Philips HDR5710/5750 DVRs, Antenna/Cable, Streaming, Int/Ext HDDs, 33TB Storage - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #121 of 745 Old 11-28-2013, 05:29 AM
mwg1's Avatar
Quoted: 13 Post(s)
Originally Posted by Kelson View Post
If you have a unit in hand, then you are the only authority posting.
Why don't you post answers to some of these questions and end the speculation.
What does the thing do for recording titles? What is the default title name when scheduled? Can you edit a title name?
How does it set and maintain the clock?
I do not want to post false info. Still finding time to do testing. Preliminary findings is that one can not edit titles.
One touch recordings defaults to name of show. example i recorded by one touch the Katie Couric show for a few seconds. It saved the title as "Katie". Could not so far find a way to edit it.
I think a timer shows title will defaut to the date time and channel recorded. That is a guess so far.
Will do more testing Friday.
mwg1 is offline
post #122 of 745 Old 11-28-2013, 06:02 AM
Clint S.'s Avatar
Quoted: 51 Post(s)
Liked: 0
Can you answer anything I mentioned in post 121 above? That's ridiculous not being able to give a recording a name. Everything I record (on a 2160A) just shows the channel and time, and I have to go to "Edit" to name it so I'll know what it is.
God Bless,
-Clint
Clint S. is offline
post #123 of 745 Old 11-28-2013, 06:11 AM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 198
He already says it picks up the show name from an OTA broadcast (mwg is OTA). Not sure yet what it does on cable.
There is no S-Video.
Check Post #1 regularly where I'm adding info as it's discovered or otherwise revealed. Also Post #2 for mwg's detailed findings, some of which I incorporate in Post #1 for people who come here from outside sites.
There's been a "SuperFW 727V" FW update available for years now that makes a 2160A operate like a 515, with pre-titling of timers so each recorded instance of shows get a title name at top of Title menu when you highlight the index pic.
7558037 is offline
post #124 of 745 Old 11-28-2013, 06:38 AM
Clint S.'s Avatar
Quoted: 51 Post(s)
Liked: 0
Right, I use cable.
Well that really sucks. That's a step backwards from the previous units.
confused.gif I already have that version installed. Evidently it only does this for OTA, it won't even add the show name for cable DTV recordings. This usually isn't a problem since I rarely save recordings, but when I occasionally do, they have to be "Edited" in order to give it the name.
God Bless,
-Clint
Clint S. is offline
post #125 of 745 Old 11-28-2013, 06:38 AM
Kansas_Tom's Avatar
Quoted: 21 Post(s)
Liked: 27
If it picks up the program name from PSIP that would be all I want. I would only want to edit the title if it only showed the date and time like the 3575/6-2160 did.
Kansas_Tom is offline
post #126 of 745 Old 11-28-2013, 06:41 AM
mwg1's Avatar
Quoted: 13 Post(s)
Did a test for just you, found you CAN edit title names after they are recorded either way. Also you can protect them. This is 100% positive fact.
Do not know where it get clock setting from besides me entering in the time on initial setup.
Clint S. likes this.
mwg1 is offline
post #127 of 745 Old 11-28-2013, 06:44 AM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 198
Manual mentions Auto Clock, but only in ref. to "If you have Auto Clock On" (or Off), ....
Manual also mentions an "On-Screen Keyboard" for one menu, so it's possible other menus have keyboard for stuff.
7558037 is offline
post #128 of 745 Old 11-28-2013, 06:44 AM
Kansas_Tom's Avatar
Quoted: 21 Post(s)
Liked: 27
The super firmware doesn't automatically add the program name, you have to manually edit the title to do that OTA or cable.
post #129 of 745 Old 11-28-2013, 06:47 AM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 198
Well then, you've been wasting your time adding titles after the fact on timer recordings. You pre-title in the timer menu by entering a timer program, then re-entering and selecting the 3rd option "Edit Title Name," as described in this help file.
You can also add a title name on timers already set up, as described in the help file.
