Official Tablo thread - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 70Likes
post #151 of 893 Old 04-04-2014, 09:51 AM
TabloTV's Avatar
Quoted: 14 Post(s)
Liked: 36
Originally Posted by Mattman13 View Post
Why is a tuner needed to re-encode recordings to different formats?
-MM13
We use our hardware to transcode the video to a lower bit rate to avoid stuttering for out-of-home streaming (othewise known as Tablo Connect).
TabloTV is offline
post #152 of 893 Old 04-04-2014, 10:04 AM
snowcat's Avatar
Quoted: 57 Post(s)
Liked: 63
sgnadeau,
I also am waiting for two things:  Decent reviews and 4-tuner model.
-MM13
http://support.tablotv.com/hc/en-us/articles/202200368-Chapter-6-Connecting-to-Tablo-Away-from-Home
If you read this section, it is because the upload bitrate is usually a lot less than the download bitrate. To accommodate viewing outside of your home network, the video has to be re-encoded at a lower quality. However, if you have a good upload bitrate (5 Mbps for 720p and 10Mbps for 1080p), you don't have to re-encode and it won't use a tuner.
snowcat is offline
post #153 of 893 Old 04-04-2014, 10:13 AM
TabloTV's Avatar
Quoted: 14 Post(s)
Liked: 36
Hey @snowcat - we're hiring for a support position now. Wanna come work for us? :D
TabloTV is offline
post #154 of 893 Old 04-04-2014, 11:20 AM
snowcat's Avatar
Quoted: 57 Post(s)
Liked: 63
It would be fun, though I am busy enough doing software and systems performance testing for my current job. smile.gif I do appreciate support/help desks and all they do. It's not an easy job, and I have been impressed so far from what I have seen from you and your company.
snowcat is offline
post #155 of 893 Old 04-04-2014, 11:31 AM
TabloTV's Avatar
Quoted: 14 Post(s)
Liked: 36
Aw thanks! We try to be the kind of company we'd want to deal with ourselves.
And I don't blame you for wanting to stay. The weather is probably nicer in Nashville.
TabloTV is offline
post #156 of 893 Old 04-04-2014, 04:04 PM
Questions123's Avatar
Originally Posted by sgnadeau View Post
Recordings can be scheduled directly in the grid under the Live TV menu. You can't do series recording using this option, only recordings for individual programs.
Not sure what you're using (tablet/roku/browser), but from the webapp if you press info (instead of record), you can record the series.
Questions123 is offline
post #157 of 893 Old 04-04-2014, 04:16 PM
First impressions: I’m very impressed
Appearance
The form factor is smaller than I expected. It’s solid. All good here.
Setup
I’m using a wired connection, and a computer, Samsung Smart TV, and Samsung smartphones. I tried using Firefox, but firefox will not connect from the PC. The Tablo recognized my harddrive right away (Toshiba Canvio 1.5TB ). It showed me the channel listings, I chose which ones I wanted to add, it downloaded the latest firmware.
And again… the Tablo asked me to format my hard drive, and again I hit format (I’m guessing the firmware update interrupted the format process, no biggie, but would’ve been nice to know). Until the drive is formatted, you can’t use the Tablo. The format probably took about 20 mins.
Tablo connect needs to be manually enabled via settings.
Tuners
The tuners are sensitive. The two channels which my TV struggles with (poor reception), work very well on the Tablo.
Computer Use
I could only add some TV shows, I’m guessing the channel guide data didn’t fully come in yet…
Samsung Smart TV Usage
I can get onto the my.tablotv.com website, it detects the Tablo, but it hangs when I try to connect to it (says “Connecting” with the spinning circle)… o well, that would’ve been nice. For now I'll keep the Roku.
Smartphone Usage
Worked both in-network and after it was paired.
Though I get a message “You are running a version of Android that supports playing Tablo video in the Android video player. Launch the video player using the button below.” That’s great, but when I launch the video in the designated viewer, I don’t have pause/rewind/etc. functionality.
