Homeworx HW-150PVR, Support and Discussion - Page 29 - AVS Forum | Home Theater Discussions And Reviews
 81Likes
post #841 of 2336 Old 01-16-2014, 09:40 AM
Thxtheater's Avatar
Quoted: 85 Post(s)
Liked: 95
I can confirm that one one of my boxes with v8 box has the Homeworx logo on bootup
Thxtheater is offline
post #842 of 2336 Old 01-16-2014, 09:50 AM
afterlife2's Avatar
Quoted: 162 Post(s)
Liked: 78
Thanks for the feedback THX are you having breakups on your boxes?
afterlife2 is offline
post #843 of 2336 Old 01-16-2014, 09:58 AM
Thxtheater's Avatar
Quoted: 85 Post(s)
Liked: 95
No, other than the digital coax anomaly the boxes work beautifully.
post #844 of 2336 Old 01-16-2014, 12:29 PM
Thxtheater's Avatar
Quoted: 85 Post(s)
Liked: 95
Just to clarify, I haven't done any recordings on the box just yet. So I can't confirm anything else.
post #845 of 2336 Old 01-16-2014, 02:08 PM
JHBrandt's Avatar
Quoted: 1430 Post(s)
Liked: 726
Interesting: two boxes with the same FW (V8), but one shows the HW logo and the other doesn't. Sounds like there may be more than one V8 out there rolleyes.gif
BTW I got my new HW today. Came with V14. First impressions:
  1. The tuner seems a bit more sensitive than the one in my old HW. Still not quite as good as my DTVPals. A 6 dB attenuator helped one channel but made another worse. (Edit: a splitter, which attenuates the signal about 3.5-4 dB, seems to be the best compromise for this box. Both channels are receivable although one breaks up a bit.) The difference between my old HW and this one could be normal variation.
  2. The loop-through does indeed stay on in standby, unlike my old box. (As I expected, loop-through does not work if the Homeworx is powered off via the front panel power switch.)
I'm lucky in that I still have one analog channel on the dial. It's a lot easier to tell if there's any drop-off with analog: you don't have to look at any signal strength meters; if the picture gets snowy, the signal has weakened!
JHBrandt is offline
post #846 of 2336 Old 01-16-2014, 06:25 PM
happy2Lurk's Avatar
Quoted: 34 Post(s)
Liked: 27
I got my HW to supplement my DTVpal, so I haven't used it much but last night something weird happened. I have read a number of times that all these boxes do is record what is received. Why then was the picture clear with "live TV" but a badly broken when time shifted/recorded? confused.gif
This happened on a station with weak signal (2%).
I changed to another fairly weak signal (7%) and could time shift/recorded with playback normal. Not a usb hard drive issue, other recordings play fine.
It seems to me that some signal is being lost when time shifting / recording. Thoughts?
happy2Lurk is offline
post #847 of 2336 Old 01-16-2014, 06:45 PM
seattlemark's Avatar
Originally Posted by chazdole View Post
New HW-150 arrived in the mail today. Fedex hands off to USPS sometimes. So, 3 days, free shipping, $35.99. gotta love it. They must be getting these things awfully cheap.
This one has identical firmware the last one I got had,(12/4) CL630133 130925 V14. Auto scan is missing one channel every time I try. (3 times so far) Tried resetting to factory defaults, no change. I had wanted to leave original firmware on to compare with the V14QAM firmware they sent me. Odd thing is, each time it has been a different channel it misses. And they aren't weak channels.
Will do a manual scan and leave original firmware on for now.
If you haven't already, maybe try this experiment:
1) On your "old" HW150:
a) Note what its "Modulation" is set to in the main menu on the old HW150. (Write down if your Modulation is set to "Loop through" (which acts as an internal splitter), or Ch3_ON, or CH4_ON.)
b) Run the autoscan on "old" HW150 and note which channels it picks up.
2) Remove the antenna cable from the "old" HW150, and put that exact same cable instead on the "new" HW150
a) Configure the Modulation on the "new" HW150 so it's identical to what you noted in step 1a. Because if the "new" is set to "Loop through", while "old" was set to Ch3_ON/CH4_ON, that's a possible big difference because of the splitter effect.
b) Run the the autoscan on "new" HW150 and note which channels it successfully finds.
