TiVo Roamio: Records up to 6 shows simultaneously, 3TB storage, streams. - Page 37 - AVS Forum | Home Theater Discussions And Reviews
 184Likes
post #1081 of 2095 Old 09-30-2014, 06:23 AM
Kelson's Avatar
Quoted: 2030 Post(s)
Liked: 1209
Originally Posted by Warner2Bruce View Post
When I made this change, I finally got the "coax" light on the Action Tec Moca adapter to turn solid green. The only trouble is even after going on on the mini and changing the connection type to "moca" and trying to connect it won't connect. I get a connection failed error message with some sort of letter and number combination (I can get it if I need to).
So, my question why I am unable to connect to the mini now that I have the solid green light on the "coax" portion of the Moca adapter?
It just seems like you keep banging your head against a wall with Moca.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #1082 of 2095 Old 09-30-2014, 08:15 PM
HotAhr's Avatar
Quoted: 79 Post(s)
Liked: 52
This Link might help you:
http://www.tivocommunity.com/tivo-vb...d.php?t=501722
Television: Samsung UN65JS9000
A/V Receiver: Denon AVR-X4300H (Ordered Dec. 9, 2016)
Subwoofer: HSU VTF Subwoofer
Speakers: Definitive Tech StudioMonitor 65, ProCenter 2000, ProMonitor 800, Heos 1 HS2
Digital Video Recorder: Directv 4K DVR
Set Top Box: Apple TV
HotAhr is offline
post #1083 of 2095 Old 10-01-2014, 05:57 PM
Bookworm's Avatar
Just got my TiVo Roamio Plus and I have a question about MoCA as well. To use the MoCA adapter in the Roamio requires an ethernet connection to the router. I don't have an ethernet network in my current home so I can't connect it in the room where I'll be using it. I have the TWC Whole Home DVR setup which uses MoCA. I've tried to connect the TiVO to this MoCA network with no success. Is that even possible? I have Minis coming tomorrow and I'll need to either be on a MoCA network or an ethernet network for them to communicate with the Roamio. This won't be a problem when I move in to my new home in February, I'll have ethernet all over the place then, but I want to set these Minis up here to make sure everything works as it should. As you can see in the first attached photo my cable modem is connected to the VoIP jack on the amp outside which isolates it from the rest of the cable connections. I'm wondering if that is keeping the TiVo from seeing the network and if so would moving the modem feed to one of the two empty jacks on amp possibly make it visible to the TiVo. Also the POE filter is attached to the white cable that feeds the main line to the amp.
Name:	2014-08-30 17.31.01.jpg
ID:	290313   Click image for larger version
Name:	2014-08-30 17.30.53.jpg
ID:	290329   Click image for larger version
Name:	2014-08-30 17.31.09.jpg
Bookworm is offline
post #1084 of 2095 Old 10-01-2014, 08:19 PM
Quoted: 85 Post(s)
Liked: 77
Have you gone into Settings> Network on the Roamio Plus and selected MOCA?
RDHolmes is offline
post #1085 of 2095 Old 10-02-2014, 10:28 AM
TonyB1966's Avatar
Quoted: 187 Post(s)
Liked: 25
Just got a Stream yesterday for our base Roamio.
Looks like it's all set-up and I hope to have time to test it outside the home network soon.
Is there a way to watch on the device, like iPad, without recording? I only had a few minutes to play around with it, but I didn't see how to watch live programming w/o recording...
Thank you.
TonyB1966 is offline
post #1086 of 2095 Old 10-03-2014, 04:40 AM
Liked: 786
Sort of - you can watch live TV but it initiates a recording for what you're currently watching, then streams it. Yes, it's dumb.
TonyB1966 likes this.
slowbiscuit is offline
post #1087 of 2095 Old 10-03-2014, 07:21 AM
TonyB1966's Avatar
Quoted: 187 Post(s)
Liked: 25
Thank you slowbiscuit.
I finally had time to call TiVo last night to inquire, and this is by design. The rep explained that it helps to better ensure the quality of the transfer. I imagine at some point that won't be needed. Thankfully, the Stream prompts to delete upon stopping... Thanks again.
post #1088 of 2095 Old 10-03-2014, 07:27 AM
Aero 1's Avatar
Quoted: 337 Post(s)
Liked: 171
it will always be needed. an ipad or android phone cant play the native mpeg 2 recording or live stream. all the stream does is grab a recording from the tivo, decrypts it, encodes it to mp4 and then deliver it to the device. There is no way to do that without the tivo initiating a recording first, it needs the program buffered. that will never change.
