Philips HDR5710/5750 DVRs, Antenna/Cable, Streaming, Int/Ext HDDs, 33TB Storage - Page 18 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #511 of 745 Old 02-14-2014, 07:36 PM
Kelson's Avatar
Quoted: 1953 Post(s)
Liked: 1148
Originally Posted by apw2607 View Post
Since I'm not a big recorder, have a guide on my tablet and may want to use with clearqam I decide to go with the Philips. I may live to regret it.
I thought you just said here that you have a DVR+ on the way.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #512 of 745 Old 02-14-2014, 09:37 PM
apw2607's Avatar
Quoted: 118 Post(s)
Liked: 229
Yes managed to catch it before it physically shipped out.
apw2607 is online now
post #513 of 745 Old 02-14-2014, 10:00 PM
Kansas_Tom's Avatar
Quoted: 21 Post(s)
Liked: 27
I've gone back and forth ... Get a dvr+, get the philips or stick with the iview.
I've been going through the same decision process. My iView hasn't been reliable enough so it hasn't been used in a while. I like the DVR+ for it's dual tuners. I could free up an HDMI port with it. If it looks like CM is going to keep developing it I might buy one down the line. The lower price on the Philips got me to bite and I've got one on the way. It will replace the oldest Magnavox 2160 in my stack.
Kansas_Tom is online now
post #514 of 745 Old 02-18-2014, 09:09 AM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
wajo is offline
post #515 of 745 Old 02-18-2014, 11:04 AM
apw2607's Avatar
Quoted: 118 Post(s)
Liked: 229
^ Rather pricey. My $179 5710 shipped from NFM yesterday. Should get it by the end of the week.
post #516 of 745 Old 02-18-2014, 11:45 AM
Kansas_Tom's Avatar
Quoted: 21 Post(s)
Liked: 27
I got mine today. It's hooked up to my small TV right now for testing, if all goes well I'll move it to my main stack and replace my oldest 2160.
One question I had can be answered now. The remote code 1 is the same as the Philips 3575/3576 SD recorders.
post #517 of 745 Old 02-18-2014, 11:51 AM
Quoted: 868 Post(s)
Liked: 350
How big is your included hard drive?
JoeKustra is offline
post #518 of 745 Old 02-18-2014, 12:11 PM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
Thanks for that remote code info. Already added to pg. 1.
wajo is offline
post #519 of 745 Old 02-20-2014, 05:10 AM
Jim19's Avatar
Amazon has lowered it's price for the 5750 to $265.18.
Also, thank you to Wajo for all the great info here and on the Magnavox 537 etc. thread!!
Jim19 is offline
post #520 of 745 Old 02-20-2014, 06:10 AM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
Thanks for the heads-up!
Amazon's prices can change hourly so, on pg. 1, I had to resort to linking to a list of its sellers with a range of prices.
wajo is offline
post #521 of 745 Old 02-20-2014, 12:00 PM
Kansas_Tom's Avatar
Quoted: 21 Post(s)
Liked: 27
Some observations and a problem on my new 5710.
I'm OTA and the tuner in the 5710 seems to be a little more sensitive to what I think is probably multi-path interference. The quick signal breakups I get on all my other equipment are worse on the 5710.
The recording title naming scheme really needs to be changed. The recorder will only grab the correct program name if the show has already started when the recording starts. I had one test recording that started just seconds early and it used the previous programs name for the title. They really should change this to have the recorder set the name something like 5 minutes after the recording starts to allow the padding of timer recording start times and to compensate for the networks that like to start their shows one or two minutes after the hour.
The remote buttons for play/ff/rew are too close to the pause/chapter f/ chapter r buttons, way too easy to hit the wrong button if you are not careful. There should have been some more space between the rows for fat American fingers like mine.
I am currently using the 5710 with a Philips TV. Using the TV remote while the 5710 is recording causes the 5710's lights to flash it's unmatched remote warning. Other brand remotes don't do this.
And now for the problem.
