Homeworx HW-150PVR, Support and Discussion - Page 58 - AVS Forum | Home Theater Discussions And Reviews
 94Likes
post #1711 of 2469 Old 07-25-2015, 11:35 AM
jjeff's Avatar
Quoted: 777 Post(s)
Liked: 278
Originally Posted by afterlife2 View Post
The cool thing also is there is no 12am bug on the Ematic either and the remote is nicer and thicker.
That would be worth it, if I were in the market for another DVR. My iView has the midnight bug where any event spanning midnight records forever unless you manually stop it, which is a pain because often times when I used it, it would be for events spanning midnight and the next morning it would still be recording
How something so obvious made it past the testing stages amazes me
jjeff is offline
post #1712 of 2469 Old 07-25-2015, 12:50 PM
afterlife2's Avatar
Quoted: 163 Post(s)
Liked: 79
Yeah I was shocked when I woke up I saw that the box was off. They also installed the cable channel firmware without having to email anyone. Just sucks that the Coaxial was not added. I wonder why HDMI can't have this feature to get Dolby Digital when viewing files on any of these DVR boxes? Am also looking to see if the Ematic has firmware update?
afterlife2 is offline
post #1713 of 2469 Old 07-25-2015, 12:57 PM
Aleron Ives's Avatar
Quoted: 1692 Post(s)
Liked: 1449
What does it matter? You don't need to "get" Dolby Digital, as it's part of the broadcast. It doesn't matter whether the Homeworx or your receiver decodes it.
Aleron Ives is offline
post #1714 of 2469 Old 07-25-2015, 01:20 PM
afterlife2's Avatar
Quoted: 163 Post(s)
Liked: 79
I like the surround on some of my shows, so yeah it's cool to have. I can use my Oppo or Sony players to get DD with the files, but the box should be able to do it.
post #1715 of 2469 Old 07-25-2015, 01:37 PM
Liked: 1449
HDMI delivers 5.1 surround, unless the Homeworx is broken and always downmixes to 2.0 over HDMI?
post #1716 of 2469 Old 07-25-2015, 02:00 PM
afterlife2's Avatar
Quoted: 163 Post(s)
Liked: 79
Yep. I will change HDMI cable on the Ematic, but the HW always had that issue and I always used the Coaxial to get 5.1 with the files.
post #1717 of 2469 Old 07-25-2015, 03:07 PM
afterlife2's Avatar
Quoted: 163 Post(s)
Liked: 79
Nope just stereo on the Ematic as well with files. Ah it's ok no biggie.
post #1718 of 2469 Old 07-25-2015, 05:19 PM
JHBrandt's Avatar
Quoted: 1792 Post(s)
Liked: 860
This is a well-known bug in all these boxes. If you're watching live or watching a "movie," you can set Digital Audio to "RAW HDMI On" and the box will pass DD 5.1 audio directly to your receiver. But if you're watching a recording, it always down-mixes to 2.0
There's a workaround but you need a PC. Simply rename your recordings, changing the extension from .mts to .ts. Then the box will think they're "movies" and pass the DD 5.1 audio to your receiver.
JHBrandt is offline
post #1719 of 2469 Old 07-25-2015, 05:29 PM
JHBrandt's Avatar
Liked: 860
I'm confused; I thought that midnight bug had already been fixed. I've scheduled midnight-crossing recordings without running into it.
There's another midnight bug that hasn't been fixed AFAIK: if you try to schedule a recording that spans midnight, and you already have other recordings scheduled for the same day, these boxes will falsely report a conflict. You have to delete the other recordings scheduled for that day, schedule the midnight-crossing recording first, then reschedule the others, to get around it.
JHBrandt is offline
post #1720 of 2469 Old 07-25-2015, 05:41 PM
afterlife2's Avatar
Quoted: 163 Post(s)
Liked: 79
Thanks I forgot about that. By the way the Ematic is V2 which was added on Jan. 2015
Was the HW-150 midnight bug fixed? If so where can I get that firmware? Darn I'm trying to buy the HW-150 remote, but when I click on it, it does nothing.
post #1721 of 2469 Old 07-25-2015, 06:14 PM
JHBrandt's Avatar
Liked: 860
Which firmware version is your HW-150 on?
