posted by MKS13 View Post
The wifi adapter that I'm using shows up as RTL8192CU Not RTL8192EU.
Not sure what the difference is but it probably explains why it isn't working with DVR+.
There are numerous posts about people looking for help on compiling drivers for the "EU" model VS the 'CU"
(the postings have nothing to do with the DVR+).
The link you posted shows the adapter that I'm using.. it has a small hole in the face right below the writing and the sides are indented.. Is that what yours looks like?
Originally Posted by Paul210 View Post
Mine looks exactly like that. Apparently there are different versions even though I ordered it from the same link on Amazon that others used.
I'm sorry this isn't a good experience for you. I can state that the RTL is a Realtek device....
Sounds like Paul and Dave both got the "new and (dis)improved" 8192EU that no longer works with the DVR+. I updated my review at the Amazon link to reflect this I suspect the EU is too new to have its driver included in Win 8, hence the inability to use it on a PC without that driver disk/download.
I still have one unused 8192CU. I sold my "official" DVR+ WiFi adapter on eBay, used most of the proceeds to buy two Realteks (back when they were selling the CU model that works), then sold one of those on eBay I'm using power-line Ethernet adapters with my DVR+ and I have a different WiFi adapter for my PC, so I'm not using the Realtek.
JHBrandt is offline
post #7944 of 14923 Old 03-26-2015, 02:31 PM
Quoted: 35 Post(s)
Tried soft and hard resets with no improvement. But thanks for the suggestion.
davebmck is offline
post #7945 of 14923 Old 03-26-2015, 02:34 PM
Quoted: 35 Post(s)
Right, I see 818A, but no B. the 8192EU is on the software disk, but I don't see it anywhere on the hardware info. How are you supposed to know what you have? For that matter, how do you know what your buying?
Paul210 and JoeKustra like this.
davebmck is offline
post #7946 of 14923 Old 03-26-2015, 02:40 PM
JHBrandt's Avatar
Liked: 863
It's confusing. Machines (like the DVR+ or a PC) look at the PID, not the model #; so you'll see the PID in Device Manager. Apparently:
  • PID_818A is model 8192CU
  • PID_818B is model 8192EU
... and only PID_818A works with the DVR+
Update: Looks like Amazon has switched back to GateShop as its "featured" seller for this adapter. GateShop sold the 8192CU's that work; unfortunately, Amazon says they only have 20 left.
I'd advise anyone else buying these to confirm they're buying from GateShop; otherwise, there's a good chance you'll get the 8192EU that doesn't work.
JHBrandt is offline
post #7947 of 14923 Old 03-26-2015, 02:41 PM
Quoted: 35 Post(s)
Looks like I'm going to re-order this. I found this one on Amazon: http://www.amazon.com/300Mbps-Realte...ords=RTL8192CU It specifically mentions the 8192CU chipset, so maybe I won't get burned again.
Paul210 likes this.
davebmck is offline
post #7948 of 14923 Old 03-26-2015, 02:51 PM
Quoted: 35 Post(s)
Do you guys think this one will work: http://www.amazon.com/Adapter-Wirele...ltek+RTL8192CU The Realtek one is 7 to 15 days shipping and this one is available for Prime. It mentions the 8192CU chipset and has pretty good reviews.
davebmck is offline
post #7949 of 14923 Old 03-26-2015, 04:26 PM
Paul210's Avatar
Quoted: 23 Post(s)
Liked: 31
I just requested a return on the 3 I purchased from UCOOL stating that none of the ones with the Realtek RTL8192EU Chipset will work with my intended application. We'll see if they let me return them. If not, at least it wasn't a lot of money.
Regarding P Smith's chastising me for not including PID, etc., that's not exactly something the seller discloses when you purchase an item. How the hell was I supposed to know what it was in advance of my purchase? I simply used the same link to an item others said worked for them. Sheesh! Get a grip, buddy! I know you've helped members on here quite a bit, but it seems you spend most of your time berating them.
Panny Plasma Relic: TC-P50VT20, TC-P50G15, TH-42PX60U
Paul210 is offline
post #7950 of 14923 Old 03-26-2015, 04:45 PM
pachinko's Avatar
Quoted: 858 Post(s)
Liked: 449
Like JHBrandt says on post 8038, the PID and VOD data can be found in the Windows Device manager, on the Details tab for the device (see post 8015 for a screenshot). The model number should appear in the device name.
The only way I can see how to know what we're buying is to ask the seller to supply the VID and PID, hope they know, and respond.
pachinko is offline
Reply HDTV Recorders
578 , 999 , Channel Master , dvr+ , maintanance restart , P552UI-B2 , vid posts 576/578 , vizio 4k
