Homeworx HW-150PVR, Support and Discussion - Page 27 - AVS Forum | Home Theater Discussions And Reviews
 83Likes
post #781 of 2348 Old 01-10-2014, 11:48 AM
jjeff's Avatar
Quoted: 688 Post(s)
Liked: 245
Originally Posted by mlaskan View Post
I've had the HW 150 PVR for a few weeks now and it seems to work well except for the quality of recorded programs. My firmware is V14. I'm recording to USB flash. Live broadcast looks good but recordings seem like a weak signal, choppy with fast audio. They are impossible to watch. Any ideas?
Have you tried recording to a USB HDD? Many flash drives just aren't fast enough to work with a HD DVR, that would explain the choppy video, not sure why the fast audio :confused:
jjeff is online now
post #782 of 2348 Old 01-10-2014, 01:14 PM
Golfdad123's Avatar
Originally Posted by png5 View Post
For HD recording, you need to have 20-25MB/s write speed, I sometime use SanDisk Ultra 32GB SD to record on IV3500 or HW150, both work perfect. However take 7-9GB per hour of HD
recording. 32GB does not have a lot of hours.
Thanks, I had a feeling it might not be fast enough.
Golfdad123 is offline
post #783 of 2348 Old 01-10-2014, 05:57 PM
mlaskan's Avatar
Thanks. I'll try a hard drive.
I did and the HW 150 doesn't see the media. It is a drive from a Toshiba laptop, about 10 years old, with XP on it, in an enclosure.
mlaskan is offline
post #784 of 2348 Old 01-10-2014, 06:29 PM
afterlife2's Avatar
Quoted: 162 Post(s)
Liked: 78
I got mine today and have been playing with it all day. I'm getting a choppy picture too with a flash drive, even though it looks clear when recording. Is there a better firmware to use than v.14?
EDIT just plugged in a Hard Drive seems to work better. So is there a way to play it in 5.1?
afterlife2 is offline
post #785 of 2348 Old 01-10-2014, 08:48 PM
jprc's Avatar
Quoted: 82 Post(s)
Liked: 120
Rename the extension to .ts and play it in the Movie section.
afterlife2 likes this.
jprc is offline
post #786 of 2348 Old 01-11-2014, 10:21 AM
geeman2001's Avatar
Does the HW150PVR allow you to set up a series recording?
geeman2001 is offline
post #787 of 2348 Old 01-11-2014, 10:40 AM
afterlife2's Avatar
Quoted: 162 Post(s)
Liked: 78
Yes but one at a time. Not 2 at the same time.
post #788 of 2348 Old 01-11-2014, 10:54 AM
afterlife2's Avatar
Quoted: 162 Post(s)
Liked: 78
Thanks! When plugged in my computer I don't see the Movie folder. Is there a way you do it? Not FAT32 right?
On sale at newegg + $10 off w/ promo code EMCPWWP38, ends 1/16 mad.gif
post #789 of 2348 Old 01-11-2014, 01:16 PM
jprc's Avatar
Quoted: 82 Post(s)
Liked: 120
You don't have to move it anywhere. Just when you plug it back into the HW, it will no longer appear in the PVR menu. You will have to go to the Movie section under Multimedia to find it. I would definetly suggest NTFS so you don't have a bunch of files to deal with. I have not tried renaming a bunch of partitioned files to .ts and see if they will play as one movie or not on the HW but it would simply be easier to have to only deal with one file anyway. You can try it though if you want to keep FAT32.
jprc is offline
post #790 of 2348 Old 01-11-2014, 01:20 PM
jprc's Avatar
Quoted: 82 Post(s)
Liked: 120
You can only set it up by time. So you can set it to record weekly or daily at the same time, but not by recognizing name of the series.
jprc is offline
post #791 of 2348 Old 01-11-2014, 03:36 PM
zerozed's Avatar
I recommend checking the owner's manual because it lists what types of devices need to be formatted which way. For example, I had a thumb drive (formatted to FAT32) that I had previous used (successfully) that failed to record anything when formatted to NTFS. The manual breaks down the formatting requirements.
