Philips HDR5710/5750 DVRs, Antenna/Cable, Streaming, Int/Ext HDDs, 33TB Storage - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #91 of 745 Old 11-22-2013, 02:23 PM
Aleron Ives's Avatar
Quoted: 1583 Post(s)
Liked: 1290
You can be sure that it won't record HDMI. That's what PC capture cards are for.
Aleron Ives is offline
post #92 of 745 Old 11-22-2013, 05:33 PM
stapler1234's Avatar
Originally Posted by Clint S. View Post
...........If you can use these to record cable, and HD cable at that, then I may be one of the first. wink.gif If not, then I'll have no interest in one...........
With the little info we have, I'm of the opinion the spec will show:
  • Cable compatible tuner
  • HDMI will be output only
  • USB will be 2.0 (not 3.0) and only for use in updating internal OS and streaming apps.
  • No external storage option (2 different sized HDD models basically rule that out.)
  • LAN input will be for wired internet only (due limited OS codec's)
Except for branding names, the Magnavox & Philips units appear identical, probably due competitive purposes, as in: Amazon vs. BestBuy. (Over the past months, my local Walmart's have been slowly replacing Magnavox models with identical units carrying just the Funai name. ?????)
stapler1234 is offline
post #93 of 745 Old 11-23-2013, 02:47 AM
Clint S.'s Avatar
Quoted: 48 Post(s)
Liked: 0
Thanks for the info and clearing that up. confused.gif So.....what's the point in having one these units? There doesn't seem to be anything really useful over that of the 2160A/513/515, etc.
God Bless,
-Clint
Clint S. is offline
post #94 of 745 Old 11-23-2013, 05:43 AM
Quoted: 865 Post(s)
Liked: 349
Some people like to buy new stuff when old stuff is no longer manufactured. Plus old stuff gets dirty.
I have a dollar that says cable is not supported unless there is a cable card slot hiding somewhere.
JoeKustra is offline
post #95 of 745 Old 11-23-2013, 09:29 AM
Kansas_Tom's Avatar
Quoted: 21 Post(s)
Liked: 27
Maybe your your statement should read There doesn't seem to be anything really useful over that of the 2160A/513/515, etc for cable subscribers that are tied to cable boxes for their high definition content.
I'm OTA and while I'm quite satisfied with my 3576, 2160, 2160A and 513 I would consider it useful to be able to record and play back in High Definition. I would consider it really useful if the remote IR codes are different between the new Philips and Magnavox units and if the codes are different between the new recorders and the old recorders.
Kansas_Tom is offline
post #96 of 745 Old 11-23-2013, 02:52 PM
Liked: 1290
They record HD, and the usefulness of that feature is a matter of opinion.
post #97 of 745 Old 11-25-2013, 07:23 PM
profhat's Avatar
Without HD capture capacities, those units are expensive and useless.
profhat is offline
post #98 of 745 Old 11-26-2013, 06:19 AM
Super Moderator
DrDon's Avatar
Quoted: 881 Post(s)
Liked: 1740
Bickering removed. Off topic posts removed. Infractions issued.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #99 of 745 Old 11-27-2013, 01:54 PM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
:D
One Member got the first Philips 5710 and PM'd me his preliminary info.
See Post #2, where I pasted his info... I haven't really reviewed it in detail except to see that it's for both antenna and cable.
I'll either keep Post #2 updated or move to Post #1, whichever makes the most sense as we get more info.
:D
wajo is offline
post #100 of 745 Old 11-27-2013, 04:13 PM
mreedelp's Avatar
Quoted: 98 Post(s)
Liked: 77
Did he say where he bought it? Looks like Best Buy may have them in stock. Adding to cart and selecting shipping says it could be delivered by December 4.
One thing I noticed in the write-up: Register up to 8 (eight) USB external devices. Sounds like what used to happen with external esata drives used on cable boxes where the contents could only be played on that machine. If true, having an external drive would be a crapshoot if you were using it to save titles. If your machine died, you would be stuck with an external drive filled with nothing you could get to. Very disappointing.
mreedelp is offline
post #101 of 745 Old 11-27-2013, 04:17 PM
Quoted: 865 Post(s)
Liked: 349
Your friend is very nice. Anyone with digital cable not using a DTA should have clear QAM. A rescan will be needed. The Madison & Milwaukee markets are pretty big.
post #102 of 745 Old 11-27-2013, 04:28 PM
mwg1's Avatar
Quoted: 13 Post(s)
I bought Philips HDR5710/F7 at Bestbuy.com. I registered an external usb hard drive, recorded to it and was able to copy/move what I recorded back and forth to the units internal hard drive. When I connected the same external usb hard drive to my computer (windows 7 64-bit), it does not recognize the drive.
mwg1 is offline
post #103 of 745 Old 11-27-2013, 04:32 PM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
I think he got it from eBay.
The "Register" thing could easily be "Japanese" for Initialize, like all new HDDs for the SD recorders... same word they use for adding titles to the Dub Menu ("Register title").
I just saw mwg's post where his WIN 7 couldn't see the HDD, however, these new HD units have a Linux OS.
wajo is offline
post #104 of 745 Old 11-27-2013, 07:19 PM
mwg1's Avatar
Quoted: 13 Post(s)
I have access to a Linux OS machine. What should I look for?
mwg1 is offline
post #105 of 745 Old 11-27-2013, 07:33 PM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
I don't do Linux but I assume you try to "read" or at least see what shows up on one of the HDDs with titles on it?
If you see something, take a screenshot and post it?
