Pioneer SD-532 hd5 Won't Come On (PS Has been re-soldered) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-17-2013, 06:36 PM - Thread Starter
Seadee's Avatar
Yes, it's the ole' Pioneer SD-532 hd5 that had the popping/flashing/turning off issue.
The power supply was recently resoldered, it worked great! On day 10, I turned it off one night as normal, came back the next night and wouldn't turn on, at all.
Any ideas as to why? Is it still the power supply or some other issue? I'm pretty much giving up on this thing, but I'm always curious as to what happened. And if it's a relatively easy/inexpensive fix I will.
Thanks for reading.
Seadee is offline
post #2 of 4 Old 10-21-2013, 11:42 AM - Thread Starter
Seadee's Avatar
Buehler? Anyone?
Seadee is offline
post #3 of 4 Old 10-26-2013, 01:41 PM
hondo21's Avatar
You might get a better response if you post this in the correct forum (Display Devices, Rear Projection Units). Mr. Bob will probably see it then.
hondo21 is offline
post #4 of 4 Old 10-30-2013, 02:36 PM - Thread Starter
Seadee's Avatar
Thanks! Didn't realize I'd posted under HDTV recorders....
Seadee is offline
Reply HDTV Recorders
