Channel Master DVR+ Owners Thread - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 3367Likes
Old 01-09-2014, 03:29 PM
DD24's Avatar
Originally Posted by JHBrandt View Post
ffmpeg -i dvr+file.ts -vcodec copy -acodec copy goodfile.ts
You are the STAR!! (along with Kelson and P Smith) That did it.  It took about 1.5 minutes running the 64 bit version of ffmpeg on my Windows 8 machine with an i7 processor to copy the 30 minute ts file but the resulting file runs without problems on VLC and PowerDVD.  Good job!
DD24 is offline
Old 01-09-2014, 03:46 PM
mickinct's Avatar
Quoted: 205 Post(s)
Liked: 902
HAS anyone tried mutiAVCHD ?
MickinCT
mickinct is offline
Old 01-09-2014, 03:49 PM
DD24's Avatar
By default ffmpeg will only copy one video, one audio, and one subtitle stream, so it'll strip out any secondary languages. Therefore, don't be surprised if the output file is a bit smaller than the input.
Actually, the output file is a little larger than the input file (3.67 GB vs 3.48 GB).
DD24 is offline
Old 01-09-2014, 03:57 PM
P Smith's Avatar
Quoted: 608 Post(s)
Liked: 320
perhaps it added I-frames to complain with DVD specs, as OTA/sat/cable using very long GOPs... I've seen 30...50 frown.gif
if you'll post log file of the session (or re-run the process with additional expanded log if it possible)
P Smith is offline
Old 01-09-2014, 04:01 PM
P Smith's Avatar
Quoted: 608 Post(s)
Liked: 320
Originally Posted by Kelson View Post
In my experience, HDTV recordings have only 1 video and 1 audio stream and no subtitle stream.
I've seen opposite in OTA files from TR-50s;
yes, there is one video PID, but multiple audio ( Spanish, French...) if you want more info goto Trip's site, he has TSReader snapshots from many stations.
P Smith is offline
Old 01-09-2014, 04:03 PM
Kelson's Avatar
Quoted: 1978 Post(s)
Liked: 1167
Yes, I've used it. It is a BluRay authoring tool with a steep learning curve and a little glitchy. I have an easier way to author BluRays.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
Old 01-09-2014, 04:14 PM
DD24's Avatar
Don't know if ffmpeg saved a log file or if it did where it might be.  But at the end of the console output it said "muxing overhead 8.21%".
DD24 is offline
Kelson's Avatar
Liked: 1167
Interesting. I've only seen a single video and audio stream in VRD. After your comment I thought perhaps VRD was filtering out the non-English audio so I just used MediaInfo to take a look at a couple recordings I just transferred over (Chicago Fire, POI, Mentalist, etc.). Only 1 video and 1 audio stream. But they did have a CC stream also. That gets filtered out in VRD.
- kelson h
Kelson is offline
Old 01-09-2014, 04:20 PM
Kelson's Avatar
Liked: 1167
I just love it when a plan comes together. There are plenty of GUI front ends for ffmpeg so I'm sure someone can find one that will create a simple batch file for multiple recordings. Thanks DD24 for putting in the effort.
@Aero 1
Is there a way you could capture this info in post #1. It is going to come up repeatedly as new people get these and want to transfer files. So far we have using Ext2Fsd on Win-7/Vista to mount and access the CM-7500 HDD and using ffmpeg to fix the .ts files.
- kelson h
Kelson is offline
Old 01-09-2014, 04:34 PM
kent2174's Avatar
Quoted: 26 Post(s)
AUDIO INPUT FINALLY ANSWERED!
Support let me know I will need the following adapter for my toslink cable to feed audio to my old Denon AVR.
Apparently only available at Amazon according to reviews of this part.
99cents, but expedited shipping $24.
Copy paste this into Amazon and read several reviews to see if this is what some need.
Recoton Fiber Optic Toslink to 3.5mm Mini Adapter
My DVR+ has shipped, order placed 12/31--UPS tracking label only today.
Paul210 and JHBrandt like this.
kent2174 is offline
Old 01-09-2014, 04:36 PM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 135
Just received a shipping notification that my 2 units were shipped today and received a tracking number.
I will monitor the tracking number for the truck being "Out For Delivery" so I can be home to sign for them tomorrow......
Exciting start to the weekend and now I have to find an external hard drive to record to....
ChuckyBear likes this.
qz3fwd is offline
Old 01-09-2014, 04:42 PM
bernieoc's Avatar
Quoted: 54 Post(s)
Ordered 1/1//14 - nothing yet
bernieoc is offline
Old 01-09-2014, 06:05 PM
Aleron Ives's Avatar
Quoted: 1640 Post(s)
Liked: 1389
Originally Posted by laridae View Post
Why does CM have to make this so difficult and complicated?