JHBrandt is offline
post #1722 of 2469 Old 07-25-2015, 07:44 PM
afterlife2's Avatar
Quoted: 163 Post(s)
Liked: 79
JH It's v14 why?
post #1723 of 2469 Old 07-25-2015, 08:22 PM
JHBrandt's Avatar
Liked: 860
That's the version I have, but I haven't experienced run-on recordings when crossing midnight IIRC I only crossed midnight by a couple of minutes, but that shouldn't make any difference.
Anyway, I don't think there's an upgrade from V14. (I do remember someone had a HW-150 with V18, but I don't know of anyone who has that version as a file. Mediasonic quit posting firmware files for download around V14 due to compatibility issues.)
JHBrandt is offline
post #1724 of 2469 Old 07-25-2015, 09:00 PM
m. zillch's Avatar
Quoted: 1999 Post(s)
Liked: 1283
Originally Posted by m. zillch View Post
I suspect USB hubs won't work without drivers and I don't think our PVRs are setup to supply drivers to outboard hubs. Instead, a powered USB splitter along the line of a USB "Y cord" with one end plugged to the USB charger port of say a cell phone, like the white cube which Apple supplies with their iphones, might be a better bet.
P.S. I have these on order from monoprice for another application but I thought to try it on my PVR and hard drive too:
http://www.monoprice.com/Product?c_i...seq=1&format=2
Oops, I guess I would need another male to male USB to make it work.
Strike that. It injects extra current from the AC adaptor. The second female USB isn't used. Think of it as a powered USB extension cord. I hope the (optional?) "hub" aspect doesn't need drivers.
So I just plugged it in. As JHBrandt said it does get recognized as a "generic hub" on both my notebook and the iView lists "USB 1" and "USB 2". Here is my initial findings should anyone else be looking to get some 32 feet of extension and expansion:
It powers and reads my thumb drive all by itself. No AC power needed thanks to the bus powered internal amp (it has a red LED to show it is active) even though it is now 32 extra feet away. My Western Digital 2 TB Ultra Passport [bus powered] is a different matter though. Without the AC cord plugged into the new extender/hub cord, its power light comes on and it seems as if it "should" work but when you attempt to read the 2TB drive all you get is a blank page and the drive does not spin. Good thing I got the optional AC power cord! That makes it all work great!
P.S. They have shorter less expensive versions and longer more expensive versions even getting up to, *gulp*, 82 feet long, should people be interested.
In A/V reproduction accuracy, there IS no concept of "accounting for personal taste/preference". As art consumers we don't "pick" the level of bass, nor the tint/brightness of a scene's sky, any more than we pick the ending of a novel or Mona Lisa's type of smile. "High fidelity" means "high truthfulness", faithful to the original artist's intent: an unmodified, neutral, accurate copy of the original master, ideally being exact and with no discernable alterations, aka "transparency".
m. zillch is offline
post #1725 of 2469 Old 07-27-2015, 06:54 AM
afterlife2's Avatar
Quoted: 163 Post(s)
Liked: 79
JH do you think if I put the v14 again on the HW the midnight bug fix may work?
post #1726 of 2469 Old 07-27-2015, 07:10 PM
JHBrandt's Avatar
Liked: 860
I suppose it's possible your HW firmware is corrupted. If so reinstalling might fix several problems - maybe even your remote. Or it might not help at all.
You'd just have to try and see, but ... if your remote isn't working, how can you get to the menu to reinstall it?
JHBrandt is offline
post #1727 of 2469 Old 07-28-2015, 07:25 AM
afterlife2's Avatar
Quoted: 163 Post(s)
Liked: 79
JH Thanks. What I do is take the battery out of the remote for 2 days and it works for like ten minutes, so hopefully it may fix both issues. Do you happen to have the firmware or where I can download it? Minor issue with the Ematic it says no signal sometimes, so I have to rescan again.
post #1728 of 2469 Old 07-28-2015, 11:48 AM
afterlife2's Avatar
Quoted: 163 Post(s)
Liked: 79
I got the 14V from HW and installed it, it did nothing. Remote worked for a minute or so than went back to not working. I'm gonna have to order another remote. I hope it resolves the problem(Grunt).
post #1729 of 2469 Old 07-28-2015, 01:17 PM
m. zillch's Avatar
Liked: 1283
Do you own a volt meter? What are the batteries unloaded voltages?