Roku Usage
Roku works fine. The rewind/fast forward displays on screen as expected. Streams well, etc.
One thing I noticed in video quality -- I set the Tablo to 720p and set the Roku to upconvert to 1080p the video quality was noticeably worse than if I set the Roku to 720p and my AVR to 1080p (I didn't try passthrough on the AVR, but I will later)
Guide
It took me about 12+ hours for the guide to download. Up until then, every few hours I would see more shows listed under "TV Shows".
I like the guide, it showing you exactly what time it is and how far along you are
I like that I can click on a show and it’ll not only show me the next episode on the “primary” channel, but it’ll search for the show and any episodes available on ANY channel. Impressive.
Issues
1. I paused live TV, through the computer, and there is no “live” or fast forward button. If I use the keyboard, then yes, I can skip forward or back, but it’s not intuitive, and I don’t see how far back I went in the episode on the screen (i.e. with my current cable DVR, if I hit pause, it’ll show me that I’m at 5:43 of the 30:00 episode). On the Roku it works fine.
2. One more issue: the conflict resolution doesn't work from the webapp, i.e. there is no conflict resolution button "Resolve "Conflict" as shown here: http://support.tablotv.com/hc/en-us/articles/201749027-Chapter-5-Using-the-Tablo-App
Wishlist (I know most of these are already in the pipeline)
5.1 surround sound passthrough
It would be nice to have an update bar on the status of the format of the hard drive
Firefox support
Smart TV apps
Automatic stream quality
Hard drive being swappable between Tablos
Adjusting the recording times (i.e. +/-1min, +/-5mins, +/-30mins)
When searching for a recording, if nothing comes up, it should say “nothing” instead of a black screen (I can’t tell if it’s still thinking, or it didn’t find anything)
Smartphone app for pause/rewind/fast forward
Ability to use a browser in someone elses home for streaming…
Place to check my subscription status
Recording through Roku
Option to resume playback from where I left off (on the webapp it does this)
post #158 of 893 Old 04-04-2014, 04:37 PM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 136
What bitrate/resolution options are there for the re-encoded recordings?
qz3fwd is offline
post #159 of 893 Old 04-04-2014, 05:05 PM
sgnadeau's Avatar
Questions123,
Yes, you're correct. You can also schedule series recording from the grid by clicking on Info. I forgot that this was also possible.
Thanks for reminding me.
sgnadeau is offline
post #160 of 893 Old 04-04-2014, 05:37 PM
sgnadeau's Avatar
@Questions123
I'll answer your question no. 2. Tablo downloads 14 days of program guide data but only displays 24 hours. That's what you see in the grid.
You can tell that it downloads 14 days if you select a TV show. It will list all the episodes that it can find in the 14 days of program guide data that it downloaded.
I thought I had mentioned it in my post but maybe I wasn't clear enough.
Questions123 and TabloTV like this.
sgnadeau is offline
post #161 of 893 Old 04-04-2014, 05:42 PM
@Questions123
I think mine didn't download all 14 days yet, because when I check now (a few hours after I installed it), I have more shows visible than I did originally. Though I don't think I'm at 14 days yet...
post #162 of 893 Old 04-04-2014, 05:50 PM
TabloTV's Avatar
Quoted: 14 Post(s)
Liked: 36
Originally Posted by Questions123 View Post
Questions
1. I didn’t realize a device needs to be paired before trying to view it outside of the home. And that it means a browser can’t be used in someone else’s home. Is this going to change?
2. I thought 14 days of guide data was promised, why can I only see ~1 day? Did it not download? How long does it take to download?
3. Where can I check my subscription status? (I know we get a year free)
Firefox support
Smart TV apps
Answers!
1 - We have to 'pair' a device first so random people don't go connecting into your Tablo. If you're often at a friend's place you can have them bring their device over to pair it with your Tablo.
