Hard reset for HomeWorX HW-150PVR ATSC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-24-2013, 06:45 AM - Thread Starter
betoc2's Avatar
Dear Forum
Is there a way to reset my HW150, I made a mistake and upload the Iview software, now the remote is useless or is there a way or function in the remote for it to learn the new functions?
Regards
Betoc2
betoc2 is offline
post #2 of 6 Old 09-26-2013, 11:56 AM
png5's Avatar
Originally Posted by betoc2 View Post
Dear Forum
Regards
Betoc2
You need either get Iview3500 or compatiable(Harmony) Remote to operate stb or you have to send back the Mediasonic to reload firmware.
Iviewus.com just send out new IV3500 Remote to current owner. IV3500 owner have a spare old remote. If you can borrow an old IVIEW 3500 from current owner in your location. Then you can load back HW150 firmware. Check wit IVIEW3500 forum
png5 is offline
post #3 of 6 Old 09-28-2013, 05:35 PM
Trent1978's Avatar
I know this is kind of off to
Trent1978 is offline
post #4 of 6 Old 09-28-2013, 05:38 PM
Trent1978's Avatar
I know this a little off topic but could someone tell me how to Record and watch a different channel at the same time on a HomeWork recorder? Thank you.
post #5 of 6 Old 09-28-2013, 05:58 PM
Thread Ender
WS65711's Avatar
Quoted: 487 Post(s)
Liked: 326
You can't do that with these devices.
To anyone interested in a Google Chromebox or Chromebook..
Be aware that these boxes run a variant of Linux and DO NOT support HDCP!!!
This means no support for HD on most streaming services. I wish I would have known this beforehand....
Blu-rays & DVD's
WS65711 is offline
post #6 of 6 Old 09-28-2013, 08:23 PM
png5's Avatar
HW150 has only one tuner. While you are recording, the only tuner is busy doing recording. The way
you can watch another channel is to use TV tuner,
1. split RF input(Antenna) into two RF, connect one to HW150 and another splided RF to TV and watch another channel in TV
2. connect HW150 RF output to TV RF input. Set Menu->Channel Search->Modulation->Loop through
You can use TV tuner to watch anther channel.
png5 is offline
Reply HDTV Recorders
