Homeworx HW-150PVR, Support and Discussion - Page 65 - AVS Forum | Home Theater Discussions And Reviews
 91Likes
post #1921 of 2420 Old 02-11-2016, 11:01 AM
DoctorM's Avatar
Quoted: 676 Post(s)
Liked: 206
Thanks. I appreciate it. What's weird is neither component nor composite deliver captions. Examining the recordings on my PC it LOOKS like Line 21 CC are being stripped. I wasn't aware that was possible without re-encoding.
I decided to give the Homeworx box a try because of the caption fix, but with that gone I'm going to return it and play wait-and-see.
DoctorM is offline
post #1922 of 2420 Old 02-11-2016, 03:59 PM
Aleron Ives's Avatar
Quoted: 1625 Post(s)
Liked: 1370
It should be possible to strip the captions without transcoding, but I can't believe the Homeworx would do that, as it would be a lot more trouble to do that than to leave the captions as they are and just ignore them.
Aleron Ives is offline
post #1923 of 2420 Old 02-11-2016, 04:22 PM
DoctorM's Avatar
Quoted: 676 Post(s)
Liked: 206
Took a recording, demuxed the video from it and ran it through CCExtractor. There are indeed Line 21 subs present in the recording.
That just means that Homeworx went out of their way to alter the analog video output to keep EIA-608 captions from showing up.
DoctorM is offline
post #1924 of 2420 Old 02-11-2016, 06:10 PM
Liked: 1370
NTSC subtitles aren't required anymore now that digital options exist, and I guess this confirms that the Homeworx doesn't output a true NTSC signal, since HDTVs probably don't really care about input devices matching the spec.
post #1925 of 2420 Old 02-12-2016, 10:40 PM
DoctorM's Avatar
Quoted: 676 Post(s)
Liked: 206
Interesting email from support today. They claim to have tested Raw/Raw on HDMI connected to an AV receiver and played back a recorded program. DD 5.1 supposedly engaged. Their firmware was dated April 10, 2015 (as opposed to April 25, 2015). He attached the firmware and asked me to test it.
Sort of wish I kept the box one more day just to see if the DD would work... maybe even the captions.
Pretty messed up that a company has two firmwares called v4.1 but with different build dates.
DoctorM is offline
post #1926 of 2420 Old 02-13-2016, 08:08 AM
JHBrandt's Avatar
Quoted: 1618 Post(s)
Liked: 788
Hang onto that firmware. If possible, upload it somewhere and post a link. Some of the more adventurous followers may want to try it on their own HW-150s....
... although I suppose there's no way to know for sure which HW-150 boxes it's compatible with in advance.
Mediasonic's firmware versions have always been a complete mess. Most of the "old" boxes came with a 2-digit version number, but it didn't always go in sequence. IIRC it was V3 (very short-lived and quickly replaced by) V10, then V12, V8, V13, and V14. I think there were even a few boxes with V18!
Then they started the new series boxes over again at V1.0. The new boxes seem to have decimal points in their firmware version numbers. Those are the ones most likely to be compatible with the firmware they sent you.
JHBrandt is offline
post #1927 of 2420 Old 02-13-2016, 09:37 AM
DoctorM's Avatar
Quoted: 676 Post(s)
Liked: 206
I think I read somewhere that v4.1 is for boxes that formerly had v4. I don't recall it ever being considered correct for any other box, but maybe.
I like how you say the 'more adventurous' considering there seems to be only 3 of us that follow this thread.
DoctorM is offline
post #1928 of 2420 Old 02-13-2016, 02:16 PM
CANNON-FODDER's Avatar
Quoted: 204 Post(s)
Liked: 97
Maybe more lurk ... like me.
Captions don't work in playback for me either. Which is partially why I never integrated this impulse buy into my regular "workflow". I routinely turn captions on, so it isn't as useful as I thought it might be.
v/r,
C-F
CANNON-FODDER is offline
post #1929 of 2420 Old 02-13-2016, 04:41 PM
JHBrandt's Avatar
Liked: 788
OK, just to make sure I'm still sane, I just made a short 2-minute recording to double-check. Closed captions do work on mine.
I apologize for these pictures being upside down. I'm left-handed so evidently I turned my cell phone camera the wrong way, and I didn't want to mess around with an image editor just to upload these.
