Homeworx HW-150PVR, Support and Discussion - Page 61 - AVS Forum | Home Theater Discussions And Reviews
 91Likes
Old 08-22-2015, 02:22 PM
JHBrandt's Avatar
Quoted: 1633 Post(s)
Liked: 795
OK so it's not the file system; everybody's using NTFS. Whew!
Still, something must be different between V9 and V10, and none of these boxes is doing anything fancy when recording: just combining the video stream and audio stream(s) for the subchannel being recorded into a file it writes to the HDD. So what could they have changed that would stop you from playing back a V9 file on a V10 box?
Here's what I can think of:
  • Different folder name. The HW150's use a folder named HBPVR for recordings. Does V9 or V10 use a different folder?
  • Different file extension/container format. The HW150's use .mts; do V9 or V10 use something else?
JHBrandt is offline
Old 08-22-2015, 02:28 PM
mickinct's Avatar
Quoted: 204 Post(s)
Liked: 901
  • Different folder name. The HW150's use a folder named HBPVR for recordings. Does V9 or V10 use a different folder? HBPVR
  • Different file extension/container format. The HW150's use .mts; do V9 or V10 use something else? .MTS THE v10 has a newer better tuner, and does not have the wall adapter for power.
MickinCT
mickinct is online now
Old 08-22-2015, 03:31 PM
JHBrandt's Avatar
Liked: 795
So everything is the same; yet the V9 files still won't play? That's very strange.
Try this: take one of the recordings that won't play and rename it on a PC, changing the ".mts" to just ".ts," then see if it plays as a "movie." (This is the old trick for getting DD 5.1 sound out a recording, but in this case I just want to see if it plays at all.)
JHBrandt is offline
Old 08-22-2015, 09:12 PM
lanb's Avatar
Quoted: 12 Post(s)
Clear QAM
Just to answer my own question, the new 180-STB does support clear QAM with firmware version 10.1. Just got mine from Amazon and was able to
tune these by selecting Channel Search -> Cable from the Menu. Also picks
up the numerous scrambled channels though.
Thanks to mediasonic support !
HTH !
PerryH likes this.
lanb is offline
Old 08-24-2015, 02:44 PM
lanb's Avatar
Quoted: 12 Post(s)
On a related note, is there a way to set the clock manually in the 180-STB ? That would help to schedule timer recordings
of these QAM channels
EDIT : Never mind , the box actually picked up the right time from the QAM channels.
lanb is offline
Old 08-24-2015, 09:50 PM
pngasius's Avatar
Quoted: 25 Post(s)
Can the mediasonic hw-150pvr play back recorded shows in dolby digital 5.1 via HDMI that were broadcasted in dolby digital 5.1?
pngasius is offline
Old 08-24-2015, 10:05 PM
Aleron Ives's Avatar
Quoted: 1631 Post(s)
Liked: 1381
IIRC you have to access the recorded file with a PC and change the file extension from .mts to .ts, and then you can get 5.1 audio on playback. You'll only get stereo if you don't change the extension.
Aleron Ives is offline
Old 08-24-2015, 10:27 PM
pngasius's Avatar
Quoted: 25 Post(s)
Thanks for the reply. I will have to pass on this one then. Do any of these cheap boxes playback in DD 5.1?
pngasius is offline
Old 08-24-2015, 11:55 PM
Liked: 1381
No. They all have the same bug, AFAIK. You need to step up to the DVR+ at least if you want 5.1 playback.
Old 08-25-2015, 06:52 AM
mickinct's Avatar
Quoted: 204 Post(s)
Liked: 901
You set audio in menu option to RAW.
MickinCT
Old 08-25-2015, 06:53 AM
mickinct's Avatar
Quoted: 204 Post(s)
Liked: 901
MickinCT
Old 08-25-2015, 11:48 AM
JHBrandt's Avatar
Liked: 795
Yes, but as Aleron Ives mentioned, due to a bug it's not exactly straightforward:
DD 5.1 bug: When playing back a recording, it always plays in stereo even on DD 5.1-capable audio equipment. Workaround is to change the file extension from .mts to .ts and play the recording as a "movie;" the audio will then play in DD 5.1.