I recorded CBS last night. When I watched the recordings I used the rewind button and instead of the normal variable speed rewind it jumped to the start of the recording. I thought I might have hit the chapter rewind button by mistake so after fast forwarding back to where I had been watching I tried rewind again making sure I hit the correct button on the remote and it jumped to the start again. To eliminate a bad remote I used the remote for my Philips 3576 and tried again and got the same result. I ran test recordings today on CBS,NBC,ABC,FOX and on playback the rewind function worked properly on all recordings except for the CBS recording. I'm currently running more test recordings to test again but it looks like either CBS or my local CBS affiliate is doing something the 5710 doesn't like.
Edit: On my second round of tests for the CBS rewind issue I made two recordings, on one trying to rewind jumped to the start and on the other trying to rewind froze the playback. confused.gif
I'll probably keep the Philips but won't buy another one or a Magnavox if they ever become reality. I currently have dedicated SD recorders for each of the major networks. I can use this one for the network that has the least interference that is not CBS and put my oldest Magnavox SD recorder into retirement. I'm going to keep watching the development of the CM DVR+ and may get one of them to bring more of my recorders into the HD age.
apw2607 likes this.
post #522 of 745 Old 02-20-2014, 03:43 PM
apw2607's Avatar
Quoted: 118 Post(s)
Liked: 229
Thanks for the observations. Mine arrives tomorrow. See if I can replicate your issue with CBS here.
post #523 of 745 Old 02-21-2014, 04:52 PM
Kansas_Tom's Avatar
Quoted: 21 Post(s)
Liked: 27
My 5710 went back today. The tuner just did not like what my antenna was feeding it.
post #524 of 745 Old 02-21-2014, 10:48 PM
Kelson's Avatar
Liked: 1148
I got mine today .
3 days -- that was quick.
Well hey, at least you got an honorable mention in post #1.
- kelson h
Kelson is offline
post #525 of 745 Old 02-22-2014, 07:29 AM
Kansas_Tom's Avatar
Quoted: 21 Post(s)
Liked: 27
I should have spent more time with it but I got so frustrated trying to watch a recorded show Thursday evening I just boxed it up. Also I was in the Kansas City area Friday so I could just return it to the store instead of shipping it back to Nebraska Furniture Mart.
What I think was the source of my problem is interference (multi-path?) I get from my antenna. What shows up as quick macro-blocking with sound disruption on all my other equipment freezes the picture on the 5710 until the signal comes back.
I've always used the fast forward/rewind buttons to zap commercials but because the playback buttons are so small and close together on the Philips remote doing that was problematic because I'd end up hitting the wrong button. I decided to use the variable skip/rewind for the show I was watching Thursday. I had it set up to skip forward 60 seconds rewind 30 seconds. On one of the commercial skips instead of going forward 60 seconds it took a big jump, probably 10-15 minutes. I'm guessing that if the recording has a signal disruption during the skip interval it causes problems. I had already had problems with the rewind function not working correctly on recordings from my CBS affiliate and now the skip function was not working correctly on a recording from FOX.
While I'd like to have a HD DVR my Philips 3576 and Magnavox 2160/2160A/513 SD recorders have been flawless workhorses. The benefit of being able to watch my recordings in HD was not worth the frustration I was experiencing with the 5710. I still have an iView but the clock issues with it are frustrating too.
apw2607 likes this.
post #526 of 745 Old 02-22-2014, 12:29 PM
Kelson's Avatar
Liked: 1148
Go take a look at the CM DVR+ thread.
- kelson h
Kelson is offline
post #527 of 745 Old 02-22-2014, 05:59 PM
Kansas_Tom's Avatar
Quoted: 21 Post(s)
Liked: 27
I've been watching the DVR+ thread. I'm taking a wait and see position on the DVR+ like I had planned to do with the Philips until Nebraska Furniture Mart put them on sale.
post #528 of 745 Old 03-01-2014, 12:01 PM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
wajo is offline
post #529 of 745 Old 03-03-2014, 03:03 PM
Quoted: 178 Post(s)
Liked: 2902
wajo, et al:
Best Buy has changed the price of the 5750 to $250.99.
tomintn is offline
post #530 of 745 Old 03-03-2014, 03:34 PM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
wajo is offline
post #531 of 745 Old 03-04-2014, 07:49 AM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
:D
A 5750 user just informed me that Vudu streams DD7.1 when available (some movies).