post #1730 of 2469 Old 07-28-2015, 02:36 PM
afterlife2's Avatar
Quoted: 163 Post(s)
Liked: 79
No, but the batteries are tripple A
post #1731 of 2469 Old 07-28-2015, 03:50 PM
afterlife2's Avatar
Quoted: 163 Post(s)
Liked: 79
JH What do you think of this one? http://www.ebay.com/itm/Black-4-Port...item2edee64b6c
post #1732 of 2469 Old 07-28-2015, 04:58 PM
m. zillch's Avatar
Liked: 1283
Out of curiosity, when the batteries start to get weak on your remote and it is nearing the time to replace them, what symptoms are exhibited?
post #1733 of 2469 Old 07-28-2015, 05:23 PM
JHBrandt's Avatar
Liked: 860
JH Thanks. What I do is take the battery out of the remote for 2 days and it works for like ten minutes.
Don't overlook the obvious - have you tried new batteries?
It sounds like either the batteries are so weak they're getting drained by a few minutes of use, or the HW is overheating. New batteries would fix the former problem. A powered USB hub might fix the latter, but no guarantees.
You can check with the cell-phone camera trick. Wait for the remote to stop working, then turn on your cell-phone camera, point the remote at it, and press some buttons. If you see the remote control's LED light up on the cell-phone screen when you press buttons on it, the remote is working.
That looks like a decent powered USB hub at a good price. It'll take a little load off your HW or eMatic power supply.
JHBrandt is offline
post #1734 of 2469 Old 07-29-2015, 07:42 AM
afterlife2's Avatar
Quoted: 163 Post(s)
Liked: 79
I use Tenergy rechargable batteries most of the time. With no problems with the other remotes I have. I re-charge them at least every one or two months. Depending on the usage.
post #1735 of 2469 Old 07-29-2015, 07:50 AM
afterlife2's Avatar
Quoted: 163 Post(s)
Liked: 79
JH All the batteries I tried are new or rechargables and same result. I tried a couple of remotes other remotes and they all lit up. The HW remote lights up too. Should I order another remote or just give up?
Cool Thanks JH. I'm gonna order that usb for the Ematic. While watching a show the picture froze once while I watched a show maybe this will help.
post #1736 of 2469 Old 07-29-2015, 11:37 AM
m. zillch's Avatar
Liked: 1283
It's a pretty simple question. Why not just tell us the answer?
post #1737 of 2469 Old 07-29-2015, 11:47 AM
afterlife2's Avatar
Quoted: 163 Post(s)
Liked: 79
Well simply no issues as I don't let the batteries run low. My Universal UR50 which gets used the most has a battery indicater, so if they are running low I recharge it and the other remotes.
post #1738 of 2469 Old 07-29-2015, 11:52 AM
afterlife2's Avatar
Quoted: 163 Post(s)
Liked: 79
So this is what the HW remote does any button I press they work as a up and down key, except that only the up button works on every button. Get what I mean?
post #1739 of 2469 Old 07-29-2015, 12:50 PM
JHBrandt's Avatar
Liked: 860
I've learned to avoid using rechargeable batteries in remote controls. They have a lower voltage than alkaline batteries and sometimes that causes problems. So you might try alkaline batteries in your HW remote just to see if it makes a difference.
It depends on the remote though; some remotes work just fine with rechargeable batteries. I just got tired of trying to keep track of which remotes would work with them and which ones wouldn't.
You might try the powered USB hub with your HW too! Plug it in and see if it goes longer before the remote stops working. If it does, that's a good indication the HW is overheating.
BTW, you've mentioned a couple of intermittent problems with your new eMatic. I hope it's not defective.
JHBrandt is offline
post #1740 of 2469 Old 07-29-2015, 02:39 PM
afterlife2's Avatar
Quoted: 163 Post(s)
Liked: 79
Actually I had alkaline on the remote when it stopped working and put fresh ones and same thing. I've read on amazon that the Ematic freezes, so I was not surprised. I bet it's the USB thing like you said. I have the Ematic standing up so air circulate better on top and underneath. I'm gonna order that USB today. What do you think of the remote only working as the down button only JH. What would cause that?
Reply HDTV Recorders