7558037 is offline
post #130 of 745 Old 11-28-2013, 06:49 AM
Clint S.'s Avatar
Quoted: 51 Post(s)
Liked: 0
God Bless,
-Clint
Clint S. is offline
post #131 of 745 Old 11-28-2013, 06:58 AM
Clint S.'s Avatar
Quoted: 51 Post(s)
Liked: 0
It's not wasting time because you still have to manually "punch-in" a name, but that's good to know it can be done pre-recording. I can't believe I never noticed that before! Wow. tongue.gif Thanks.
God Bless,
-Clint
Clint S. is offline
post #132 of 745 Old 11-28-2013, 07:04 AM
mwg1's Avatar
Quoted: 13 Post(s)
Here is a pic of menu to change titles. The title names in the center where automatically entered (not by me). I have OTA in WI.
videobruce likes this.
mwg1 is offline
post #133 of 745 Old 11-28-2013, 07:05 AM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 198
Wasting time titling every recorded instance of a show, rather than one time in timer program.
7558037 is offline
post #134 of 745 Old 11-28-2013, 07:17 AM
Clint S.'s Avatar
Quoted: 51 Post(s)
Liked: 0
I don't follow you there. Are you saying it will remember you naming that recording so you won't have to ever do it again the following times?
I think I may see what you're saying: If it's a consistent program and time, and if you just leave the timed recording there all the time. ? But that's rarely ever the case. Every program I record; the networks insist on jacking up the season with BS reruns so each time I have to check to see if it's new (or if it's even airing).
God Bless,
-Clint
Clint S. is offline
post #135 of 745 Old 11-28-2013, 07:24 AM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 198
Yes, as long as you're setting timers, you expect those shows to repeat so auto-titling seems like a no-brainer. Even a one-time show timer-recorded can have an auto name unless that show isn't "worth the trouble". i.e., you prob. wouldn't name a one-time show anyway, either before or after recording?
7558037 is offline
post #136 of 745 Old 11-28-2013, 07:36 AM
videobruce's Avatar
Quoted: 669 Post(s)
Liked: 254
mwg1;
You have a PM.
How far are you from Madison? Have you found your physical, 'in the clear' CATV channels yet? If not have to tried the local reception thread for you market?
That is no surprise. Unfortunately, there isn't a need for that anymore with equipment manufactured in the past 5 or so years. Look at component. That's much more recent and those inputs/outputs are pretty much gone. Thank the CEA and HDMI for that. mad.gif
Recording free OTA TV for 'time shifting' has been here since 1977. Will there be DVR's to do the same when ATSC3 obsoletes existing DVR's??
videobruce is offline
post #137 of 745 Old 11-28-2013, 07:47 AM
Clint S.'s Avatar
Quoted: 51 Post(s)
Liked: 0
Right, like I mentioned, I never bother naming them unless I'm going to keep them for a while. For one example (in both cases), I've been saving "Marvel's Agents of SHIELD" so I have to manually name them, but, once again they are skipping a frickin' week so that's another show where you can't leave it set. I haven't looked into "Skip" yet, but I'm assuming once you find out a network is screwing fans again, you can check "Skip" and it will not record. Then when you find out it's back, set it back again.
God Bless,
-Clint
Clint S. is offline
post #138 of 745 Old 11-28-2013, 07:49 AM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 198
:D
mwg1 is supplying pics (Attachments) that I'm converting to AVS format in-post images.
I've added quite a few lately. I'm not titling each one since I think they're self-explanatory (at this early stage, at least).
Check them out in Post #2 here.
Keep checking Post #1 and #2 where I'm trying to assimilate the most important info for ease of ref.
:D
7558037 is offline
post #139 of 745 Old 11-28-2013, 09:03 AM
jjeff's Avatar
Quoted: 777 Post(s)
Liked: 278
I give credit to Funai for having a manual clock setting, something many other DVR manufactures have omitted and has led to their demise.
jjeff is offline
post #140 of 745 Old 11-28-2013, 09:48 AM
Quoted: 920 Post(s)
Liked: 368
It's also nice that firmware updates are via the internet. Time via PSIP is not always reliable, so I've heard. Cable with no PSIP could be an issue for some people. Access to some web sites is easier with a USB keyboard. No mention of time via NTP was made in the manual.
