Homeworx HW-150PVR, Support and Discussion - Page 44 - AVS Forum | Home Theater Discussions And Reviews
 78Likes
post #1291 of 2312 Old 06-03-2014, 05:48 PM
ColdCase's Avatar
The PVR has been known to not work well with USB sticks with flash memory. Just saying to perhaps think about purchasing at outlets with a generous return policy.
PDP-6010FD, VSX1123K, HW-150PVR, Snell E111 Mains, Polk Center, VTF3Mk4 Sub, DIY surrounds, HD XA2, DMR HS2, DV F27, HR21-200, TH-50PH9UK, VSP-1100, PSW200... some other stuff.
ColdCase is offline
post #1292 of 2312 Old 06-03-2014, 07:02 PM
satpro's Avatar
No just slow usb flash drives, others work great.
I have been using mine with team color brown 16gb usb 3.0 and maxell color green 32gb usb 3.0 for nearly a year and have no problems. Both models write in usb 2.0 mode at over 20-30 MBs.
Can even timeshift with no problem, These are also 4 channel usb 3.0.
Other brands and models like adata value usb 3.0 color yellow do not work and skip seconds here and there because they are slower and 2 channel.
satpro is offline
post #1293 of 2312 Old 06-19-2014, 01:24 PM
Liked: 0
I just bought this device and it seems that the output is blurry, and when I change the resolution / screen size it doesn't seem to make a noticable difference. Is this the expected behavior or did I possibly get a bad unit?
avs_n00b is offline
post #1294 of 2312 Old 06-19-2014, 02:50 PM
laridae's Avatar
Quoted: 29 Post(s)
Liked: 49
Are you using HDMI out to the TV?
If so the PQ should be just as good as if you went straight to your TV's tuner ie uncompressed HD which is very good.
Cable-free since Nov 2013
laridae is offline
post #1295 of 2312 Old 06-19-2014, 05:29 PM
jjeff's Avatar
Quoted: 666 Post(s)
Liked: 244
Agreed, HDMI or Component should be as clear as is broadcast, composite(yellow cable) is somewhat "blurry" and is really only good for a old blurry tube TV or very small(<10") flat screen. If changing the screen size/resolution doesn't change things it sounds like your watching through composite which is always 480i regardless of settings.
jjeff is offline
post #1296 of 2312 Old 06-20-2014, 11:29 AM
JHBrandt's Avatar
Quoted: 1387 Post(s)
Liked: 718
If you're using composite (a cable with 3 RCA plugs colored yellow, red, and white) or RF (on channel 3 or 4), the resolution is fixed at SD and can't be changed. Try using HDMI or component cables instead.
If your TV doesn't have those inputs, then you can only get standard definition (SD) from a set-top box like the Homeworx. But even SD shouldn't be terribly blurry (except on a large screen or a screen close to your eyes).
It could be the source broadcast. A lot of stations are still in SD, and some use poor-quality equipment to digitize analog content. Try other stations.
It could also be your TV/monitor.
JHBrandt is offline
post #1297 of 2312 Old 06-20-2014, 02:03 PM
ColdCase's Avatar
You will find the PVR menu text blurry in SD. Some are often not readable.
ColdCase is offline
post #1298 of 2312 Old 06-23-2014, 08:26 AM
JHBrandt's Avatar
Liked: 718
That's true - I've noticed that with some other STB's as well. You often need more than composite to read box-generated closed captions, menus, etc.
The only SD output the HW doesn't support is S-video. True, few use it anymore, but it does make SD text more readable, and since the HW supports composite anyway, they could easily have thrown it in.
JHBrandt is offline
post #1299 of 2312 Old 06-23-2014, 12:13 PM
Liked: 0
Thanks for the replies everyone. I am feeding the composite outputs straight to the TV and it is the blurry and the resolution does not change. It is fixed at the standard screen size, and will not fill the widescreen TV.
I am also using the HDMI output through the Xbox One. This looks much better and takes up the full screen, but still looks a bit blurry as compared to feeding the cable directly into the TV.