zerozed is offline
post #792 of 2348 Old 01-11-2014, 03:42 PM
afterlife2's Avatar
Quoted: 162 Post(s)
Liked: 78
That worked great Thank you so much jprc! For those who don't know how to change extension files: http://www.youtube.com/watch?v=sAnaI08M--8
post #793 of 2348 Old 01-11-2014, 03:55 PM
jprc's Avatar
Quoted: 82 Post(s)
Liked: 120
Cool. Glad you got it working. And just want to give credit to user DD24 who originally told us about this.
jprc is offline
post #794 of 2348 Old 01-11-2014, 09:49 PM
colgate2004's Avatar
Hello,
This is my first post here at AVS Forum, so I apologize if this is the wrong place to post this question.
The time shift function of my HomeWorx HW-150PVR is not working, and I don't understand why.
I''m somewhat new to the HW-150PVR, but I've read the manual and a lot of posts online, so I don't understand why not.
I have a 500GB hard drive attached to the unit via USB (formatted to FAT32) and I've set the time shift capacity to 4GB (the maximum)…
But when I'm watching a program and press the "Play" button on the remote to activate Time Shift as described in the manual, nothing happens. No message on screen, nothing.
**Recording** programs works just fine… but using the "Play" button to use time shift doesn't work at all.
Am I doing something wrong? What's going on?
Thank you for any help you may provide!
colgate2004 is offline
post #795 of 2348 Old 01-11-2014, 09:58 PM
jprc's Avatar
Quoted: 82 Post(s)
Liked: 120
Originally Posted by colgate2004 View Post
Hello,
Press the Pause button.
jprc is offline
post #796 of 2348 Old 01-12-2014, 03:44 PM
seattlemark's Avatar
Hello,
What happened to colgate2004, is easy to happen. I got stuck on the same thing originally. The manual is rather poor here. It says in the Timeshift section, "When watching a program, press the PLAY key on the remote control to activate the function." rolleyes.gif
seattlemark is offline
post #797 of 2348 Old 01-12-2014, 06:41 PM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
Thats why i don't read manuals. Cause I would of assumed it was pause. Why would you want to play.
bori is offline
post #798 of 2348 Old 01-12-2014, 06:55 PM
JHBrandt's Avatar
Quoted: 1456 Post(s)
Liked: 741
Actually, what I would've assumed, if I didn't read either the manual or this thread, is that once enabled, time-shifting starts automatically as soon as you tune to a station, and you don't have to press any buttons at all.
Luckily I know better, but it is kinda weird that the Homeworx operates this way.
JHBrandt is offline
post #799 of 2348 Old 01-12-2014, 07:27 PM
Aleron Ives's Avatar
Quoted: 1580 Post(s)
Liked: 1289
Some DVRs give you the option to use automatic timeshifting or to only use it when you press pause, the TViX 6620 among them.
Aleron Ives is offline
post #800 of 2348 Old 01-12-2014, 08:12 PM
JHBrandt's Avatar
Liked: 741
That would be a nice option to add to Homeworx firmware (hint, hint, Mediasonic) biggrin.gif
JHBrandt is offline
post #801 of 2348 Old 01-12-2014, 08:17 PM
JHBrandt's Avatar
Liked: 741
Thanks; but they're sold out already frown.gif Not likely to get more in by 1/16 but I'll keep checking just in case
JHBrandt is offline
post #802 of 2348 Old 01-13-2014, 01:40 PM
oldspammer's Avatar
Originally Posted by chazdole View Post
HD Nation reviews the HW-150~ http://www.dailymotion.com/HDNation#video=x195cx9
Starts @ 04:58 > 10:23.
Seems to me from my experimentation of feeding the HDMI output to a computer capture card and having the digital audio coax go to my 5.1 audio receiver, the only audio mode that delivered Dolby digital AC3 to the audio receiver was the setting designated "PCM" in the menus--a non-obvious setting.  Other settings changed the recognition done by my receiver as "non-5.1" audio.