Ext is the default filesystem of Linux, which the DVR likely uses as its OS. It's only difficult if you're using Windows. tongue.gif
On my cheap Homeworx box I just add any USB drive, no formatting required. It just works and I have the added advantage of being able to move it back and forth to other devices like my smart TV and PC if I want.
Flash drives are pre-formatted, usually with FAT32.
And also, why are they making their own WiFi dongle?
It's more profitable to sell your own non-standard accessories. Just ask Apple, which probably makes millions on selling iPhone charging cables alone. rolleyes.gif
Originally Posted by Charles R View Post
Come to think of it why didn't they go the DLNA route like SiliconDust? That way it would work with a ton of existing streamers...
DLNA certification probably costs money, and qualifying for it probably requires them to enable some type of DRM on the DVR.
HDTV can have closed captions, which you can extract as SRT subtitles with CCExtactor. You need to re-time them if you remove the commercials, though.
Aleron Ives is offline
Old 01-09-2014, 06:42 PM
smintn's Avatar
got mine wednesday it's ok
smintn is offline
Old 01-09-2014, 07:23 PM
mikebw22's Avatar
Just received my dvr. I like it.
I tried updating the dvr with a usb drive but don't know if it actually updated.
It says software version 101R(0.5). There is no date and nothing on Channel Master saying what the latest version is.
Does anyone know what the latest version is.
mikebw22 is offline
Old 01-09-2014, 07:24 PM
P Smith's Avatar
Quoted: 608 Post(s)
Liked: 320
101R
I did wrote about it see my posts
P Smith is offline
Old 01-09-2014, 07:41 PM
mikebw22's Avatar
101R
Thanks. I did search but missed it.
mikebw22 is offline
Old 01-09-2014, 07:44 PM
kucharsk's Avatar
Quoted: 1393 Post(s)
Liked: 751
I'm no Apple fanboy, but one thing Apple does right IMO is that they don't change their successful UI! Why do so many other companies fail to learn the simple lesson, "if it ain't broke, don't fix it"?
I love Apple and am a huge fan, always have been.
That said, the changes from OS X Mountain Lion to Mavericks have been pretty huge, and the look and feel changes from iOS 6 to 7 were obnoxious and IMHO uncalled for.
So yes, Apple does change their UI when there's no need to and breaks a lot of things in the process, just as all tech companies do in the name of chasing what some consider to be the latest trends.
videobruce likes this.
kucharsk is offline
Old 01-09-2014, 07:46 PM
P Smith's Avatar
Quoted: 608 Post(s)
Liked: 320
OK, lets get technical info about its guts:
Engineering sample [DVT/PVT ?] posted by davezats:
Short BOM:
CPU: U1: BROADCOM BCM72131ZBKFEBA03G/TN1333 P22/313468 P3A
RAM:U3/U4: NANYA NT5CC256M116CP-D1 {2x512 MB DDR3? memory 256 Mx16bit}
NAND Flash: U6: SPANSION ML02G100BHI00/327BB407 A [SLC NAND Flash parallel 3/3.3V 2Gbit 256Mx8bit 20 nS]
Serial Flash: U7: WINBOND 25Q64FVCIP/1222/6205/6540 [3V 64M-BIT SERIAL FLASH MEMORY WITH DUAL /QUAD SPI & QPI]
Flash: U10: KINGSTON 2400096-004.A00G/1318 2552971/KE4CN4K6A {16 GB ?}
TUNER:U15/U19: MXL603/52322.22 http://www.maxlinear.com/press-release-07-23-12/
DEMOD: U11/U14: MN88436/335P4123 http://www.semicon.panasonic.co.jp/en/products/systemlsis/dtv_frontend/
Note: info in square brackets taken from mfg sheets, in {} - suggestions.
Photos of production device, to dismantle it just unscrew 8 screws at bottom:
Notes:
- production PCB has green color
- production DVR+ has BUILD CONFIG "ABBB" ; engineering sample [was it PVT ?] - " AKF"
HiRes pictures:
K77_PCB_1 642k .JPG file K77_PCB_2 1704k .JPG file K77_PCB_3 1702k .JPG file K77_PCB_4 1702k .JPG file K77_PCB_5 1705k .JPG file K77_PCB_6 413k .JPG file K77_PCB_7 1719k .JPG file K77_PCB_8 1711k .JPG file K77_PCB_9 1717k .JPG file K77_PCB_A 1715k .JPG file
ID:	74734   Click image for larger version
ID:	74735   Click image for larger version
ID:	74736   Click image for larger version
ID:	74737   Click image for larger version
ID:	74812   Click image for larger version
ID:	74813   Click image for larger version
ID:	74814   Click image for larger version
ID:	74815   Click image for larger version
P Smith is offline
Old 01-09-2014, 07:50 PM
kucharsk's Avatar
Liked: 751
And don't think that TiVo's "lifetime" subscription is absolutely guaranteed either.  I don't think they are on solid footing financially and if they go out of business, nothing is guaranteed.
