Homeworx HW-150PVR, Support and Discussion - Page 64 - AVS Forum | Home Theater Discussions And Reviews
 86Likes
post #1891 of 2389 Old 12-30-2015, 08:10 AM
dmatch's Avatar
Quoted: 34 Post(s)
Liked: 24
IMHO, jprc did a fine job of describing the 150 PVR. Regarding:
Originally Posted by jprc View Post
I don't know what your neighbor's tolerance is for buggy software. If he's the kind of guy that will get pissed if his show doesn't always get recorded, this is not the box to rely on. It works most of the time, but there will be occasions when if the reception is off for a moment, or even for no apparent reason, it may just not record or it may stop recording in the middle....
I found that even very short losses of signal (e.g. plane flying over or lightning in the distance) would cause the PVR to stop when playing the video. In these instances it wasn't that it didn't record but that the PVR thought the recording was thru when the hiccup hit and would stop. If I played the same exact recording on my PC (moved HDD to PC) recording would play past those signal glitches.
dmatch
JHBrandt likes this.
dmatch is offline
post #1892 of 2389 Old 01-15-2016, 06:17 AM
JHBrandt's Avatar
Quoted: 1572 Post(s)
Liked: 769
Originally Posted by GuruSR View Post
Cheat! Get yourself a USB 2 Y cable, buy a cheap (6$-ish) 0.5amp AC to USB adapter, plug the spare one onto it, then the data cable (has 2 wires on it) into the Homeworx, should work fine. If you find it doesn't work, keep the bill for the 0.5amp AC to USB and go get a 1A one, that *will* make it fire up because combined you're giving it ~1.25A to play with, if the external drive can't run on that, then you really need to find a replacement for that power hog, but yes, the Homeworx doesn't have great USB power, their port is the typical 250mA that is necessary for standard hub pairs (500mA for the pair).
As for the heat issue, not sure why you're having it, my sister's doesn't seem to heat up that much after an hour of playing off their usb stick, though due to it being plastic, it's possible it's receiving heat transfer from whatever you have above or below it? Is it alone or enclosed in a cabinet?
GuruSR.
Thanks for that info. Actually, I've made the same suggestion for others who have trouble with not enough power to their USB-powered HDDs.
My "vision" for this one was to get everything installed within the box, and to have the fan run only when the HW was on. (It's not loud but does make a little noise.) That's why I tried to power it from the HW's own port.
I suppose the ideal answer would be a powered USB hub, provided the hub's power supply could be safely wired to the 120V input power within the HW's box somehow, and provided it switched power to its USB ports based on whether power was supplied to its input port. Possible, I suppose; but it sounds like a very tight fit.
As for overheating, I've found you can't always tell by feeling the outside of the box. It was only after I opened it up (initially, to try to repair its USB port) that I noticed some components could get pretty hot, and thought a fan might improve things.
JHBrandt is offline
post #1893 of 2389 Old 01-15-2016, 11:55 AM
GuruSR's Avatar
Not sure if this will help, as I don't know the internals of the Homeworx, though, try looking at a "heatsink kit" for older PCs, they typically will have small sleeve bearing fans, also small video card replacement fan kits may also be of help. You may have better luck looking at electronic component stores to find items that may be best suited for that unit, although my sister's unit isn't having this issue with heat. I know the USB is a bit of a pain issue, but hers doesn't seem to get hot, I checked it after it was playing a show for an hour, was moderate. Any idea how hot it is getting? Too hot to touch or comfortably warm?
GuruSR.
GuruSR is offline
post #1894 of 2389 Old 01-15-2016, 12:26 PM
JHBrandt's Avatar
Liked: 769
A couple of the chips inside were too hot to touch, so I figured a fan was in order. That said, it didn't seem to be malfunctioning in any way aside from the broken USB port (which I was able to fix, albeit with some difficulty).
I should also mention that the internal design of these units has changed several times; this was one of the older Homeworxes with a separate small PCB for the USB port, making it both easier to break and easier to fix This older model also had separate PCBs for the power supply and main board. Newer HWs are built differently, with fewer PCBs. Probably makes them cheaper to build and maybe a bit more reliable; but also harder to repair if they do break and harder to tinker with.