It sounds like the composite output result is expected, but maybe the HDMI looking worse than regular TV connection is not expected. Is this correct?
avs_n00b is offline
post #1300 of 2312 Old 06-24-2014, 12:41 PM
JHBrandt's Avatar
Liked: 718
Yes, if your TV screen is large (it sounds like it is), then composite is going to look a little blurry (especially on text, as mentioned earlier). BTW, if you want to stretch or zoom the composite output, you should be able to do that with your TV. Switch to the composite input, then there should be an "aspect" control on your TV's remote or menu.
As for your HDMI not looking right, I'd start by removing the XBox from the chain and temporarily connecting the HW directly to the TV via HDMI. (You'll add the XBox back to the chain later.)
Set your HW's resolution to the value nearest your TV's "native" resolution. Use 1080p or 1080i if your TV's screen has at least that many lines; if it has fewer, use 720p. At this point, the HW output should look very close to your TV's tuner.
Now disconnect the HW, connect the XBox, and set your XBox's output resolution to the same value as the HW. Finally, hook the HW up to the XBox. Hopefully, everything will be OK now.
What we're trying to do here is avoid rescaling the image more than necessary. We want the HW to scale the image to the TV screen's resolution, or at least as close as possible, then stay the same resolution going through the XBox, then hopefully the TV won't have to rescale it again, or at least not by a noticeable amount.
laridae likes this.
JHBrandt is offline
post #1301 of 2312 Old 06-25-2014, 04:32 PM
Mbajner's Avatar
Quoted: 39 Post(s)
I just bought the HW150pvr off Amazon a few weeks ago. Very impressed with the quality of the signal using and HDMI connection
sure beats out the lower SD picture quality of my other STB boxeds(Zenith, RCA, Colby)
so far the recording to a USB thumb drive works out OK. only glitch I noticed is breakup in the recording when past the half hour mark
this maybe my thumb drive, will try a newer faster one soon
Mbajner is offline
post #1302 of 2312 Old 06-25-2014, 10:10 PM
Liked: 0
Thanks for this reply. I did as you suggested and I am now unable to tell any difference between the HDMI signal from the HW. , the HDMI signal run through the converter, and the picture produced by the TV's internal converter. (Yes my TV has a DTV input - I am just using this device to get OTA TV through the Xbox interface.) I think connecting it directly to the TV helped get the resolution right. The other thing that I think was throwing me off is I was using two news/weather stations with overlays which appear to have been produced in a different lower resolution than 1080p, and are just blurry even using the TV's converter.
avs_n00b is offline
post #1303 of 2312 Old 07-05-2014, 03:58 PM
Firestorm64's Avatar
Liked: 0
Originally Posted by jprc View Post
<div class="quote-container" data-huddler-embed="/t/1482341/homeworx-hw-150pvr-support-and-discussion/400_100#post_23960493" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>satpro</strong> <a href="/t/1482341/homeworx-hw-150pvr-support-and-discussion/400_100#post_23960493"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
Has anyone tried the HW180stb yet and does it record?<br><br>
<a href="http://www.amazon.com/gp/redirect.html?ie=UTF8&amp;linkCode=ur2&amp;camp=17 89&amp;creative=9325&amp;tag=avsforum_vs-20&amp;location=http%3A%2F%2Fwww.amazon.com%2FHome Worx-HW180STB-Digital-Converter-Function%2Fdp%2FB00G5RXM16%2Fref%3Dpd_sim_sbs_e_1" rel="norewrite" target="_blank">http://www.amazon.com/HomeWorx-HW180STB-Digital-Converter-Function/dp/B00G5RXM16/ref=pd_sim_sbs_e_1#productDetails</a></div>
</div>
<br>
Don't have it but it is not supposed to record and it only supports a 64GB thumb drive for playback.<br><br>
Edit: I found the post on mediasonic's forum that I was looking for when they were asked about this a while ago. Here are two of the admin's posts:<br><br>
Admin_Mediasonic wrote:actually 180STB is an update to the now discontinued 100stb<br>
So NO PVR<br><br>
basically is similar to 150PVR, BUT no PVR, NO digital audio out.<br>
so upgrading the 100stb to include HDMI and Media player for people to watch their downloaded or self created content<br>
so just a basic ATSC Tuner + media player
Are theere any firmware updates for the hw 180stb?