Anyway, the first image shows the firmware version where CC works; the second shows what happens when I press the CC button during a recording (I get "CC*ON" instead of "Invalid") and the third shows an actual caption while playing back the recording.
So apparently the firmware developer managed to get this working once. I'm just totally baffled that:
  • They broke it again
  • Mediasonic denies that it ever worked
ID:	1250729   Click image for larger version
ID:	1250737   Click image for larger version
DoctorM likes this.
JHBrandt is offline
post #1930 of 2420 Old 02-14-2016, 10:06 PM
DoctorM's Avatar
Quoted: 676 Post(s)
Liked: 206
Thanks. I'll keep watching this thread. If they ever fix that, I'll be buying again right away.
DoctorM is offline
post #1931 of 2420 Old 02-14-2016, 10:15 PM
Liked: 1
Originally Posted by Klaatu58 View Post
Just flashed iView firmware V3 onto HW V1 firmware box and iView remote works fine. Guess the demodulators matched. Now when turned on, the box shows "iView" rather than HomeWorx. Man, that was too easy. Didn't even have to reset to factory defaults after the flash or rescan channels. Only had to re-enter time zone and language settings; all others transferred including timer data.
Am using HDMI so can't comment on HW's outputs (especially the analog audio outputs) operating, though.
Also nice about the iView remote is that it uses AA rather than HW remote's AAA batteries.
This sounds like what I need to do, but there are so many versions of iView and HomeWorx that I could still use some further advice, please.
I have iView 3500STBII with CH 3/4 switch (serial no. 1504...) that successfully decodes FioS Local TV channels IF AND ONLY IF it is loaded with what is now called "V3" firmware on the iView support site.
Would like more boxes like this, but when I order now I get new box without CH 3/4 switch, and although iView support is happy to send various firmware, nothing they send works for me for this new box.
So I guess if someone knows where to get an older iView box (I'm told serial number must be less than 1510...) that would be one solution, so please feel free to suggest where to get these...
Another idea is, as per above quote, maybe we can we load the iView "V3" firmware onto some HomeWorx box. But which one?? If I look on Amazon, I see:
-HW-150PVR which looks like no CH 3/4 switch
-HW 180STB (OLD version) which looks like CH 3/4 switch
-HW 180STB (NEW version) which also looks like CH 3/4 switch
-HW 220STB which looks like CH 3/4 switch and ALSO rest of rear panel looks identical to my iView box that works
Any idea as to which (if any) of the above Homeworx box would work if loaded with the iView "V3" firmware?
Also on this thread people speak of getting Homeworx firmware but I don't see that on their site, so if one wanted to recover the Homeworx box original firmware where would one get it?
rramjet is offline
post #1932 of 2420 Old 02-14-2016, 10:31 PM
DoctorM's Avatar
Quoted: 676 Post(s)
Liked: 206
What the heck is a 220stb? That's news to me. I know the 180stb is actually a step down from the 150pvr, does the 220stb actual have refinements?
DoctorM is offline
post #1933 of 2420 Old 02-15-2016, 07:27 AM
Liked: 0
I'd be happy to reveal my HW box's version but not sure where to find it.
Klaatu58 is offline
post #1934 of 2420 Old 02-15-2016, 07:50 AM
JHBrandt's Avatar
Liked: 788
I believe you have to email Mediasonic. Also, they're unlikely to send you a firmware file just because you ask for it. You probably have to have a problem or complaint with your HW box that new firmware might fix.
BTW, you can't match HW and iView firmware by the channel 3/4 switch. AFAIK no HW-150 has ever had a channel 3/4 switch, but V1-V3 iView firmware works on V1.0 HW boxes anyway. On the iViews, the switch was just a handy external marker for an unrelated internal chip change. Both HW and iView made the same chip change, but only iView added that channel 3/4 switch.
JHBrandt is offline
post #1935 of 2420 Old 02-15-2016, 08:06 AM
JHBrandt's Avatar
Liked: 788
I hadn't heard of it either. I found nothing at Amazon, but there is a 220STB on Mediasonic's website: http://www.mediasonic.ca/product.php?id=1450334285#tab1. It does have the component video and coaxial digital audio outputs that were removed from the HW-180, and it has a channel 3/4 RF output switch. Also it looks like it may have an iView-like LED display, although it's hard to tell because none of their photos show the box powered on.