The originating channel may have complete control over what audio gets into the broadcast, and therefore, the recording. 3 streams of audio I found in one recording had the 6-channel stream be much more quiet than the stereo other two audio streams.  I had to increase the volume level of my computer playback of the video files to be +30 to +40% higher when the 6-channel audio stream was selected versus the other two stereo streams.
oldspammer is offline
post #803 of 2348 Old 01-13-2014, 02:33 PM
afterlife2's Avatar
Quoted: 162 Post(s)
Liked: 78
Hurry back on sale: http://www.newegg.com/Product/Product.aspx?Item=N82E16882576003
post #804 of 2348 Old 01-13-2014, 02:48 PM
JHBrandt's Avatar
Liked: 741
Thanks - I guess they did get some more in stock! Was just about to buy an iView but that discount saved me a few bucks.
JHBrandt is offline
post #805 of 2348 Old 01-13-2014, 05:33 PM
afterlife2's Avatar
Quoted: 162 Post(s)
Liked: 78
Welcome guys! Anybody ever tried these for signal boosting? Thinking about getting one instead of the cheap splitter that i have: http://www.amazon.com/Digital-Amplifier-Internet-Signal-Booster/dp/B001EKCGT8/ref=sr_1_2?s=electronics&ie=UTF8&qid=1389658970&sr=1-2
post #806 of 2348 Old 01-13-2014, 08:23 PM
JHBrandt's Avatar
Liked: 741
Haven't used it myself. Had to go to another site (Solid Signal) to get its noise figure: 2.7 dB. (Lower is better. I generally insist on a NF under 3 dB, so this should be OK.)
The only thing I'd watch out for is over-amplifying the signal, especially if you already have another amp in the signal path, such as an amplified antenna. There was quite a bit of ignorant advice about this at the Amazon site. Each output is 7 dB (5-fold) stronger than the input. If you're using a unamplified 4-way splitter now, each output is 7 dB weaker, so that'd be a swing of 14 dB (25-fold), and the Homeworx in particular is susceptible to overload. If your Homeworx performs worse with the amplified signal, try an attenuator at the Homeworx's RF input to bring the signal level back down some.
JHBrandt is offline
post #807 of 2348 Old 01-13-2014, 09:51 PM
afterlife2's Avatar
Quoted: 162 Post(s)
Liked: 78
Thanks guys for your help. I'm getting breakups on some channels in my apt. I have this antenna outside my window on the 6th fl. : http://www.amazon.com/gp/product/B002TIELEM/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
and I'm using this cheap amp: http://www.amazon.com/gp/product/B002ETDSUE/ref=oh_details_o00_s00_i01?ie=UTF8&psc=1
Should I get the attenuator or the booster I posted? It will be for the OTA TV and the Homeworx box only. Thanks!
post #808 of 2348 Old 01-13-2014, 11:20 PM
Yes, thanks! Snapped one up. The HW-150 has been more stable for me than my iview-3500. Didn't expect to find one on sale so soon, if ever. Went for the free shipping, hope they don't run over it too many times with a forklift.
After they got more in stock at NewEgg today, I also bought another this afternoon. I plan on using two HW-150s in series, using the RF out (with "Loop through" Modulation setting) of the first unit sending the antenna signal to the second unit. (So no splitter necessary for this.) That way I can record back-to-back TV programs (even on different channels), without losing any of the second program's recording. (Which can happen with just one unit when it's switching to recording mode for the second program.) With two units, both units can be programmed to record their shows a bit early, and end a bit late, without a problem. So I will basically have a two tuner DVR setup (like I had with the cable company I cut the cord from). Since my TV has multiple Component and HDMI inputs, I won't even have to move cables to watch either recording; I will just need to switch inputs on the TV.
Chazdole, in addition to today I previously bought two of these from NewEgg a month ago, and the free shipping was great. I received them very fast in prefect shape.
post #809 of 2348 Old 01-13-2014, 11:33 PM
plplplpl's Avatar
Liked: 24
plplplpl is offline
post #810 of 2348 Old 01-13-2014, 11:38 PM
jprc's Avatar
Quoted: 82 Post(s)
Liked: 120
Originally Posted by plplplpl View Post
But it's $30 off. A bit more expensive than the US but $46 with shipping is still not a bad price. With the exchange rate, you're really only paying the shipping cost as difference.
plplplpl likes this.
jprc is offline
Reply HDTV Recorders
