Homeworx HW-150PVR, Support and Discussion - Page 80 - AVS Forum | Home Theater Discussions And Reviews
 86Likes
post #2371 of 2390 Old 03-26-2017, 10:10 AM
mdbratch's Avatar
Liked: 4
Originally Posted by eherberg View Post
5.3 does have the ability to show CC during recorded show playback. (Of course, the program has to have closed captioning - so prime time shows are good to test).
For my 5.4 test I would turn on CC, see that I had it on the live show, turn on the timeshift, and the CC would stop displaying. I also tried a similar test on a station. I verified CC was working, pressed record, let it record about 30 seconds or so. Immediately when I had pressed record, the CC stopped. When I stopped the recording, CC resumed. The playback of the recorded snippet also did not have CC.
mdbratch is online now
post #2372 of 2390 Old 03-26-2017, 11:18 AM
eherberg's Avatar
Quoted: 73 Post(s)
That would make it a deal-breaker for my friend's system. He has complained about the military time, but closed-captioning for his wife is an absolute must for their recorded programs. :-(
eherberg is online now
post #2373 of 2390 Old 03-26-2017, 01:36 PM
plplplpl's Avatar
Quoted: 12 Post(s)
Liked: 26
I am understanding the English speak very good
...but it's that epidemic of mumbling actors that often makes CC or subs necessary nowadays.
dmatch and DoctorM like this.
plplplpl is online now
post #2374 of 2390 Old 03-26-2017, 04:48 PM
JHBrandt's Avatar
Quoted: 1568 Post(s)
Liked: 769
It sounds like the V5.4 beta is very similar to iView's latest firmware, which also adds a 12-hour time option.
On the iView, 12-hour time worked but wasn't perfect: Times from midnight to 1AM still displayed as 00:##am instead of 12:##am. Times from noon-1PM sometimes (but not always) displayed as 00:##pm as well.
Also, strictly speaking this isn't a "bug," but I thought the EPG display was confusing. The times are formatted ##:##-##:##am (or pm) but the "am/pm" refers to the first of the two times, not the second. So a show that runs from 11:30AM to 12:30PM would be listed as 11:30-12:30am.. I probably would have eliminated the "m" and listed it as 11:30a-12:30p, which would take the same number of characters but be less confusing.
For these reasons, I switched my iView back to 24-hour time. You might check your HomeWorX program guides for the same bug and quirk.
On all firmware versions I've tried for 7802-based boxes, including HW V2.# and V5.# as well as the latest iView firmware, closed captions work during playback but not when time-shifting. The latest iView versions, however, have a bug that sometimes causes the box to lock up and reboot if you try to use CC during playback. From what you said, it sounds like Mediasonic may have had CC during playback disabled to avoid the reboot issue. Please let them know it worked in V5.3 and some of us would miss it.
JHBrandt is offline
post #2375 of 2390 Old Yesterday, 04:14 AM
mdbratch's Avatar
Liked: 4
Also, strictly speaking this isn't a "bug," but I thought the EPG display was confusing. The times are formatted '##:##-##:##am' (or pm) but the "am/pm" refers to the first of the two times, not the second. So a show that runs from 11:30AM to 12:30PM would be listed as 11:30-12:30am.. I probably would have eliminated the "m" and listed it as 11:30a-12:30p, which would take the same number of characters but be less confusing.
In the HW-150PVR v5.4 beta, time ranges have the AM/PM designator on both times, so you have '##:##[AP]M-##:##[AP]M' format for a time range, which is nice. Also, the afternoon seems properly designated as 12:xxPM. In fact, if you try to enter 00:xxPM it will auto-correct it as 12:xxPM. However, it likes 00:xxAM as opposed to 12:xxAM and will auto-correct that to the leading 00.
post #2376 of 2390 Old Yesterday, 07:31 AM
JHBrandt's Avatar
Liked: 769
Well, that's closer than iView: I could probably live with it if the only wrinkle is that midnight has to be 00:xxAM vs. 12:xxAM. Not bad for a beta version.
The only problem with leaving the m's in the EPG times is, that leaves fewer characters for the show title on the right, which was already pretty short even with 24-hour times with no AM/PM at all. (These screens have to be readable even on the composite output, so the number of characters across is going to be rather limited.)
On the closed captions, I've never understood why this has been so tough to get right. On the older 7816-based boxes, I understand they had it working during time-shift, but if you tried CC during playback it would just curtly flash "Invalid" at you. Then the 7802-based boxes came out, and we found CC now worked during playback - but didn't work during time-shift any more! And with the latest versions, they managed to break it in both cases You'd think they could combine code from the old 7816 boxes with code from, say, V5.3, and get CC working everywhere.
There's also a bug involving DD 5.1, but you'd have to own an AVR to test it.
As for that midnight bug, that one has existed since the very first boxes. I'd love it if they could finally fix that, but I'm not holding my breath.
