SA 8300HDC (Comcast Houston) help please . . . - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-14-2013, 08:56 AM - Thread Starter
Lloyd-TX's Avatar
Quoted: 21 Post(s)
Liked: 48
IMG_0181s.jpg 149k .jpg file Hello all:
I've been trying my best to cure a SEVERE channel change lag problem with a replacement DVR I picked up on Monday. Replaced another 8300HDC which had a hard drive failure over the weekend.
Best that I can determine, the severe lag only occurs when the channel change involves a video format change, say 720P to 1080i, or whatever. The lag / dropout can last as long as 4 or 5 seconds - MUCHO aggravating to say the least. This was NEVER an issue with my older 8300.
I downloaded the so-called SA "Explorer HDTV Setup Wizard" and the SA "Explorer Digital Video Recorder" pdf's and tried following the "Setup Wizard" instructions with absolutely no results. I can't yet get into setup screens! Obviously I have outdated information. After hours of searching this forum I'm more confused than ever. I still have NO idea which software this particular DVR is running. I'm SO dumb . . .frown.gif
Anyway, attached is a screenshot of my 8300's "configuration" screen. Hopefully someone who reads this post will be able to identify my software and take the time to post a blow-by-blow, keystroke by keystroke description of how to get into my 8300's setup screens so I can lock the video output to 1080i.
By the way, my setup is as follows: 8300HDC - HDMI - Yamaha RX-Z7 A-V Receiver - HDMI - Panasonic TCP-65V10 Plasma Display
Many, MANY thanks in advance for helping this stupid ol' fat guy out! cool.gif
Best regards,
Lloyd C.
Lloyd-TX is offline
post #2 of 4 Old 11-15-2013, 06:09 AM - Thread Starter
Lloyd-TX's Avatar
Quoted: 21 Post(s)
Liked: 48
If anyone gives a rats a$$, the procedure outlined in the attached document worked like a champ. Found it in a forum somewhere yesterday. Mucho thanks to the original poster, whomever you are!
SA 8300 HD Video Setup Procedures.doc 30k .doc file
Best regards,
Lloyd C.
Lloyd-TX is offline
post #3 of 4 Old 11-15-2013, 12:57 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
...whoever...
domino92024 is offline
post #4 of 4 Old 11-15-2013, 01:04 PM - Thread Starter
Lloyd-TX's Avatar
Quoted: 21 Post(s)
Liked: 48
Originally Posted by domino92024 View Post
...whoever...
Best regards,
Lloyd C.
Lloyd-TX is offline
Reply HDTV Recorders
Yamaha Rx Z7bl 7 1 Channel High End Network Home Theater Receiver , Panasonic Tc P65v10 65 Inch 1080p Plasma Hdtv , Optoma Hd8300 3d Projector