We need a Linux expert!
wajo is offline
post #106 of 745 Old 11-27-2013, 07:34 PM
Liked: 1290
I think he just wants you to test the drive with a Linux system to see if it will recognise the drive. I would think that Windows 7 should be capable of seeing the files on its own, though, as I thought Windows 7 came with ext2/3 drivers pre-installed. If you can get VLC or similar software to play one of the recordings under Linux, that would prove the drive's contents are accessible.
post #107 of 745 Old 11-27-2013, 07:46 PM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
Link to "rough" manual ... also now in Post #1.
... it's "rough" and not searchable.
(Thanks again to our anonymous donor.)
wajo is offline
post #108 of 745 Old 11-27-2013, 08:19 PM
Kansas_Tom's Avatar
Quoted: 21 Post(s)
Liked: 27
I've read through the manual and don't see anything about being able to name the recording when scheduling it.
post #109 of 745 Old 11-27-2013, 08:26 PM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
You really will have to "read" that rough manual to find something specific... I just discovered it's not searchable like a "normal" pdf file!
wajo is offline
post #110 of 745 Old 11-27-2013, 08:49 PM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
:D
Tidbits:
External USB HDD can be 32GB - 4TB capacity.
2 remote codes for 5710/5750.
100 timer programs (with "titles" from somewhere?).
:D
wajo is offline
post #111 of 745 Old 11-27-2013, 09:06 PM
Kansas_Tom's Avatar
Quoted: 21 Post(s)
Liked: 27
I did read through it. What I couldn't make out were the pictures of the menu for scheduling. Hopefully the ability to rename titles is there but just not documented in the text.
post #112 of 745 Old 11-27-2013, 09:10 PM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
I took a screen shot of the timer programming instruction where it says item 1 is the "Title"... not sure where that comes from but it's apparently not the nondescript date, time, channel stuff since that's mentioned separately? I didn't see any manual "user-titling" feature/menu.
Edit: I noticed an "On-Screen Keyboard" mentioned in HDD registering instructions. Might appear in other menus as well, like the Timer Programming menu... hope?
wajo is offline
post #113 of 745 Old 11-27-2013, 09:27 PM
MarkB49's Avatar
Quoted: 35 Post(s)
Wajo
Is that a 3.0 or 2.0 USB on the back.
Would kindda like to know.Bought 2 8gb at BB .
They do have 32 gb 3.0 on sale also.
Mark
MarkB49 is offline
post #114 of 745 Old 11-27-2013, 09:32 PM
mwg1's Avatar
Quoted: 13 Post(s)
Originally Posted by MarkB49 View Post
Wajo
Mark
I own a HDR5710 and it is USB 3.0 on the back
mwg1 is offline
post #115 of 745 Old 11-27-2013, 09:45 PM
MarkB49's Avatar
Quoted: 35 Post(s)
I set aside 350. That is part of the reason why I didn't buy the more exspensive one.Enough saved for
support. Cables HD's batteries etc.
2 TB external HD's are on sale everywhere.
Thanks again mwg1
Mark
MarkB49 is offline
post #116 of 745 Old 11-27-2013, 10:48 PM - Thread Starter
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
Thanks again mwg1
Mark
The manual says the USB can only be used for external HDD or memory stick with software update only, as shown here:
Still worth a try to record to a stick, but doesn't sound like it would work... only an external HDD?
wajo is offline
post #117 of 745 Old 11-27-2013, 11:22 PM
Kelson's Avatar
Quoted: 1952 Post(s)
Liked: 1147
I own a HDR5710
If you have a unit in hand, then you are the only authority posting.
Why don't you post answers to some of these questions and end the speculation.
What does the thing do for recording titles? What is the default title name when scheduled? Can you edit a title name?
How does it set and maintain the clock?
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #118 of 745 Old 11-27-2013, 11:43 PM
Liked: 1290
That's merely a disclaimer to reduce the number of people who complain that recording to a flash drive doesn't work. Most flash drives use cheap, slow memory that can't handle the throughput necessary to record HD, but some of them will work. Since there is no standardised rating system for the speed of flash drives, it's almost impossible to tell if a particular make or model of drive will work without testing it. Even if you do find one that works, it's not a very practical solution, as flash drives offer a low $ / GB ratio and are not designed for the repeated write cycles they will experience when used for recording.
post #119 of 745 Old 11-27-2013, 11:58 PM
MarkB49's Avatar
Quoted: 35 Post(s)
I'm gonna check prices all day on 2 TB WD Win Books.
The 3.0 SanDisk stick at BB was 30 bucks earlier this week.
I'll probably take that and put it toward a win book.
Meanwhile my 5710 is "Stuck in L.A." LOL
Mark
www.gottadeal.com
A real good site for Today!!
MarkB49 is offline
post #120 of 745 Old 11-28-2013, 03:27 AM
Clint S.'s Avatar
Quoted: 48 Post(s)
Liked: 0
There's no S-video input on these? I can't tell from the rear image if the image is of the entire back.
(Anyone), please let us know when there is a searchable PDF manual available.
Will you be adding these new units to the DVR comparison page/post?
Also (anyone) please keep us posted on the accuracy of these statements:
Things we think we know so far on 5710/5750:
  • For antenna or clear-QAM cable.
got my unit.
manual indicates:
can record from antenna or cable.
can not record analog from cable
specification im back on manual contradict rest of manu[al?]
Specs say:
TV system ATSC/NTSC MTV standard
Channel coverage terrestrial: VHF 2-13, UHF 14-69 (Analog/Digital)
cable 1-135 (Analog/Digital)
........do you know of the clear qam channels for charter cable for my zip code 54968 that i could test at a place that has basic cable??
God Bless,
-Clint
Clint S. is offline
Reply HDTV Recorders
Philips Hdr5710 F7 Digital Video Recorder Black