Edit: I just had a (different) Homeworx die. (It would power on, but wouldn't boot. Wouldn't even show the "HomeWorX" splash screen.) It was out of warranty so I took the cover off. Didn't see any obvious problems that I could fix, so it went in the trash; but while I had it apart I noticed that, compared to the older model:
  1. The power supply and main board were combined into one single board
  2. The USB port was on the same PCB as the LED, channel switches, and IR remote sensor, not its own PCB as in the older model.
JHBrandt is offline
post #1895 of 2389 Old 01-19-2016, 02:31 PM
JHBrandt's Avatar
Liked: 769
dmatch
I suppose you could also try the "GoTo" button on the remote to skip to a point past the glitch and continue watching the recording.
JHBrandt is offline
post #1896 of 2389 Old 01-20-2016, 07:59 AM
dmatch's Avatar
Quoted: 34 Post(s)
Liked: 24
Correct, sometimes that would work, but sometimes it would just stop like the program had ended. Not very predictable or user friendly.
dmatch
dmatch is offline
post #1897 of 2389 Old 01-20-2016, 09:03 PM
JHBrandt's Avatar
Liked: 769
For the first time ever, my HW has found a "radio" station. In DFW, KSTR broadcasts on RF 48. They've long had three video subchannels (49-1, Unimas; 49-2, GetTV; and 49-3, Grit). But they added an audio-only subchannel recently. Oddly, it's not in their channel map, so it's listed under the RF channel (48) instead of KSTR's virtual channel (49), and it has one of the HW's infamous made-up PRnnnnn names.
This confirms that the HW's "radio" channels are indeed used for audio-only subchannels. When I bring up the channel list by pressing OK, the TV channels are listed but if I press Left or Right on the remote, it switches to the Radio channel list (with only that single channel listed).
Instead of a blank screen, the HW shows a pleasant graphic with musical notes and a floating radio icon while listening to the station.
JHBrandt is offline
post #1898 of 2389 Old 01-21-2016, 12:54 AM
m. zillch's Avatar
Quoted: 1958 Post(s)
Liked: 1239
Good to know. So it has absolutely nothing to do with AM/FM. I didn't know that. [I've never seen any stations found in my area.]
In A/V reproduction accuracy, there IS no concept of "accounting for personal taste/preference". As art consumers we don't "pick" the level of bass, nor the tint/brightness of a scene's sky, any more than we pick the ending of a novel or Mona Lisa's type of smile. "High fidelity" means "high truthfulness", faithful to the original artist's intent: an unmodified, neutral, accurate copy of the original master, ideally being exact and with no discernable alterations, aka "transparency".
m. zillch is offline
post #1899 of 2389 Old 01-21-2016, 06:29 AM
JHBrandt's Avatar
Liked: 769
Audio-only channels are rare in the TV bands. I never really understood why, given the low bandwidth requirements. But the only other audio-only channel I've found in the DFW area is 51-8. (Oddly, that one scans in as a "TV" channel, not a "radio" channel, but there's no video; just a black screen.)
JHBrandt is offline
post #1900 of 2389 Old 01-23-2016, 04:47 AM
Liked: 0
I am having trouble with the Hw 150pvr. I can not get the programs to show up in the program guide or when I flip through the channels as it always says searching. Any advice as to what I need to do?
runnercoach is offline
post #1901 of 2389 Old 01-23-2016, 07:45 AM
dmatch's Avatar
Quoted: 34 Post(s)
Liked: 24
Unplug (from AC power outlet) wait 20-30 seconds and plug it back in. See if that helps.
dmatch
dmatch is offline
post #1902 of 2389 Old 01-23-2016, 10:50 AM
JHBrandt's Avatar
Liked: 769
The front-panel power switch also physically disconnects power. (The LED will go dark.) So you can turn it off there instead of unplugging.
If that doesn't work, you can try a factory reset from the menu. Of course you'll have to rescan your channels & reschedule your recordings, so only as a last resort
JHBrandt is offline
post #1903 of 2389 Old 01-24-2016, 12:42 PM
Pilottv37's Avatar
Liked: 1
My unit suddenly stopped working last night. I could hear audio, but no picture. I tried the composite video and found a rolling picture. I immediately suspected that somehow the unit got switched over to PAL, instead of NTSC. With the rolling picture, I could barely make out the menu commands, but somehow managed to switch it over to NTSC, and voilà - it worked!