2 - Yes - you've got 14 days but Live TV only shows 24 hours.
3 - We'll have our subscription status area online in the next couple of weeks. Stay tuned.
Tx for the wishlist as well! Yes - lots of this stuff is already on the map. Like the suggestion around not finding anything in search!
TabloTV is offline
post #163 of 893 Old 04-04-2014, 07:28 PM
mbellaire's Avatar
Received my Tablo today, was able to set it up without a problem - so far so good (main use is through a Roku box).
Have a question, does the Tablo box ever tell the USB HD to spin down, or is that a function of the HD itself? It would seem that during long periods of inactivity this would make sense.
mbellaire is offline
post #164 of 893 Old 04-05-2014, 04:07 AM
And about 12 hours later, there are even more shows available [possibly all of them now]. I guess it takes some time to populate.
post #165 of 893 Old 04-05-2014, 04:28 AM
Attached a screenshot.
Quality.jpg 101k .jpg file
post #166 of 893 Old 04-05-2014, 04:30 AM
post #167 of 893 Old 04-05-2014, 06:54 AM
mohanman's Avatar
Quoted: 40 Post(s)
Liked: 33
So far very nice device. I like it. Can you please add recording option to live tv via roku
mohanman is offline
post #168 of 893 Old 04-05-2014, 09:51 AM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 136
Does full quality mean it saves the original mpeg2 ts without altering it in any way?
So far from the reports it sounds like a well executed very nice device. I cannot wait to order the 4 tuner model.
I still don't understand the pairing logic between the hard drive and device. It this an attempt to appease the content owners/broadcasters? Why is pairing required?
qz3fwd is offline
post #169 of 893 Old 04-05-2014, 10:06 AM
Charles R's Avatar
Liked: 649
Earlier in the thread they stated it never captures the naive image as it's encoded (at a lower bit rate) during the recording process. At least that is what I remember and a reason I marked it off my list (the 4 tuner version).
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Sony UBP-X800 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Roku Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
post #170 of 893 Old 04-05-2014, 10:18 AM
Guest
Quoted: 38 Post(s)
Liked: 198
See this post by TabloTV.
7558037 is offline
post #171 of 893 Old 04-05-2014, 10:51 AM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 136
Again, what does "Full" quality mean? What resolution and bitrate?
qz3fwd is offline
post #172 of 893 Old 04-05-2014, 11:48 AM
snowcat's Avatar
Quoted: 57 Post(s)
Liked: 63
I answered that earlier. Full Quality for remote viewing means that it doesn't re-encode the stream and therefore doesn't require an open tuner (so it plays just like you were on your home network). But you have to have 5 Mpbs upload speed for 720p recordings and 10 Mpbs upload speed for 1080p recordings.
snowcat is offline
post #173 of 893 Old 04-05-2014, 11:51 AM
Xzyl's Avatar
The screen shot is of remote streaming quality section of settings.  Full quality would mean that the recording will not be transcoded again and remain in the resolution and bitrate it was originally recoded in when remotely streamed.
Tablo records at the following bitrates and resolutions:
1080P at 10 Mbps
  720P at   5 Mbps
  480P at   2 Mbps
Xzyl is offline
post #174 of 893 Old 04-05-2014, 12:43 PM
Charles R's Avatar
Liked: 649
Since they aren't storing the raw data and are saving it in another codec I think it's hard to know what if any image loss there is based strictly on numbers...
From my post here you can see my locals exceed 15Mbps. I believe H.264 uses less space than MPEG-2 so in this case it best use 1/3 less or they will have to be dropping quality. It would be nice if someone actually explained the entire process.
