Considering a DirecTV Genie - AVS Forum | Home Theater Discussions And Reviews
Old 07-13-2013, 12:31 PM - Thread Starter
twright's Avatar
I currently have 2 HD DVRs and one standard receiver. If I get a Genie, I would want to keep one of the HD DVRs that has a lot of shows on it and replace the 2 other receivers with Genie minis. If I get a new Genie, is it possible to set it up such that there is a combined playlist that includes existing shows on my old DVR with new shows recorded by the Genie?
twright is offline
Old 07-13-2013, 02:10 PM
veryoldschool's Avatar
yes
A.K.A. VOS
veryoldschool is offline
Old 07-13-2013, 06:44 PM - Thread Starter
twright's Avatar
Is there some special configuration that I need to ask for or will the "standard" installation allow me to view existing shows from the old DVR in the Living Room.
I should have mentioned that I plan to install the Genie in the Family Room and move the existing DVR to a bedroom.
So to summarize, existing DVR that is in the Family Room has a lot of shows that we want to watch. If I move that to a bedroom will we be able to view existing shows from that DVR in the Living Room once the Genie is installed in the Living Room?
twright is offline
Old 07-13-2013, 07:48 PM
You'll need to have the multi-room viewing on your account and the connected home networking, which is fairly "standard" these days.
A.K.A. VOS
