Homeworx HW-150PVR, Support and Discussion - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 83Likes
post #541 of 2349 Old 12-09-2013, 08:08 PM
Aleron Ives's Avatar
Quoted: 1593 Post(s)
Liked: 1300
Originally Posted by ColoradoSteve View Post
Any suggestions for a replacement?
The only thing I can say for certain is that you shouldn't get an iView. It has identical hardware, so it's almost guaranteed that it wouldn't work, either. It's possible that the iView firmware would solve the problem, but I doubt it's related to the firmware. If you really want to be sure, you could load the iView firmware on your Homeworx, but you'd need the iView remote to be able to use the DVR after that (and you'd also want to load the Homeworx firmware again before returning it).
I'm partial to the TViX 6620, but I don't know if it would work for you, either. Mine is connected directly to the TV via HDMI, so it doesn't suffer from AVR problems.
Aleron Ives is offline
post #542 of 2349 Old 12-09-2013, 09:43 PM
zerozed's Avatar
I have successfully connected it to a second 46" Samsung that I have.  No issues.  I tried to connect to the Epson projector directly.  Message keeps popping up on the screen that says 'not supported'.  I saw in another forum that the HW150 sends junk through the ilink channel so I turned that off on the projector.  Same issue.  Nothing.
I guess I'll have to send it back and get something else.  I was excited about having the time shifting on this unit for the price...
I know this might sound like a really stupid question, but are you testing the HomeWorx tuner with the same HDMI cable on both the projector and the TVs? The only reason I bring this up is I once spent over an hour trying to fix a similar problem only to eventually discover that the HDMI cable I was using had a problem.
zerozed is offline
post #543 of 2349 Old 12-10-2013, 05:10 AM
Thxtheater's Avatar
Quoted: 109 Post(s)
Liked: 101
I hope someone can offer some suggestions.
I'm putting together a theater in the basement.
I purchased the Homeworx HW-150PVR to connect to my Epson PowerLite Home Cinema 2000 projector through a Pioneer VSX-42 receiver.  HDMI from the receiver to the projector is 15' Monoprice CL2 cable.
In addition, I have a PS3 and a Roku LT connected to the Epson projector through the Pioneer.  Those 2 devices have no issues making the connection and are performing well.
With the 150pvr, the HDMI will not negotiate.  The units seem to be performing the handshake, then the screen shows a 'not supported' message and then a 'no connection' message.  The HDMI connection on the receiver goes off and on about every 10 seconds - again appearing to show a negotiation going on.  I have gone through the 'hdmi' resolution choices with the same results.
The 150pvr arrived with software v14 installed on it.
I have connected the 150pvr to my Samsung television with no issues.  Picture is good, channels are clear and sound is nice so I know that the hdmi output is good.
Is there a fix for this issue?  Looking through Google searches, it appears that others have had problems with Epson projectors, but none as bad as this.  And - I haven't found anyone that posted the fix.
Any help you could provide would be appreciated
Test with a 6' HDMI cable and see if you get the same message. If not you may need Dr. HDMI from HDMI Fury to fix the issue.
Thxtheater is offline
post #544 of 2349 Old 12-10-2013, 05:41 AM
jobedo's Avatar
On sale at newegg for 33$ with code EMCWVWX94 http://www.newegg.com/Product/Product.aspx?Item=N82E16882576003
Joe
jobedo is offline
post #545 of 2349 Old 12-10-2013, 08:30 AM
JHBrandt's Avatar
Quoted: 1506 Post(s)
Liked: 750
Originally Posted by bori View Post
Originally Posted by zerozed View Post
Why are you doing that with the coax out? I'm all confused. You should just take the HDMI output of the HW150 and run it to the input of the X-Box, then take the HDMI out of your X-Box to your TV.
I'm not sure your setup might be interfering with the X-Box voice controls, but it might be.
The reason I have it like that cause the coax is going to the TVs tuner. The hdmi is going to the Xbox. Instead of using a splitter I just use the ouput of the coax to TV. So if I want to watch TV without turning on Xbox I can do that. Hopefully that clears it up. But I was wondering if this could be the problem thaat is why I posted it to see if anyone has a similar setup.
Many of us are using the Homeworx's RF output to watch one channel (using our TV's tuner) while the Homeworx records another. I can't see any possible way that would interfere with the XBox One.
The only thing I can think of is, perhaps the Homeworx can't "see" the IR signals coming from the XBox. Could you make sure the XBox's IR blaster is pointed directly at the Homeworx's IR sensor?
JHBrandt is offline
post #546 of 2349 Old 12-10-2013, 08:50 AM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
I tried that. I don't get why the Xbox remote can't change the channel on the homeworx either using the guide.