The unique thing is a "Karaoke" function. I have no idea how this is supposed to work, but there are two Microphone inputs on the front panel. Other than that, it does look a lot like one of the iViews with the channel 3/4 switch. It does come with one microphone.
The remote resembles the HW-180 remote, so the firmware may also be similar to the HW-180. The HW-180s have their own firmware series. I have no idea if HW-150/iView 3500 firmware is compatible with the HW-180 or HW-220. If it is compatible, I assume loading iView firmware would require an iView remote (and probably disable the Karaoke function).
Edit: I finally found it at Amazon: http://www.amazon.com/Mediasonic-HOM.../dp/B01ARGXJ90. They have it for $60 (free shipping). Makes sense that it costs a bit more, due to the included microphone. It'll be interesting to follow this box.
JHBrandt is offline
post #1936 of 2420 Old 02-16-2016, 09:16 PM
Liked: 1
Don't know about HW, but for iView go to Menu-->System-->Information to find hardware and software versions. If you can find it yes please post.
rramjet is offline
post #1937 of 2420 Old 02-16-2016, 09:33 PM
jprc's Avatar
Quoted: 82 Post(s)
Liked: 120
That doesn't necessary give you the hardware version. The HW version is hard-coded into the software - it's not read from the actual hardware configuration. So what is listed there may or may not give accurate information, depending whether the devs bothered to change the HW version to match the actual hardware configuration (some versions they definitely didn't) and whether it is the original software the box came with.
jprc is offline
post #1938 of 2420 Old 02-16-2016, 09:35 PM
Liked: 1
Well my problem would be that their box didn't work for me after loading iView firmware, and I wanted to try to restore it before returning it But I hoped maybe someone else might have saved a copy of the firmware so I could do this without involving Mediasonic directly. Is there a copy saved anywhere?
But it sounds promising--I did understand that the CH 3/4 switch per se is not necessarily the issue from the previous posts. If I understand correctly, iView V3 firmware should work on HW V1.0 boxes? If I just order any "new" HW box, can I assume I will get V1.0?
rramjet is offline
post #1939 of 2420 Old 02-16-2016, 09:43 PM
jprc's Avatar
Quoted: 82 Post(s)
Liked: 120
No, you can't assume which box you will get. There are several hardware versions and all are still being sold new. Unless it is an open box/used item or you find someone willing to open it and set it up to find the software version on it, most likely the seller will not be able to tell you with accuracy which box it is.
jprc is offline
post #1940 of 2420 Old 02-17-2016, 07:56 AM
JHBrandt's Avatar
Liked: 788
Most likely you'll get version 4.0 or later. (iView is already up to version 5.0.) But iView V3 firmware may still work on a V4.x HomeWorX. There's no way to know for sure.
I suppose what you could do is write down the HomeWorX firmware version you get, then try the iView firmware, and if it doesn't work, just tell Mediasonic you have both a HomeWorX and iView, and they're so similar you mistakenly updated the HomeWorX with the iView firmware. (Of course that assumes the iView firmware doesn't completely brick the HomeWorX so you can reload the firmware Mediasonic sends you iView's firmware update page is pretty scary.)
JHBrandt is offline
post #1941 of 2420 Old 02-17-2016, 08:01 AM
JHBrandt's Avatar
Liked: 788
Not to mention the fact that @Klaatu58 already (successfully) updated his HomeWorX with iView firmware, thus overlaying whatever hardware version info was coded into the original firmware.
There might be some info printed on (or in - I assume it's out of warranty by now so it'd be safe to open) the box itself, but I wouldn't know where to look.
JHBrandt is offline
post #1942 of 2420 Old 02-17-2016, 08:20 AM
Liked: 0
My Amazon orders indicate I have the Mediasonic HW-150PVR (http://www.amazon.com/Mediasonic-HW-.../dp/B00I2ZBD1U), purchased in July, 2014. I also found a filed called "usb_upgrade_all_flashV31.bin" on one of my hard drives. It's size is 3175KB.
Klaatu58 is offline
post #1943 of 2420 Old 02-17-2016, 08:25 AM
JHBrandt's Avatar
Liked: 788
A firmware update Mediasonic once sent you, perhaps?