JHBrandt is offline
post #2377 of 2390 Old Yesterday, 08:08 PM
eherberg's Avatar
Quoted: 73 Post(s)
The only solution was to change the system 'on' commands that are sent from the XBox One -- eliminating the power toggle to the box. Since they all primarily use voice to control the system - they are not going to remember (nor will they have the desire to) use the remote for that one function when voice will handle everything else in the system. My thought was simply to leave the box 'on' all the time. It has minimal power draw. It solves the problem of the power toggle and the box not having the ability to protect or check for a recording in-progress if power toggle is received via remote.
So it turns out that my solution of leaving the box on to avoid the power toggle from the XBox One killing a recording is not going to work. I got a call tonight from my friend telling me that he got home this evening and discovered that the box was not recording. When he then manually tried to record by using the 'record' button from the remote, he got the 'unknown error' result. Doing a little trouble-shooting over the phone, he was able to access the drive just fine through the usb menu and play any previous recording on the drive. But even after doing that, he was still not able to initiate a recording. I had him toggle the box to stand-by and then back on using the remote and then try the record button again. Wallah! Recording started just fine. So the solution of leaving the box on doesn't seem like it is a workable solution. (Not to mention that when his wife realizes that DWTS didn't record tonight, I may find a hit being put out on me). :-)
The current plan is for them to simply see if they can live with having to use the remote to turn on the box when they want to watch TV. I get that to most of us, this doesn't sound like a big thing -- but I can certainly see it from their perspective where they have this sweet voice control setup that works with everything (including their old Dish DVR) - but now doesn't work with its replacement. I wouldn't care much for it either, if I were in their shoes.
I'm actually thinking about simply giving them one of my TiVo's. That would be a guaranteed solution that would work seamlessly with their system. Initially they balked at buying one themselves due to the cost - but my wife and I have been thinking about getting rid of our TiVo's this summer anyway. We're using Plex more and more -- and frankly TiVo is looking a little long-in-the-tooth lately with falling behind other's on features and performance. Add the recent Rovi problems after the transition and we're using it less and less. We had initially thought about waiting until late summer to see if anything interesting would be coming from the Mavrik line. If not - then we would sell the TiVo's and use the money to set up a bad-ass Plex server. But perhaps the better solution is to take the HW150 from him for our minimal recording needs (only the wife's daily chat shows that aren't online) and give him the friends and family discount on one of the TiVo's. Even if we move to a headless system with something under Mavrik or something integrated with a future Plex server - the HW150 could still live happily as a daily recorder or dedicated football time-shifter in the fall.
post #2378 of 2390 Old Today, 05:41 AM
mdbratch's Avatar
Liked: 4
I have to believe these should be easy for Mediasonic to fix and they could eventually have a real 5.4 production version that has the CC and the AM/PM. But their SW quality control seems to be a bit lacking. My plan is to keep using 5.4 and accumulate any more notes on just a few issues and wishes (not big wishes, but small ones - as they can't seem to handle big ones) and send them my small list along with suggestions for remedy.
post #2379 of 2390 Old Today, 05:44 AM
mdbratch's Avatar
Liked: 4
That's a real bummer. That generic failure message seems odd, and I haven't seen it before. Any thoughts on root cause? You're using a drive that goes to sleep on its own when it hasn't been accessed for awhile? I've been using an old, left-over 250GB Hitachi SATA drive (lefto over from a Macbook Pro drive upgrade) and stuck in a cheapo external USB 2.0 box I bought on Amazon. It's been working really well. It's powered by the USB on the HW-150PVR and does meet their max current draw requirements of < 800mA. In my case, the HW-150PVR is normally in sleep mode and wakes up automatically (and applies power to the USB HDD at that time) to do recording.
post #2380 of 2390 Old Today, 06:24 AM
mdbratch's Avatar
Liked: 4
I was just browsing the iView support area on their site, and they claim they fixed the midnight bug in 3200STB in their latest firmware. Do you know if that's really so?
post #2381 of 2390 Old Today, 06:57 AM
JHBrandt's Avatar
Liked: 769
I've seen this annoying problem myself on occasion, with a HW on firmware version 2.1. Recording just stops working until you reboot by going into standby. (At least these boxes reboot quickly.) I would've thought they'd fixed it by now, but as mdbratch said, they may not even realize their firmware has a problem!
Well, no; I actually own a 3200, and the midnight bug I described is still there. (And I tried all 7802 firmware versions I could find.)
But you see, at one time there was another midnight bug, which iView (and HomeWorX) did fix. IIRC if you scheduled a recording that crossed midnight, it wouldn't stop recording when it was supposed to and would still be recording when you checked the box the next day. That bug got fixed early on. I think they may have even had to fix it twice; years ago in the firmware for 7816 boxes, then again when the 7802 boxes (the 3200 and the newest 3500s) came out. iView's first 7802 firmware revived a lot of "oldies" like that
JHBrandt is offline
post #2382 of 2390 Old Today, 07:31 AM
JHBrandt's Avatar
Liked: 769
It occurred to me that a likely scenario could be: Recording starts at 7:00 PM for DWTS (or some other program). Sometime in the next 2 hours - somebody comes home and turns on the system with the 'Hey Cortana' appropriate command. Kinect turns on the XBox One ... sends the TV Power On command ... and then sends the [power-on] toggle to the HW150 [thus turning it off and interrupting the recording].