Firestorm64 is offline
post #1304 of 2312 Old 07-05-2014, 04:04 PM
jprc's Avatar
Quoted: 82 Post(s)
Liked: 120
This isn't the place to be asking. Go to Mediasonic's forum for info on that box.
jprc is offline
post #1305 of 2312 Old 07-11-2014, 12:11 PM - Thread Starter
MediasonicEast's Avatar
Hi,
QAM is already enable on it,
So there is no firmware update for HW180STB
currently No firmware update is needed for HW150PVR
only update is for people looking to enable QAM
and a reminder to people asking for QAM update on HW150PVR
QAM is disabled by default. And we strictly sell HW150PVR as OTA
we don't advertise QAM ready etc..
QAM firmware was done by user request. We don't officially support it
So find out if your cable provider supports it 1st. if you want to try QAM
Don't complain that QAM is not working for you and that this box is useless for you now, etc.. and that you will return the product.
If that keep happening, we might as well stop giving people QAM enabled firmware and stick to OTA as our original plan.
regards,
MediasonicEast is offline
post #1306 of 2312 Old 07-12-2014, 08:47 AM
afterlife2's Avatar
Quoted: 162 Post(s)
Liked: 78
Anyone here having a problem with fast fowarding through commercials 32x and it gets stuck?
afterlife2 is offline
post #1307 of 2312 Old 07-12-2014, 11:28 AM
laridae's Avatar
Quoted: 29 Post(s)
Liked: 49
Not anymore, not since I started using a Logitech Harmony 650 to replace their flimsy little highly-directional remote. It works great and the Homeworx 150 is supported in their database. It's easy to set up; just select and sync.
If you can just get past the fact that the Harmony costs way more than the Homeworx box then just go ahead and get one!
In my case it helped that it was a Christmas gift, otherwise I'd probably still be making do and struggling.
Read more about it here;
http://forum.mediasonic.ca/viewtopic...fe5aa2e8bc98d0
laridae is offline
post #1308 of 2312 Old 07-13-2014, 07:26 PM
Liked: 0
Is it possible to get name of recorded shows instead of just an encoding of the channel and date? That would be way more useful.
RCKadath is offline
post #1309 of 2312 Old 07-14-2014, 06:01 AM
laridae's Avatar
Quoted: 29 Post(s)
Liked: 49
Many have asked, but no. As you've found at that price it's a pretty basic box with no bells and whistles.
Best you can do is manually edit the filename after the fact.
laridae is offline
post #1310 of 2312 Old 07-14-2014, 11:07 AM
afterlife2's Avatar
Quoted: 162 Post(s)
Liked: 78
I should have been more clear, when I use 32x the picture gets stuck. I have to turn it off to get it back to play. I'm using 16x now hopefully that will help. The remote works fine.
post #1311 of 2312 Old 07-17-2014, 08:30 AM
underminded999's Avatar
Quoted: 29 Post(s)
Originally Posted by Mbajner View Post
I just bought the HW150pvr off Amazon a few weeks ago...
I had the same problem. On a certain channel 1hr long programs were cutting off at 28min. On other channels, I could get hours of recording.
Channels with sub channels, can record more for longer. On our local CW station, there are no sub channels, and 1hr programs are quite large. I missed it because I would do my test records based on shows on other channels and other stations, but once I got a bigger HD, everything has been solved. So yeah, it is a file space/size issue.
Get a larger thumb drive, a la 16 or 32GB, or just bite the bullet and get an External HDD.
underminded999 is offline
post #1312 of 2312 Old 07-17-2014, 10:10 AM
plplplpl's Avatar
Liked: 24
Just to be sure, your USB flash drive is formatted to NTFS, not FAT32, isn't it?
plplplpl is offline
post #1313 of 2312 Old 07-17-2014, 04:23 PM
happy2Lurk's Avatar
Quoted: 34 Post(s)
Liked: 27
Posted this in the Pal DVR thread, but may be of interest here too ...