JHBrandt is offline
post #1944 of 2420 Old 02-17-2016, 08:36 AM
Liked: 0
Actually, I think this is the iView firmware V3 that I flashed onto my HW-150PVR box to make the iView remote work to address rramjet's question.
Klaatu58 is offline
post #1945 of 2420 Old 02-17-2016, 12:42 PM
JHBrandt's Avatar
Liked: 788
I have a copy of that file I downloaded from iView's web site some time ago. Mine is named "usb_upgrade_all_flashV3.bin;" almost the same except without the "1". It's the same size as yours, so there's a good chance it's the same file (iView V3 firmware).
JHBrandt is offline
post #1946 of 2420 Old 02-17-2016, 04:14 PM
DoctorM's Avatar
Quoted: 676 Post(s)
Liked: 206
A lot of talk about flashing iView firmware to the Mediasonic, but I have to ask why? The prices are fairly close and the Mediasonic, afaik, has superior firmware.
What's the purpose?
DoctorM is offline
post #1947 of 2420 Old 02-17-2016, 04:46 PM
Liked: 0
What's the purpose?
iView's remote is better than HW's for reasons already mentioned. Flashing iView firmware V3 onto a HW V1 firmware box enables iView's remote to control HW's box.
Klaatu58 is offline
post #1948 of 2420 Old 02-17-2016, 06:38 PM
JHBrandt's Avatar
Liked: 788
Also, @rramjet had a specific application: iView V3 firmware works with Verizon FiOS, but iView's newer boxes don't work with FiOS and don't support V3. The Mediasonic boxes don't officially support clear QAM systems like FiOS, but if he can flash iView V3 onto one, that would solve his problem.
DoctorM likes this.
JHBrandt is offline
post #1949 of 2420 Old 02-17-2016, 10:21 PM
Liked: 1
Exactly. I would not even try this if I could just get someone to sell me the right iView box. But I've asked iView and B&H and they gave no help. I got the right one by accident from Amazon the first time I ordered, but the next time I ordered I got the "newest" hardware which will not run their V3 firmware. They happily send any firmware they have, but seem not to understand what it does. What they sent for the new box did not work. So I was hoping to find another brand of box with "the right" hardware to run the iView V3 firmware.
Actually, just for academic interest...
It's not that other IView firmware totally fails. It will do a scan on FiOS and find around 380+/- channels. Most of these are scrambled. Still, this would not be impossible to work with. But the bigger problem is that the scan does not find all the unscrambled channels, and especially it seems to miss some HD channels that tend to be at the higher physical frequencies on the FiOS cable. Also, a scan does not necessarily find the same number of channels each time you do it.
On the other hand, V3 finds all unscrambled "Local TV" channels and ignores all the scrambled ones, correctly labeling the local channels by off-air numbers (like 2-1) and call letters (like WCBS). It does fail to find the local "FioS 1" news channel and the weird "commercials only" channels, local government channels, etc., but no problem with that. It finds 2 versions of the channels where there are both on the FiOS cable, and labels them with the same number (like 2-1), but you can just tag the SD versions as "skip". Although, sometimes the V3 firmware does "forget" which channels to skip and you have to remind it by re-tagging them "skip".
So not sure what to do a this point since not clear that ordering any given box would be likely to deliver one that would work. Plus, as pointed out, if you load V3 onto the wrong box you can brick it with no way to restore it.
Anyway I do appreciate the discussion so if any other thoughts occur please post.
rramjet is offline
post #1950 of 2420 Old 02-18-2016, 08:01 AM
JHBrandt's Avatar
Liked: 788
We are in luck! Found an old post of yours where you revealed this info before you installed iView's firmware on it:
Hi. Just took delivery an a HW-150PVR and have two questions, please.
1) Every Sunday, I want to record a series of three programs that begin at 9 p.m. and end at 12 a.m. (midnight). I set the Start Time to 21:00 but have to set the End Time to 23:59 because the unit apparently won't allow 24:00. I keep pressing the "4" key but it just inputs a "3" and moves to the next field. I also tried setting the End Time to 00:00 (and 00:01) but get the message, "This schedule is conflict with Event02 - [OK]:Return." Event02 is set the same day with the settings: Start Time 17:30, End Time 18:00 (5:30 p.m. to 6:00 p.pm.). Is this a programming bug?
