hi,
you may post any questions / issues/ suggestions you may have about Homeworx HW-150PVR here
or in our forum
http://forum.mediasonic.ca/viewforum.php?f=44
HW-150PVR Firmware update V10
http://forum.mediasonic.ca/download/file.php?id=321
it fixes the following issues
* Time
* Recordings / Daily / weekly
* Page down in EPG
**Note: Due to not being able to get Program guide from QAM Clear channels, We decided to continue just to focus on OTA support, as we originally intended to do.
Edit: Sept. 09, 2013
New Remote Layout on new batch of HW-150PVR
due to customer's feedback, we changed the layout of the remote (no new button, just new layout)
If your HW-150PVR have serial # HW-150PVR13070001 and UP. it comes with a new remote layout "Timer" beside the "REC", This unit has V8 version of firmware and it contains same fix as V10, so you do not need to flash the firmware on it.
http://forum.mediasonic.ca/viewtopic.php?f=44&t=1811
ATTN: If you have V8 or V13 Firmware DO NOT install V10. Your V8 and V13 is latest for your unit, With same fixes as V10
V8, no firmware update required.
V10, no firmware update required.
V13, no firmware update required.
V14, no firmware update required
V1, no firmware update required
If your box come with different firmware then the above,please contact us and let us know which firmware you have now
V1 has a new Dome MSD1237 and comes with PAL disabled (don't think we use that in North America)
So whoever got V1, Do not think is old, cause V14, V13,V8 will not work with it
if you need QAM for V1
contact us
Stop chasing for firmware update ( there is no update)
if you box came with
V8 is the latest for your unit
V13 is the latest for your unit
V14 is the latest for your unit
V1 is the latest for your unit
all the above have the same fix as V10 (the only major fix we released)
if there any firmware update we will announce it
email us: rma_east AT mediasonic.ca
or in our forum
* Time
* Page down in EPG
contact us