Sent from the TermiNOTEr 2! ;-)
bori is offline
post #547 of 2349 Old 12-10-2013, 08:55 AM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
Do we know of any other converter that works work Xbox one?
bori is offline
post #548 of 2349 Old 12-10-2013, 09:55 AM
JHBrandt's Avatar
Liked: 750
I'm pretty sure the XBox remote doesn't control the Homeworx directly. It controls the XBox, and the XBox itself then controls the Homeworx through its IR blaster. So if it doesn't work through voice it won't work through the XBox remote either, and vice versa.
Can you use a cell-phone camera to see if the XBox's IR blaster is emitting anything? Perhaps it's defective
JHBrandt is offline
post #549 of 2349 Old 12-10-2013, 11:01 AM
SoNic67's Avatar
Liked: 29
Originally Posted by MediasonicEast View Post
The thing we want to avoid is unnecessary return of a good unit.
Say a user buy an unit goes home and scan for channels looking for QAM and doesn't find any. And he doesn't know his Cable provider is encrypting QAM or is not providing QAM
so he goes and return the unit and then write a bad review.
I didn't buy your unit EXACTLY because you retired the support for QAM.
Is not illegal to record the un-encrypted channels that I have paid subscription. Cox and Verizon FiOS are sending the local channels unencrypted. If they choose to encrypt those channels in the future (as allowed by 2012 FCC ruling) it will be between them and me, nothing to do with your support.
Also, all the existing TV's have QAM enabled - one user can scan the channels with their TV in order to verify if it has unencrypted QAM.
SoNic67 is offline
post #550 of 2349 Old 12-10-2013, 11:13 AM
jdmx's Avatar
I bought a HW-150PVR off Amazon (from third-party seller "DependableResource") in late October. Over the six weeks I've owned it, I've developed a sort of love-hate relationship with it.
I love that it captures the ATSC signal and saves it as-is without re-encoding it, so I get the full clarity of the original broadcast. (This was a beef I had with the Simple.TV: it saved everything as compressed 720p, and the results never looked as sharp as the original.)
However, I hate that I can't count on it to record what I tell it to. Recordings work more often than not, but they fail often enough that it's a serious problem. Also, the "HBPVR" directory in which recordings are saved on the hard disk periodically gets corrupted somehow, where a recording file won't play, but it also can't be deleted. I have to unplug the HD and connect it to my computer to fix the problem.
Here's an example that illustrates the recording problem I'm having. Last Thursday, I pre-scheduled a recording of a three-hour overnight program on my local PBS channel from 3:00am to 6:00am Saturday. Later, on Sunday evening, I tuned into NBC Sunday Night Football on the HW-150 and manually started recording by pressing the "Record" button on the remote, then switched the TV back over to another input so my wife could continue watching her Netflix movie while the game was recording. A couple of hours later, after my wife was done with her movie, I sat back down in front of the TV to watch the game and noticed something was wrong: the activity light on the HD that I have plugged into the Homeworx, which blinks when it's recording, was on steady. Uh-oh.
Sure enough, I discovered that the unit had inexplicably stopped recording the game at some point. Upon investigating, I discovered that it had stopped at the 1:02:03 mark (one hour, two minutes, three seconds), with a file size of about 6.4 GB. So I missed most of the game. Then I checked the pre-scheduled recording from early Saturday morning, and discovered that it too had stopped early. It began at the correct time, but had stopped at the 1:02:04 mark, also with a file size of 6.4 GB. So I missed most of that program as well.
One of these recordings was pre-scheduled, and the other was manually started, but both prematurely stopped recording at exactly the same length. WTF?!
I did another test last night. Late last night, I reformatted the HD in NTFS on my computer, then connected it to the HW-150 and pre-scheduled a three-hour recording for 3:00am to 6:00am this morning. I just went and checked, and sure enough, the recording cut off after 1:02:03.
But what's weird is that these past few days are the first time I've encountered this particular problem. The unit has successfully made a few pre-scheduled recordings of up to four hours (more NFL games) in the past.
This is just the latest example of the many misfires I've suffered with this unit. It's pretty good when it works, but in my experience, it's just not reliable.
I have some relatively minor gripes with the unit's user interface, but that's almost irrelevant when the unit can't be relied upon to perform its most essential function.
If anyone has suggestions for how to overcome these problems, I'm all ears.