AFAIK all these boxes (HW150, HW180, iView 3200, iView 3500, eMatic, etc.) have this bug. But I don't have a DD 5.1 AVR and I couldn't possibly test them all myself anyway. If anyone has one of these boxes that plays back recordings in DD 5.1 without having to change the file extension, please post the box and firmware version that works!
Well, you have to do that to get DD 5.1 at all, even when watching live. But unless your box has firmware that fixes the above bug (and please let us know if you do!) it still doesn't work when playing back a recording.
JHBrandt is offline
Old 08-25-2015, 12:22 PM
JHBrandt's Avatar
Liked: 795
Originally Posted by lanb View Post
Just to answer my own question, the new 180-STB does support clear QAM with firmware version 10.1. Just got mine from Amazon and was able to tune these by selecting Channel Search -> Cable from the Menu. Also picks up the numerous scrambled channels though.
HTH !
It does help. As I noted earlier, the last HW150 I bought also supported clear QAM (although I have nothing to test it with). So apparently Mediasonic is now shipping these boxes with clear QAM enabled, even if they don't advertise or support it. Probably saves them from having to provide umpteen different QAM firmware versions to folks who request it. Seems like they change firmware versions every few months, and trying to keep up with all the different versions they've sold probably just got out of hand.
Picking up scrambled channels is a longstanding bug, and an especially annoying one if it makes you hit the 400-channel limit. I guess they still haven't addressed that one.
JHBrandt is offline
Old 08-25-2015, 01:11 PM
mickinct's Avatar
Quoted: 204 Post(s)
Liked: 901
I have v10.0 no DD 5.1 on playback through unit, but when played back on my KDlinks hd720 units is is full 5.1 DD.via HDMI to my Yamaha HTR
MickinCT
Old 08-25-2015, 01:37 PM
lanb's Avatar
Quoted: 12 Post(s)
Getting rid of scrambled channels
Yeah, Here is what I did -
1) Did the auto scan to get both the scrambled and clear channels. Luckily, my max was 378 channels (below 400 limit).
2) Went thru all the channels and noted the main channels which had clear QAM (about 10+)
3) Set the channel search to Air and did a auto scan again which cleared all the stored channels.
4) Set the channel search to Cable and did a channel by channel manual scan of the 10 clear QAM channels, using the previously noted main channel #s .
Easier than deleting 368 scrambled channels
JHBrandt likes this.
lanb is offline
Old 08-25-2015, 01:44 PM
Liked: 1381
Yes, but you're bypassing the bug in a different way. People want to get DD 5.1 when playing their recordings on the DVR, and you can't. There's nothing wrong with the recordings; the DD 5.1 is still there. These boxes just refuse to play all 6 channels unless you change the extension from .mts to .ts, and you can't do that unless you connect your HDD to a PC to rename the files. Connecting the HDD to another media player also lets you bypass the firmware bug, but it doesn't solve the problem.
Old 08-25-2015, 02:10 PM
JHBrandt's Avatar
Liked: 795
I have v10.0 no DD 5.1 on playback through unit....
Thanks @mickinct and @lanb !
OK, so HW180 firmware V10.0 still has the DD 5.1 bug. Lanb has V10.1, but I don't know if he has an AVR to test DD 5.1 with.
They probably didn't fix it in V10.1 either, but we don't know for sure yet.
JHBrandt is offline
Old 08-25-2015, 02:13 PM
mickinct's Avatar
Quoted: 204 Post(s)
Liked: 901
I tried mts to ts and tried to see if it would have DD in the 180 nothing but stereo. I also have a v9 180 have not tried that one.
MickinCT
Old 08-25-2015, 02:29 PM
Liked: 1381
Wow, so not only did they not fix the bug in the new model, but they broke one of the original workarounds, too? That's not a good sign.