So I got a call tonight from my friend telling me that he got home this evening and discovered that the box was not recording. When he then manually tried to record by using the 'record' button from the remote, he got the 'unknown error' result. Doing a little trouble-shooting over the phone, he was able to access the drive just fine through the usb menu and play any previous recording on the drive. But even after doing that, he was still not able to initiate a recording. I had him toggle the box to stand-by and then back on using the remote and then try the record button again. Wallah! Recording started just fine. So the solution of leaving the box on doesn't seem like it is a workable solution.
This is admittedly a kludge, but it sounds like the problem is that the HW just needs to be rebooted periodically, in order to ensure scheduled recordings work. So I wonder if you could plug it into one of those old-fashioned mechanical timers, set to power the HW off for, say, 15 minutes sometime during the night when no one is watching and no recordings are likely to be scheduled?
My HW always turns itself on after a power loss, so this might be all it takes to keep it on and recording reliably the other 23.75 hours a day.
JHBrandt is offline
post #2383 of 2390 Old Today, 10:30 AM
eherberg's Avatar
Quoted: 73 Post(s)
The drive was this hard drive powered externally by this hub.
I opted for a lower storage drive to avoid the responsiveness time increases that occur with larger drives. Keeping it under 500 GB gives a response time that approaches flash drive speeds while still giving them approx 60 hours of recording capability. On a side note - it was refreshing to have a hard drive that didn't have stuff already loaded onto the drive. Just plugged it in -- and no extra software or utilities that I don't want or need. Having it externally powered avoids any issues with the limited power draw through the USB port.
Right now, they are only using it to record 2 items a week: SNL on Saturday night -- and DWTS on Monday. Since the drive didn't have a problem with recording earlier programming even with extended time between access, I'm going to fall on the side that speculates it's a box issue. Especially since previous recordings could be accessed just fine -- but try to immediately do a recording after and you still got the generic error message until the box was cycled in and out of stand-by.
post #2384 of 2390 Old Today, 10:32 AM
eherberg's Avatar
Quoted: 73 Post(s)
If external power is lost -- don't you lose timers, though? I thought I recalled that being mentioned. Use stand-by and timers are intact ... use the physical power switch or unplug and timers are lost. But perhaps that is not accurate?
post #2385 of 2390 Old Today, 10:59 AM
mdbratch's Avatar
Liked: 4
I think that's a reasonable conclusion. One thing I will try when I get a chance is to leave my HW-150PVR on all the time and see if it starts to fail recording. My HW version is V5. Since it's normally in standby, it's potentially self-correcting. So I think this would be an interesting test.
post #2386 of 2390 Old Today, 01:01 PM
JHBrandt's Avatar
Liked: 769
No, they're stored in on-board nonvolatile memory. (If that happened, the front-panel power switch would be pretty dangerous!)
But of course, if a timer is scheduled for when the power is off, it obviously won't record. I think somebody had that problem - they turned the HW off via the front panel and didn't get any recordings because it's a hard power switch (unlike other clones like the iView, which have a soft power switch that just puts it into standby like the remote button).
JHBrandt is offline
post #2387 of 2390 Old Today, 01:04 PM
JHBrandt's Avatar
Liked: 769
The drive was this hard drive powered externally by this hub. Having it externally powered avoids any issues with the limited power draw through the USB port.
I'm confused. I clicked your hub link, and Amazon showed me a 4-port hub with an LED, but no power source I could see anywhere!
Edit: The page links to a USB 3.0 hub that does appear to have an external power supply: https://www.amazon.com/dp/B00DQFGH80. Is that the one you used?
JHBrandt is offline
post #2388 of 2390 Old Today, 01:24 PM
mdbratch's Avatar
Liked: 4
You can see it in the image of the back of the hub. There's a DC 5V input.
post #2389 of 2390 Old Today, 01:49 PM
JHBrandt's Avatar
Liked: 769
Now I'm even more confused. I clicked the same link again, and this time Amazon showed me a 7-port hub (with an external PS)!
Seems there's something a bit flaky about that Amazon web page.
JHBrandt is offline
post #2390 of 2390 Old Today, 02:28 PM
eherberg's Avatar
Quoted: 73 Post(s)
Yeah -- I just clicked the link from my order history page and noticed I'm being brought to the 4 port hub --- even though on my order page it correctly shows as the AmazonBasics 7 Port USB 2.0 Hub with 5V/4A Power Adapter. If I try to click 'Buy it Again', I get a notice that the item is now unavailable -- which may explain the page flakiness.
Reply HDTV Recorders