Cord Cutter | OTA - NYC DMA - 6 TB TiVo Roamio - 3 TiVo Mini's | Plex Pass | Netflix | Hulu | Amazon Prime | MLB.tv & MLS Live with No Blackouts!
Aero 1 is offline
post #1089 of 2095 Old 10-03-2014, 07:52 AM
TonyB1966's Avatar
Quoted: 187 Post(s)
Liked: 25
Thanks Aero 1. The rep did not go into such detail. Given what you said, yep, this won't change. It's just a minor inconvenience as I don't think I'll ever want to record in those instances. Looking forward to trying it outside the home. Might even take the iPad with me to The Home Depot later to see how it works... Thanks for the explanation.
post #1090 of 2095 Old 10-03-2014, 09:54 AM
Keenan's Avatar
Quoted: 2523 Post(s)
Liked: 2376
This is basically how any DVR works anyway, when we watch something "live" on a TiVo DVR it's actually a recording being made of what ever channel we've tuned to.
I'm glad this question was asked as to this point I though the Stream device was only for pre-recorded shows, like how DIRECTV does it(transfers/copies to mobile device), which has very little value for me.
Can out of home streaming be done with a Stream? And is there any service charge associated with using a Stream? And does it work with a B&N Nook HD+?
Keenan is offline
post #1091 of 2095 Old 10-03-2014, 10:08 AM
Liked: 786
Yes, no, no (without an aftermarket ROM like CM 11). I have the HD+ and the stock 4.0 OS is too old, have to have 4.1 min.
post #1092 of 2095 Old 10-03-2014, 10:44 AM
Keenan's Avatar
Liked: 2376
So it does work with the CyangenMod? And it will play content just as it would normally from the DVR, minus the premium channels?
I sideloaded(?) something on my Nook awhile back that suppresses the Nook OS and allows it to operate like a generic Android tablet, I think it was something you recommended in fact. Is it similar to how that process went? I picked the Nook up when they were dumping them at around $150.
Keenan is offline
post #1093 of 2095 Old 10-03-2014, 02:14 PM
UHD Addict
aaronwt's Avatar
Quoted: 6417 Post(s)
Liked: 3965
I'm able to do out of home streaming with the Stream built into my Romaio Pro and with My Droid DNA using LTE.
aaronwt is offline
post #1094 of 2095 Old 10-03-2014, 02:57 PM
Aleron Ives's Avatar
Quoted: 1693 Post(s)
Liked: 1451
It's how all TiVos work, but TiVo seems to be the only DVR that always works this way. Other DVRs do let you watch TV live and don't involve the HDD until you tell them to record (and some DVRs let you switch between modes).
Aleron Ives is offline
post #1095 of 2095 Old 10-04-2014, 07:00 AM
Liked: 786
Won't work for now since CM is by default rooted (and Tivo app will stupidly not work with root), so you'd have to wait for a root cloaker that can hide root from the Tivo app. This which will come out eventually. Loading CM on a Nook HD+ is not a trivial task, so you might be better off getting a newer Kindle Fire HD or something else if you want to use a tab.
post #1096 of 2095 Old 10-04-2014, 07:10 AM
Charles R's Avatar
Liked: 649
If you follow this thread it takes less than 30 minutes and you can always go home.
http://forum.xda-developers.com/show...6#post42406126
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Sony UBP-X800 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Roku Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
post #1097 of 2095 Old 10-04-2014, 07:32 AM
ncted's Avatar
Quoted: 84 Post(s)
Liked: 38
All Dish and DirecTV DVRs use the hard drive for live buffering. I know TWC Navigator, SARA, and Passport all do as well. I am curious to know what DVRs out there don't involve the HDD while watching live TV and how they implement live TV trick play functionality without it.
ncted is offline
post #1098 of 2095 Old 10-04-2014, 07:38 AM
pghyndman's Avatar
Not so. If a DVR allows pause or, more importantly, rewind of live TV it MUST spool from the hard drive to do so, otherwise it would not be able to perform those functions (barring exotic/expensive buffers). If those functions were not to be allowed from live TV, then it need not spool to HDD... but then that would be a pretty lame DVR, n'est pas? One of the nice nuances of a DVR is being able to go back to any of the most recently used stations, even when the TV was "off" and recording was not selected, and view the past hour or two that were spooled.
The heavy 24/7 workload has spawned a market of hard drives specifically designed for the task, some of which can reliably handle up to 20 simultaneous streams of HD content.