Hopefully you will have the same results in step 1b as you do in step 2b since the antenna related settings have been configured the same and you are using the identical antenna input. If you don't get same results, and "Loop through" was the modulation setting, I'd try either the Ch3_ON or CH_4ON setting and see if that helps.
I also compare to what my TV's tuner picks up with autoscan. But for a fair test I have to always use the same antenna cable as I did on the HW150.
seattlemark is offline
post #848 of 2336 Old 01-16-2014, 07:08 PM
jprc's Avatar
Quoted: 82 Post(s)
Liked: 120
It's an interference issue. These boxes are very sensitive to interference and with such a weak signal (I'm surprised you're even getting the channel in at all really) when you add the interference of the hard drive it breaks up the signal. You can try moving the hard drive father away or try a different drive that may have less effect on the signal, and if you happen to have an indoor antenna move that as far away as possible. But with such a weak signal to begin with there may not be anything you can do. Depending on your setup and circumstances an amplifier may or may not help.
afterlife2 likes this.
jprc is offline
post #849 of 2336 Old 01-16-2014, 07:46 PM
JHBrandt's Avatar
Liked: 726
Another possibility, if you were watching live using either your DTVPal or your TV but recording or time-shifting using the Homeworx: the Homeworx tuner is a bit weak, so a signal that looks fine on your DTVPal or TV may be broken up on the Homeworx.
If that's not what you were doing, then clearly the tuners aren't the issue. But it's still something to be aware of since you have weak stations.
JHBrandt is offline
post #850 of 2336 Old 01-16-2014, 08:26 PM
afterlife2's Avatar
Quoted: 162 Post(s)
Liked: 78
Thanks jprc. I moved my Radio Alarm clock and Hard drive to a lower level. Let's see if it helps. If not I'll order the CM Booster Monday.
post #851 of 2336 Old 01-16-2014, 10:09 PM
happy2Lurk's Avatar
Quoted: 34 Post(s)
Liked: 27
It's an interference issue. These boxes are very sensitive to interference and with such a weak signal (I'm surprised you're even getting the channel in at all really) when you add the interference of the hard drive it breaks up the signal.You can try moving the hard drive father away or try a different drive that may have less effect on the signal, and if you happen to have an indoor antenna move that as far away as possible. But with such a weak signal to begin with there may not be anything you can do. Depending on your setup and circumstances an amplifier may or may not help.
First, the only reason the signal is so weak is that I have temporarily relocated my outdoor antenna while doing some work on my house. Before this, I had never experienced some of the effects I had read others have - weather, planes, etc. effecting reception. I have been OTA only for years.
Signal strength varies all the time now on some stations. Tonight, I turned on the HW and checked channels until I found one at 2% (different channel then before) - this time, time shift / record worked. The problem channel from before was at 5% and now time shift / record worked.
So, at least for my environment, 2% is pushing the limit.
JH - all remarks are HW only. I only mentioned the DTVpal because since it provides a much better user experience, I only use the HW when I need a third tuner recording. Which isn't that often, so I do not have a lot of user time with the HW. That said, I haven't really noticed a difference in reception between the pal and the HW.
Okay, before posting this I played around some more. The problem station had dropped to 2% again and again the time-shift was bad, not as bad as before but not clean like live. So I moved the drive as far as the cable allowed and now time-shift is clean at 2%. Looks like the drive broadcasts at about the same frequency.
It occurred to me that if farther is better, closer should be worse. So I tried moving the drive around, I had it right next to and even on top of the HW with very little effect. Maybe the 2% tonight is more steady than before. I just can't get it as bad as before. When I originally experienced this, live was clean and recorded was unwatchable - both picture and sound badly broken. The worse I can get tonight is a little pixelation, minor breaks in the image.
Thanks jprc, I probably wouldn't of thought to try moving the drive without your suggestion. If I experience a similar situation, I will see if moving the drive helps.
post #852 of 2336 Old 01-17-2014, 01:45 AM
avsforumun's Avatar
Can the homeworx record the signal coming from a cable box? I would like to go Cable box (Comcast) -> Homeworx -> TV. I know it will only have basic functionality (I assume it would only record Ch 3), but that would be fine.
