Cisco Explorer 8642HDC expander - AVS Forum | Home Theater Discussions And Reviews
Old 10-14-2013, 06:38 AM - Thread Starter
ehimemikan's Avatar
Hello,
I would like to find out what DVR expander is compatible with Cisco Explorer 8642HDC. Time Warner Cable in Hawaii is unable to support me with this information. They said that the eSATA port is enabled but the USB port is not. Any information you could give me would be appreciated.
Thank you.
Ehimemikan
ehimemikan is offline
Old 10-14-2013, 02:38 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
Originally Posted by ehimemikan View Post
Hello,
Thank you.
Ehimemikan
HDD expansion is a function of the DVR's IPG (or firmware), not the DVR itself. In the case of TWC, it would depend on which version of Navigator it is running.
domino92024 is offline
Old 10-15-2013, 06:25 AM - Thread Starter
ehimemikan's Avatar
Thank you for replying to my post.
I asked TWC for the version of the navigator but the representative I spoke to didn't know what the navigator was but provided me with the software version of the DVR.  It is ODN 6.1.0_5 (K release).  Is this information helpful in determining the compatible expander?
Thank you.
Ehimemikan
Old 10-15-2013, 01:17 PM
Quoted: 126 Post(s)
Liked: 216
Thank you.
Ehimemikan
I'm not sure if that version even supports HDD expanders. I would read and/or ask your question (with all information) at:
http://www.avsforum.com/t/723830/time-warner-cable-navigator