Paul (currently a Moxi user, but always interested in what else is out there)
pghyndman is offline
post #1099 of 2095 Old 10-04-2014, 07:41 AM
Aero 1's Avatar
Quoted: 337 Post(s)
Liked: 171
huh? All DVR's use the HDD for live tv. how else are you going to pause or rewind live tv? even the DVR+ with no HDD use the 16 Gb internal storage for trick play on live tv.
Aero 1 is offline
post #1100 of 2095 Old 10-04-2014, 07:55 AM
Kelson's Avatar
Liked: 1209
He's probably referring to the low-end units that are primarily used to record. They don't have a live record buffer and so can't do trick play on live TV but can only do trick-play on recorded content.
- kelson h
Kelson is offline
post #1101 of 2095 Old 10-04-2014, 11:53 AM
Keenan's Avatar
Liked: 2376
Yes, I checked it out after my initial post and it looks fairly straight-forward to do, definitely something I'm comfortable with doing anyway. The fact that TiVo won't like it though makes it a moot point, at least until if/when the cloaker slowbiscuit mentions becomes available.
Keenan is offline
post #1102 of 2095 Old 10-04-2014, 11:56 AM
Keenan's Avatar
Liked: 2376
What low end units?
Keenan is offline
post #1103 of 2095 Old 10-04-2014, 02:28 PM
jjeff's Avatar
Quoted: 778 Post(s)
Liked: 278
iView and it's many clones, Philips HD DVR, etc. which are basically glorified VCRs. They can timeshift but they generally don't always record a buffer like Tivo, one must initiate the recording process.
While I like the Tivo's always live buffer and use it frequently I kind of like it that not all DVRs are always ON and recording. For one thing to have 3 or 4 DVRs always on and recording would use a fair amount of electricity, the other DVRs probably only use a watt or two off while a Tivo or similar uses many times that always recording.
jjeff is offline
post #1104 of 2095 Old 10-04-2014, 03:38 PM
Liked: 1451
Aside from those, the CM DVR+ seems to have that as an optional feature, since you can watch TV with it when you don't have any storage attached (and I don't think it buffers live TV to the internal 16GB storage). The TViX 6620 lets you select whether you want a background buffer all the time or whether you only want to engage the HDD when you press the pause button while watching live TV.
post #1105 of 2095 Old 10-04-2014, 04:10 PM
Kelson's Avatar
Liked: 1209
LOL, I would hardly call disabling functionality by pulling out the HDD an "optional feature". Hell, if you want to play that game you can pull the HDD out of a TiVo and it won't buffer the tuners either.
- kelson h
Kelson is offline
post #1106 of 2095 Old 10-04-2014, 04:20 PM
Liked: 1451
I'm surprised a TiVo would let you do that. I don't know if the DVR+ will let you change the buffer settings when the HDD is connected, since I don't own one.
post #1107 of 2095 Old 10-04-2014, 06:53 PM
Bookworm's Avatar
Yes. It turns out that the problem is the distribution amp TWC provides. TiVo tech support says the FWD frequency of any splitter or amp needs to be greater than 1200 MHz and all TWC equipment tops out at 1002 MHz. I've found several amps that have MoCA ratings in the 1125 to1550 MHz range. I'm just trying to figure out which one to get.
Bookworm is offline
post #1108 of 2095 Old 10-05-2014, 06:31 AM
ncted's Avatar
Quoted: 84 Post(s)
Liked: 38
Per Dave Zatz:
"...the Channel Master DVR+ ships with a mere 16GB of flash storage, good for 2 hours of HD recording and the ability to pause live television for up to 15 minutes."
http://zatznotfunny.com/2013-12/chan...vrplus-cm7500/
ncted is offline
post #1109 of 2095 Old 10-05-2014, 08:07 AM
Liked: 786
I know full well what it takes as I've played around with all sort of stuff on my HD+, but will reiterate that it is not a trivial upgrade for the average user. There are known issues with the SD card driver native to the HD+, for example, and some cards are flakier than others.
But as mentioned it's pointless now anyway until a working root bypass for the Tivo app is released.
Keenan likes this.
post #1110 of 2095 Old 10-06-2014, 01:57 PM
UHD Addict
aaronwt's Avatar
Liked: 3965
The lowest TiVo MoCA frequency is 1150 MHz. Which is channel 15.
aaronwt is offline
Reply HDTV Recorders
Tivo Roamio Dvr , Tivo Roamio Plus Dvr , Tivo Roamio Pro Dvr