I just want basic time shifting/pausing, and conversion from rca/coax in, to HDMI out.
avsforumun is offline
post #853 of 2336 Old 01-17-2014, 01:47 AM
jprc's Avatar
Quoted: 82 Post(s)
Liked: 120
No. Same answers as you got on the iview thread.
jprc is offline
post #854 of 2336 Old 01-17-2014, 09:46 AM
oldspammer's Avatar
Originally Posted by Thxtheater View Post
Anyone here using the homeworx coax digital audio out? I just got a replacement unit and I still cannot get digital audio via COAX. audio over HDMI is fine. I have tried PCM, RAW, and RAW HDMI with no luck. I have also disconnected the HDMI cable. My Anthem says there is no digital input.
I tested the cable on an Oppo and it works just fine and I tested it on the same input port.
I'm at a loss as to why I can't get audio via digital coax??
The source signal or video file--mine have 3 audio streams. 1=5.1 AC3, 2 & 3=English Stereo. See my post above. The originating channel can put any stuff in each stream.
There should be some way to select which stream is used.
PCM for me had the coaxial audio cable produce AC3 5.1 surround sound recognized as such by my audio receiver. See my post above. I have two units, but cannot recall if I tried to test just one or both of them.
oldspammer is offline
post #855 of 2336 Old 01-17-2014, 09:53 AM
oldspammer's Avatar
I just thought of a method of improvement for show scheduling...
On the hard disk drive I noticed some .ini files or whatever that may contain the schedules for recordings.
When the HDD is safely disconnected from the PVR and connected to a PC, the PC could manipulate the .ini files to augment their contents with more shows scheduled to record.
A small gui program or a text file with tab separated fields and a command line program could be used to dump existing .ini or save a more expanded .ini back to the disk so that when the disk is re-plugged back into the Homeworx HW-150PVR these added recordings would nicely operate it.
The user would have to get their show's times from a web site like Zap2it for their local region, then place the information via the PC program.
post #856 of 2336 Old 01-17-2014, 02:24 PM
huntt26's Avatar
Picked up one of these to use with my Xbox One and it was a great choice! If you are a cable cutter and want to watch OTA TV with the Xbox One guide using the controller or voice, this is the box for you! You can even play and pause with the built-in xbox commands. It's nice to be able to play games and snap TV off to the side as well. Multitasking at its finest!
If you decide to do this, I highly reccommend using an IR extender. You can plug it in the back of the xbox one and run the extender to the IR logo on the 150PVR. Then you don't have to worry about IR signal loss or mis-transmitted channel numbers. I tried using it without the IR extender (even with the Kinect right next to the 160PVR) and it didn't work about 25% of the time. With the IR extender I've had 100% success so far.
huntt26 is offline
post #857 of 2336 Old 01-17-2014, 02:53 PM
JHBrandt's Avatar
Liked: 726
FYI:
Originally Posted by apw2607 View Post
I just ordered the AT-163 (or VT-163) from Amazon. Its actually now selling for $29.95. You have to add it to your cart and you will get a $30 off promotion automatically ... order 2 and get $60 off.
This is now cheaper than the homeworx and iview ...
I will get it tonight and see how it compares to the iview. Probably identical, but for whatever reason my iview cannot pick up any of my digital clearQAM channels. OTA works fine though.
Originally Posted by satpro View Post
Walmart has the ematic at103b for 29.99, they also have a 90 day return policy and offer a $5 two year warranty.
http://www.walmart.com/search/search-ng.do?search_query=at103b
http://www.ematic.us/tv-accessories/at103b
Both boxes appear to be iView clones. The V/AT-163 uses the Homeworx remote, but the front panel has the iView display and some extra buttons (menu, OK, and volume/left-right), as well as the channel/up-down buttons and power switch the Homeworx and iView have, so some functions can be performed without the remote.
The Ematic AT103B resembles the iView more closely; I haven't seen its remote.
JHBrandt is offline
post #858 of 2336 Old 01-17-2014, 03:15 PM
Thxtheater's Avatar
Quoted: 85 Post(s)
Liked: 95
im going to query Anthem. They usually fan get technical and under the hood. It may be a flag that is not being done a particular way on the Homeworx box.
post #859 of 2336 Old 01-18-2014, 06:52 AM
jkuhlmann's Avatar
I'm wondering if any of you who have updated the Homeworx firmware for QAM support have experienced missing channels when trying to set up a timer recording?