FYI, the unit's System Information panel shows:
Model: HW-150 PVR
SW Version: CL630133 130807 V13
HW Version: 7816-ATSC-03
The unit came with the "new" remote. The external HD that I use with the unit is a WD Passport, formatted in NTFS.
jdmx is offline
post #551 of 2349 Old 12-10-2013, 11:49 AM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
I did do the cell phone camera trick. It is working my Kinect can control my av receiver and my TV with voice command.
bori is offline
post #552 of 2349 Old 12-10-2013, 02:10 PM
zerozed's Avatar
Just a random thought...could the problem be that when you switch to another AV input the CEC is somehow turning off the record feature?
zerozed is offline
post #553 of 2349 Old 12-10-2013, 03:52 PM
JHBrandt's Avatar
Liked: 750
jdmx: I wonder if there's some kooky bug that cuts off a recording at 6.4 GB? Of course that wouldn't explain why it used to work.
As for fixing it, the only things I can suggest are: 1) reload the FW, and 2) try another HDD. No reason to believe either will work, but it's all I can think of at the moment.
As a workaround, I suppose you could schedule several 1-hour recordings instead of a single 3- or 4-hour recording. Of course you'd lose a few seconds at the end of each one, but that's better than losing everything after 1:02.
bori: OK, we know the XBox's IR blaster is working, since it controls other devices and you can see it flashing with the cell phone camera. And we know the Homeworx accepts IR commands (since its own remote works too). And you said the two are in sight of each other.
The only possibility that leaves is that the wrong remote codes are being used. But you also said you have the new remote and V14 FW (which works with the new remote), and others have confirmed that the XBox uses the Homeworx's new remote codes.
So at this point I'm stumped. Most likely it's an XBox setup issue, but it's really hard to know just where the problem might be. Anyone else have an idea?
JHBrandt is offline
post #554 of 2349 Old 12-10-2013, 04:04 PM
jprc's Avatar
Quoted: 82 Post(s)
Liked: 120
I would attach the HDD to a computer and do a detailed thorough scan for errors/bad sectors, etc. I know when I was running Homeworx v10 FW, I recorded files much larger than 6.4GB on a regular basis. They can't load v10 on their new box to check if it's a fw version problem. Maybe they can get v14 or v8 though from mediasonic and see if it makes a difference.
jprc is offline
post #555 of 2349 Old 12-10-2013, 04:28 PM
jdmx's Avatar
Does anyone know what differences there are between the V13 and V14 firmware versions?
jdmx is offline
post #556 of 2349 Old 12-10-2013, 05:55 PM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
I have both firmware and I noticed the v14 the boot up logo of homeworx. Didn't notice that on v13.
Regarding my situation I think I am going to try a different Xbox. I have two more sitting at home. To see what happens. If that doesn't work maybe I would try returning for a new homeworx.
bori is offline
post #557 of 2349 Old 12-11-2013, 02:00 AM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
I have a question for the ones that got the voice command working with the HW. Are you able to change channels with the xbox controller too? Or is it the voice that changes channels only?
bori is offline
post #558 of 2349 Old 12-11-2013, 08:14 AM
ColoradoSteve's Avatar
I did that.  No different.
It's going back today.  Researching alternatives.
ColoradoSteve is offline
post #559 of 2349 Old 12-11-2013, 11:28 AM
jdmx's Avatar
What happens if you connect the HW-150 directly to the projector (without going thru the receiver)? If it works, then the problem is with the receiver somehow. If it doesn't work, then your projector may not support 1080i video via HDMI, which is what the HW-150 outputs.
I just looked up the Epson PowerLite Home Cinema 2000 specifications and found this:
Input Signal:
  • Composite: NTSC / NTSC4.43 / PAL / M-PAL / N-PAL / PAL60 / SECAM
  • Component: 480i / 576i / 480p / 576p / 720p / 1080i / 1080p
  • HDMI: TMDS
If HDMI doesn't work, you might try connecting with component video cabling instead.
jdmx is offline
post #560 of 2349 Old 12-11-2013, 11:45 AM
jdmx's Avatar
I got an answer to this question directly from Mediasonic tech support:
V14 is same thing no new fix over V13
only difference is inside the machine with V14 we switched one of the chip to a different brand because the one original used was discontinued
and still same functionality it doesn't make one better then other
This raises the question of whether Mediasonic will have to release two different flavors of every future firmware update, to support boxes with the two different chipsets. And people will have to figure out on their own which flavor their box needs. Sounds to me like a recipe for a clusterf_ck.
JHBrandt likes this.
jdmx is offline
post #561 of 2349 Old 12-11-2013, 11:55 AM
The projector doesn't support component in.  It requires a component to VGA adapter.  Not going there.
The Pioneer vsx-43 I have doesn't convert from component to hdmi.  It only passes the component through.
The 150pvr is going back.