Two big things:
1) TiVo's "lifetime" subscription is for the box, not the owner; if your box dies they are under no obligation to move your subscription to a new one (unless the box is under warranty.)
2) If TiVo goes under, you have a brick as the device is useless without their guide information.
The problem is there's no good source of guide information for third-party DVRs; most sources have gone away and PSIP data is very notoriously unreliable; many stations don't bother with it and it's frequently hours off.
kucharsk is offline
Old 01-09-2014, 07:56 PM
JHBrandt's Avatar
Quoted: 1667 Post(s)
Liked: 813
Ffmpeg is pretty fast if you aren't re-encoding video. It routinely remuxes 30-minute recordings in under a minute on my PC - and I only have a dual-core A4 processor.
BTW if you add -report at the start of the command line (right after 'ffmpeg') it will write a log file with a name like ffmpeg-20140109-215500.log. That can show you what it's doing in excruciating detail.
JHBrandt is offline
Old 01-09-2014, 08:08 PM
JHBrandt's Avatar
Liked: 813
I'd heard about the iOS 7 glitches, but i guess even I fell for some of the hype. Of course many of us Windows users were appalled by the changes between Win 7 & Win 8. But even earlier Windows updates had a lot of annoying & unnecessary changes - just not as huge.
TheKrell likes this.
JHBrandt is offline
DD24's Avatar
Yes, I found the -report option after looking at the internal help information and ran it once with that option but nothing jumped out at me as being very important.  But thanks for giving me the right command to run.
DD24 is offline
Old 01-09-2014, 08:11 PM
videobruce's Avatar
Quoted: 648 Post(s)
Liked: 254
Take a look at the VRX thread, post 2 for details. It's fairly easy after you load the proper drivers. wink.gif
Recording free OTA TV for 'time shifting' has been here since 1977. Will there be DVR's to do the same when ATSC3 obsoletes existing DVR's??
videobruce is offline
Old 01-09-2014, 08:13 PM
MannyNY's Avatar
This thread is titled "Channel Master DVR+ Owners Thread," but it's seems (at least to me it does) many of these posts DON'T have anything to do with the DVR+.
MannyNY is offline
Old 01-09-2014, 08:16 PM
videobruce's Avatar
Quoted: 648 Post(s)
Liked: 254
RAM:U3/U4: NANYA NT5CC256M116CP-D1 {512 MB DDR memory 256 Mbx16bit}
It's about time! someone had the initiative to open the damn thing up and get into the meat and potatoes. If it was a motor vehicle it would of been torn apart by now.
How about some detailed photos?
Regarding the tuner and demod;
http://www.fool.com/investing/businesswire/2012/08/27/maxlinear-and-panasonic-semiconductor-collaborate-.aspx
http://www.broadwayworld.com/bwwgeeks/article/SiliconDust-Selects-MaxLinear-for-Next-Generation-of-HDHomeRun-Network-Attached-Tuner-Products-20130108
http://www.techzone360.com/news/2013/04/08/7044044.htm
Want to buy some?
http://szmjd.en.alibaba.com/product/884164088-200625318/_IC_MxL603.html
Silicon Labs does a TiVo. Just think how cheap everything would really be if they would stop suing one another;
http://www.docstoc.com/docs/120580110/Maxlinear-v-Silicon-Laboratories
Old 01-09-2014, 08:24 PM
P Smith's Avatar
Quoted: 608 Post(s)
Liked: 320
something changed at the site - full editor have no provision to attach photos frown.gif it was my setting for AdBlockPlus ...
P Smith is offline
Old 01-09-2014, 08:32 PM
JHBrandt's Avatar
Liked: 813
I think the hard part about accessing the DVR+'s recordings wasn't installing ext2fsd so Windows can access them; that's simple. It was figuring out how to remux the files, having to play a bit of each recording after remuxing to identify it (since the file names are completely meaningless), needing another NTFS-formatted HDD to play the files back on an iView or Homeworx, etc. But, we're getting it all figured out - and pretty quickly too!
JHBrandt is offline
Old 01-09-2014, 08:39 PM
P Smith's Avatar
Quoted: 608 Post(s)
Liked: 320
P Smith is offline
Old 01-09-2014, 08:53 PM
videobruce's Avatar
Quoted: 648 Post(s)
Liked: 254
The paper clip (4th from the right) will add an attachment, the odd icon to the left of that will embed a photo in the post in both the quick reply and full editor.
578 , 999 , Channel Master , dvr+ , maintanance restart , P552UI-B2 , vid posts 576/578 , vizio 4k