I just received an HW-150PVR from Amazon and updated the firmware with the V14 QAM file provided by the Mediasonic RMA Dept. Everything works as expected, and I am able to view the QAM channels as I had hoped, but when I try to set up a timer recording I’m only seeing a small number of channels in the “Channel No.” list in the “Event Add” screen. In fact, I can be successfully watching a particular channel through the HW-150PVR and the channel that I’m watching will not even show up in the list, so I have no way to set up a timer recording for that channel. Has anyone run into this or have any suggestions for how to get all the channels to be displayed in the “Channel No.” list that have been found during the Auto Search process?
jkuhlmann is offline
post #860 of 2336 Old 01-18-2014, 08:29 AM
Richard Cohen's Avatar
Quoted: 26 Post(s)
Liked: 37
I am having exactly the same problem.
I posted the following on the mediasonic forum but have not received an answer
"I have set up the box and have about 8 channels available to view or record. When I try and set up a future recording using the timer button and screen only 4 of the 8 channels are available as an option to record.
If I hit the list button all channels are listed and have reception but some channels are deleted as an option in the timer set up screen. I have tried turning the unit off and doing a factory reset and new selection of channels but the same limitation exists.
What am I doing wrong?
Has anyone had a similar problem?
I am using V14
Help"
Does anyone here have an idea what to do? Thanks
Home Theater is GREAT
Richard Cohen is offline
post #861 of 2336 Old 01-18-2014, 08:40 AM
afterlife2's Avatar
Quoted: 162 Post(s)
Liked: 78
Richard, I think you need to play with your antenna. I live in NYC and I'm getting 67 channels by putting my antenna on the fire escape on the 6th fl. What antenna are you using?
post #862 of 2336 Old 01-18-2014, 08:46 AM
afterlife2's Avatar
Quoted: 162 Post(s)
Liked: 78
FYI:
Looks to have the same screen as the HW. The remote is different then the HW. Might be the same as iview: http://www.ematic.us/sites/default/files/AT103B%20IM_Eng_size130x185mm.pdf
post #863 of 2336 Old 01-18-2014, 09:07 AM
Quoted: 26 Post(s)
Liked: 37
The problem I am having is not the number of channels I am receiving. It is that all the channels I can receive are not available to be recorded
on the "programmed timer recording screen" under "channel" as I scroll and try and select a channel to record.
post #864 of 2336 Old 01-18-2014, 10:48 AM
jprc's Avatar
Quoted: 82 Post(s)
Liked: 120
At least two people on the iview thread had success in your situation when they moved the missing channels to the top of the list. You move channels under Program Edit. Otherwise I would ask mediasonic for the v14 QAM firmware to see if a different fw flash would help.
jprc is offline
post #865 of 2336 Old 01-18-2014, 11:27 AM
Quoted: 26 Post(s)
Liked: 37
JPRC
Thank you for the move to the top of the list idea. I did try that along with deleting the channels and doing a re flash and reset. Still in the same situation. I have sent an email to Mediasonic and hopefully they have a fix
post #866 of 2336 Old 01-18-2014, 01:25 PM
geeman2001's Avatar
Does anyone have the V14 QAM firmware?
geeman2001 is offline
post #867 of 2336 Old 01-18-2014, 03:41 PM
Aleron Ives's Avatar
Quoted: 1570 Post(s)
Liked: 1274
Since jkuhlmann is trying to use QAM, my guess would be that perhaps the channels that don't appear for recording don't send any clock data. If the Homeworx doesn't know what time it is, using timers is impossible.
Aleron Ives is offline
post #868 of 2336 Old 01-18-2014, 04:44 PM
JHBrandt's Avatar
Liked: 726
I was about to say, timer recording with QAM is not likely to work in any case due to lack of PSIP to set the clock.
JHBrandt is offline
post #869 of 2336 Old 01-18-2014, 04:49 PM
JHBrandt's Avatar
Liked: 726
Doesn't look like either of the iView remotes. Here's a pic:
Actually looks pretty good, except for the odd placement of the zero and dash keys confused.gif
JHBrandt is offline
post #870 of 2336 Old 01-18-2014, 08:47 PM
2flags's Avatar
I hope this Q isn't out of order .... but after using the PVR .... any suggestions on how to edit the recordings? Case in point, to ensure that I get the full program, I set the record timer for a minute before and a minute after the programming. In situations where 2 shows are back to back (on same channel) - 1 make one recording. Now I wonder how to delete out the extra materials or how to split the file. Any suggestions? Thanks.
2flags is offline
Reply HDTV Recorders