JoeKustra is offline
post #141 of 745 Old 11-28-2013, 01:54 PM
Aleron Ives's Avatar
Quoted: 1692 Post(s)
Liked: 1449
Yes, this is a major feature missing from several current models, but it's too bad that the price on these is so much higher just to get one feature that is so basic it's inexcusable for it to be missing on even the cheapest DVR.
Aleron Ives is offline
post #142 of 745 Old 11-28-2013, 06:24 PM
Mister B's Avatar
Quoted: 17 Post(s)
I connected my old CECB box a couple of weeks ago and the PSIP time was the worst I have ever seen it. It seemed to be at random from several hours slow to many hours in the future. Even the minutes were no where near correct. It reminded me of old alarm clocks that started at 12:00 when plugged in and proceed from that point. If this unit gets title information from PSIP, I wonder if the manual clock set overrides the PSIP time on the guide. When the clock is so completely incorrect that makes the guide useless anyway. The CECB box was showing "current show" as what would be on in the evening or was on several hours ago.
Mister B is offline
post #143 of 745 Old 11-29-2013, 03:14 AM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 198
These have an Auto Clock ON and OFF setting, so OFF should be running with a manual clock.
7558037 is offline
post #144 of 745 Old 11-29-2013, 08:41 AM
Kelson's Avatar
Quoted: 2029 Post(s)
Liked: 1209
Devices that set their clock via PSIP generally "refresh" the time every time you change the channel. For whatever reason, many stations don't particularly care about the accuracy of their PSIP clock so if you live in a very bad market, you can see the time jump around as you surf the channels. Obviously a DVR with a bad clock is pretty much useless.
Another problem comes from the design of the devices. A device that is designed to have it's clock time refreshed from an external source on a regular basis will not be designed with a robust clock circuit that will maintain an accurate time over a "long" period of several days. You may have seen posts in the other thread about people soldering trimming capacitors on the motherboard to tune the clock circuit and minimize the amount of time that is lost. What remains to be seen is whether or not this unit can utilize an Internet time signal. There is no excuse for an Internet connected device to not have a dependably accurate clock, especially something like a DVR whose function depends on a continuously accurate clock.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #145 of 745 Old 11-29-2013, 10:29 AM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 198
:D
First user has supplied more info... see bottom of Post #2:
Cable channel scan got both analog and digital channels.
Linux saw the HDD but not his two recorded titles.... more research to come.
Linux Users:
Please check out the "License" pic in Post #2, just above the latest two info on channel scan and Linux, and see if that gives a clue on what Linux or open-source components might be needed to read the files on the HDD... I'm hoping that 1st line provides a big part of the OS elements!?
:D
7558037 is offline
post #146 of 745 Old 11-29-2013, 10:34 AM
jjeff's Avatar
Quoted: 777 Post(s)
Liked: 278
Can we assume the tuner scans analog and digital channels one after another, eg channel 2, then 2.1, 2.2, then 3, etc.(like most TVs) as apposed to the hybrid tuner on the Magnavox DVDRs where all the digital and all the analogs are scanned separately?
jjeff is offline
post #147 of 745 Old 11-29-2013, 10:57 AM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 198
Yes, it tunes in numerical sequence... no "switch" required.
I'm going yo add that to Post #2.
7558037 is offline
post #148 of 745 Old 11-29-2013, 10:59 AM
mwg1's Avatar
Quoted: 13 Post(s)
They were one after the other (ex 2, then 2.1, 2.2, 2.3, 3 ....etc ). No switching between analog/digital needed.
mwg1 is offline
post #149 of 745 Old 11-29-2013, 11:15 AM
Kelson's Avatar
Liked: 1209
Have you actually recorded an analog channel yet?
- kelson h
Kelson is offline
post #150 of 745 Old 11-29-2013, 11:29 AM - Thread Starter
Guest
Quoted: 38 Post(s)
Liked: 198
:D
New pic added to Post #2 showing Auto Clock setting menu, which allows user to Search for a time signal (which it also uses for initial setup) or enter a specific channel, like in our SD DVDR "11:57 Procedure."
:D
7558037 is offline
Reply HDTV Recorders
Philips Hdr5710 F7 Digital Video Recorder Black