Pilottv37 is offline
post #1904 of 2389 Old 01-28-2016, 11:55 PM
DoctorM's Avatar
Quoted: 659 Post(s)
Liked: 201
Do these devices have variable playback speed (faster or slower)? I haven't seen a mention of it.
DoctorM is offline
post #1905 of 2389 Old 01-29-2016, 06:23 AM
JHBrandt's Avatar
Liked: 769
Not really. They do have fast-forward, but that's about it.
It would be a nice firmware enhancement to make the rewind and fast-forward work like other DVRs: if you pause then press RW/FF, it starts playing backward/forward in slow-motion, gradually speeding up each time you press RW/FF again.
But these boxes have been around for years with no significant firmware enhancements (and very few bug fixes), so I'm just dreaming about that.
JHBrandt is offline
post #1906 of 2389 Old 01-29-2016, 10:44 AM
DoctorM's Avatar
Quoted: 659 Post(s)
Liked: 201
I have a Philips (Funai) DVR has x1.3 and x0.8 playback, with pitch corrected sound. I use it more often than I probably should. I suppose I could just as well remove the USB drive and play the files back via VLC.
DoctorM is offline
post #1907 of 2389 Old 01-29-2016, 02:32 PM
JHBrandt's Avatar
Liked: 769
A nice feature.
A while back, someone reported it was possible to "trick" the HomeWorX (or was it the iView?) into playing audio while fast-forwarding at 2x. The audio was reportedly the correct pitch and not "Donald Duck"-like. But I never could get the trick to work myself.
JHBrandt is offline
post #1908 of 2389 Old 01-29-2016, 02:57 PM
DoctorM's Avatar
Quoted: 659 Post(s)
Liked: 201
A nice feature.
I'd love to find out how that was done. 2x is a bit fast for viewing, but interesting.
DoctorM is offline
post #1909 of 2389 Old 01-29-2016, 04:43 PM
CANNON-FODDER's Avatar
Quoted: 203 Post(s)
Liked: 95
A quick search turned up this post:
post #1509 12-01-2014, 12:13 PM
But I haven't tried it yet.
v/r,
C-F
DoctorM likes this.
CANNON-FODDER is offline
post #1910 of 2389 Old 01-29-2016, 07:12 PM
JHBrandt's Avatar
Liked: 769
Very long post but here's the relevant part:
Originally Posted by oldspammer View Post
On two of my units (Homeworx HW-150PVR) that have v14 firmware (HW Version 7816-ATSC-03), I can press the volume up once and the sound will play back at the 2x speed without the chipmunk effect better than when using Windows media player for Windows 7 on .mp4 files. Every time that the unit auto-mutes the sound for 2x speed, you can unmute the sound via the remote control by pressing volume up once (successfully).
I have a third Homeworx HW-150PVR that has v1 firmware (HW Version 7816-1237-ASTC-v2) and this same functionality is missing --why is that so if all these listed firmware configurations are supposedly the "latest."
BTW, I used to have a HomeWorX with v14 firmware. Unfortunately it died recently.
In answer to oldspammer's question, v1 is indeed later than v14; the demod chip used in the oldest HW's stopped being made, which forced a new "generation" of HWs with both a new chip and new firmware. Inexplicably, the firmware developer chose to start firmware version numbers over with V1 again! This also happened with the very similar iView DVRs.
As to why this feature disappeared in the new v1 firmware, I'd conjecture that the developer considered it a "bug" and "fixed" it
JHBrandt is offline
post #1911 of 2389 Old 02-09-2016, 03:31 PM
DoctorM's Avatar
Quoted: 659 Post(s)
Liked: 201
Just received my box today. Two questions.
First, is there a secret to recording/playing back closed captions? I see them live, but I can't get them to come up on playing back.
Second, is there a native resolution output for HDMI or does everyone just set it to 1080p?