With WMC my recordings typically range from 4.5 to 7.5GBs per hour... again it's not apples to apples since the codec is different.
post #175 of 893 Old 04-05-2014, 03:18 PM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 136
There will be quality loss due to the transcoding/re - encoding , but 10 maps he 60 should look really good. I do wish they had the capability of also storing the original mpeg2 ts on the hard drive. It would be simple for them to implement....
qz3fwd is offline
post #176 of 893 Old 04-05-2014, 07:22 PM
I know we had a conversation earlier in the thread about conflicting recordings, but to me the answer wasn't clear. I decided to run an experiment.
If a show runs to 10:01, instead of 10pm, and for 1minute (10:00pm-10:01pm) there are 3 recordings scheduled, what happens at 10:02pm? Sadly, the show that was in conflict doesn't get recorded at all...
In the attached example, Fox news at ten wasn't recorded at all.
post #177 of 893 Old 04-06-2014, 04:41 AM
snowcat's Avatar
Quoted: 57 Post(s)
Liked: 63
My biggest problem so far is a known bug where the Seagate Backup Plus 2TB drive (not the portable one) is not recognized by the Tablo due to the sector size. I do have a 500 GB WD drive that is pretty old that I am able to use for now, but I really want to get the 2TB drive to work.
I have made it work with my Android tablet, iPad2, and laptop. I have a Win8 phone, and while it will detect the Tablo in its browser, it isn't able to play anything. I think this is because the only two browsers that work with it now are Chrome and Safari, and the Win8 phone has to use IE.
It has worked fine on my Roku and Chromecast as well. The main pain of the Chromecast is that if you want to switch channels or recordings, you have to have your tablet/browser take back control, make the change, and then send it back to the Chromecast. On the Roku, everything is done on the Roku menus.
The picture quality is very good (I am using 720P) on all the devices and my TVs. I haven't seen any kind of stuttering yet.
If they can get my hard drive problem fixed, I will be very happy.
snowcat is offline
post #178 of 893 Old 04-06-2014, 10:08 AM
HomerJay's Avatar
Looking forward to reviews on the two tuner model. I am patiently (not very well) awaiting the arrival of my 4 tuner model.
HomerJay is offline
post #179 of 893 Old 04-06-2014, 10:16 AM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 136
Will there be a channel skip feature added to the Tablo software?
I mean that the device scans the recording for commercial breaks and keeps a record of the commercial breaks such that they can be skipped during playack?
The commercial breaks would remain in the recorded file, but the device would present a timeline in which the commercial break segments are hidden.
Kinda like a playlist, though transitions would need to be seamless when playing over a commercial break.
That would be a really cool feture and I think the Hopper has this functionality.
qz3fwd is offline
post #180 of 893 Old 04-06-2014, 10:32 AM
ekgdoc's Avatar
Strange, Snowcat. I have a Seagate Backup Plus 2TB drive and it is working fine with the Tablo.
I have had the Tablo for a day and my initial impressions are very favorable. I am in the process of cutting the cord and the Tablo may have saved me from the hassle/expense of getting an outdoor antenna. The reception is poor from an indoor antenna placed near my main TV on the ground floor. I placed the same antenna (Mohu Curve) and Tablo in the attic. Since my wireless router is on the ground floor, I figured this would not work very well. But so far it is working great! I have watched TV on my big screen TV, iPad mini, and a 2011 Macbook Air. I have noticed some stuttering on the Macbook but the picture looks pristine on the TV and iPad. This suggests the problem is with the Macbook rather than the Tablo per se. I have streamed to the TV using the iPad (AirPlay) as well as the new $49 Roku stick which simply plugs into an HDMI port on the back of the TV. Both look great (720p). The Roku is nice (wife factor) since you use a regular remote to change channels, pause, view recordings, etc. You can't do everything with the Roku and the interface is not as polished as the iPad app, but it works just fine. As an experiment, I watched a bit of live TV using a T-Mobile LTE connection where Wi-Fi was not available. It worked.
I am looking forward to canceling my Time Warner $150/month cable bill. In fact, I'll do that later today.
To the folks at Tablo, well done!
David Martin
ekgdoc is offline
Reply HDTV Recorders