2) Noticed at another forum (http://forum.mediasonic.ca) that there are updates available. When I choose System>Information, it reads "SW Version: CL503883 131012 v1, HW Version:7816-1237-ATSC-V2."
Of course I realize this is just what's hard-coded into HW V1 firmware, but I'm betting it's probably correct nevertheless.
BTW, the "midnight" bug you noted in part 1 of your post appears to have finally been fixed in V2.0 firmware for the HomeWorX. But given that the "CC" bug came back in V4 and later, no one can guarantee that the midnight bug didn't come back as well Perhaps someone with V4.0 or V4.1 can try to enter a midnight-crossing event with another event on the same day, and see if the HW incorrectly reports a conflict.
Edit 1: HW boxes with V2.0 firmware (like mine) report a different hardware version:
SW Version: DEC 27 2014 09:48:15-V2.0
HW Version: MLG7802-ATSC-QAM-V2
Edit 2:
I had actually forgotten about this, but there was a V18 released between V1 and V2.0! From the below, it appears V18 boxes have the same hardware as V1 boxes (and so are presumably also compatible with iView V3).
Originally Posted by larryintx View Post
Ordered 2 units, 1 from Newegg and the other from Amazon
Newegg HW-150PVR14074319V2 ________ | This unit works absolutely fine exept for
SW Version: CL503883 140215 V18 ______ | closed captions ( Says INVALID when CC button
HW Version: 7816-1237-ATSC-V18 _______ | is pressed on recording playback)
Amazon HW-150PVR141015750V3 _____ | This unit locks up a lot and sometimes doesn't
SW Version: NOV 18 2014 16:44:14 _____ | record the full amount of time. The CC's display,
HW Version: MLG7802-ATSC-V3 _________ | but are in english on english channels and spanish on spanish
_________________________________ | channels. I need eng. subs on spanish channels
And from the second HW, there was an "unnumbered" firmware version that also fixed the CC that came out just about a month before V2.0.
Also, you can see from larryintx's post that the way they fixed CCs in V2.0 and the unnumbered version (V1.9?) isn't ideal. Unlike with live viewing, you can't select from multiple CC streams when playing back recordings. So if you're watching (say) Telemundo, when viewing live you can select CC3 for English captions, but when playing back all you can get is the Spanish captions on CC1. Still better than nothing, though.
Edit 3: Incidentally, I believe the iView boxes with the channel 3/4 switch report this:
HW Version ATSC7816XD-02-A00
... so it would seem the "7816" is the key to look for, to ensure compatibility with iView firmware versions V1 through V3.
Edit 4: I don't believe it!
Originally Posted by rlent View Post
Spent some time perusing both threads and ultimately decided to go with the HW-150PVR which we picked up @ Micro Center in Mayfield Heights, OH this past Saturday.
The unit I have is:
SW: April 24 2015 16:33:56 - V4.1
HW: MLG7816-ATSC-V4
I don't know whether to or but yes, it looks like Mediasonic switched back to 7816 hardware for the latest boxes! Good news for @rramjet because it means the newest HW boxes are probably compatible with iView V3 firmware!
OTOH it's probably bad news for @DoctorM because he probably has the same box, and no known firmware version for 7816 boxes fixes the CC bug.
Finally, user @acrosstic received (and may still have) a genuine copy of V2.0 firmware from Mediasonic:
Originally Posted by acrosstic View Post
Got an update from Mediasonic for HW Version: MLG7802-ATSC-V3 (New from Amazon). Initially had date bug on EPG that was 5 hours behind.
New and working very well so far:
Oddities: My hardware version changed to V2 from V3. That seems odd. Also looks like they've added the version numbers back to the SW update along with the date.
I did notice a loss in tuner performance with the update and a noticeable degradation of signal strength on my Samsung Plasma using pass through. I lost two different channels on each device. I added a splitter and that seems to have solved both issues. YMMV.
AFAIK the three firmware versions (V2.1, V2.0, and the unnumbered version dated Nov 2014) for the 7802-series HW-150s are the only Homeworx or iView firmware to (sort of) fix the CC bug - and naturally Mediasonic isn't importing these anymore
JHBrandt is offline
Reply HDTV Recorders