DoctorM is offline
post #1912 of 2389 Old 02-09-2016, 04:36 PM
jprc's Avatar
Quoted: 82 Post(s)
Liked: 120
It sounds like you didn't get one of the latest boxes that had the CC playback fixed. If you did, you wouldn't have to do anything special to get it to work. You can use VLC on a computer to play them back with CC, but if you want to get it with the Homeworx, you will need to get one of the newer versions that have the fix. You can look back in the thread a bit to see which versions have the fix - I don't remember off hand anymore.
No there is no native res setting.
jprc is offline
post #1913 of 2389 Old 02-09-2016, 05:05 PM
Aleron Ives's Avatar
Quoted: 1606 Post(s)
Liked: 1348
Is it possible to download and install the fixed firmware onto an old box, or does it only exist on new units? I don't recall anybody ever posting a link to get an update that fixes the CC.
Aleron Ives is offline
post #1914 of 2389 Old 02-09-2016, 05:10 PM
DoctorM's Avatar
Quoted: 659 Post(s)
Liked: 201
Firmware version is 4.1. It seems to be the latest dated April 2015.
Is there a hardware version I should check as well?
And to be clear, the captions should work via HDMI, correct?
I also noticed that playing back a recording that the output isn't the raw Dolby even though I set it up that way in the menu.
DoctorM is offline
post #1915 of 2389 Old 02-09-2016, 05:10 PM
jprc's Avatar
Quoted: 82 Post(s)
Liked: 120
My understanding was that it was only fixed on the new boxes that had their own firmware that was incompatible with the older boxes. However, it has been awhile since I've visited Mediasonic's own forums, so I don't know if there is any news over there that is different than what was posted here. DoctorM or anyone this matters to should check with Mediasonic directly - tell them exactly what your software version is on your box and ask them if there is an update compatible with your box that will fix the issue. I know they used to be pretty good at responding but I haven't checked over there lately like I mentioned.
jprc is offline
post #1916 of 2389 Old 02-09-2016, 05:22 PM
jprc's Avatar
Quoted: 82 Post(s)
Liked: 120
There is a line in this admin post that makes it seem like 4.1 should include the fix: http://forum.mediasonic.ca/viewtopic.php?f=44&t=1616
"V4.0, update to V4.1 if you use close caption. (Id you don't use close caption, there is no need to update"
Right under that, you will see an email address. I would email them there and ask for details about how it should and shouldn't work in your version.
jprc is offline
post #1917 of 2389 Old 02-09-2016, 05:38 PM
jprc's Avatar
Quoted: 82 Post(s)
Liked: 120
I don't know if you added the Dolby question later or I just missed it, but there is another bug with that. You can get around it by using your computer to rename the .mts file to a .ts file. You will then be able to reattach the drive to the homeworx and you will find the file under "movies" where it will playback Dolby 5.1.
jprc is offline
post #1918 of 2389 Old 02-09-2016, 06:16 PM
DoctorM's Avatar
Quoted: 659 Post(s)
Liked: 201
The DD issue isn't a deal breaker. I'm using it on a 2.0 system, but I would prefer raw audio outputted.
Maybe that'll come in an update.
DoctorM is offline
post #1919 of 2389 Old 02-10-2016, 08:53 AM
JHBrandt's Avatar
Liked: 769
Keep us posted please. I tested CC on playback on my HW, which is older than yours (V2.0, dated Dec 2014) and it does work, so they fixed it awhile ago. But it sounds like they managed to break it again somehow.
JHBrandt is offline
post #1920 of 2389 Old 02-10-2016, 09:16 AM
DoctorM's Avatar
Quoted: 659 Post(s)
Liked: 201
Their response puzzles me:
Unfortunately, Homeworx won't support CC on playback.
V4.1 is the latest.
What?!?!
Edit: In response to my further questioning...
From day 1, Homeworx won't support CC on playback.
Can ANYONE report success with CC playback of recordings on the HW-150PVR?
I was under the impression this was a thing. They say it is not. I'm now on the fence about returning the unit.
Sure it's cheap and I can play the captions back if I relocate my USB device to other hardware, but I shouldn't need to.
@JHBrandt - Did you use HDMI or analog wiring?
DoctorM is offline
Reply HDTV Recorders