I was flipping between channels today, watching coverage of the downed plane. Around 1pm Pacific Time, ABC was black screen for 10 seconds or more before tuning in. I could see the HDD had no activity (external dock) until just before the picture appeared. Repeated this several times.
I then tried my Mediasonic HomeWorX HW150PVR - it tuned ABC quickly. Tried WMC using SiliconDust HDHomeRun Dual HDHR3-US - would not tune. My TV also would not tune ABC.
Used the, "Hdmomerun Signal Meter," to check signal - normal signal strength/Quality - but no channel or call letters.
Sent an email to the station and problem now corrected.
Not a pal issue but interesting that the cheap Hmwrx had no problem, while the pal tuned eventually - but HDHomeRun QuickTV and WMC would not tune at all.
What might be most interesting to you all here - ABC is my worst "flashy" station - but while this was going on, no flashing. After the station ID was restored - Flashy! (Flashy is the picture, black screen, picture cycle when tuning some stations)
happy2Lurk is offline
post #1314 of 2312 Old 07-20-2014, 12:58 PM
Liked: 0
Hi.. I would like to know if this devise has an update software driver that is QAM PSIP Type that located sd channels
loz0 is offline
post #1315 of 2312 Old 07-20-2014, 02:16 PM
laridae's Avatar
Quoted: 29 Post(s)
Liked: 49
If you are asking if this machine supports QAM broadcasts, the answer is No - it only has ATSC tuning for OTA signals.
Some of its clones, like the iView, for example may have some limited or beta QAM support and you can learn more about that on their forums.
laridae is offline
post #1316 of 2312 Old 07-20-2014, 03:44 PM
Aleron Ives's Avatar
Quoted: 1556 Post(s)
Liked: 1261
This is wrong: the Homeworx and iView have the same hardware, and both of them can tune QAM. The difference is that the latest Homeworx firmware disables QAM support. If you want to be able to tune QAM, you have to use one of the old, unsupported QAM firmware revisions.
Aleron Ives is offline
post #1317 of 2312 Old 07-20-2014, 06:24 PM
laridae's Avatar
Quoted: 29 Post(s)
Liked: 49
Thank you, I stand corrected.
So a better answer for the OP would be that he could try to get an Old version of the firmware for the Homeworx. But is that a good idea? As I recall the older versions of the f/w were very buggy.
Otherwise he should look into one of the clones, as I suggested.
laridae is offline
post #1318 of 2312 Old 07-20-2014, 07:32 PM
Liked: 1261
Yes, it isn't recommended, which is why MediaSonic removed it. You can't set the clock or see channel names on most cable systems, as they don't provide PSIP. This makes it impossible to perform timed recordings and renders the Homeworx useless except as a tuner (or if you want to record something immediately). MediaSonic didn't want to deal with the customer service complaints that this would generate, so they removed QAM support from the most recent firmware revisions.
post #1319 of 2312 Old 07-20-2014, 11:00 PM
Liked: 0
Question in regards to mediasonic Hw-150 PVR . My device continues to be unresponsive or will not remember configures when device is booted back on. ie: the aspect will change with no audio . Only prosperity is to re alter the aspect to my desire or go through the list once till it rolls over = the responsive aspect + audio. If there is a fix!! Or if already discussed can I have a relay to that?
loz0 is offline
post #1320 of 2312 Old 07-21-2014, 06:31 AM
Liked: 0
Also I would to know if you recommend Gold played cable wires or in this case it is recommended but the differences are minor if not no comparison. Because I changed the hdmi cable to gold plated and the audio is now sustained when powered off and back on ! As far as I know . Btw only has been tested once!
loz0 is offline
Reply HDTV Recorders
For the best viewing experience please update your browser to Google Chrome