Old 08-25-2015, 05:45 PM
lanb's Avatar
Quoted: 12 Post(s)
Dd 5.1
Yes, the bug is still there in 10.1 and the .ts workaround works as before.
Here are the various results when playing
Live : DD 5.1
Timeshift : DD 5.1
Recorded program with .mts extension : No DD 5.1
Recorded program with .ts extension : DD 5.1 [Note that you have to access the .ts file thru the USB -> Multimedia -> Movies option]
lanb is offline
Old 08-25-2015, 06:51 PM
mickinct's Avatar
Quoted: 204 Post(s)
Liked: 901
Recorded program with .ts extension : DD 5.1 [Note that you have to access the .ts file thru the USB -> Multimedia -> Movies option][/QUOTE] STILL did not work for me.
MickinCT
Old 08-25-2015, 07:39 PM
JHBrandt's Avatar
Liked: 795
Live : DD 5.1
Timeshift : DD 5.1
Well that confirms it. This bug is still in all boxes and all firmware versions.
Not terribly surprising though. To the extent they're working on any bugs at all (which is probably not a very great extent), I'm sure this one isn't at the top of the list.
JHBrandt is offline
Old 08-25-2015, 07:42 PM
JHBrandt's Avatar
Liked: 795
STILL did not work for me.[/QUOTE]
It does seem like they broke it even worse in HW180 versions 9 and 10.0. From the previous post it seems that in 10.1 they put it back the way it was which is still bad, but at least it's not as bad.
JHBrandt is offline
Old 08-26-2015, 08:03 AM
afterlife2's Avatar
Quoted: 163 Post(s)
Liked: 79
The fan seems to be working on the ematic so far...
afterlife2 is offline
Old 08-28-2015, 01:03 PM
mickinct's Avatar
Quoted: 204 Post(s)
Liked: 901
It does seem like they broke it even worse in HW180 versions 9 and 10.0. From the previous post it seems that in 10.1 they put it back the way it was which is still bad, but at least it's not as bad.[/QUOTE]
Just spoke to CS about the DD 5.1 problem they are going to look into it.
MickinCT
Old 09-02-2015, 06:07 PM
Quoted: 25 Post(s)
Liked: 5
I have an HW150 that was working fine. My grandaughter decided to push the front on an off button so I ended up removing the device until she left.
When I reinstalled it, I did everything the same and it works well except for one change.
Previously, if I set the time to record a program, I could put it into sleep mode (the red light is on). At the required time, it would wake up, the light turned green, the program recorded, then it went back to sleep with the red light on.
Now, I must leave it on, awake, the green light on at all time if I want the timer to work and record a show.
I can't seem to figure out how I got it to sleep and wake up. Any help appreciated.
pdbphoto is offline
Old 09-02-2015, 06:20 PM
afterlife2's Avatar
Quoted: 163 Post(s)
Liked: 79
Try a reset.
Old 09-02-2015, 07:15 PM
RF8655's Avatar
Quoted: 12 Post(s)
What might be happening is the last channel tuned has its time incorrectly set or not at all. This is a known problem in using the timer feature. In these cases, the unit will not wake up nor record even though a record program was set, as the unit depends on the the tuned station for correct time (it has no internal clock). The solution is to set the unit's channel to one known to have a reliable clock before turning off, probably the channel you want to record.
RF8655 is offline
Old 09-03-2015, 09:26 AM
Quoted: 25 Post(s)
Liked: 5
Thanks RF. I will certainly give that a try.
It's been a reliable device overall and I would like to continue using it.
pdbphoto is offline
Old 09-15-2015, 08:40 PM
DoctorM's Avatar
Quoted: 681 Post(s)
Liked: 207
Maybe you guys know: Does the HW-180STB have the fixed closed caption firmware that the 150PVR has so that you can turn them on during playback (over HDMI)?
Also, besides losing the component output, are there any other differences between the 150 and 180?
For being an updated version, the 180 seems surprisingly unpopular.
DoctorM is online now