Steve
post #562 of 2349 Old 12-11-2013, 12:32 PM - Thread Starter
MediasonicEast's Avatar
There is no need to chase for firmware update ( there is no new update)
if you box came with
V8 is the latest for your unit
V13 is the latest for your unit
V14 is the latest for your unit
all the above have the same fix as V10 (the only major fix we released)
if there any firmware update we will announce it
If you need QAM,
then you email us your current firmware version
and we will email you the proper QAM for your version
rma_east AT mediasonic.ca
thanks
MediasonicEast is offline
post #563 of 2349 Old 12-11-2013, 12:36 PM - Thread Starter
No need cause V14 works on V13
but there is no need for people with V13 to must have V14
as it makes no difference, your 150PVR will not gain super powers biggrin.gif
post #564 of 2349 Old 12-11-2013, 03:03 PM
jdmx's Avatar
Steve, I realize that connecting the HW-150 directly to the projector via HDMI is not a long-term option for you, but it would be useful for troubleshooting. Did you try it?
jdmx is offline
post #565 of 2349 Old 12-11-2013, 03:09 PM
steveurban's Avatar
i'm a long time member, rare poster who's read all these posts and the posts of the much longer iview thread, and will buy either this or the iview version very soon. my question: for someone just looking to record one ota hdtv show at a time (to be viewed later with no time shifting or record-and-watch at the same time) using one of these with an attached usb hard drive (either 2.5" powered by the device or a self powered 3.5" unit), is one "better" (less buggy, cooler running, better passtrough, etc etc) than the other? thanks for your time & helpful input.
steveurban is offline
post #566 of 2349 Old 12-11-2013, 03:15 PM
Yes.  I tried it with a 5' cable I used on the Samsung.  Same issue.  Kept displaying "not supported"
It just doesn't look like it's going to work.
post #567 of 2349 Old 12-11-2013, 03:25 PM
jprc's Avatar
Quoted: 82 Post(s)
Liked: 120
I posted this reply in the iview thread but just replying here as well in case anyone with a Homeworx wants to disagree with me since I don't have a physical Homeworx box and have only run the Homeworx firmware on my iview:
If you want passthrough to work, right now you'd be better off with the Homeworx since several iview FW versions broke that feature. Overall, the Homeworx FW is more stable as well. There is not a big difference between the two boxes however, but as things stand currently, the Homeworx would be slightly better for you.
jprc is offline
post #568 of 2349 Old 12-11-2013, 03:50 PM
JHBrandt's Avatar
Liked: 750
If you need QAM,
thanks
OK, let's see if I have this straight:
V3 (buggy) and V10 (bugs fixed) support the original HW-150PVR with the old remote
V8 (no logo) and V13 (with logo) support the original HW-150PVR with the new remote
V14 supports the new HW-150PVR with the new chip and remote
Feature-wise, they're all the same and there are QAM versions of each (except V3). So if you were to load V14 onto an original HW-150PVR, it'll detect the old chip and work OK, but won't act any different than with V13.
So in the event of a future firmware upgrade, I'd think they won't need different versions for different chips (the FW can detect the chip), but they will need different versions for the different remotes (the FW can't detect that), and they'll need QAM versions of each. So four slightly different versions would be needed.
That still leaves open the question of which chip was changed. If it was the tuner, could it be better than the original tuner at dealing with the mix of strong and weak signals I have? (If it was any other chip, it probably wouldn't make any observable difference.)
JHBrandt is offline
post #569 of 2349 Old 12-11-2013, 07:49 PM
zerozed's Avatar
Yes you can. You can hit either the "view" or "menu" button and it will pull up recent channels, etc. and you can use the D-Pad and "A" button to select.
Also, I just had an opportunity to set up yet another X-Box One and took the opportunity to try my HW-150PVR on it. No problem getting it working at all on the other XB1. I did enter Mediasonic as the manufacturer, but I didn't let it automatically set it up--opting instead to select manual. At the manual menu, I tied in "HW" and hit "enter." That gave me the pull down screen to select my model; the only model listed was the HW-150PVR (just like in the video)--I selected that, and voila! It works.
I did have one issue with it (minor). I was fooling around with the power settings and I told the XB1 to turn on/off my TV, by tuner box, and my A/V stuff. That works awesome, except that for some reason the XB1 didn't receive the video signal from the Mediasonic tuner after turning it back on...I had to pull the HDMI cable and replug it...which fixed it. I'll probably just leave the tuner turned on and see if the next XB1 firmware update fixes it.
zerozed is offline
post #570 of 2349 Old 12-11-2013, 07:58 PM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
What firmware are you using?
bori is offline
Reply HDTV Recorders