:D
wajo is offline
post #532 of 745 Old 03-16-2014, 05:10 PM
apw2607's Avatar
Quoted: 118 Post(s)
Liked: 229
Although the specs say the 5710 supports Dolby Digital Plus (for streaming content), I've only found the 5710 will only send a Dolby Digital bitstream (tried both Vudu and Netflix). Also no support for Dolby Digital Plus 7.1 in Vudu, only 5.1 Dolby Digital.
Another odd piece of behavior. netflix seems capped at 3000kbps @ 720p on the 5710.
post #533 of 745 Old 03-23-2014, 09:47 AM
ALP
ALP's Avatar
Quoted: 64 Post(s)
Liked: 26
I am sorry, but I have not had a chance to read the entire thread. I currently use Magnavox 537's to record SD OTA. I am about 30+ miles from the broadcast antennas in NYC and receive very good signal on the Maggi's and my three TV's (Pioneer, Panasonic and Sharp). Does anyone know if the tuner used in the new Phillips 5750 is the same as the tuner Funai used in the Magnavox 57X series?
Tony Plachy
ALP is offline
post #534 of 745 Old 03-23-2014, 09:56 AM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
No. The 53x tuner is "hybrid" (switched analog/digital) while the new Philips is "integrated" like a HDTV tuner (all analog/digital channels in sequence).
wajo is offline
post #535 of 745 Old 03-23-2014, 10:12 AM
ALP
ALP's Avatar
Quoted: 64 Post(s)
Liked: 26
Wajo, Thanks. Do you know (or does anyone know) if the new tuner in the Phillips has as much sensitivity (i.e. the ability to receive a weak signal) as the old Maggi tuner in the 537? What I am trying to avoid is buying one of the new Phillips DVR's only to learn that its tuner is not "strong" enough to give me good OTA reception were I am located.
Tony Plachy
ALP is offline
post #536 of 745 Old 03-23-2014, 03:21 PM
Kansas_Tom's Avatar
Quoted: 21 Post(s)
Liked: 27
I can't help with weak signals. If anything I suffer from too strong a signal. My towers are 1, 3, 8 and 15 miles away.
post #537 of 745 Old 03-23-2014, 04:26 PM
apw2607's Avatar
Quoted: 118 Post(s)
Liked: 229
Perhaps I can help. I've being living with the 5710 (and 5750 for a short period) for the last couple of weeks. I would say the 5710 tuners are ok. I live in a pretty awful area for reception. I've tried a iview, dvr+, TiVo premier and Roamio, and now the 5710.
In order for me as being worse for receiving my 5 main locals ...
TiVo premier
Dvr+
TiVo Roamio
Philips 5710
Iview
Sony tv tuner
post #538 of 745 Old 03-23-2014, 04:30 PM
apw2607's Avatar
Quoted: 118 Post(s)
Liked: 229
As I mentioned above. I now have used both the 5710 and 5750. One thing I've noticed on the 5750 is the hard drive is much louder. Perhaps it was just a one off and I got a bad one, but in comparison to the 5710 ... Mine was really loud. Clicking and rattling. To a point where I sent it back and just settled on the smaller 500GB version which is whisper quiet.
post #539 of 745 Old 03-23-2014, 04:33 PM
apw2607's Avatar
Quoted: 118 Post(s)
Liked: 229
I've tried both the 5750 and 5710 and neither can output Dolby Digital Plus (5.1 or 7.1) from VUDU. They can only output standard Dolby Digital 5.1
Same for Netflix. No Dolby Digital Plus.
The fact that 7.1 Dolby digital plus movies are listed on VUDU doesn't necessarily mean the client can send that to your receiver.
post #540 of 745 Old 03-23-2014, 04:35 PM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
TiVo premier
Dvr+
TiVo Roamio
Philips 5710
Iview
Sony tv tuner
So, would it be safe to re-order your list from best to worst as follows?
1. Sony tv tuner
2. iView
3. Philips 5710
4. TiVo Roamio
5. DVR+
6. TiVo Premiere
wajo is offline
Reply HDTV Recorders
Philips Hdr5710 F7 Digital Video Recorder Black
